  4. Adapter: iobroker.backitup (stable Release)
    6.1k
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.5m Aufrufe 50 Beobachtet
    paul.honka
    #1501
    Hallo simatec, bischen verwirrend, ein Ausdruck für zwei Sachen.
    Hier das neue Log.
    ! backitup.0 2019-01-16 13:19:31.358 debug system.adapter.admin.0: logging true
    ! backitup.0 2019-01-16 13:19:26.838 warn Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/lib/total.json'
    ! backitup.0 2019-01-16 13:19:26.837 debug [EXIT] 1
    ! backitup.0 2019-01-16 13:19:26.837 error [ERROR] [minimal] Stop iobroker first!
    ! backitup.0 2019-01-16 13:19:26.836 debug Printing logs of previous backup
    ! backitup.0 2019-01-16 13:19:26.830 info starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
    ! backitup.0 2019-01-16 13:19:26.691 debug statesDB connected
    ! backitup.0 2019-01-16 13:19:26.650 debug objectDB connected
    ! host.ioBroker-Sted1 2019-01-16 13:19:25.833 info instance system.adapter.backitup.0 started with pid 3915
    ! discovery.0 2019-01-16 13:19:22.648 info starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.15.0
    ! host.ioBroker-Sted1 2019-01-16 13:19:21.835 info instance system.adapter.discovery.0 started with pid 3905
    ! admin.0 2019-01-16 13:19:21.542 info Repository received successfully.
    ! host.ioBroker-Sted1 2019-01-16 13:19:20.131 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    ! admin.0 2019-01-16 13:19:20.023 info Use link "http://localhost:8081" to configure.
    ! admin.0 2019-01-16 13:19:20.023 info http server listening on port 8081
    ! admin.0 2019-01-16 13:19:19.972 info received all objects
    ! admin.0 2019-01-16 13:19:19.526 info received all states
    ! admin.0 2019-01-16 13:19:19.301 info Request actual repository…
    ! admin.0 2019-01-16 13:19:19.300 info requesting all objects
    ! admin.0 2019-01-16 13:19:19.298 info requesting all states
    ! admin.0 2019-01-16 13:19:19.286 info starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.850 info instance system.adapter.admin.0 started with pid 3895
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.817 info starting 3 instances
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.811 info 3 instances found
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.802 info InMemoryDB connected
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.786 info inMem-objects listening on port 9001
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.690 info inMem-states listening on port 9000
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.628 info ip addresses: 192.168.0.80 2a02:8109:dc0:40cc:ae93:e08a:dff2:31f1 fe80::cbf:4678:3b10:d5d2
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.626 info hostname: ioBroker-Sted1, node: v8.15.0
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.625 info Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    ! host.ioBroker-Sted1 2019-01-16 13:19:17.621 info iobroker.js-controller version 1.4.2 js-controller starting
    ! admin.0 2019-01-16 13:19:16.765 info terminating http server on port 8081
    ! admin.0 2019-01-16 13:19:15.263 info terminating http server on port 8081
    ! backitup.0 2019-01-16 13:19:11.625 debug sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
    ! backitup.0 2019-01-16 13:19:05.845 debug sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
    ! backitup.0 2019-01-16 13:19:03.620 debug system.adapter.admin.0: logging false
    ! backitup.0 2019-01-16 13:18:58.777 info starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
    ! backitup.0 2019-01-16 13:18:58.636 debug statesDB connected
    ! backitup.0 2019-01-16 13:18:58.597 debug objectDB connected
    ! host.ioBroker-Sted1 2019-01-16 13:18:57.869 info instance system.adapter.backitup.0 started with pid 3811
    ! host.ioBroker-Sted1 2019-01-16 13:18:55.894 info instance system.adapter.backitup.0 terminated with code 0 (OK)
    ! host.ioBroker-Sted1 2019-01-16 13:18:55.346 info stopInstance system.adapter.backitup.0 killing pid 3785
    ! backitup.0 2019-01-16 13:19:31.359 debug system.adapter.admin.0: logging true
    • simatecS Offline
      simatecS Offline
      simatec
      #1502
      OK mache mal bitte folgendes.
      Gehe in den Pfad /opt/iobroker/node_modules/iobroker.backitup/lib/
      Dort liegen 4 shell Dateien (*.sh) für start und stop bei backup und restore.
      Setze mal bitte bei allen 4 Dateien vor systemctl stop iobroker und systemctl start iobrober ein „sudo“ davor.
      Danach stelle aber bitte noch sicher, dass für den User auf dem iobroker läuft (theoretisch User: iobroker) die sudo Rechte ohne Passwortabfrage aktiv sind.
      Wie du das einstellen kannst, steht im ersten Beitrag hier.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • sigi234S Online
        sigi234S Online
        sigi234
        #1503
        Hallo, bekomme seit dem Update folgendes:
        BackItUp:
        Das Backup wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!!
        redis: No source for compress!
        cifs: Error: ENOENT: no such file or directory, open 'C:\ioBroker\backups\redis_2019_01_16-11_42_34_backupiobroker.tar.gz'
        Immer Daten sichern!
        • simatecS Offline
          simatecS Offline
          simatec
          #1504
          Dann hattest du den Fehler schon länger.
          Erst mit Version 1.0.5 wurden die Fehlermeldungen an den Messenger weitergegeben.
          Entweder stimmt dein Pfad nicht, oder redis läuft bei dir garnicht.
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            #1505
            Ich bekomme jetzt den Fehler, daß ich anscheinend doch root aktivieren muß.
            Wie Verhältnis sich das mit der alten bzw neuen Installationsroutine?
            Ich denke, mit der alten dürfte es keine Probleme geben, weil ich IObroker als root installiere
            Gesendet von meinem MI 8 mit Tapatalk
            IObroker auf dem NUC als VM.
            • simatecS Offline
              simatecS Offline
              simatec
              #1506
              Ja Matthias, die neue Methode macht noch ein paar Probleme.
              Das hat nix mit backitup zu tun.
              Aber iobroker benötigt in einigen Situationen Root Rechte und mit der neuen Installationsmethode ist das eher schwierig
              Du kannst für deinen neuen User "iobroker" mit sudo arbeiten.
              Dafür musst du aber die sudo Passwortabfrage für den User iobroker deaktivieren.
              Dies geht mit folgenden Schritten:
              sudo visudo
              In der Datei am Ende folgende Zeile einfügen:
              Username ALL=(ALL) NOPASSWD: /bin/mount, /bin/umount, /bin/systemctl
              "Username" durch euren iob User ersetzen
              Dann mit STR+o speichern, mit Enter bestätigen und im Anschluss mit STR+x schließen.
              Danach empfehle ich einen reboot … Dies ist aber System abhängig.
              Ich möchte aber hier noch einmal betonen, dass diese Dinge nicht mit backitup zu tun haben und auch backitup deswegen kein Problem hat.
              Diese Dinge betreffen einzig und allein euer System.
                #1507
                @simatec:
                Diese Dinge betreffen einzig und allein euer System. `
                …und ich möchte nochmals betonen, dass es sich dabei nur um einen momentanen Workaround handeln darf, da damit die Sicherheitsbestrebungen, nicht mehr unter root zu arbeiten, ausgehebelt werden.
                Rainer
                  paul.honka
                  #1508
                  Hallo simatec,
                  ` > Gehe in den Pfad /opt/iobroker/node_modules/iobroker.backitup/lib/
                  Setze mal bitte bei allen 4 Dateien vor systemctl stop iobroker und systemctl start iobrober ein „sudo“ davor. `
                  Ich finde da die start_b_IOB.sh startIOB.sh stopIOB.sh stop_r_IOB.sh. Wie sudo davor setzen, umbenennen oder?
                  Ich habe den IOBroker mit dem Usernamen tinker mit dem neuen Script installiert. also heisst die Zeile
                  iobroker ALL=(ALL) NOPASSWD: ALL oder tinker ALL=(ALL) NOPASSWD: ALL
                  Beste Grüsse paul
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    #1509
                    Der User wäre iobroker, da der Installer den User iobroker beim installieren anlegt.
                    Du musst in den Dateien das sudo setzen oder installiere die Version 1.0.6 vom github.
                    Habe ich gerade gepusht.
                    Aktuell bestehen leider die Probleme aufgrund von Startschwierigkeiten bei dem neuen Installer.
                    Es wird aber an einer Lösung gearbeitet, damit der installer zukünftig auch gleich alle Rechte richtig mit installiert.
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      #1510
                      Ab sofort ist die Version 1.0.6 im Github und im latest verfügbar.
                      1.0.6 (16.01.2019)
                      (simatec) Fix Start/Stop for new iobroker-installer
                      • C Offline
                        Conquest
                        #1511
                        ich versuche auch gerade mein System neu aufzusetzen. Iobroker habe ich über die neue Installationsroutine installiert. Jetzt versuche ich gerade mein System mit Backitup wiederherzustellen. Es dauert jetzt schon über 3 Stunden und es sieht so aus wie auf dem Bild. Ist dies normal? Es handelt sich um das Komplette Backup.
                        Gruß Torsten
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #1512
                          Ist iobroker schon neu gestartet oder wurde iobroker garnicht beendet (rotierender Kreis in der Mitte der Weboberfläche)?
                          • C Offline
                            Conquest
                            #1513
                            Nein kam glaub ich kein Kreis.
                            Gesendet von meinem MHA-L29 mit Tapatalk
                            • simatecS Offline
                              simatecS Offline
                              simatec
                              #1514
                              @spoerl.torsten:
                              Gesendet von meinem MHA-L29 mit Tapatalk `
                              Schließe mal das Fenster und aktualisiere deinen Browser.
                              Sollte kein Restore erfolgt sein, liegt das an dem aktuellen problemen mit dem neuen Installer.
                              Dann bitte backitup auf Version 1.0.6 updaten und folgendes in der Konsole ausführen:
                              sudo visudo
                              iobroker ALL=(ALL) NOPASSWD: /bin/mount, /bin/umount, /bin/systemctl
                              • C Offline
                                Conquest
                                #1515
                                @simatec:
                                @spoerl.torsten:
                                sudo visudo
                                Danach empfehle ich einen reboot … Dies ist aber System abhängig. `
                                Wurde kein Restore gemacht. Hab jetzt das Update auf 1.0.6 gemacht.
                                • simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #1516
                                  Am Ende der Datei ist OK.
                                    paul.honka
                                    #1517
                                    Hallo simatec, auf 1.0.6 upgedatet, immer noch das gleiche Problem.
                                    sudo visudo und iobroker ALL=(ALL) NOPASSWD: ALL eingefügt, reboot.
                                    Was meinst du mit
                                    Beste Grüsse paul
                                    • simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #1518
                                      Hast du die Änderungen an der visudo auch richtig gespeichert? (Strg-o >>>> Enter >>>> Strg-x)
                                      Die shell Dateien habe ich in Version 1.0.6 bereits geändert.
                                      Poste mal bitte die Ausgabe von "systemctl status iobroker"
                                        paul.honka
                                        #1519
                                        Hallo simatec, anbei die Ausgabe von "systemctl status iobroker"
                                        ! tinker@ioBroker-Sted1:/opt/iobroker$ systemctl status iobroker
                                        ! ● iobroker.service - ioBroker Server
                                        ! Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset:
                                        ! Active: active (running) since Wed 2019-01-16 17:10:26 CET; 17min ago
                                        ! Docs: http://iobroker.net
                                        ! Main PID: 1556 (iobroker.js-con)
                                        ! Tasks: 40 (limit: 4915)
                                        ! CGroup: /system.slice/iobroker.service
                                        ! ├─1556 iobroker.js-controller
                                        ! ├─1566 io.admin.0
                                        ! ├─1576 io.discovery.0
                                        ! └─1586 io.backitup.0
                                        ! Jan 16 17:10:26 ioBroker-Sted1 systemd[1]: Started ioBroker Server.
                                        ! Jan 16 17:10:27 ioBroker-Sted1 node[1556]: host.ioBroker-Sted1 check instance "s
                                        ! Jan 16 17:10:30 ioBroker-Sted1 node[1556]: Send diag info: {"uuid":"9e9e5144-81c
                                        ! Jan 16 17:10:33 ioBroker-Sted1 node[1556]: Send diag info: {"uuid":"9e9e5144-81c
                                        ! lines 1-19/19 (END)
                                        Beste Grüsse paul
                                        • C Offline
                                          Conquest
                                          #1520
                                          Bei mir funktioniert es auch nicht.
                                          Iobroker wird nicht gestoppt.
                                          Ich schau morgen nochmal.
                                          Gruß Torsten
