  4. Zigbee Adapter startet nicht? Kann jemand helfen?
40 Beiträge 11 Kommentatoren 10.3k Aufrufe 3 Beobachtet
  • V Offline
    V Offline
    vogtländer
    Hallo ich bekomme den folgenden Fehler muß ich wirklich ein Downgrade durchführen?
    host.ioBroker-Rock 2019-05-14 20:08:41.936 error instance system.adapter.zigbee.1 terminated with code 1 ()
    host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Module._compile (module.js:653:30)
    host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/lib/bindings/linux.js:2:36)
    host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:81:44)
    host.ioBroker-Rock 2019-05-14 20:08:41.936 error Caught by controller[0]: at require (internal/module.js:11:18)
    host.ioBroker-Rock 2019-05-14 20:08:41.935 error Caught by controller[0]: at Module.require (module.js:597:17)
    host.ioBroker-Rock 2019-05-14 20:08:41.935 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.ioBroker-Rock 2019-05-14 20:08:41.932 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.ioBroker-Rock 2019-05-14 20:08:41.932 error Caught by controller[0]: at Module.load (module.js:566:32)
    host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: Error: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
    host.ioBroker-Rock 2019-05-14 20:08:41.931 error Caught by controller[0]: ^
    host.ioBroker-Rock 2019-05-14 20:08:41.930 error Caught by controller[0]: throw e
    host.ioBroker-Rock 2019-05-14 20:08:41.929 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:88
    ioBroker-Rock
    Betriebssystem linux
    Architektur arm64
    CPUs 4
    Geschwindigkeit 600 MHz
    Modell unknown
    RAM 3.9 GB
    Node.js v8.16.0
    NPM 6.4.1
    Anzahl der Adapter 239
    Betriebszeit 01:02:23
    Hostname ioBroker-Rock
    • V vogtländer
      ioBroker-Rock
      Architektur arm64
      CPUs 4
      Modell unknown
      RAM 3.9 GB
      Node.js v8.16.0
      NPM 6.4.1
      arteckA Offline
      arteckA Offline
      arteck
      @vogtländer welches Betriebsystem ??
      • V Offline
        V Offline
        vogtländer
        Estmal Entschuldigung für die den zweiten thread.
        Das Betriebssystem:
        Armbian Debian Stretch Server - (Rock64 Image von der ioBroker Seite)
        • arteckA Offline
          arteckA Offline
          arteck
          hmmm..nen rock hab ich hier...müsste ich mal schauen..
          da scheint der serialport nicht richtig installiert zu sein.. komisch komisch
          • V Offline
            V Offline
            vogtländer
            Hallo ich habe heute den ganzen Tag versucht das Probelm zu beheben leider
            ohne Erfolg. Das Interessante ist das der gleiche Fehler kommt auch ohne Stick.
            SpegeliS 1 Antwort Letzte Antwort
            • V vogtländer
              SpegeliS Offline
              SpegeliS Offline
              Spegeli
              @vogtländer sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
              Hast du bereits eine Lösung dafür gefunden? Erhalten ebenfalls folgende Meldung:
              • SpegeliS Spegeli
                arteckA Offline
                arteckA Offline
                arteck
                @Spegeli muss ich mir im live anschauen..
                • arteckA arteck
                  SpegeliS Offline
                  SpegeliS Offline
                  Spegeli
                  @arteck sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                  Hab den Fehler nun endlich beheben können via:
                  npm install @serialport/bindings
                  Adapter ist nun Grün ;-)
                    sicuro0815
                    leider habe das gleiche Problem. Ein "npm install @serialport/bindings" brachte leider nicht den gewünschten erfolg.
                    host.ioBroker-RasPi 2019-07-05 14:06:07.914 error instance system.adapter.zigbee.0 terminated with code 1 ()
                    host.ioBroker-RasPi 2019-07-05 14:06:07.913 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.913 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.912 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.911 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.911 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.910 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.909 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.909 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.908 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.907 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
                    host.ioBroker-RasPi 2019-07-05 14:06:07.906 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
                    host.ioBroker-RasPi 2019-07-05 14:06:07.906 error Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                    host.ioBroker-RasPi 2019-07-05 14:06:07.905 error Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                    host.ioBroker-RasPi 2019-07-05 14:06:07.904 error Caught by controller[0]: was compiled against a different Node.js version using
                    host.ioBroker-RasPi 2019-07-05 14:06:07.903 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                    host.ioBroker-RasPi 2019-07-05 14:06:07.902 error Caught by controller[0]: ^
                    host.ioBroker-RasPi 2019-07-05 14:06:07.902 error Caught by controller[0]: throw e
                    host.ioBroker-RasPi 2019-07-05 14:06:07.901 error Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                    host.ioBroker-RasPi 2019-07-05 14:06:05.912 info instance system.adapter.zigbee.0 started with pid 3105
                    host.ioBroker-RasPi 2019-07-05 14:05:35.922 info Restart adapter system.adapter.zigbee.0 because enabled
                    Hat jemand ggf. noch eine Idee woran es liegen könnte?
                    Sven
                    • S sicuro0815
                      Sven
                      sicuro0815
                      Ich noch mal.
                      Das Problem konnte ich nun doch lösen indem ich folgt vorgegangen bin:
                      Adapter Deinstalliert. Über die "Katze" den Adapter noch mal runtergeladen. Dann in Experteneinstellung beim Adapter auf die 3 Punkte geklickt und auf das + zum installieren..
                      den COM Anschluss Pfad dann noch eingetragen und jetzt läuft es wie es soll.
                      Sven
                        Maxim
                        Muss ich den Zigbee Adapter unbedingt neu installieren und alle Geräte neu verbinden? Ich habe zur noch Zeit node v6.10.0 laufen. Sobald ich auf 8.x updatete, geht der Adapter nicht mehr.
                        • M Maxim
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @Maxim sagte in Zigbee Adapter startet nicht? Kann jemand helfen?:
                          Neu installieren - ja.
                          Geräte neu anlernen- nein.
                          A.
                          • AsgothianA Asgothian
                            A.
                            Maxim
                            @Asgothian und wie genau? Einfach Adapter löschen und installieren? Muss es eine bestimmte Version sein?
                            AsgothianA arteckA 2 Antworten Letzte Antwort
                            • M Maxim
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @Maxim soweit ich das weiss nein. Ich wuerde aber die aktuelle installieren
                              • M Maxim
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @Maxim es gibt ein thread umstellung Node 8 auf Node 10 da ist alles beschrieben
                                den kannst du nutzen auch wenn du von Node 6 auf Node 10 gehst..
                                Node 8 würde ich nicht mehr installieren..
