  4. [gelöst] Zigbee Geräte nach Proxmox Update disconnected
61 Beiträge 9 Kommentatoren 11.7k Aufrufe 8 Beobachtet
  • P PROcrastinator
    @thomas-braun @Codierknecht
    Ich hab der LXC jetzt mal 4GB Ram gegeben, bisher lief es alles gut, es kommt ja aber auch immer mehr dazu. bei 16 GB ist der RAM ja nicht zu knapp.
    Hier die lange Version:
    Skript v.2023-04-15
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     10:17:11 up 3 days,  1:09,  1 user,  load average: 0.39, 0.56, 0.45
    CPU threads: 3
    *** Time and Time Zones ***
                   Local time: Tue 2023-05-09 10:17:11 CEST
               Universal time: Tue 2023-05-09 08:17:11 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.1G        1.5G        2.2G        0.0K        328M        2.6G
    Swap:           2.0G        723M        1.3G
    Total:          6.1G        2.2G        3.6G
             4096 M total memory
             1526 M used memory
             1192 M active memory
              561 M inactive memory
             2241 M free memory
                0 M buffer memory
              328 M swap cache
             2048 M total swap
              723 M used swap
             1324 M free swap
    *** FILESYSTEM ***
    Filesystem           Type   Size  Used Avail Use% Mounted on
    /dev/loop0           ext4    15G  3.6G   11G  26% /
    none                 tmpfs  492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root ext4    94G   11G   79G  13% /dev/ttyACM0
    tmpfs                tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                tmpfs  3.1G  116K  3.1G   1% /run
    tmpfs                tmpfs  5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/loop0                                             ext4   rw,relatime
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    621M    /var/
    243M    /var/cache
    239M    /var/lib
    237M    /var/cache/apt
    151M    /var/cache/apt/archives
    Archived and active journals take up 136.0M in the file system.
    /opt/iobroker/backups:
    214M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    624M    /opt/iobroker/iobroker-data/
    311M    /opt/iobroker/iobroker-data/history
    168M    /opt/iobroker/iobroker-data/files
    69M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    65M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.js.map
    11M     /opt/iobroker/iobroker-data/states.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.js
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.0
    /usr/bin/node           v16.20.0
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.0-deb-1nodesource1
      Candidate: 16.20.0-deb-1nodesource1
      Version table:
     *** 16.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 1701, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
      system.adapter.snmp.1                   : snmp                  : iobroker                                 - disabled
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "snmp"         : 2.4.7    , installed 2.4.7
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        8692
    States:         7586
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:4 https://deb.nodesource.com/node_16.x jammy InRelease
    Reading package lists... Done
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30503      1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       10392120   7443/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       31803      116/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       31796      116/iobroker.js-con
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        32844      102/systemd-resolve
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          31677      284/master
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          31678      284/master
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       10474647   7522/io.sonos.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          31383      1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          30505      1/init
    tcp6       0      0 :::1701                 :::*                    LISTEN      1000       33114      305/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       45060      866/io.web.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       3612459    897/io.upnp.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        32843      102/systemd-resolve
    udp        0      0 192.168.178.100:68      0.0.0.0:*                           105        31379      91/systemd-networkd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30504      1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       46915      897/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          30506      1/init
    2023-05-09 10:14:21.765  - info: host.iobroker iobroker upload [40] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
    2023-05-09 10:14:21.793  - info: host.iobroker iobroker upload [30] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Speaker.db548379676317470c4f.svg static/media/Speaker.db548379676317470c4f.svg image/svg+xml
    2023-05-09 10:14:21.817  - info: host.iobroker iobroker upload [20] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
    2023-05-09 10:14:21.820  - info: host.iobroker iobroker upload [19] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
    2023-05-09 10:14:21.826  - info: host.iobroker iobroker upload [18] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
    2023-05-09 10:14:21.831  - info: host.iobroker iobroker upload [17] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
    2023-05-09 10:14:21.834  - info: host.iobroker iobroker upload [16] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
    2023-05-09 10:14:21.837  - info: host.iobroker iobroker upload [15] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
    2023-05-09 10:14:21.840  - info: host.iobroker iobroker upload [14] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
    2023-05-09 10:14:21.843  - info: host.iobroker iobroker upload [13] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
    2023-05-09 10:14:21.846  - info: host.iobroker iobroker upload [12] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
    2023-05-09 10:14:21.849  - info: host.iobroker iobroker upload [11] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
    2023-05-09 10:14:21.852  - info: host.iobroker iobroker upload [10] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
    2023-05-09 10:14:21.855  - info: host.iobroker iobroker upload [9] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
    2023-05-09 10:14:21.857  - info: host.iobroker iobroker upload [8] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
    2023-05-09 10:14:21.860  - info: host.iobroker iobroker upload [7] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
    2023-05-09 10:14:21.864  - info: host.iobroker iobroker upload [6] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
    2023-05-09 10:14:21.867  - info: host.iobroker iobroker upload [5] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
    2023-05-09 10:14:21.870  - info: host.iobroker iobroker upload [4] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
    2023-05-09 10:14:21.874  - info: host.iobroker iobroker upload [3] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
    2023-05-09 10:14:21.877  - info: host.iobroker iobroker upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
    2023-05-09 10:14:21.880  - info: host.iobroker iobroker upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
    2023-05-09 10:14:21.883  - info: host.iobroker iobroker upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
    2023-05-09 10:14:22.908  - info: host.iobroker iobroker exit 0
    2023-05-09 10:17:37.229  - warn: zigbee.0 (7491) DeviceAvailability:Stopping to ping 0xa4c138f6ce64ab7a TS011F after 564 ping attempts
    Dann werde ich nodejs und npm mal angehen.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @procrastinator
    Und hampel im Container nicht als root herum.
    P 1 Antwort Letzte Antwort
      @procrastinator
      P
      P
      PROcrastinator
      @thomas-braun nodejs ist jetzt bei 18.16.0, npm 9.5.1, neuer User ist abgelegt.
      Ist das Boot target ein Problem? Muss ich da was ändern?
      Leider lassen sich immer noch keine Kommandos an die Zigbee Geräte senden:
      error	Send command to 0xa4c138afffcf7a65 failed with no error code (no response received)
      • P PROcrastinator
        Thomas BraunT
        Thomas BraunT
        @procrastinator sagte in Zigbee Geräte nach Proxmox Update disconnected:
        Das war auch nicht anders zu erwarten. Die getätigten Korrekturen sind eher grundsätzlicher Art.
        Ich vermute hier eher Probleme im ZigBee-Netzwerk, die Geräte dürften schlicht und einfach nicht erreichbar sein.
          P
          P
          PROcrastinator
          @thomas-braun Von meinem Testen habe ich die Ahnung, dass der Stick zwar Daten von den Geräten empfängt, aber keine Daten senden kann. Einstellungen an den Steckdosen werden zwar auf der Zigbee Oberfläche angezeigt, kommen aber nicht an den Geräten an.
          Hat jemand eine Lösung, sonst bleibt mir nur die komplette Maschine neu zu machen.
          • P PROcrastinator
            Moin,
            ist einen Versuch Wert, zieh die Steckdose doch mal ab, Stromlos machen, einige Zeit warten und wieder einstecken, die sollte sich dann ja wieder im ZigBee Netzwerk anmelden und noch mal versuchen.
            Wenn ich mir diese Seite anschaue, dann hat dieses Device so einige Probleme, ob das etwas mit Deinen zu tun hat, kann ich nicht sagen, da mir dazu die Informationen fehlen.
            https://www.zigbee2mqtt.io/devices/TS011F_plug_1.html
            Vielleicht musst Du da mal schauen, welche Firmware drauf ist und Up-/Down Graden.
            Bernd
              Moin,
              Bernd
              P
              P
              PROcrastinator
              @dp20eic Moin, ich hab jetzt nochmal eine Steckdose vom Netz genommen und wieder angeschlossen, dann wird sie als verbunden angezeigt, allerdings war sie heute wieder nicht erreichbar. Da ioBroker die Geräte nicht pingen kann wechselt der Zustand anscheinend je nachdem ob die Geräte von sich aus ein Lebenszeichen senden.
              Mir fällt nun nicht mehr ein, außer die Installation entweder auf eine neu aufgesetzte LXC oder direkt auf eine VM zu portieren.
              Mit den Steckdosen hatte ich bisher überhaupt keine Probleme, die Variante des Herstellers (NOUS) sendet auch immer noch automatisch die Werte. Firmwareupgrade habe ich auch nicht gemacht. Nur die Updates im Proxmox bevor das Problem anfing.
              • P PROcrastinator
                Moin,
                bin nicht alle Posts durchgegangen, aber Ich nutze den Conbee 2 mit Zigbee Adapter (v1.8.10) das ist noch aktuell? Kannst Du mal auf die Version 1.8.11 gehen über
                oder
                Betrifft das alle Geräte, dieses Typs?
                Hast Du mal die Position zum Zigbee Stick geändert, ein Zigbee Netzwerk braucht so seine Zeit um das Mesh aufzubauen, verbinden sich denn andere Zigbee Geräte an die Steckdose, da die ja auch gleichzeitig Repeater sind?
                Beispiel
                Ich wüsste nicht, was sich daran dann ändern sollte, außer dass Du alles neu anlernen musst.
                Ich mache täglich Updates, sollten welche da sein, von Proxmox und auch in den LXC Containern oder Office-PCs und bei mir funktioniert Zigbee und Zwave, Tasmota usw. ohne Probleme.
                Leider besitze ich keine diese Steckdosen, um da mehr sagen zu können, ich würde mal eine, so es ein Firmware Update gibt, flashen und schauen wie es sich verhält.
                Und den Zigbee-Adapter mal auf die 1.8.11 bringen.
                Bernd
                  Moin,
                  oder
                  Beispiel
                  Bernd
                  P
                  P
                  PROcrastinator
                  @dp20eic Also mit Version 1.8.11 hat es auch nicht funktioniert. Das Phänomen betrifft generell alle Geräte, nicht nur Steckdosen. Meine Thermometer (mit Display) zeigen auch an, dass sie nicht verbunden sind und keine Zeitinformationen vom Server bekommen. Ich kann auch keine neuen Geräte hinzufügen (eben nochmal probiert) und das log ist voll von den Meldungen, dass die Geräte nicht gepingt werden können. Die Befehle des Sticks kommen einfach nicht bei den Geräten an, bzw. können nicht gesendet werden. Geräte in unmittelbarer Nähe des Sticks funktionieren auch nicht.
                  Da das Problem abrupt nach einem Update von Proxmox auftrat, denke ich das es da einen Zusammenhang gibt. In einer schnell gebastelten VM mit HomeAsstant wurden alle Geräte erkannt und ich konnte sich auch steuern. An der Hardware sollte es also nicht liegen. Evtl. ist beim Update was schief gelaufen und eine neue VM oder LXC löst das Problem. So lange wie ich damit schon rumhantiere bin ich langsam ratlos.
                  So sieht meiner Netzwerkkarte aus:
                  • P PROcrastinator
                    @procrastinator
                    Moin,
                    Du kannst ja ein Issue auf Github https://github.com/ioBroker/ioBroker.zigbee/issues anlegen, oder schauen, ob da noch jemand ein Problem hat.
                    Bernd
                    P.S.: Oder Du setzt mal auf die Kombination mqtt, zigbee2mqtt und zigbee2mqtt-Adapter (ioBroker)
                    Bei mir ist
                    • mqtt (mosquito) -> Docker Synology
                    • LXC Container mit
                      • zigbee2mqtt <- https://www.zigbee2mqtt.io/guide/getting-started/
                      • ioBroker(Test) mit
                        • zigbee2mqtt Adapter
                    • P
                      P
                      PROcrastinator
                      @dp20eic Ich habe mal ein Issue auf Github aufgemacht. Nachdem ich die Version von Github installiert habe, kommt nun die Fehlermeldung
                      Device 0xa4c138af5361218a "A1Z" not described in statesMapping.
                      in der Datei tuya.js sind die Geräte und der Hersteller aber eingetragen. Nachdem ich zurück auf 1.8.10 gegangen bin geht es wieder.
                      Einen Umweg über mqtt möchte ich eigentlich nicht unbedingt gehen, da bisher ja alles gut lief, werde ich aber im Hinterkopf behalten, danke!
                        tuya
                        Moin,
                        wenn ich Tuya lese, dann kommt mir auch noch der Tuya-Adapter in den Sinn :)
                        Bernd
                          tuya
                          Moin,
                          Bernd
                          P
                          P
                          PROcrastinator
                          @dp20eic So, hier ein kurzes Update vom Wochenende:
                          Ich hatte die "Hoffnung", dass evtl. der Stick einfach kaputt ist. In meiner Installation von Homeassistant konnte der Stick auch nicht sende, ebenso nicht in einer zweiten, frischen ioBroker-LXC. Ich habe die Firmware des ConBee II downgegraded nachdem ich einen Hinweis auf instabile Netzwerke ab Version 0x26580700. Hat leider auch nicht geholfen. Also hab ich den Sonoff 3.0 Zigbee Plus Stick bestellt. Auch dieser konnte keine neuen Devices hinzufügen.
                          Also bin ich zurück auf Anfang und habe den Fehler beim Proxmox System gesucht. Habe die udev auf die 247.3-7+deb11u1 zurückgesetzt und die Datei 60-serial.rules angelegt. Leider auch ohne Erfolg. Ich erinnere mich, dass in einem Thread mach den groups gefragt wurde. Evtl. ist irgendjemand nicht in der Gruppe dialout? Das würde ja das Problem erklären, dass Daten empfangen, aber nicht gesendet werden können.
                          Wer muss in der Gruppe dialout sein in der LXC bzw. in der Proxmox Installation?
                          Ich weiß wirklich nicht, wo ich noch nach der Ursache des Problems suchen soll. Gibt es noch irgendwelche Protokolle oder Logs, die ich nach der Ursache durchsuchen kann?
                          • P PROcrastinator
                            Moin,
                            in meiner Proxmox Installation sieht das so aus
                            PVE
                            root@pve:~# ls -la /dev/ttyACM*
                            crw-rw-rw- 1 root dialout 166, 0 May 22 17:30 /dev/ttyACM0
                            crw-rw-rw- 1 root dialout 166, 1 May 12 08:58 /dev/ttyACM1
                            crw-rw-rw- 1 root dialout 166, 2 May 22 17:11 /dev/ttyACM2
                            crw-rw-rw- 1 root dialout 166, 3 May 22 17:38 /dev/ttyACM3
                            root@pve:~# ls -la /dev/serial/by-id/usb-*
                            lrwxrwxrwx 1 root root 13 May 12 08:58 /dev/serial/by-id/usb-0658_0200-if00 -> ../../ttyACM2
                            lrwxrwxrwx 1 root root 13 May 12 08:58 /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001938A67D-if00 -> ../../ttyACM3
                            lrwxrwxrwx 1 root root 13 May 12 08:58 /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if00 -> ../../ttyACM0
                            lrwxrwxrwx 1 root root 13 May 12 08:58 /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if03 -> ../../ttyACM1
                            by-id/   by-path/
                            root@pve:~# ls -la /dev/serial/by-path/
                            total 0
                            drwxr-xr-x 2 root root 120 May 12 08:58 .
                            drwxr-xr-x 4 root root  80 May 12 08:58 ..
                            lrwxrwxrwx 1 root root  13 May 12 08:58 pci-0000:00:12.0-usb-0:1:1.0 -> ../../ttyACM2
                            lrwxrwxrwx 1 root root  13 May 12 08:58 pci-0000:00:13.1-usb-0:3:1.0 -> ../../ttyACM3
                            lrwxrwxrwx 1 root root  13 May 12 08:58 pci-0000:00:13.2-usb-0:1:1.0 -> ../../ttyACM0
                            lrwxrwxrwx 1 root root  13 May 12 08:58 pci-0000:00:13.2-usb-0:1:1.3 -> ../../ttyACM1
                            LXC ioBroker Container
                            dp20eic@iobroker:~$ ls -la /dev/ttyACM*
                            crw-rw-rw- 1 nobody nogroup 166, 0 May 22 17:40 /dev/ttyACM0
                            crw-rw-rw- 1 nobody nogroup 166, 2 May 22 17:11 /dev/ttyACM2
                            dp20eic@iobroker:~$ id iobroker
                            uid=1000(iobroker) gid=1000(iobroker) groups=1000(iobroker),5(tty),20(dialout),29(audio),44(video),1001(wheel),116(bluetooth)
                            Hoffe, Du kommst noch dahinter, was da klemmt.
                            Wenn Du nichts verändert hast, dann schreibt Proxmox ein Journal in welchem alles, was auf dem System passiert geloggt wird.
                            Journal von Anfang an
                            # journalctl | grep -i 'ttyACM*'
                            Hilfe zur Bedienung:
                            # journalctl -h
                            Bernd
                              Moin,
                              PVE
                              by-id/   by-path/
                              total 0
                              # journalctl -h
                              Bernd
                              P
                              P
                              PROcrastinator
                              @dp20eic said in Zigbee Geräte nach Proxmox Update disconnected:
                              Vielen dank für Deine beharrliche Hilfe! Mein Output ist:
                              PVE
                              root@Jarvis:~# ls -la /dev/ttyACM*
                              crw-rw-rw- 1 root dialout 166, 0 May 22 15:42 /dev/ttyACM0
                              root@Jarvis:~# ls -la /dev/serial/by-id/usb-*
                              lrwxrwxrwx 1 root root 13 May 22 15:42 /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2464320-if00 -> ../../ttyACM0
                              ls: cannot access '/dev/serial/by-': No such file or directory
                              root@Jarvis:~# ls -la /dev/serial/by-path/
                              total 0
                              drwxr-xr-x 2 root root 60 May 22 15:42 .
                              drwxr-xr-x 4 root root 80 May 22 15:42 ..
                              lrwxrwxrwx 1 root root 13 May 22 15:42 pci-0000:00:14.0-usb-0:2:1.0 -> ../../ttyACM0
                              LXC
                              roland@iobroker:~$ ls -la /dev/ttyACM*
                              crw-rw-rw- 1 nobody nogroup 166, 0 May 23 16:04 /dev/ttyACM0
                              roland@iobroker:~$ id iobroker
                              Also von dieser Seite her sehe ich keine Probleme. Dann muss ich wohl mal ins Proxmoxforum gehen, evtl. gibt es da Hilfe.
                              Schönen Abend, Roland
                              ? Thomas BraunT 2 Antworten Letzte Antwort
                              • P PROcrastinator
                                PVE
                                total 0
                                LXC
                                Moin,
                                mal einen anderen USB-Port benutzt, hast Du USB 2/3 vielleicht ist ja einer hin?
                                Bernd
                                P.S.: Wie sieht bei Dir das Durchreichen im LXC aus
                                root@pve:~# cat /etc/pve/lxc/100.conf
                                #Produktiver ioBroker LXC Container.
                                unprivileged: 1
                                lxc.cgroup.devices.allow: c 189:* rwm
                                lxc.cgroup.devices.allow: c 166:* rwm
                                lxc.mount.entry: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if00 dev/ttyACM0 none bind,optional,create=file
                                lxc.mount.entry: /dev/serial/by-id/usb-0658_0200-if00 dev/ttyACM2 none bind,optional,create=file
                                • P PROcrastinator
                                  PVE
                                  total 0
                                  LXC
                                  Thomas BraunT
                                  Thomas BraunT
                                  nobody:nogroup ist soweit wie ich das kenne ein klarer Fall von 'nicht richtig durchgereicht/gemappt'.
                                    Moin,
                                    Bernd
                                    unprivileged: 1
                                    P
                                    P
                                    PROcrastinator
                                    schrieb am zuletzt editiert von PROcrastinator
                                    @dp20eic
                                    Die config sieht so aus:
                                    lxc.cgroup2.devices.allow: c 189:* rwm
                                    lxc.mount.entry: usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2464320-if00 dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2464320-if00 none bind,optional,create=file
                                    lxc.cgroup2.devices.allow: c 166:* rwm
                                    lxc.mount.entry: /var/lib/lxc/101/devices/ttyACM0 dev/ttyACM0 none bind,optional,create=file
                                    Aus diesem Toutorial. Hat bisher ja gut funktioniert. Den neuen Sonoff Stick habe ich am Homeassistant zum laufen gebracht, konnte neue Geräte zufügen und auch steuern. Hab dann eine neue VM mit Ubuntu Server gemacht, ioBroker installiert, Stick rein, wieder genau das selbe. Stick wird erkannt, kann aber keine neuen Geräte anlernen.
                                    Hab alle 3 USB Ports versucht, war immer das Gleiche.
                                    @Thomas-Braun In dem verwendeten Tutorial steht das in dem Container auch als nobody nogroup drin. Bisher hat es ja gut funktioniert, aber ich weiß auch nicht wie die Ausgabe vor dem Problem war. Ist auch durchaus möglich dass ich bei meinen Versuchen mit dem Durchreichen zwischen den verschiedenen Maschinen was versaut habe. Bin echt am Verzweifeln langsam. Zum Glück steuere ich damit keine Geräte im Haus, bzw. nur eine Festplatte. Sonst wäre meine Frau schon im Hotel. 😞
                                    Thomas BraunT ? 2 Antworten Letzte Antwort
                                    • P PROcrastinator
                                      @dp20eic
                                      Thomas BraunT
                                      Thomas BraunT
                                      @procrastinator
                                      Es gibt nur keine entsprechende Gruppe/User im Zielsystem die dann über diese group/user Rechte zugreifen könnte. Das sind immer nur Platzhalter, wenn das Durchreichen an valide Gruppen/User nicht möglich ist.
                                      • P PROcrastinator
                                        @dp20eic
                                        Moin,
                                        ja, das mit dem User passt und auch die Gruppen sind richtig für einen LXC Container, wo die Verantwortung beim Proxmox liegen, funktioniert bei mir seit dem ersten Tag so auch mit unterschiedlichen Zigbee Sticks und mit mqtt2zigbee als auch mit Zigbee-Adapter. Wenn Du eine VM nimmst, dann haben die eingebundenen USB Sachen auch die User/Gruppen, wie @Thomas-Braun sagt, nur im LXC Container ist das so korrekt, denn der nutzt ja die Datei/Device am Proxmox.
                                        Die Vermutung von @Thomas-Braun würde zutreffen, wenn Du den Stick nicht im Adapter einbinden kannst, wenn dort ein Permission deny oder kein Zugriff auf das Device möglich wäre, das ist aber nicht der Fall.
                                        In Deinem Fall kann ich mir auch nichts mehr Vorstellen, in Home Asisstant klappt es im ioBroker nicht ist halt seltsam.
                                        Versuch mal mqtt2zigbee ist aber auch nur ein Schuss ins blaue
                                        Bernd
                                        • P
                                          P
                                          PROcrastinator
                                          @dp20eic Moin Bernd, bevor ich auf mqtt2zigbee umsteige, möchte ich es nochmal mit der VM versuchen. Das sollte ja einfacher gehen. Evtl. habe ich den Stick ja nicht richtig eingebunden.
                                          Ich habe ihn über die GUI von Proxmox an die VM weiter gereicht.
                                          In der VM habe ich:
                                          Sind die Berechtigungen richtig, oder muss ich was ändern?
                                          Bei YT sieht man, dass der Stick immer als "usb-ITead_Sonoff_Zigbee_3.0_...." angegeben, mit langer ID. Habe ich da einen gefälschten Stick oder haben die die Bezeichnung geändert?
                                          Vielen Dank, Roland
                                          84.1k
