  4. Zigbee Adapter startet nicht? Kann jemand helfen?
40 Beiträge 11 Kommentatoren 10.3k Aufrufe 3 Beobachtet
  • F Offline
    Fabian1995
    Ich habe noch folgenden LOG der mich zum verzweifeln bringt:
    • host.raspberrypi 2019-01-19 14:33:05.236 error instance system.adapter.zigbee.0 terminated with code 1 ()
    host.raspberrypi 2019-01-19 14:33:05.236 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi 2019-01-19 14:33:05.236 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi 2019-01-19 14:33:05.236 error Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi 2019-01-19 14:33:05.236 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/zigbee-shepherd/lib/shepherd.js:9:9)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: at Function.Module._load (module.js:475:25)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: Error: Cannot find module 'busyman'
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: ^
    host.raspberrypi 2019-01-19 14:33:05.235 error Caught by controller[0]: throw err;
    host.raspberrypi 2019-01-19 14:33:05.234 error Caught by controller[0]: module.js:550
    host.raspberrypi 2019-01-19 14:33:04.748 info instance system.adapter.zigbee.0 started with pid 1612
    host.raspberrypi 2019-01-19 14:32:34.725 info Restart adapter system.adapter.zigbee.0 because enabled</anonymous>
    • arteckA Offline
      arteckA Offline
      arteck
      probier mal mit
      npm installl busyman
      und neustart des adapters
        rewe9
        Hallo Helfende,
        meine Konfiguration lautet:
        node -v: 8.15.0
        nodejs -v: 8.15.0
        npm -v: 6.7.0
        irgendwie will mein zwave Adapter nicht grün werden. Er lief ein parr Tage und nun nicht mehr. folgende Fehlermeldung gibt er aus.
        host.zbox-debian 2019-01-25 15:06:29.998 info instance system.adapter.zwave.0 started with pid 6022
        host.zbox-debian 2019-01-25 15:05:59.991 info Restart adapter system.adapter.zwave.0 because enabled
        host.zbox-debian 2019-01-25 15:05:59.991 error instance system.adapter.zwave.0 terminated with code 0 (OK)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Module.load (module.js:566:32)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Module._compile (module.js:653:30)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at require (internal/module.js:11:18)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Module.require (module.js:597:17)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
        host.zbox-debian 2019-01-25 15:05:59.991 error Caught by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2019-01-25 15:05:59.984 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory at Object.Module._extensions..node (module.js:682:18) at Module.load (module.js:566:32) at tryModuleLo
        zwave.0 2019-01-25 15:05:59.984 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2019-01-25 15:05:59.984 debug received all objects
        zwave.0 2019-01-25 15:05:59.970 info starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.15.0
        Was kann ich tun, damit alles wieder läuft?
        Vielen Dank
        Gruß René</anonymous>
        • arteckA Offline
          arteckA Offline
          arteck
          dir ist schon klar das die Fehlermeldung vom zwave kommt weil nicht vom Zigbee
            rewe9
            Oh, sorry falscher Thread.
            • V Offline
              V Offline
              vogtländer
              Hallo ich bekomme den folgenden Fehler muß ich wirklich ein Downgrade durchführen?
              host.ioBroker-Rock 2019-05-14 20:08:41.936 error instance system.adapter.zigbee.1 terminated with code 1 ()
              host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
              host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Module._compile (module.js:653:30)
              host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/lib/bindings/linux.js:2:36)
              host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:81:44)
              host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at require (internal/module.js:11:18)
              host.ioBroker-Rock 2019-05-14 20:08:41.935 error Caught by controller[0]: at Module.require (module.js:597:17)
              host.ioBroker-Rock 2019-05-14 20:08:41.935 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
              host.ioBroker-Rock 2019-05-14 20:08:41.932 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
              host.ioBroker-Rock 2019-05-14 20:08:41.932 error Caught by controller[0]: at Module.load (module.js:566:32)
              host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
              host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: Error: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
              host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: ^
              host.ioBroker-Rock 2019-05-14 20:08:41.930 error Caught by controller[0]: throw e
              host.ioBroker-Rock 2019-05-14 20:08:41.929 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:88
              ioBroker-Rock
              Betriebssystem linux
              Architektur arm64
              CPUs 4
              Geschwindigkeit 600 MHz
              Modell unknown
              RAM 3.9 GB
              Node.js v8.16.0
              NPM 6.4.1
              Anzahl der Adapter 239
              Betriebszeit 01:02:23
              Hostname ioBroker-Rock
              • V vogtländer
                ioBroker-Rock
                Architektur arm64
                CPUs 4
                Modell unknown
                RAM 3.9 GB
                Node.js v8.16.0
                NPM 6.4.1
                arteckA Offline
                arteckA Offline
                arteck
                @vogtländer welches Betriebsystem ??
                • V Offline
                  V Offline
                  vogtländer
                  Estmal Entschuldigung für die den zweiten thread.
                  Das Betriebssystem:
                  Armbian Debian Stretch Server - (Rock64 Image von der ioBroker Seite)
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    hmmm..nen rock hab ich hier...müsste ich mal schauen..
                    da scheint der serialport nicht richtig installiert zu sein.. komisch komisch
                    • V Offline
                      V Offline
                      vogtländer
                      Hallo ich habe heute den ganzen Tag versucht das Probelm zu beheben leider
                      ohne Erfolg. Das Interessante ist das der gleiche Fehler kommt auch ohne Stick.
                      SpegeliS 1 Antwort Letzte Antwort
                      • V vogtländer
                        SpegeliS Offline
                        SpegeliS Offline
                        Spegeli
                        @vogtländer sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                        Hast du bereits eine Lösung dafür gefunden? Erhalten ebenfalls folgende Meldung:
                        • SpegeliS Spegeli
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @Spegeli muss ich mir im live anschauen..
                          • arteckA arteck
                            SpegeliS Offline
                            SpegeliS Offline
                            Spegeli
                            @arteck sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                            Hab den Fehler nun endlich beheben können via:
                            npm install @serialport/bindings
                            Adapter ist nun Grün ;-)
                              sicuro0815
                              leider habe das gleiche Problem. Ein "npm install @serialport/bindings" brachte leider nicht den gewünschten erfolg.
                              host.ioBroker-RasPi 2019-07-05 14:06:07.914 error instance system.adapter.zigbee.0 terminated with code 1 ()
                              host.ioBroker-RasPi 2019-07-05 14:06:07.913 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.913 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.912 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.911 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.911 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.910 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.909 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.909 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.908 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.907 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
                              host.ioBroker-RasPi 2019-07-05 14:06:07.906 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
                              host.ioBroker-RasPi 2019-07-05 14:06:07.906 error Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                              host.ioBroker-RasPi 2019-07-05 14:06:07.905 error Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                              host.ioBroker-RasPi 2019-07-05 14:06:07.904 error Caught by controller[0]: was compiled against a different Node.js version using
                              host.ioBroker-RasPi 2019-07-05 14:06:07.903 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                              host.ioBroker-RasPi 2019-07-05 14:06:07.902 error Caught by controller[0]: ^
                              host.ioBroker-RasPi 2019-07-05 14:06:07.902 error Caught by controller[0]: throw e
                              host.ioBroker-RasPi 2019-07-05 14:06:07.901 error Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                              host.ioBroker-RasPi 2019-07-05 14:06:05.912 info instance system.adapter.zigbee.0 started with pid 3105
                              host.ioBroker-RasPi 2019-07-05 14:05:35.922 info Restart adapter system.adapter.zigbee.0 because enabled
                              Hat jemand ggf. noch eine Idee woran es liegen könnte?
                              Grüße
                              Sven
                              • S sicuro0815
                                Grüße
                                Sven
                                sicuro0815
                                Ich noch mal.
                                Das Problem konnte ich nun doch lösen indem ich folgt vorgegangen bin:
                                Adapter Deinstalliert. Über die "Katze" den Adapter noch mal runtergeladen. Dann in Experteneinstellung beim Adapter auf die 3 Punkte geklickt und auf das + zum installieren..
                                den COM Anschluss Pfad dann noch eingetragen und jetzt läuft es wie es soll.
                                Grüße
                                Sven
                                  Maxim
                                  Muss ich den Zigbee Adapter unbedingt neu installieren und alle Geräte neu verbinden? Ich habe zur noch Zeit node v6.10.0 laufen. Sobald ich auf 8.x updatete, geht der Adapter nicht mehr.
                                  • M Maxim
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @Maxim sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                                    Neu installieren - ja.
                                    Geräte neu anlernen- nein.
                                    A.
                                    • AsgothianA Asgothian
                                      A.
                                      Maxim
                                      @Asgothian und wie genau? Einfach Adapter löschen und installieren? Muss es eine bestimmte Version sein?
                                      AsgothianA arteckA 2 Antworten Letzte Antwort
                                      • M Maxim
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        @Maxim soweit ich das weiss nein. Ich wuerde aber die aktuelle installieren
                                        • M Maxim
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @Maxim es gibt ein thread umstellung Node 8 auf Node 10 da ist alles beschrieben
                                          den kannst du nutzen auch wenn du von Node 6 auf Node 10 gehst..
                                          Node 8 würde ich nicht mehr installieren..
