  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 321.4k Aufrufe 54 Beobachtet
    @frankjoke
    Ich habe soeben mal ein update gemacht, jedoch erscheinen nun folgende Warnmeldungen
    radar2.0 2019-03-31 22:28:02.602 warn error item Alexa-Noel=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anon
    radar2.0 2019-03-31 22:27:55.592 warn error item ACER-Extensa=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <an
    radar2.0 2019-03-31 22:27:48.662 warn error item JaninaA5=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonym
    radar2.0 2019-03-31 22:27:47.430 warn error item GalaxyS8Mario=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <a
    radar2.0 2019-03-31 22:27:44.631 warn error item Forum=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonymous
    radar2.0 2019-03-31 22:27:44.604 info Init item ECB- with { name: 'ECB-', ip: 'USD,RUB,GBP', id: 'ECB', type: 'ECB' }
    radar2.0 2019-03-31 22:27:44.573 warn error item Fritzbox=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonym
    radar2.0 2019-03-31 22:27:44.504 warn error item Ich-=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonymous>
    frankjokeF Offline
    frankjokeF Offline
    frankjoke
    #401
    @crunchip
    Ok, das sollte jetzt auf Git behoben sein, auf npm mit v 1.0.5 kommts auch bald.
    Das kommt davon wenn man nicht selbst neu von git beim Testen installiert....
    Frank,
    crunchipC 2 Antworten Letzte Antwort
    • frankjokeF frankjoke
      @crunchip
      crunchipC Abwesend
      crunchipC Abwesend
      #402
      @frankjoke ok
      guck ich dann gleich mal
        @crunchip
        crunchipC Abwesend
        crunchipC Abwesend
        #403
        @frankjoke wie der Unwetterwarner..."No Warnings" 👌
        aber eine Frage habe ich noch
        radar2.0._nHere
        bezieht sich auf was?? irgendwas versteh ich da nicht
        habe 5 Abfragen mit true
        2 mit false
        _nHere zeigt mir den Wert 4
        frankjokeF 1 Antwort Letzte Antwort
          radar2.0._nHere
          2 mit false
          frankjokeF Offline
          frankjokeF Offline
          frankjoke
          schrieb am zuletzt editiert von frankjoke
          #404
          @crunchip sagte in [Adapter] Neuer radar2-Adapter:
          radar2.0._nHere
          2 mit false
          _nHere zählt nur jene Geäte die da sind und nicht mittels '-' am Ende des Names ausgeblendet werden.
          Du kannst z.B. 10 Geräte prüfen aber für die Anwesenheitsinformation sind nur 3 davon relevant. Dann kannst bei den anderen ein '-' ans Ende des Namens setzten und _nHere wird nur die 3 restlichen zählen.
          Frank,
            radar2.0._nHere
            2 mit false
            crunchipC Abwesend
            crunchipC Abwesend
            #405
            @frankjoke jetzt hab ichs gerafft 😀
            danke
            habe es angepasst, nun kommt folgendes
            radar2.0	2019-03-31 23:38:59.885	warn	Invalid item name '''', must be at least 2 letters long
            edit
            Bild war unten abgeschnitten...hatte mir die letzte Zeile nicht angezeigt...die war natürlich leer 🤦
            unter Objekte ist nun ECB- verschwunden, daran hatte ich gar nichts geändert., habe auch den Adapter nochmal neu gestartet
              danke
              edit
              frankjokeF Offline
              frankjokeF Offline
              frankjoke
              #406
              danke
              edit
              Kann es ein dass du ein 'leeres' Gerät ohne Namen in deiner Konfig hast?
              Der Fehler wird angezeigt wenn du ein Gerät mit einem Namen mit weniger als 2 Zeichen (nicht Leerzeichen) erzeugst.
              Wenn nicht poste mir im chat deine Konfig....
              Frank,
                danke
                edit
                crunchipC Abwesend
                crunchipC Abwesend
                #407
                @frankjoke
                ja, hatte ich bereits geschrieben, war eine leere Zeile. Muss immer eine zeile hinzufügen, damit die Liste nach oben rutscht, sonst seh ich nicht alle Geräte, liegt wohl am chromcast browser...und hatte vergessen, die zeile wieder zu löschen.
                aber das Objekt ECB fehlt seit version 1.0.5, ist nach wie vor im Adapter eingetragen, jedoch wird es nicht mehr mit aufgelistet.
                  @frankjoke
                  frankjokeF Offline
                  frankjokeF Offline
                  frankjoke
                  #408
                  @frankjoke
                  Was meinst mit 'aufgelistet'? Die Daten fehlen?
                  Hast mal den Adapter im debug gestartet und z.B.
                  will scan UWZ with code UWZAT00184 every 120 minutes
                  Will scan ECB for [ 'USD,RUB,GBP' ] every 60 minutes
                  UWZ found the following (changed) warnings: No warnings
                  debug: ChangeState ack:true of _UWZ = No warnings
                  debug: ChangeState ack:true of ECB = 2019-03-29
                  debug: ChangeState ack:true of ECB.USD = 1.1235
                  debug: ChangeState ack:true of ECB.GBP = 0.8583
                  debug: ChangeState ack:true of ECB.RUB = 72.8564
                  sowas gesehen?
                  Frank,
                    @frankjoke
                    sowas gesehen?
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #409
                    @frankjoke wenn ich auf debug stelle, kommt nur
                    radar2.0	2019-04-01 01:20:12.686	debug	system.adapter.admin.0: logging true
                    radar2.0	2019-04-01 01:20:12.340	debug	statesDB connected
                    radar2.0	2019-04-01 01:20:12.298	debug	objectDB connected
                    edit: hatte das ! vergessen
                    nein davon taucht bei mir nichts auf
                    die einzigste Zeile die sich auf ECB bezieht
                    er zeigt an
                    	radar2 found 8 devices in config
                    das ist auch korrekt, jedoch fehlt ECB
                    seit heute Nacht nur noch Störungen und Neustarts
                    	No geo location data found configured in admin to calculate UWZ AREA ID!
                    	err from getObjects: TypeError: Cannot read property 'pE' of undefined
                    	radar initialization finished with error TypeError: Cannot read property 'pE' of undefinedat pE (/opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/myAdapter.js:387:26)at <a
                      @SBorg sagte in [Adapter] Neuer radar2-Adapter:
                      ich weiß nur nicht warum...? Ich hatte mir zwar DNS-Einträge, hosts, Iptables etc. angeschaut (wg. eines anderen Clients), aber, zumindest soweit ich es gerade noch in Erinnerung habe, nichts an deren Config geändert. Komisch warum er em0 zweimal findet? Via Shell funktioniert es übrigens nicht, da muss ich nach wie vor bei arp-scan das Interface/IP angeben. Von daher würde ich sagen: "radar2 tut was er soll", dass andere ist mein "Problem", wobei dies mich nicht stört, denn das Gerät funktioniert im Netzwerk ansonsten wie es soll.
                      Kannst mal schauen ob ifconfig auch 2x em0 bringt.
                      Der Adapter ruft gleichzueitig 1 oder mehrere Instanzen mit --interface=xxx von arp-scan auf und scannt daher auf den verschiedenen Schnittstellen gleichzeitig. Auf der Kommandozeile kannst nur die Instanzen separat aufrufen...
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      #410
                      @frankjoke sagte in [Adapter] Neuer radar2-Adapter:
                      Thx, dann ist mir auch klar warum es per Shell nicht geht. Hatte mich da auf die Log-Ausgabe verlassen, dort taucht der Interface-Parameter nicht auf.
                      Noppe, ist genau wie vorher:
                      em0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                              inet 192.168.2.1  netmask 255.255.255.0  broadcast 192.168.2.255
                              inet6 fe80::xxx  prefixlen 64  scopeid 0x20<link>
                              ether xxx  txqueuelen 1000  (Ethernet)
                              RX packets 85283  bytes 6461710 (6.4 MB)
                              RX errors 0  dropped 0  overruns 0  frame 0
                              TX packets 193086482  bytes 12390402411 (12.3 GB)
                              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                              device interrupt 17  memory 0x80120000-80140000
                      eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                              inet 192.168.1.30  netmask 255.255.255.0  broadcast 192.168.1.255
                              inet6 2001:xxx  prefixlen 64  scopeid 0x0<global>
                              RX packets 167075147  bytes 145806185874 (145.8 GB)
                              RX errors 0  dropped 557473  overruns 0  frame 0
                              TX packets 314705354  bytes 184065188207 (184.0 GB)
                              device interrupt 16  memory 0x80220000-80240000
                      lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                              inet 127.0.0.1  netmask 255.0.0.0
                              inet6 ::1  prefixlen 128  scopeid 0x10<host>
                              loop  txqueuelen 1000  (Local Loopback)
                              RX packets 900245719  bytes 138423683089 (138.4 GB)
                              TX packets 900245719  bytes 138423683089 (138.4 GB)
                      Ist auch keine besondere Konfiguration:
                      Ich hatte nur keinen Port mehr am Switch frei, dafür aber einen Netzwerk-Anschluss vom Intel-Board über. Also Crosslink dran und an den Drucker gestöpselt, IP-Route eingestellt und druckt :)
                      Die weiteren Subnetze kann, und darf er nicht sehen, ist also soweit korrekt. Wenn du dabei neue Erkenntnisse erlangst/es wissen willst etc. immer gerne, ansonsten funktioniert es ja wie es soll und musst dir deswegen nicht extra "einen Kopp machen".
                      LG SBorg ( SBorg auf GitHub)
                        er zeigt an
                        frankjokeF Offline
                        frankjokeF Offline
                        frankjoke
                        #411
                        @crunchip
                        das schaut nicht gut aus, wie wenn nicht richtig alles neu installiert worden wäge da du Fehler hast die alle addressiert wurden und in dieser Version behoben sein sollten!
                        Kannst nochmal vom git installieren nachdem du den Adapter gestoppt hast (kannst bei git den radar2 nehmen, sollte schon drin sein).
                        Wennst dann immer noch Probleme hast stoppe Adapter und lösche dann die Verzeichnisse sudo rm -Rf /opt/iobroker/node_modules/@frankjoke und sudo rm -Rf /opt/iobroker/node_modules/iobroker.radar2 und installierst es von git neu? Bitte dann upload machen falls das admin nicht macht!
                        Irgendwie scheinst du da mit den Versionen durcheinandergekommen zu sein...
                        Frank,
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #412
                          @frankjoke de/neu installieren und upload hatte ich heut morgen schon probiert, jedoch die gleichen Fehler
                          probier ich es mal mit Verzeichnis löschen
                          scheint wieder zu laufen
                          dankeschön👍
                            steimi
                            #413
                            Bei mir ändern sich mit der 1.0.5 nicht die _here-States. Während der übergeordnete Wert (Handy) auf false steht, steht der _here immervnoch auf true. Woran kann das liegen?
                            • S steimi
                              frankjokeF Offline
                              frankjokeF Offline
                              frankjoke
                              #414
                              @steimi
                              Hattest Recht, leider hat es davon abgehängt wie das Gerät gefunden wurde, die eine hat es gesetzt, die andere nicht.
                              Auf git unter gleicher Versionsnummer upgedated, alle Teile setzten jetzt beides (bei mir).
                              Frank,
                                steimi
                                #415
                                Irgendwas läuft bei mir schief. Ich habe den Adapter komplett entfernt und die von dir oben angegebenen Verzeichnisse unter /opt/iobroker gelöscht. Anschliessend habe ich Adapter über die Katze wieder neu installiert und konfiguriert. Nun habe ich unter den Objekten allerdings alle Einträge doppelt - Handy und Handy+. Wobei unter dem Handy+ nur der _here-State vorhanden ist.
                                • S steimi
                                  frankjokeF Offline
                                  frankjokeF Offline
                                  frankjoke
                                  #416
                                  @steimi
                                  Sorry, das '+' war ein Tippfehler, schon korrigiert.
                                  p.s.: Die states sollten nach dem 1. kompletten scan dann selbst gelöscht werden...
                                  Frank,
                                  • DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #417
                                    Besteht die Chance dass der neue Adapter auch wieder getrennt anzeigt über welche Methode das Gerät erkannt wurde?
                                    Also bt_here und ip_here usw. wie beim alten Adapter auch.
                                    ..:: So long! Tom ::..
                                    • DiginixD Diginix
                                      Muchul
                                      #418
                                      An diesen Wunsch von @Diginix würde ich mich gerne anschließen.
                                      Wlan greift bei mir manchmal schon 100 meter von der Wohnung, da ist aber noch niemand zuhause.
                                      • M Muchul
                                        frankjokeF Offline
                                        frankjokeF Offline
                                        frankjoke
                                        #419
                                        @Muchul sagte in [Adapter] Neuer radar2-Adapter:
                                        Na ja, andere freuen sich da sie das Garagentor automatisch öffnen können :)
                                        Momentan kann ich das nicht ändern da dieser Teil komplett durch die neue Logik ersetzt worden ist und wahrscheinlich müsste man auch einen neuen State/Gerät einführen. Das mach ich nur bei der nächsten gößeren Version die aber etwas später kommt da ich jetzt noch andere 5 Adapter umbauen muss dass sie mit dem js-controller funktionieren!
                                        Frank,
                                        • J Offline
                                          jensus11
                                          #420
                                          hi, ich erhalte immer folgende Meldung:
                                          Promise failed @ '' error: { TypeError: Cannot read property 'name' of undefined at seriesOf.i (/opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:254:52) at p.then (/opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:745:37) at <anonymous> [stack]: 'TypeError: Cannot read property \'name\' of undefined\n    at seriesOf.i (/opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:254:52)\n    at p.then (/opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:745:37)\n    at <anonymous>', [message]: 'Cannot read property \'name\' of undefined' }
                                          Kurz danach kommt dann das.
                                          host.ioBroker instance system.adapter.radar2.0 terminated due to SIGSEGV
                                          host.ioBroker instance system.adapter.radar2.0 terminated with code null ()
                                          jemand ne Idee?
                                          Gruss
