  4. Neuer Robonect HX Adapter
    6.7k
robonectgardenahusqvarnamährobotergarten
470 Beiträge 59 Kommentatoren 168.5k Aufrufe 43 Beobachtet
  • A Aiouh
    Hallo, seit dem Update auf 1.3.4 bekomme ich folg. Warnung
    robonect.0 2023-10-23 15:53:52.071	warn	Error returned from Robonect device: {"message":"Maximum number of redirects exceeded","name":"Error [ERR_FR_TOO_MANY_REDIRECTS]","stack":"Error [ERR_FR_TOO_MANY_REDIRECTS]: Maximum number of redirects exceeded\n at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.robonect/node_modules/axios/lib/core/AxiosError.js:89:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.robonect/node_modules/axios/lib/adapters/http.js:593:25)\n at RedirectableRequest.emit (node:events:513:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at RedirectableRequest._processResponse (/opt/iobroker/node_modules/follow-redirects/index.js:371:10)\n at ClientRequest.RedirectableRequest._onNativeResponse (/opt/iobroker/node_modules/follow-redirects/index.js:62:10)\n at Object.onceWrapper (node:events:628:26)\n at ClientRequest.emit (node:events:525:35)\n at ClientRequest.emit (node:domain:489:12)\n at HTTPParser.parserOnIncomingClient (node:_http_client:701:27)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.5.1","Accept-Encoding":"gzip, compress, deflate, br"},"auth":{"username":"xxx","password":"yyy"},"params":{"cmd":"status"},"method":"get","url":"http://192.168.178.52/api/json"},"code":"ERR_FR_TOO_MANY_REDIRECTS","status":null}
    robonect.0 2023-10-23 15:53:52.071	error	Maximum number of redirects exceeded
    Hab ich vielleicht was übersehen anzupassen?
    Der ioBroker ist auf aktuellem Stand
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    schrieb am zuletzt editiert von Grizzelbee
    #421
    @aiouh sagte in Neuer Robonect HX Adapter:
    Das ist (soweit ich das verstehe) ein HTTP-/Netzwerkfehler und wird nicht durch den Adapter sondern durch den Robonect verursacht. Siehe: https://github.com/axios/axios/issues/4832
    Ich selbst habe diesen Fehler bei mir auch noch nicht gesehen.
    Hast Du im Robonect die aktuelle Firmware?
    Das wäre so die erste Idee, die ich habe.
    @malz1902 sagte in Neuer Robonect HX Adapter:
    bekomme seit dem Update wenn Robonect mal nicht erreichbar ist folgende Meldung:
    Ich denke, die Antwort liegt bereits in deiner Frage:
    Wenn der Robonect nicht erreichbar ist, gibt es einen Connection-Reset. Das halte ich erst einmal für normal. Wir können aber darüber diskutieren, ob man die wirklich sehen will. Aktuell tendiere ich noch zu einem: Ja, will man.
    A 1 Antwort Letzte Antwort
    • GrizzelbeeG Grizzelbee
      Aiouh
      #422
      @grizzelbee Danke !! Mir ist zwar nicht klar weshalb das erst nach dem Adapter Update aufgetreten ist, so wie es aussieht war es aber die Firmware. Habe diese auf 1.3 aktualisiert und seitdem keine Warnungen mehr im log.
      Im Changelog der FW steht etwas das passen "könnte", aber Hauptsache der Fehler ist weg
      Fehler behoben: Unter Umständen wurde ein Request unendlich oft gesendet, wenn es eine Fehlfunktion des Mähers gab
      • afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        schrieb am zuletzt editiert von afuerhoff
        #423
        @Grizzelbee: Hallo, kann es sein, dass der Mode im Automodus im Mähbetrieb falsch in das Objekt geschrieben wird?
        Weboberfläche Robonect:
        ioBroker:
        GrizzelbeeG 1 Antwort Letzte Antwort
        • afuerhoffA afuerhoff
          ioBroker:
          GrizzelbeeG Offline
          GrizzelbeeG Offline
          Grizzelbee
          #424
          @afuerhoff
          Ich kann deinem Gedankengang gerade leider nicht folgen.
          Wenn im Objektbaum zur selben Zeit etwas anderes steht als in der Visu (welcher auch immer), liegt es meines Erachtens und meiner Erfahrung nach in der Regel an einer falschen Konfig in der Visu, denn der Adapter gibt ja nur numerische Status aus - der Text kommt ja aus der Visu-Konfig. Und wenn dort der Zahl ein falscher Text zugeordnet ist ...
          afuerhoffA 1 Antwort Letzte Antwort
            @afuerhoff
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #425
            @grizzelbee
            Das obere Bild kommt von Robonect. Das untere aus den Objekten. Hat nichts mit Visu zu tun.
            Die Objekte werden doch aus deinem Adapter direkt erstellt.
            Oder gab es evtl. eine Änderung zwischen verschiedenen Versionen, so dass das Objekt nicht mehr passt?
              @grizzelbee
              GrizzelbeeG Offline
              GrizzelbeeG Offline
              Grizzelbee
              #426
              @afuerhoff
              Ah! Okay. Jetzt bin ich gedanklich bei dir.
              Das muss ich mir dann tatsächlich angucken ob es Differenzen zwischen der Anzeige in der Robonect WebUI und dem Adapter gibt. Das kann aber noch etwas dauern. Habe gerade keinen rechten Zugriff auf meine Dev-Umgebung.
                @afuerhoff
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #427
                @grizzelbee
                Kein Problem. Mäher kommt ja auch nicht mehr so häufig raus 😃.
                Muss ihn langsam mal Winterfest machen.
                  afuerhoffA Offline
                  afuerhoff
                  #428
                  @Grizzelbee
                  Jetzt hab ich gerade gesehen, dass ich im Takt des Intervalls diese Meldung im Log habe.
                  Meine Android App sagt aber, dass er online ist. Auch auf die Robonect Web-Seite kann ich mich anmelden. Verbindung Adapter ist grün.
                  No connection to lawn mower (Not able to ping it). Check network connection.
                    afuerhoffA Offline
                    afuerhoff
                    #429
                    @Grizzelbee
                    Und noch ein Problem mit dem Push-Service. Das Log sagt es gibt ein Problem.
                    Konfiguration ist auf beiden Seiten die 192.168.178.113 eingetragen. Mit User und Passwort.
                    PS: Vorher war mal die 192.168.178.68 eingetragen.
                    Robonect sagt alles erfolgreich:
                      @Grizzelbee
                      GrizzelbeeG Offline
                      GrizzelbeeG Offline
                      Grizzelbee
                      #430
                      @afuerhoff
                      Da ich meinen Robi zwischenzeitlich wegen Schneefalls in den Winterurlaub geschickt habe und deswegen gerade nicht so richtig debuggen kann, habe ich mal Issues dazu aufgemacht, damit das nicht in Vergessenheit gerät:
                      https://github.com/Grizzelbee/ioBroker.robonect/issues/37
                      https://github.com/Grizzelbee/ioBroker.robonect/issues/38
                      https://github.com/Grizzelbee/ioBroker.robonect/issues/39
                      Falls sich irgend etwas dazu ergibt (@Alle: auch Bestätigungen der/des Bugs) bitte dort vermerken.
                      • LatziL Latzi
                        @opossum sagte in Neuer Robonect HX Adapter:
                        würdest Du uns vielleicht den Export zur Verfüging stellen?
                        sicherlich (Design ist geklaut - nicht meine Kreation)!
                        Um den Modus und Status als Klartext darstellen zu können, hab ich 2 Datenpunkte angelegt (werden mit folgenden Skripten befüllt), diese lauten bei mir:
                        • javascript.0.Status.Flocki.Mode
                        • javascript.0.Status.Flocki.Status
                        Skript für "Mode":
                        var Mode_akt;
                        on({id: "robonect.0.status.mode", change: "ne"}, function (obj) {
                          var value = obj.state.val;
                          Mode_akt = getState("robonect.0.status.mode").val;
                          if (Mode_akt == 0) {
                            setState("javascript.0.Status.Flocki.Mode", 'Auto', true);
                          } else if (Mode_akt == 1) {
                            setState("javascript.0.Status.Flocki.Mode", 'Manuell', true);
                          } else if (Mode_akt == 2) {
                            setState("javascript.0.Status.Flocki.Mode", 'Home', true);
                          } else if (Mode_akt == 98) {
                            setState("javascript.0.Status.Flocki.Mode", 'End of day', true);
                          } else if (Mode_akt == 99) {
                            setState("javascript.0.Status.Flocki.Mode", 'Job', true);
                        Skript für "Status":
                        var Status_akt;
                        on({id: "robonect.0.status.status", change: "ne"}, function (obj) {
                          Status_akt = getState("robonect.0.status.status").val;
                          if (Status_akt == 0) {
                            setState("javascript.0.Status.Flocki.Status", 'Unbekannt', true);
                          } else if (Status_akt == 1) {
                            setState("javascript.0.Status.Flocki.Status", 'Parken', true);
                          } else if (Status_akt == 2) {
                            setState("javascript.0.Status.Flocki.Status", 'Mähen', true);
                          } else if (Status_akt == 3) {
                            setState("javascript.0.Status.Flocki.Status", 'Suchen der Ladestation', true);
                          } else if (Status_akt == 4) {
                            setState("javascript.0.Status.Flocki.Status", 'Laden', true);
                          } else if (Status_akt == 5) {
                            setState("javascript.0.Status.Flocki.Status", 'Umsetzen', true);
                          } else if (Status_akt == 7) {
                            setState("javascript.0.Status.Flocki.Status", 'Fehler', true);
                          } else if (Status_akt == 8) {
                            setState("javascript.0.Status.Flocki.Status", 'Schleifensignal verloren', true);
                          } else if (Status_akt == 16) {
                            setState("javascript.0.Status.Flocki.Status", 'Abgeschaltet', true);
                          } else if (Status_akt == 17) {
                            setState("javascript.0.Status.Flocki.Status", 'Schlafen', true);
                        Skript für die Mähtage:
                        var Timer_Tage;
                        schedule('{"time":{"exactTime":true,"start":"18:24"},"period":{"days":1}}', function () {
                          Timer_Tage = '';
                          if (getState("robonect.0.timer.0.weekdays.monday").val == true) {
                            if (Timer_Tage == '') {
                              Timer_Tage += 'Mo';
                            } else {
                              Timer_Tage += ', Mo';
                          if (getState("robonect.0.timer.0.weekdays.tuesday").val == true) {
                              Timer_Tage += 'Di';
                            } else {
                              Timer_Tage += ', Di';
                          if (getState("robonect.0.timer.0.weekdays.wednesday").val == true) {
                              Timer_Tage += 'Mi';
                            } else {
                              Timer_Tage += ', Mi';
                          if (getState("robonect.0.timer.0.weekdays.thursday").val == true) {
                              Timer_Tage += 'Do';
                            } else {
                              Timer_Tage += ', Do';
                          if (getState("robonect.0.timer.0.weekdays.friday").val == true) {
                              Timer_Tage += 'Fr';
                            } else {
                              Timer_Tage += ', Fr';
                          if (getState("robonect.0.timer.0.weekdays.saturday").val == true) {
                              Timer_Tage += 'Sa';
                            } else {
                              Timer_Tage += ', Sa';
                          if (getState("robonect.0.timer.0.weekdays.sunday").val == true) {
                              Timer_Tage += 'So';
                            } else {
                              Timer_Tage += ', So';
                          if (Timer_Tage != '') {
                            Timer_Tage += ' von ';
                            Timer_Tage += String(('' + getState("robonect.0.timer.0.start_time").val));
                            Timer_Tage += ' bis ';
                            Timer_Tage += String(('' + getState("robonect.0.timer.0.end_time").val));
                            Timer_Tage += ' Uhr';
                          setState("javascript.0.Status.Flocki.Tage_Timer"/*Tage_Timer*/, Timer_Tage, true);
                        Wetterpause & Fehler an telegram senden:
                        var Flocki_Status_alt, timeout;
                        on({id: "robonect.0.status.status"/*Current status*/, change: "ne"}, function (obj) {
                          Flocki_Status_alt = getState("robonect.0.status.status").val;
                          if (Flocki_Status_alt == 2 && (getState("javascript.0.Wetterstation.Regen_Tag").val >= 0.5 || getState("javascript.0.Wetterstation.Aussentemperatur").val <= 1)) {
                            // Pause: bisherige Regenmenge > 0,5 l/m² oder Temp < 1°C -> Feierabend
                            setState("robonect.0.status.mode"/*Current mode*/, 98); //  -> Feierabend
                            setState("javascript.0.Status.Flocki.Regenpause"/*Regenpause*/, ([formatDate(new Date(), "YYYY.MM.DD"),' ',formatDate(new Date(), "hh:mm:ss")].join('')), true);
                          } else if (Flocki_Status_alt == 7) {
                            // Fehler! Telegram-Nachricht senden
                            timeout = setTimeout(function () {
                              sendTo("telegram", "send", {
                                  text: (['Störung bei Flocki !!!','\n','Fehler: ',getState("robonect.0.error.0.message").val,'\n','am ',getState("robonect.0.error.0.date").val,' um ',getState("robonect.0.error.0.time").val,' Uhr!'].join(''))
                            }, 120000);
                        Und hier noch die View: Robonect_view.txt
                        WLAN-Empfang: Robonect_WLAN.txt
                        Fehlermeldungen: Robonect_error.txt
                        materialdesign (in allen Varianten die es gibt) sind erforderlich!
                        Programmierung ist verbesserungswürdig (lerne gerade damit umzugehen) und vis ist eher als quick&dirty zu bezeichnen und noch nicht vollständig, z.B. Fehleranzeige, ... ;-)
                        Stimpy23
                        #431
                        @latzi
                        erstmal Danke für deine Scripte. Funktionieren nach Anpassungen super.
                        Jedoch bekomme ich keine Daten bei dem Script Mähtage. was genau muss ich da anpassen?
                        etwas bei Time?
                        Meine 2, Frage wär, wo du die letzte Mäh- und Ladezeit und die Strecken her bekommst?
                        LatziL 1 Antwort Letzte Antwort
                          Stimpy23
                          #432
                          Wie bekomme ich es hin, das der Mähroboter unter Robonect nach dem Timer mäht?
                          egal welchen Modus ich einstelle, es steht immer da bei Timer: Nicht im Auto Modus.
                          Deshalb bekomme ich auch keine Daten bei dem Script von @Latzi
                          • S Stimpy23
                            @latzi
                            etwas bei Time?
                            LatziL Offline
                            LatziL Offline
                            Latzi
                            #433
                            @stimpy23 sagte in Neuer Robonect HX Adapter:
                            etwas bei Time?
                            Hast du in den Einstellungen der Instanz den Timer aktiviert?
                            • LatziL Latzi
                              etwas bei Time?
                              Stimpy23
                              #434
                              @latzi
                              ja, aber das Script Mähtage gibt immer noch keine Daten aus
                              • S Stimpy23
                                @latzi
                                LatziL Offline
                                LatziL Offline
                                Latzi
                                schrieb am zuletzt editiert von Latzi
                                #435
                                @stimpy23
                                wie schauen die DP´s unter robonect.0.timer.0.weekdays aus (steht da bei irgendeinem Tag true?):
                                In Robonect sind auch Zeiten defniert?
                                • LatziL Latzi
                                  @stimpy23
                                  Stimpy23
                                  #436
                                  @latzi
                                  ja, steht bei allen true
                                  • S Stimpy23
                                    @latzi
                                    LatziL Offline
                                    LatziL Offline
                                    Latzi
                                    #437
                                    @stimpy23
                                    Wann hast du das Script erstellt? Heute? Es läuft nur 1 Mal am Tag ;-)
                                    Zeig mal dein Script.
                                    • LatziL Latzi
                                      @stimpy23
                                      Stimpy23
                                      #438
                                      @latzi
                                      habe es jetzt hingekommen, habe die Zeit früher gestellt, damit es ausgelöst wird.
                                      Vielen Danke für deine Hilfe
                                        Stimpy23
                                        #439
                                        kennt einer die ganzen Modi für den Timer (Deaktiviert, Standby, usw.) mit Nummern?
                                        • S Stimpy23
                                          LatziL Offline
                                          LatziL Offline
                                          Latzi
                                          #440
                                          @stimpy23
                                            "type": "state",
                                            "common": {
                                              "name": "Timer status",
                                              "type": "number",
                                              "role": "state",
                                              "read": true,
                                              "write": false,
                                              "desc": "",
                                              "states": {
                                                "0": "Deaktiviert",
                                                "1": "Aktiv",
                                                "2": "Standby"
                                            "native": {},
                                            "from": "system.adapter.robonect.0",
                                            "user": "system.user.admin",
                                            "ts": 1715968728146,
                                            "_id": "robonect.0.timer.status",
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                              "owner": "system.user.admin",
                                          0, 1, 2
