  4. Zigbee Adapter startet nicht? Kann jemand helfen?
40 Beiträge 11 Kommentatoren 10.3k Aufrufe 3 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    dir ist schon klar das die Fehlermeldung vom zwave kommt weil nicht vom Zigbee
    • R Offline
      rewe9
      Oh, sorry falscher Thread.
      • V Offline
        V Offline
        vogtländer
        Hallo ich bekomme den folgenden Fehler muß ich wirklich ein Downgrade durchführen?
        host.ioBroker-Rock 2019-05-14 20:08:41.936 error instance system.adapter.zigbee.1 terminated with code 1 ()
        host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
        host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Module._compile (module.js:653:30)
        host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/lib/bindings/linux.js:2:36)
        host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:81:44)
        host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at require (internal/module.js:11:18)
        host.ioBroker-Rock 2019-05-14 20:08:41.935 error Caught by controller[0]: at Module.require (module.js:597:17)
        host.ioBroker-Rock 2019-05-14 20:08:41.935 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
        host.ioBroker-Rock 2019-05-14 20:08:41.932 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
        host.ioBroker-Rock 2019-05-14 20:08:41.932 error Caught by controller[0]: at Module.load (module.js:566:32)
        host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
        host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: Error: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
        host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: ^
        host.ioBroker-Rock 2019-05-14 20:08:41.930 error Caught by controller[0]: throw e
        host.ioBroker-Rock 2019-05-14 20:08:41.929 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:88
        ioBroker-Rock
        Betriebssystem linux
        Architektur arm64
        CPUs 4
        Geschwindigkeit 600 MHz
        Modell unknown
        RAM 3.9 GB
        Node.js v8.16.0
        NPM 6.4.1
        Anzahl der Adapter 239
        Betriebszeit 01:02:23
        Hostname ioBroker-Rock
        • V vogtländer
          ioBroker-Rock
          Architektur arm64
          CPUs 4
          Modell unknown
          RAM 3.9 GB
          Node.js v8.16.0
          NPM 6.4.1
          arteckA Offline
          arteckA Offline
          arteck
          @vogtländer welches Betriebsystem ??
          • V Offline
            V Offline
            vogtländer
            Estmal Entschuldigung für die den zweiten thread.
            Das Betriebssystem:
            Armbian Debian Stretch Server - (Rock64 Image von der ioBroker Seite)
            • arteckA Offline
              arteckA Offline
              arteck
              hmmm..nen rock hab ich hier...müsste ich mal schauen..
              da scheint der serialport nicht richtig installiert zu sein.. komisch komisch
              • V Offline
                V Offline
                vogtländer
                Hallo ich habe heute den ganzen Tag versucht das Probelm zu beheben leider
                ohne Erfolg. Das Interessante ist das der gleiche Fehler kommt auch ohne Stick.
                SpegeliS 1 Antwort Letzte Antwort
                • V vogtländer
                  SpegeliS Offline
                  SpegeliS Offline
                  Spegeli
                  @vogtländer sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                  Hast du bereits eine Lösung dafür gefunden? Erhalten ebenfalls folgende Meldung:
                  • SpegeliS Spegeli
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @Spegeli muss ich mir im live anschauen..
                    • arteckA arteck
                      SpegeliS Offline
                      SpegeliS Offline
                      Spegeli
                      @arteck sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                      Hab den Fehler nun endlich beheben können via:
                      npm install @serialport/bindings
                      Adapter ist nun Grün ;-)
                        sicuro0815
                        leider habe das gleiche Problem. Ein "npm install @serialport/bindings" brachte leider nicht den gewünschten erfolg.
                        host.ioBroker-RasPi 2019-07-05 14:06:07.914 error instance system.adapter.zigbee.0 terminated with code 1 ()
                        host.ioBroker-RasPi 2019-07-05 14:06:07.913 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.913 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.912 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.911 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.911 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.910 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.909 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.909 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.908 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.907 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
                        host.ioBroker-RasPi 2019-07-05 14:06:07.906 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
                        host.ioBroker-RasPi 2019-07-05 14:06:07.906 error Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                        host.ioBroker-RasPi 2019-07-05 14:06:07.905 error Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                        host.ioBroker-RasPi 2019-07-05 14:06:07.904 error Caught by controller[0]: was compiled against a different Node.js version using
                        host.ioBroker-RasPi 2019-07-05 14:06:07.903 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                        host.ioBroker-RasPi 2019-07-05 14:06:07.902 error Caught by controller[0]: ^
                        host.ioBroker-RasPi 2019-07-05 14:06:07.902 error Caught by controller[0]: throw e
                        host.ioBroker-RasPi 2019-07-05 14:06:07.901 error Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                        host.ioBroker-RasPi 2019-07-05 14:06:05.912 info instance system.adapter.zigbee.0 started with pid 3105
                        host.ioBroker-RasPi 2019-07-05 14:05:35.922 info Restart adapter system.adapter.zigbee.0 because enabled
                        Hat jemand ggf. noch eine Idee woran es liegen könnte?
                        Sven
                        • S sicuro0815
                          Sven
                          sicuro0815
                          Ich noch mal.
                          Das Problem konnte ich nun doch lösen indem ich folgt vorgegangen bin:
                          Adapter Deinstalliert. Über die "Katze" den Adapter noch mal runtergeladen. Dann in Experteneinstellung beim Adapter auf die 3 Punkte geklickt und auf das + zum installieren..
                          den COM Anschluss Pfad dann noch eingetragen und jetzt läuft es wie es soll.
                          Sven
                            Maxim
                            Muss ich den Zigbee Adapter unbedingt neu installieren und alle Geräte neu verbinden? Ich habe zur noch Zeit node v6.10.0 laufen. Sobald ich auf 8.x updatete, geht der Adapter nicht mehr.
                            • M Maxim
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @Maxim sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                              Neu installieren - ja.
                              Geräte neu anlernen- nein.
                              A.
                              • AsgothianA Asgothian
                                A.
                                Maxim
                                @Asgothian und wie genau? Einfach Adapter löschen und installieren? Muss es eine bestimmte Version sein?
                                AsgothianA arteckA 2 Antworten Letzte Antwort
                                • M Maxim
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @Maxim soweit ich das weiss nein. Ich wuerde aber die aktuelle installieren
                                  • M Maxim
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @Maxim es gibt ein thread umstellung Node 8 auf Node 10 da ist alles beschrieben
                                    den kannst du nutzen auch wenn du von Node 6 auf Node 10 gehst..
                                    Node 8 würde ich nicht mehr installieren..
