  4. [gelöst] Zigbee Geräte nach Proxmox Update disconnected
    apollon77A
61 Beiträge 9 Kommentatoren 11.3k Aufrufe 8 Beobachtet
    @procrastinator sagte in Zigbee Geräte nach Proxmox Update disconnected:
    Soll ich das alles komplett als Code posten?
    Wäre vielleicht hilfreich.
    P
    P
    PROcrastinator
    @thomas-braun Vielen Dank für Deine Geduld, hier mal das Protokoll:
    zigbee.0
    2023-05-08 10:41:52.829	info	0xa4c138b585a549dd (addr 3503): E6 - Nous Temperature & humidity LCD sensor (EndDevice)
    zigbee.0
    2023-05-08 10:41:52.828	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_type":"EndDevice","_ieeeAddr":"0xa4c138b585a549dd","_networkAddress":3503,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":81,"inputClusters":[4,5,61184,0],"outputClusters":[25,10],"deviceNetworkAddress":3503,"deviceIeeeAddress":"0xa4c138b585a549dd","clusters":{"genBasic":{"attributes":{"65503":"���+i���+i���+i���+i���+i���+iɯ�+iӯ�+i6��+i@��+iq��+i{��+i","65506":51,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_nnrfa68v","powerSource":3,"zclVersion":3,"appVersion":66,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_nnrfa68v","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":66,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":821693351},"_lastSeen":1683534971733,"_defaultSendRequestWhen":"immediate"},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_nnrfa68v"}],"model":"E6","vendor":"Nous","description":"Temperature & humidity LCD sensor","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandDataResponse","commandDataReport"],"options":[{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"humidity_precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"manuSpecificTuya","type":["commandMcuSyncTime"]}],"toZigbee":[{"key":["min_temperature","max_temperature","temperature_sensitivity","temperature_unit_convert","temperature_report_interval","min_humidity","max_humidity","humidity_sensitivity","humidity_report_interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"enum","name":"temperature_unit_convert","property":"temperature_unit_convert","access":3,"values":["celsius","fahrenheit"],"description":"Current display unit"},{"type":"enum","name":"temperature_alarm","property":"temperature_alarm","access":1,"values":["canceled","lower_alarm","upper_alarm"],"description":"Temperature alarm status"},{"type":"numeric","name":"max_temperature","property":"max_temperature","access":3,"unit":"°C","value_min":-20,"value_max":60,"description":"Alarm temperature max"},{"type":"numeric","name":"min_temperature","property":"min_temperature","access":3,"unit":"°C","value_min":-20,"value_max":60,"description":"Alarm temperature min"},{"type":"numeric","name":"temperature_sensitivity","property":"temperature_sensitivity","access":3,"unit":"°C","value_min":0.1,"value_max":50,"value_step":0.1,"description":"Temperature sensitivity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":["[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0xa4c138b585a549dd"}
    zigbee.0
    2023-05-08 10:41:52.828	info	0xa4c13865b5be7e19 (addr 25067): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.0
    2023-05-08 10:41:52.828	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":7,"_type":"Router","_ieeeAddr":"0xa4c13865b5be7e19","_networkAddress":25067,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":25067,"deviceIeeeAddress":"0xa4c13865b5be7e19","clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":239,"activePower":0,"rmsCurrent":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,11938]}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":2}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":25067,"deviceIeeeAddress":"0xa4c13865b5be7e19","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683533674245,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c13865b5be7e19"}
    zigbee.0
    2023-05-08 10:41:52.827	info	0xa4c138f6ce64ab7a (addr 15255): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.0
    2023-05-08 10:41:52.827	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c138f6ce64ab7a"}
    zigbee.0
    2023-05-08 10:41:52.826	info	0xa4c1380f22d07657 (addr 21958): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.0
    2023-05-08 10:41:52.826	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"_type":"Router","_ieeeAddr":"0xa4c1380f22d07657","_networkAddress":21958,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":21958,"deviceIeeeAddress":"0xa4c1380f22d07657","clusters":{"genBasic":{"attributes":{"65503":"��5+\u0016","65506":53,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":1,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":1,"switchType":0,"powerOnBehavior":1}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":236,"rmsCurrent":126,"activePower":8}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,9794]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":21958,"deviceIeeeAddress":"0xa4c1380f22d07657","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":-1798312590},"_lastSeen":1683535307105,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c1380f22d07657"}
    zigbee.0
    2023-05-08 10:41:52.826	info	0xa4c138072cd30165 (addr 45291): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.0
    2023-05-08 10:41:52.825	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"_type":"Router","_ieeeAddr":"0xa4c138072cd30165","_networkAddress":45291,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":45291,"deviceIeeeAddress":"0xa4c138072cd30165","clusters":{"genBasic":{"attributes":{"65506":53,"65508":0,"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":2}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":237,"rmsCurrent":11,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,24824],"status":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":45291,"deviceIeeeAddress":"0xa4c138072cd30165","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535269237,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c138072cd30165"}
    zigbee.0
    2023-05-08 10:41:52.825	info	0x00158d0007e08b8f (addr 53667): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0
    2023-05-08 10:41:52.824	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e08b8f","_networkAddress":53667,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":53667,"deviceIeeeAddress":"0x00158d0007e08b8f","clusters":{"genBasic":{"attributes":{"65281":{"1":2945,"4":17320,"5":109,"6":[0,1],"10":45291,"100":1858,"101":8439,"102":101426},"modelId":"lumi.weather","appVersion":5,"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2461}},"msRelativeHumidity":{"attributes":{"measuredValue":6300}},"msPressureMeasurement":{"attributes":{"measuredValue":1015,"scale":-1,"scaledValue":10158}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1683534856956,"_defaultSendRequestWhen":"immediate"},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","options":[{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}],"type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},"[Circular]","[Circular]"]},"name":"0x00158d0007e08b8f"}
    zigbee.0
    2023-05-08 10:41:52.821	info	0x00158d0007d3d429 (addr 62218): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0
    2023-05-08 10:41:52.821	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007d3d429","_networkAddress":62218,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":62218,"deviceIeeeAddress":"0x00158d0007d3d429","clusters":{"genBasic":{"attributes":{"65281":{"1":2965,"4":5032,"5":36,"6":[0,327681],"10":40551,"100":2152,"101":8224,"102":102406},"modelId":"lumi.weather","appVersion":5,"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2369}},"msRelativeHumidity":{"attributes":{"measuredValue":7391}},"msPressureMeasurement":{"attributes":{"measuredValue":1023,"scale":-1,"scaledValue":10236}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1683534699122,"_defaultSendRequestWhen":"immediate"},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","options":[{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}],"type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},"[Circular]","[Circular]"]},"name":"0x00158d0007d3d429"}
    zigbee.0
    2023-05-08 10:41:52.820	debug	DeviceConfigure:DeviceConfigure 0xa4c138af5361218a TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.820	debug	DeviceConfigure:DeviceConfigure 0xa4c13820ce967adb TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0x9035eafffeaf5fb5 TS0101 not needed
    zigbee.0
    2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c13854d4832e15 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c1385c80119b31 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c138d89c4c8614 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c1383d52854eef TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c138afffcf7a65 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c138450bb97d84 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c1389037c5ef89 TS0601 not needed
    zigbee.0
    2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c1383a0d04dafc TS0203 not needed
    zigbee.0
    2023-05-08 10:41:52.817	debug	DeviceConfigure:DeviceConfigure 0xa4c138e3a62b2502 TS0601 not needed
    zigbee.0
    2023-05-08 10:41:52.817	debug	DeviceConfigure:DeviceConfigure 0xa4c1386a948505ae TS0601 not needed
    zigbee.0
    2023-05-08 10:41:52.816	debug	DeviceConfigure:DeviceConfigure 0xa4c138c66f278d96 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.816	debug	DeviceConfigure:DeviceConfigure 0xa4c138cf4ef6de5c TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138cc531cbee1 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138e2021c1cc0 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138931420cd2b TS0601 not needed
    zigbee.0
    2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138da9533e551 TS0601 not needed
    zigbee.0
    2023-05-08 10:41:52.814	debug	DeviceConfigure:DeviceConfigure 0xa4c138b585a549dd TS0601 not needed
    zigbee.0
    2023-05-08 10:41:52.813	debug	DeviceConfigure:DeviceConfigure 0xa4c13865b5be7e19 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0xa4c138f6ce64ab7a TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0xa4c1380f22d07657 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0xa4c138072cd30165 TS011F not needed
    zigbee.0
    2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0x00158d0007e08b8f lumi.weather not needed
    zigbee.0
    2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0x00158d0007d3d429 lumi.weather not needed
    zigbee.0
    2023-05-08 10:41:52.810	debug	DeviceAvailability:Publish LQ for 0xa4c1389037c5ef89 = 10
    zigbee.0
    2023-05-08 10:41:52.809	debug	DeviceAvailability:Publish available for 0xa4c1389037c5ef89 = true
    zigbee.0
    2023-05-08 10:41:52.809	debug	DeviceAvailability:Publish LQ for 0xa4c1383a0d04dafc = 10
    zigbee.0
    2023-05-08 10:41:52.808	debug	DeviceAvailability:Publish available for 0xa4c1383a0d04dafc = true
    zigbee.0
    2023-05-08 10:41:52.807	debug	DeviceAvailability:Publish LQ for 0xa4c138e3a62b2502 = 10
    zigbee.0
    2023-05-08 10:41:52.806	debug	DeviceAvailability:Publish available for 0xa4c138e3a62b2502 = true
    zigbee.0
    2023-05-08 10:41:52.806	debug	DeviceAvailability:Publish LQ for 0xa4c1386a948505ae = 10
    zigbee.0
    2023-05-08 10:41:52.805	debug	DeviceAvailability:Publish available for 0xa4c1386a948505ae = true
    zigbee.0
    2023-05-08 10:41:52.804	debug	DeviceAvailability:Publish LQ for 0xa4c138931420cd2b = 10
    zigbee.0
    2023-05-08 10:41:52.801	debug	DeviceAvailability:Publish available for 0xa4c138931420cd2b = true
    zigbee.0
    2023-05-08 10:41:52.800	debug	DeviceAvailability:Publish LQ for 0xa4c138da9533e551 = 10
    zigbee.0
    2023-05-08 10:41:52.799	debug	DeviceAvailability:Publish available for 0xa4c138da9533e551 = true
    zigbee.0
    2023-05-08 10:41:52.798	debug	DeviceAvailability:Publish LQ for 0xa4c138b585a549dd = 10
    zigbee.0
    2023-05-08 10:41:52.798	debug	DeviceAvailability:Publish available for 0xa4c138b585a549dd = true
    zigbee.0
    2023-05-08 10:41:52.796	debug	DeviceAvailability:Publish LQ for 0x00158d0007e08b8f = 10
    zigbee.0
    2023-05-08 10:41:52.794	debug	DeviceAvailability:Publish available for 0x00158d0007e08b8f = true
    zigbee.0
    2023-05-08 10:41:52.792	debug	DeviceAvailability:Publish LQ for 0x00158d0007d3d429 = 10
    zigbee.0
    2023-05-08 10:41:52.790	debug	DeviceAvailability:Publish available for 0x00158d0007d3d429 = true
    zigbee.0
    2023-05-08 10:41:52.790	info	Currently 26 devices are joined:
    zigbee.0
    2023-05-08 10:41:52.781	info	Unable to set transmit power, unsupported function.
    zigbee.0
    2023-05-08 10:41:52.725	info	--> transmitPower : high
    zigbee.0
    2023-05-08 10:41:52.719	info	Unable to disable LED, unsupported function.
    zigbee.0
    2023-05-08 10:41:52.718	debug	Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
    zigbee.0
    2023-05-08 10:41:52.696	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
    zigbee.0
    2023-05-08 10:41:52.692	debug	zigbee-herdsman started
    zigbee.0
    2023-05-08 10:41:52.681	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_05_08-10_41_52.tar.gz success
    zigbee.0
    2023-05-08 10:41:52.660	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-05-08 10:41:52.430	debug	Starting zigbee-herdsman...
    zigbee.0
    2023-05-08 10:41:52.429	info	Starting Zigbee npm ...
    zigbee.0
    2023-05-08 10:41:52.428	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-05-08 10:41:52.403	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
    zigbee.0
    2023-05-08 10:41:52.378	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.0, js-controller: 4.0.23
    zigbee.0
    2023-05-08 10:41:52.112	debug	Plugin sentry Initialize Plugin (enabled=true)
    zigbee.0
    2023-05-08 10:41:48.054	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2023-05-08 10:41:48.054	debug	Plugin sentry destroyed
    zigbee.0
    2023-05-08 10:41:48.054	info	terminating
    zigbee.0
    2023-05-08 10:41:47.701	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-05-08 10:41:47.699	debug	DeviceAvailability:Publish LQ for 0xa4c138af5361218a = 0
    zigbee.0
    2023-05-08 10:41:47.698	debug	DeviceAvailability:Publish available for 0xa4c138af5361218a = false
    zigbee.0
    2023-05-08 10:41:47.697	debug	DeviceAvailability:Publish LQ for 0xa4c13820ce967adb = 0
    zigbee.0
    2023-05-08 10:41:47.695	debug	DeviceAvailability:Publish available for 0xa4c13820ce967adb = false
    zigbee.0
    2023-05-08 10:41:47.694	debug	DeviceAvailability:Publish LQ for 0x9035eafffeaf5fb5 = 0
    zigbee.0
    2023-05-08 10:41:47.694	debug	DeviceAvailability:Publish available for 0x9035eafffeaf5fb5 = false
    zigbee.0
    2023-05-08 10:41:47.693	debug	DeviceAvailability:Publish LQ for 0xa4c13854d4832e15 = 0
    zigbee.0
    2023-05-08 10:41:47.692	debug	DeviceAvailability:Publish available for 0xa4c13854d4832e15 = false
    zigbee.0
    2023-05-08 10:41:47.691	debug	DeviceAvailability:Publish LQ for 0xa4c1385c80119b31 = 0
    zigbee.0
    2023-05-08 10:41:47.691	debug	DeviceAvailability:Publish available for 0xa4c1385c80119b31 = false
    zigbee.0
    2023-05-08 10:41:47.690	debug	DeviceAvailability:Publish LQ for 0xa4c138d89c4c8614 = 0
    zigbee.0
    2023-05-08 10:41:47.689	debug	DeviceAvailability:Publish available for 0xa4c138d89c4c8614 = false
    zigbee.0
    2023-05-08 10:41:47.688	debug	DeviceAvailability:Publish LQ for 0xa4c1383d52854eef = 0
    zigbee.0
    2023-05-08 10:41:47.687	debug	DeviceAvailability:Publish available for 0xa4c1383d52854eef = false
    zigbee.0
    2023-05-08 10:41:47.686	debug	DeviceAvailability:Publish LQ for 0xa4c138afffcf7a65 = 0
    zigbee.0
    2023-05-08 10:41:47.686	debug	DeviceAvailability:Publish available for 0xa4c138afffcf7a65 = false
    zigbee.0
    2023-05-08 10:41:47.685	debug	DeviceAvailability:Publish LQ for 0xa4c138450bb97d84 = 0
    zigbee.0
    2023-05-08 10:41:47.684	debug	DeviceAvailability:Publish available for 0xa4c138450bb97d84 = false
    zigbee.0
    2023-05-08 10:41:47.683	debug	DeviceAvailability:Publish LQ for 0xa4c1389037c5ef89 = 0
    zigbee.0
    2023-05-08 10:41:47.682	debug	DeviceAvailability:Publish available for 0xa4c1389037c5ef89 = false
    zigbee.0
    2023-05-08 10:41:47.681	debug	DeviceAvailability:Publish LQ for 0xa4c1383a0d04dafc = 0
    zigbee.0
    2023-05-08 10:41:47.681	debug	DeviceAvailability:Publish available for 0xa4c1383a0d04dafc = false
    zigbee.0
    2023-05-08 10:41:47.680	debug	DeviceAvailability:Publish LQ for 0xa4c138e3a62b2502 = 0
    zigbee.0
    2023-05-08 10:41:47.679	debug	DeviceAvailability:Publish available for 0xa4c138e3a62b2502 = false
    zigbee.0
    2023-05-08 10:41:47.677	debug	DeviceAvailability:Publish LQ for 0xa4c1386a948505ae = 0
    zigbee.0
    2023-05-08 10:41:47.676	debug	DeviceAvailability:Publish available for 0xa4c1386a948505ae = false
    zigbee.0
    2023-05-08 10:41:47.675	debug	DeviceAvailability:Publish LQ for 0xa4c138c66f278d96 = 0
    zigbee.0
    2023-05-08 10:41:47.674	debug	DeviceAvailability:Publish available for 0xa4c138c66f278d96 = false
    zigbee.0
    2023-05-08 10:41:47.673	debug	DeviceAvailability:Publish LQ for 0xa4c138cf4ef6de5c = 0
    zigbee.0
    2023-05-08 10:41:47.671	debug	DeviceAvailability:Publish available for 0xa4c138cf4ef6de5c = false
    zigbee.0
    2023-05-08 10:41:47.670	debug	DeviceAvailability:Publish LQ for 0xa4c138cc531cbee1 = 0
    zigbee.0
    2023-05-08 10:41:47.669	debug	DeviceAvailability:Publish available for 0xa4c138cc531cbee1 = false
    zigbee.0
    2023-05-08 10:41:47.668	debug	DeviceAvailability:Publish LQ for 0xa4c138e2021c1cc0 = 0
    zigbee.0
    2023-05-08 10:41:47.668	debug	DeviceAvailability:Publish available for 0xa4c138e2021c1cc0 = false
    zigbee.0
    2023-05-08 10:41:47.667	debug	DeviceAvailability:Publish LQ for 0xa4c138931420cd2b = 0
    zigbee.0
    2023-05-08 10:41:47.666	debug	DeviceAvailability:Publish available for 0xa4c138931420cd2b = false
    zigbee.0
    2023-05-08 10:41:47.665	debug	DeviceAvailability:Publish LQ for 0xa4c138da9533e551 = 0
    zigbee.0
    2023-05-08 10:41:47.664	debug	DeviceAvailability:Publish available for 0xa4c138da9533e551 = false
    zigbee.0
    2023-05-08 10:41:47.663	debug	DeviceAvailability:Publish LQ for 0xa4c138b585a549dd = 0
    zigbee.0
    2023-05-08 10:41:47.662	debug	DeviceAvailability:Publish available for 0xa4c138b585a549dd = false
    zigbee.0
    2023-05-08 10:41:47.661	debug	DeviceAvailability:Publish LQ for 0xa4c13865b5be7e19 = 0
    zigbee.0
    2023-05-08 10:41:47.660	debug	DeviceAvailability:Publish available for 0xa4c13865b5be7e19 = false
    zigbee.0
    2023-05-08 10:41:47.660	debug	DeviceAvailability:Publish LQ for 0xa4c138f6ce64ab7a = 0
    zigbee.0
    2023-05-08 10:41:47.659	debug	DeviceAvailability:Publish available for 0xa4c138f6ce64ab7a = false
    zigbee.0
    2023-05-08 10:41:47.658	debug	DeviceAvailability:Publish LQ for 0xa4c1380f22d07657 = 0
    zigbee.0
    2023-05-08 10:41:47.656	debug	DeviceAvailability:Publish available for 0xa4c1380f22d07657 = false
    zigbee.0
    2023-05-08 10:41:47.655	debug	DeviceAvailability:Publish LQ for 0xa4c138072cd30165 = 0
    zigbee.0
    2023-05-08 10:41:47.653	debug	DeviceAvailability:Publish available for 0xa4c138072cd30165 = false
    zigbee.0
    2023-05-08 10:41:47.653	debug	DeviceAvailability:Publish LQ for 0x00158d0007e08b8f = 0
    zigbee.0
    2023-05-08 10:41:47.652	debug	DeviceAvailability:Publish available for 0x00158d0007e08b8f = false
    zigbee.0
    2023-05-08 10:41:47.651	debug	DeviceAvailability:Publish LQ for 0x00158d0007d3d429 = 0
    zigbee.0
    2023-05-08 10:41:47.650	debug	DeviceAvailability:Publish available for 0x00158d0007d3d429 = false
    zigbee.0
    2023-05-08 10:41:47.646	info	cleaned everything up...
    zigbee.0
    2023-05-08 10:41:47.645	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2023-05-08 10:41:47.255	debug	Publish {"current":0} to "a4c138f6ce64ab7a"
    zigbee.0
    2023-05-08 10:41:47.248	debug	Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate","_linkquality":255},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c138f6ce64ab7a"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate","_linkquality":255},"endpoint":"[Circular]","data":{"rmsCurrent":0},"linkquality":255,"groupID":null,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":179,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":tru
    e,"reservedBits":0}}}
    zigbee.0
    2023-05-08 10:41:47.248	debug	Received Zigbee message from '0xa4c138f6ce64ab7a', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":0}' from endpoint 1 with groupID null
    zigbee.0
    2023-05-08 10:41:47.247	debug	handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate","_linkquality":255},"endpoint":"[Circular]","data":{"rmsCurrent":0},"linkquality":255,"groupID":null,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":179,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    zigbee.0
    2023-05-08 10:41:47.114	debug	Publish {"power":8} to "a4c1380f22d07657"
    Ich hoffe, das sagt Dir was, ich musste kräftig was löschen, so schnell läuft das voll.
    Gruß, Roland
    • P PROcrastinator
      @thomas-braun Vielen Dank für Deine Geduld, hier mal das Protokoll:
      zigbee.0
      2023-05-08 10:41:52.829	info	0xa4c138b585a549dd (addr 3503): E6 - Nous Temperature & humidity LCD sensor (EndDevice)
      zigbee.0
      2023-05-08 10:41:52.828	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_type":"EndDevice","_ieeeAddr":"0xa4c138b585a549dd","_networkAddress":3503,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":81,"inputClusters":[4,5,61184,0],"outputClusters":[25,10],"deviceNetworkAddress":3503,"deviceIeeeAddress":"0xa4c138b585a549dd","clusters":{"genBasic":{"attributes":{"65503":"���+i���+i���+i���+i���+i���+iɯ�+iӯ�+i6��+i@��+iq��+i{��+i","65506":51,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_nnrfa68v","powerSource":3,"zclVersion":3,"appVersion":66,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZE200_nnrfa68v","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":66,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":821693351},"_lastSeen":1683534971733,"_defaultSendRequestWhen":"immediate"},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_nnrfa68v"}],"model":"E6","vendor":"Nous","description":"Temperature & humidity LCD sensor","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandDataResponse","commandDataReport"],"options":[{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"humidity_precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"manuSpecificTuya","type":["commandMcuSyncTime"]}],"toZigbee":[{"key":["min_temperature","max_temperature","temperature_sensitivity","temperature_unit_convert","temperature_report_interval","min_humidity","max_humidity","humidity_sensitivity","humidity_report_interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"enum","name":"temperature_unit_convert","property":"temperature_unit_convert","access":3,"values":["celsius","fahrenheit"],"description":"Current display unit"},{"type":"enum","name":"temperature_alarm","property":"temperature_alarm","access":1,"values":["canceled","lower_alarm","upper_alarm"],"description":"Temperature alarm status"},{"type":"numeric","name":"max_temperature","property":"max_temperature","access":3,"unit":"°C","value_min":-20,"value_max":60,"description":"Alarm temperature max"},{"type":"numeric","name":"min_temperature","property":"min_temperature","access":3,"unit":"°C","value_min":-20,"value_max":60,"description":"Alarm temperature min"},{"type":"numeric","name":"temperature_sensitivity","property":"temperature_sensitivity","access":3,"unit":"°C","value_min":0.1,"value_max":50,"value_step":0.1,"description":"Temperature sensitivity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":["[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0xa4c138b585a549dd"}
      zigbee.0
      2023-05-08 10:41:52.828	info	0xa4c13865b5be7e19 (addr 25067): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      2023-05-08 10:41:52.828	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":7,"_type":"Router","_ieeeAddr":"0xa4c13865b5be7e19","_networkAddress":25067,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":25067,"deviceIeeeAddress":"0xa4c13865b5be7e19","clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":239,"activePower":0,"rmsCurrent":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,11938]}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":2}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":25067,"deviceIeeeAddress":"0xa4c13865b5be7e19","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683533674245,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c13865b5be7e19"}
      zigbee.0
      2023-05-08 10:41:52.827	info	0xa4c138f6ce64ab7a (addr 15255): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      2023-05-08 10:41:52.827	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c138f6ce64ab7a"}
      zigbee.0
      2023-05-08 10:41:52.826	info	0xa4c1380f22d07657 (addr 21958): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      2023-05-08 10:41:52.826	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"_type":"Router","_ieeeAddr":"0xa4c1380f22d07657","_networkAddress":21958,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":21958,"deviceIeeeAddress":"0xa4c1380f22d07657","clusters":{"genBasic":{"attributes":{"65503":"��5+\u0016","65506":53,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":1,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":1,"switchType":0,"powerOnBehavior":1}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":236,"rmsCurrent":126,"activePower":8}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,9794]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":21958,"deviceIeeeAddress":"0xa4c1380f22d07657","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":-1798312590},"_lastSeen":1683535307105,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c1380f22d07657"}
      zigbee.0
      2023-05-08 10:41:52.826	info	0xa4c138072cd30165 (addr 45291): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      2023-05-08 10:41:52.825	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"_type":"Router","_ieeeAddr":"0xa4c138072cd30165","_networkAddress":45291,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":45291,"deviceIeeeAddress":"0xa4c138072cd30165","clusters":{"genBasic":{"attributes":{"65506":53,"65508":0,"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":0,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":2}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":237,"rmsCurrent":11,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,24824],"status":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":45291,"deviceIeeeAddress":"0xa4c138072cd30165","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535269237,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c138072cd30165"}
      zigbee.0
      2023-05-08 10:41:52.825	info	0x00158d0007e08b8f (addr 53667): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0
      2023-05-08 10:41:52.824	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e08b8f","_networkAddress":53667,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":53667,"deviceIeeeAddress":"0x00158d0007e08b8f","clusters":{"genBasic":{"attributes":{"65281":{"1":2945,"4":17320,"5":109,"6":[0,1],"10":45291,"100":1858,"101":8439,"102":101426},"modelId":"lumi.weather","appVersion":5,"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2461}},"msRelativeHumidity":{"attributes":{"measuredValue":6300}},"msPressureMeasurement":{"attributes":{"measuredValue":1015,"scale":-1,"scaledValue":10158}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1683534856956,"_defaultSendRequestWhen":"immediate"},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","options":[{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}],"type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},"[Circular]","[Circular]"]},"name":"0x00158d0007e08b8f"}
      zigbee.0
      2023-05-08 10:41:52.821	info	0x00158d0007d3d429 (addr 62218): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0
      2023-05-08 10:41:52.821	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007d3d429","_networkAddress":62218,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":62218,"deviceIeeeAddress":"0x00158d0007d3d429","clusters":{"genBasic":{"attributes":{"65281":{"1":2965,"4":5032,"5":36,"6":[0,327681],"10":40551,"100":2152,"101":8224,"102":102406},"modelId":"lumi.weather","appVersion":5,"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2369}},"msRelativeHumidity":{"attributes":{"measuredValue":7391}},"msPressureMeasurement":{"attributes":{"measuredValue":1023,"scale":-1,"scaledValue":10236}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1683534699122,"_defaultSendRequestWhen":"immediate"},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","options":[{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}],"type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"temperature_calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"temperature_precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"pressure_precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},"[Circular]","[Circular]"]},"name":"0x00158d0007d3d429"}
      zigbee.0
      2023-05-08 10:41:52.820	debug	DeviceConfigure:DeviceConfigure 0xa4c138af5361218a TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.820	debug	DeviceConfigure:DeviceConfigure 0xa4c13820ce967adb TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0x9035eafffeaf5fb5 TS0101 not needed
      zigbee.0
      2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c13854d4832e15 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c1385c80119b31 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c138d89c4c8614 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.819	debug	DeviceConfigure:DeviceConfigure 0xa4c1383d52854eef TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c138afffcf7a65 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c138450bb97d84 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c1389037c5ef89 TS0601 not needed
      zigbee.0
      2023-05-08 10:41:52.818	debug	DeviceConfigure:DeviceConfigure 0xa4c1383a0d04dafc TS0203 not needed
      zigbee.0
      2023-05-08 10:41:52.817	debug	DeviceConfigure:DeviceConfigure 0xa4c138e3a62b2502 TS0601 not needed
      zigbee.0
      2023-05-08 10:41:52.817	debug	DeviceConfigure:DeviceConfigure 0xa4c1386a948505ae TS0601 not needed
      zigbee.0
      2023-05-08 10:41:52.816	debug	DeviceConfigure:DeviceConfigure 0xa4c138c66f278d96 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.816	debug	DeviceConfigure:DeviceConfigure 0xa4c138cf4ef6de5c TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138cc531cbee1 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138e2021c1cc0 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138931420cd2b TS0601 not needed
      zigbee.0
      2023-05-08 10:41:52.815	debug	DeviceConfigure:DeviceConfigure 0xa4c138da9533e551 TS0601 not needed
      zigbee.0
      2023-05-08 10:41:52.814	debug	DeviceConfigure:DeviceConfigure 0xa4c138b585a549dd TS0601 not needed
      zigbee.0
      2023-05-08 10:41:52.813	debug	DeviceConfigure:DeviceConfigure 0xa4c13865b5be7e19 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0xa4c138f6ce64ab7a TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0xa4c1380f22d07657 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0xa4c138072cd30165 TS011F not needed
      zigbee.0
      2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0x00158d0007e08b8f lumi.weather not needed
      zigbee.0
      2023-05-08 10:41:52.812	debug	DeviceConfigure:DeviceConfigure 0x00158d0007d3d429 lumi.weather not needed
      zigbee.0
      2023-05-08 10:41:52.810	debug	DeviceAvailability:Publish LQ for 0xa4c1389037c5ef89 = 10
      zigbee.0
      2023-05-08 10:41:52.809	debug	DeviceAvailability:Publish available for 0xa4c1389037c5ef89 = true
      zigbee.0
      2023-05-08 10:41:52.809	debug	DeviceAvailability:Publish LQ for 0xa4c1383a0d04dafc = 10
      zigbee.0
      2023-05-08 10:41:52.808	debug	DeviceAvailability:Publish available for 0xa4c1383a0d04dafc = true
      zigbee.0
      2023-05-08 10:41:52.807	debug	DeviceAvailability:Publish LQ for 0xa4c138e3a62b2502 = 10
      zigbee.0
      2023-05-08 10:41:52.806	debug	DeviceAvailability:Publish available for 0xa4c138e3a62b2502 = true
      zigbee.0
      2023-05-08 10:41:52.806	debug	DeviceAvailability:Publish LQ for 0xa4c1386a948505ae = 10
      zigbee.0
      2023-05-08 10:41:52.805	debug	DeviceAvailability:Publish available for 0xa4c1386a948505ae = true
      zigbee.0
      2023-05-08 10:41:52.804	debug	DeviceAvailability:Publish LQ for 0xa4c138931420cd2b = 10
      zigbee.0
      2023-05-08 10:41:52.801	debug	DeviceAvailability:Publish available for 0xa4c138931420cd2b = true
      zigbee.0
      2023-05-08 10:41:52.800	debug	DeviceAvailability:Publish LQ for 0xa4c138da9533e551 = 10
      zigbee.0
      2023-05-08 10:41:52.799	debug	DeviceAvailability:Publish available for 0xa4c138da9533e551 = true
      zigbee.0
      2023-05-08 10:41:52.798	debug	DeviceAvailability:Publish LQ for 0xa4c138b585a549dd = 10
      zigbee.0
      2023-05-08 10:41:52.798	debug	DeviceAvailability:Publish available for 0xa4c138b585a549dd = true
      zigbee.0
      2023-05-08 10:41:52.796	debug	DeviceAvailability:Publish LQ for 0x00158d0007e08b8f = 10
      zigbee.0
      2023-05-08 10:41:52.794	debug	DeviceAvailability:Publish available for 0x00158d0007e08b8f = true
      zigbee.0
      2023-05-08 10:41:52.792	debug	DeviceAvailability:Publish LQ for 0x00158d0007d3d429 = 10
      zigbee.0
      2023-05-08 10:41:52.790	debug	DeviceAvailability:Publish available for 0x00158d0007d3d429 = true
      zigbee.0
      2023-05-08 10:41:52.790	info	Currently 26 devices are joined:
      zigbee.0
      2023-05-08 10:41:52.781	info	Unable to set transmit power, unsupported function.
      zigbee.0
      2023-05-08 10:41:52.725	info	--> transmitPower : high
      zigbee.0
      2023-05-08 10:41:52.719	info	Unable to disable LED, unsupported function.
      zigbee.0
      2023-05-08 10:41:52.718	debug	Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
      zigbee.0
      2023-05-08 10:41:52.696	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
      zigbee.0
      2023-05-08 10:41:52.692	debug	zigbee-herdsman started
      zigbee.0
      2023-05-08 10:41:52.681	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_05_08-10_41_52.tar.gz success
      zigbee.0
      2023-05-08 10:41:52.660	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0
      2023-05-08 10:41:52.430	debug	Starting zigbee-herdsman...
      zigbee.0
      2023-05-08 10:41:52.429	info	Starting Zigbee npm ...
      zigbee.0
      2023-05-08 10:41:52.428	info	delete old Backup files. keep only last 10
      zigbee.0
      2023-05-08 10:41:52.403	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2023-05-08 10:41:52.378	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.0, js-controller: 4.0.23
      zigbee.0
      2023-05-08 10:41:52.112	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2023-05-08 10:41:48.054	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2023-05-08 10:41:48.054	debug	Plugin sentry destroyed
      zigbee.0
      2023-05-08 10:41:48.054	info	terminating
      zigbee.0
      2023-05-08 10:41:47.701	info	Zigbee: disabling joining new devices.
      zigbee.0
      2023-05-08 10:41:47.699	debug	DeviceAvailability:Publish LQ for 0xa4c138af5361218a = 0
      zigbee.0
      2023-05-08 10:41:47.698	debug	DeviceAvailability:Publish available for 0xa4c138af5361218a = false
      zigbee.0
      2023-05-08 10:41:47.697	debug	DeviceAvailability:Publish LQ for 0xa4c13820ce967adb = 0
      zigbee.0
      2023-05-08 10:41:47.695	debug	DeviceAvailability:Publish available for 0xa4c13820ce967adb = false
      zigbee.0
      2023-05-08 10:41:47.694	debug	DeviceAvailability:Publish LQ for 0x9035eafffeaf5fb5 = 0
      zigbee.0
      2023-05-08 10:41:47.694	debug	DeviceAvailability:Publish available for 0x9035eafffeaf5fb5 = false
      zigbee.0
      2023-05-08 10:41:47.693	debug	DeviceAvailability:Publish LQ for 0xa4c13854d4832e15 = 0
      zigbee.0
      2023-05-08 10:41:47.692	debug	DeviceAvailability:Publish available for 0xa4c13854d4832e15 = false
      zigbee.0
      2023-05-08 10:41:47.691	debug	DeviceAvailability:Publish LQ for 0xa4c1385c80119b31 = 0
      zigbee.0
      2023-05-08 10:41:47.691	debug	DeviceAvailability:Publish available for 0xa4c1385c80119b31 = false
      zigbee.0
      2023-05-08 10:41:47.690	debug	DeviceAvailability:Publish LQ for 0xa4c138d89c4c8614 = 0
      zigbee.0
      2023-05-08 10:41:47.689	debug	DeviceAvailability:Publish available for 0xa4c138d89c4c8614 = false
      zigbee.0
      2023-05-08 10:41:47.688	debug	DeviceAvailability:Publish LQ for 0xa4c1383d52854eef = 0
      zigbee.0
      2023-05-08 10:41:47.687	debug	DeviceAvailability:Publish available for 0xa4c1383d52854eef = false
      zigbee.0
      2023-05-08 10:41:47.686	debug	DeviceAvailability:Publish LQ for 0xa4c138afffcf7a65 = 0
      zigbee.0
      2023-05-08 10:41:47.686	debug	DeviceAvailability:Publish available for 0xa4c138afffcf7a65 = false
      zigbee.0
      2023-05-08 10:41:47.685	debug	DeviceAvailability:Publish LQ for 0xa4c138450bb97d84 = 0
      zigbee.0
      2023-05-08 10:41:47.684	debug	DeviceAvailability:Publish available for 0xa4c138450bb97d84 = false
      zigbee.0
      2023-05-08 10:41:47.683	debug	DeviceAvailability:Publish LQ for 0xa4c1389037c5ef89 = 0
      zigbee.0
      2023-05-08 10:41:47.682	debug	DeviceAvailability:Publish available for 0xa4c1389037c5ef89 = false
      zigbee.0
      2023-05-08 10:41:47.681	debug	DeviceAvailability:Publish LQ for 0xa4c1383a0d04dafc = 0
      zigbee.0
      2023-05-08 10:41:47.681	debug	DeviceAvailability:Publish available for 0xa4c1383a0d04dafc = false
      zigbee.0
      2023-05-08 10:41:47.680	debug	DeviceAvailability:Publish LQ for 0xa4c138e3a62b2502 = 0
      zigbee.0
      2023-05-08 10:41:47.679	debug	DeviceAvailability:Publish available for 0xa4c138e3a62b2502 = false
      zigbee.0
      2023-05-08 10:41:47.677	debug	DeviceAvailability:Publish LQ for 0xa4c1386a948505ae = 0
      zigbee.0
      2023-05-08 10:41:47.676	debug	DeviceAvailability:Publish available for 0xa4c1386a948505ae = false
      zigbee.0
      2023-05-08 10:41:47.675	debug	DeviceAvailability:Publish LQ for 0xa4c138c66f278d96 = 0
      zigbee.0
      2023-05-08 10:41:47.674	debug	DeviceAvailability:Publish available for 0xa4c138c66f278d96 = false
      zigbee.0
      2023-05-08 10:41:47.673	debug	DeviceAvailability:Publish LQ for 0xa4c138cf4ef6de5c = 0
      zigbee.0
      2023-05-08 10:41:47.671	debug	DeviceAvailability:Publish available for 0xa4c138cf4ef6de5c = false
      zigbee.0
      2023-05-08 10:41:47.670	debug	DeviceAvailability:Publish LQ for 0xa4c138cc531cbee1 = 0
      zigbee.0
      2023-05-08 10:41:47.669	debug	DeviceAvailability:Publish available for 0xa4c138cc531cbee1 = false
      zigbee.0
      2023-05-08 10:41:47.668	debug	DeviceAvailability:Publish LQ for 0xa4c138e2021c1cc0 = 0
      zigbee.0
      2023-05-08 10:41:47.668	debug	DeviceAvailability:Publish available for 0xa4c138e2021c1cc0 = false
      zigbee.0
      2023-05-08 10:41:47.667	debug	DeviceAvailability:Publish LQ for 0xa4c138931420cd2b = 0
      zigbee.0
      2023-05-08 10:41:47.666	debug	DeviceAvailability:Publish available for 0xa4c138931420cd2b = false
      zigbee.0
      2023-05-08 10:41:47.665	debug	DeviceAvailability:Publish LQ for 0xa4c138da9533e551 = 0
      zigbee.0
      2023-05-08 10:41:47.664	debug	DeviceAvailability:Publish available for 0xa4c138da9533e551 = false
      zigbee.0
      2023-05-08 10:41:47.663	debug	DeviceAvailability:Publish LQ for 0xa4c138b585a549dd = 0
      zigbee.0
      2023-05-08 10:41:47.662	debug	DeviceAvailability:Publish available for 0xa4c138b585a549dd = false
      zigbee.0
      2023-05-08 10:41:47.661	debug	DeviceAvailability:Publish LQ for 0xa4c13865b5be7e19 = 0
      zigbee.0
      2023-05-08 10:41:47.660	debug	DeviceAvailability:Publish available for 0xa4c13865b5be7e19 = false
      zigbee.0
      2023-05-08 10:41:47.660	debug	DeviceAvailability:Publish LQ for 0xa4c138f6ce64ab7a = 0
      zigbee.0
      2023-05-08 10:41:47.659	debug	DeviceAvailability:Publish available for 0xa4c138f6ce64ab7a = false
      zigbee.0
      2023-05-08 10:41:47.658	debug	DeviceAvailability:Publish LQ for 0xa4c1380f22d07657 = 0
      zigbee.0
      2023-05-08 10:41:47.656	debug	DeviceAvailability:Publish available for 0xa4c1380f22d07657 = false
      zigbee.0
      2023-05-08 10:41:47.655	debug	DeviceAvailability:Publish LQ for 0xa4c138072cd30165 = 0
      zigbee.0
      2023-05-08 10:41:47.653	debug	DeviceAvailability:Publish available for 0xa4c138072cd30165 = false
      zigbee.0
      2023-05-08 10:41:47.653	debug	DeviceAvailability:Publish LQ for 0x00158d0007e08b8f = 0
      zigbee.0
      2023-05-08 10:41:47.652	debug	DeviceAvailability:Publish available for 0x00158d0007e08b8f = false
      zigbee.0
      2023-05-08 10:41:47.651	debug	DeviceAvailability:Publish LQ for 0x00158d0007d3d429 = 0
      zigbee.0
      2023-05-08 10:41:47.650	debug	DeviceAvailability:Publish available for 0x00158d0007d3d429 = false
      zigbee.0
      2023-05-08 10:41:47.646	info	cleaned everything up...
      zigbee.0
      2023-05-08 10:41:47.645	info	Got terminate signal TERMINATE_YOURSELF
      zigbee.0
      2023-05-08 10:41:47.255	debug	Publish {"current":0} to "a4c138f6ce64ab7a"
      zigbee.0
      2023-05-08 10:41:47.248	debug	Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate","_linkquality":255},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_outage_memory","property":"power_outage_memory","access":7,"values":["on","off","restore"],"description":"Recover state after power outage"},{"type":"enum","name":"indicator_mode","property":"indicator_mode","access":7,"values":["off","off/on","on/off","on"],"description":"LED indicator mode"},{"type":"numeric","name":"power","property":"power","access":1,"unit":"W","description":"Instantaneous measured power"},{"type":"numeric","name":"current","property":"current","access":1,"unit":"A","description":"Instantaneous measured electrical current"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"energy","property":"energy","access":1,"unit":"kWh","description":"Sum of consumed energy"},{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":3,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"power_calibration","property":"power_calibration","access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"power_precision","property":"power_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for power, takes into effect on next report of device."},{"type":"numeric","name":"current_calibration","property":"current_calibration","access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"current_precision","property":"current_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for current, takes into effect on next report of device."},{"type":"numeric","name":"voltage_calibration","property":"voltage_calibration","access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"voltage_precision","property":"voltage_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device."}]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"NEO","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"Nous","model":"A1Z"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"}],"ota":{},"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]",{"type":"numeric","name":"energy_precision","property":"energy_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for energy, takes into effect on next report of device."},{"type":"numeric","name":"energy_calibration","property":"energy_calibration","access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."}]},"name":"0xa4c138f6ce64ab7a"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate","_linkquality":255},"endpoint":"[Circular]","data":{"rmsCurrent":0},"linkquality":255,"groupID":null,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":179,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":tru
      e,"reservedBits":0}}}
      zigbee.0
      2023-05-08 10:41:47.248	debug	Received Zigbee message from '0xa4c138f6ce64ab7a', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":0}' from endpoint 1 with groupID null
      zigbee.0
      2023-05-08 10:41:47.247	debug	handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"Router","_ieeeAddr":"0xa4c138f6ce64ab7a","_networkAddress":15255,"_manufacturerID":4417,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57345,57344,0],"outputClusters":[25,10],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{"genBasic":{"attributes":{"modelId":"TS011F","manufacturerName":"_TZ3000_ksw8qtmt","powerSource":1,"zclVersion":3,"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"20480":1,"32768":0,"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"53264":2,"switchType":0,"powerOnBehavior":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":0,"activePower":0}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,3806]}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff07b66f","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1]}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":15255,"deviceIeeeAddress":"0xa4c138f6ce64ab7a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_ksw8qtmt","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":74,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":680236614},"_lastSeen":1683535307247,"_defaultSendRequestWhen":"immediate","_linkquality":255},"endpoint":"[Circular]","data":{"rmsCurrent":0},"linkquality":255,"groupID":null,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":179,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      zigbee.0
      2023-05-08 10:41:47.114	debug	Publish {"power":8} to "a4c1380f22d07657"
      Ich hoffe, das sagt Dir was, ich musste kräftig was löschen, so schnell läuft das voll.
      Gruß, Roland
      Thomas BraunT
      Thomas BraunT
      @procrastinator sagte in Zigbee Geräte nach Proxmox Update disconnected:
      Wenn das auch auf 'debug' läuft ist das klar.
      Interessanter wäre zunächst aber die Ausgabe von iob diag.
      P 1 Antwort Letzte Antwort
        P
        P
        PROcrastinator
        @thomas-braun Hallo Thomas, hier die Ausgabe vom diagnose Skipt. Leider komme ich erst jetzt dazu.
                             v.2023-04-15
        Operatingsystem:        Ubuntu 22.04.2 LTS
        Kernel:                 5.15.107-1-pve
        Installation:           lxc
        User-ID:                0
        X-Server:               false
        Pending OS-Updates:     1
        Pending iob updates:    1
        Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                                /usr/bin/node           v16.20.0
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            2.0G        1.5G         73M        0.0K        496M        570M
        Swap:           2.0G        706M        1.3G
        Total:          4.1G        2.2G        1.4G
        Active iob-Instances:   22
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.23
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 1701, bind: 0.0.0.0 (SSL), run as: admin
        Objects:                8692
        States:                 7586
        Size of iob-Database:
        65M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/states.jsonl
        Danke, Roland
        • P PROcrastinator
                               v.2023-04-15
          Installation:           lxc
          User-ID:                0
          X-Server:               false
                                  /usr/bin/npm            8.19.4
                                  /usr/bin/npx            8.19.4
          MEMORY:
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                8692
          States:                 7586
          Danke, Roland
          Thomas BraunT
          Thomas BraunT
          @procrastinator
          Bis auf die nodejs-Version nix wildes. Die Langfassung?
            @procrastinator
            CodierknechtC
            CodierknechtC
            Codierknecht
            @thomas-braun sagte in Zigbee Geräte nach Proxmox Update disconnected:
            Außer vielleicht das Boot-Target ;-)
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • CodierknechtC Codierknecht
              Thomas BraunT
              Thomas BraunT
              @codierknecht
              Und die beiden ausstehenden Updates.
              Ja, sollte man beides angehen.
                @codierknecht
                CodierknechtC
                CodierknechtC
                Codierknecht
                Für 22 Instanzen scheinen mir 2GB RAM etwas dürftig.
                Aber von Proxmox + LXC habe ich keine Ahnung - kann ja sein, dass der Speicher dort dynamisch zugewiesen wird.
                  Thomas BraunT
                  Thomas BraunT
                  @codierknecht
                  Ja, das auch.
                    @codierknecht
                    Ja, das auch.
                    P
                    P
                    PROcrastinator
                    @thomas-braun @Codierknecht
                    Ich hab der LXC jetzt mal 4GB Ram gegeben, bisher lief es alles gut, es kommt ja aber auch immer mehr dazu. bei 16 GB ist der RAM ja nicht zu knapp.
                    Hier die lange Version:
                    Skript v.2023-04-15
                    *** BASE SYSTEM ***
                    Architecture    : x86_64
                    Docker          : false
                    Virtualization  : lxc
                    Distributor ID: Ubuntu
                    Description:    Ubuntu 22.04.2 LTS
                    Release:        22.04
                    Codename:       jammy
                    PRETTY_NAME="Ubuntu 22.04.2 LTS"
                    NAME="Ubuntu"
                    VERSION_ID="22.04"
                    VERSION="22.04.2 LTS (Jammy Jellyfish)"
                    VERSION_CODENAME=jammy
                    ID=ubuntu
                    ID_LIKE=debian
                    HOME_URL="https://www.ubuntu.com/"
                    SUPPORT_URL="https://help.ubuntu.com/"
                    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                    UBUNTU_CODENAME=jammy
                    Systemuptime and Load:
                     10:17:11 up 3 days,  1:09,  1 user,  load average: 0.39, 0.56, 0.45
                    CPU threads: 3
                    *** Time and Time Zones ***
                                   Local time: Tue 2023-05-09 10:17:11 CEST
                               Universal time: Tue 2023-05-09 08:17:11 UTC
                                     RTC time: n/a
                                  NTP service: inactive
                              RTC in local TZ: no
                    *** User and Groups ***
                    root
                    /root
                    root
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:            4.1G        1.5G        2.2G        0.0K        328M        2.6G
                    Swap:           2.0G        723M        1.3G
                    Total:          6.1G        2.2G        3.6G
                             4096 M total memory
                             1526 M used memory
                             1192 M active memory
                              561 M inactive memory
                             2241 M free memory
                                0 M buffer memory
                              328 M swap cache
                             2048 M total swap
                              723 M used swap
                             1324 M free swap
                    *** FILESYSTEM ***
                    Filesystem           Type   Size  Used Avail Use% Mounted on
                    /dev/loop0           ext4    15G  3.6G   11G  26% /
                    none                 tmpfs  492K  4.0K  488K   1% /dev
                    /dev/mapper/pve-root ext4    94G   11G   79G  13% /dev/ttyACM0
                    tmpfs                tmpfs  7.8G     0  7.8G   0% /dev/shm
                    tmpfs                tmpfs  3.1G  116K  3.1G   1% /run
                    tmpfs                tmpfs  5.0M     0  5.0M   0% /run/lock
                    dmesg: read kernel buffer failed: Operation not permitted
                    TARGET         SOURCE                                                 FSTYPE OPTIONS
                    /              /dev/loop0                                             ext4   rw,relatime
                    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                    /var:
                    621M    /var/
                    243M    /var/cache
                    239M    /var/lib
                    237M    /var/cache/apt
                    151M    /var/cache/apt/archives
                    Archived and active journals take up 136.0M in the file system.
                    /opt/iobroker/backups:
                    214M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    624M    /opt/iobroker/iobroker-data/
                    311M    /opt/iobroker/iobroker-data/history
                    168M    /opt/iobroker/iobroker-data/files
                    69M     /opt/iobroker/iobroker-data/backup-objects
                    51M     /opt/iobroker/iobroker-data/files/javascript.admin
                    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.js.map
                    11M     /opt/iobroker/iobroker-data/states.jsonl
                    8.2M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.4f0a34b4.js
                    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                    *** NodeJS-Installation ***
                    /usr/bin/npm            8.19.4
                    /usr/bin/npx            8.19.4
                    nodejs:
                      Installed: 16.20.0-deb-1nodesource1
                      Candidate: 16.20.0-deb-1nodesource1
                      Version table:
                     *** 16.20.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                         12.22.9~dfsg-1ubuntu3 500
                            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                    No problems detected
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                    + system.adapter.history.0                : history               : iobroker                                 -  enabled
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                      system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
                      system.adapter.snmp.1                   : snmp                  : iobroker                                 - disabled
                      system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                    + instance is alive
                    ioBroker-Repositories
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                    Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                    Adapter    "parser"       : 1.1.8    , installed 1.1.8
                    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
                    Adapter    "snmp"         : 2.4.7    , installed 2.4.7
                    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                    Objects and States
                    Objects:        8692
                    States:         7586
                    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
                    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                    Hit:4 https://deb.nodesource.com/node_16.x jammy InRelease
                    Reading package lists... Done
                    Pending Updates: 1
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30503      1/init
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       10392120   7443/io.mqtt.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       31803      116/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       31796      116/iobroker.js-con
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        32844      102/systemd-resolve
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          31677      284/master
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          31678      284/master
                    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       10474647   7522/io.sonos.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          31383      1/init
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          30505      1/init
                    tcp6       0      0 :::1701                 :::*                    LISTEN      1000       33114      305/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       45060      866/io.web.0
                    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       3612459    897/io.upnp.0
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        32843      102/systemd-resolve
                    udp        0      0 192.168.178.100:68      0.0.0.0:*                           105        31379      91/systemd-networkd
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30504      1/init
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       46915      897/io.upnp.0
                    udp6       0      0 :::111                  :::*                                0          30506      1/init
                    2023-05-09 10:14:21.765  - info: host.iobroker iobroker upload [40] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
                    2023-05-09 10:14:21.793  - info: host.iobroker iobroker upload [30] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Speaker.db548379676317470c4f.svg static/media/Speaker.db548379676317470c4f.svg image/svg+xml
                    2023-05-09 10:14:21.817  - info: host.iobroker iobroker upload [20] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                    2023-05-09 10:14:21.820  - info: host.iobroker iobroker upload [19] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                    2023-05-09 10:14:21.826  - info: host.iobroker iobroker upload [18] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                    2023-05-09 10:14:21.831  - info: host.iobroker iobroker upload [17] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                    2023-05-09 10:14:21.834  - info: host.iobroker iobroker upload [16] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                    2023-05-09 10:14:21.837  - info: host.iobroker iobroker upload [15] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                    2023-05-09 10:14:21.840  - info: host.iobroker iobroker upload [14] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                    2023-05-09 10:14:21.843  - info: host.iobroker iobroker upload [13] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                    2023-05-09 10:14:21.846  - info: host.iobroker iobroker upload [12] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                    2023-05-09 10:14:21.849  - info: host.iobroker iobroker upload [11] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                    2023-05-09 10:14:21.852  - info: host.iobroker iobroker upload [10] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                    2023-05-09 10:14:21.855  - info: host.iobroker iobroker upload [9] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                    2023-05-09 10:14:21.857  - info: host.iobroker iobroker upload [8] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                    2023-05-09 10:14:21.860  - info: host.iobroker iobroker upload [7] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                    2023-05-09 10:14:21.864  - info: host.iobroker iobroker upload [6] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                    2023-05-09 10:14:21.867  - info: host.iobroker iobroker upload [5] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                    2023-05-09 10:14:21.870  - info: host.iobroker iobroker upload [4] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                    2023-05-09 10:14:21.874  - info: host.iobroker iobroker upload [3] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                    2023-05-09 10:14:21.877  - info: host.iobroker iobroker upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                    2023-05-09 10:14:21.880  - info: host.iobroker iobroker upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
                    2023-05-09 10:14:21.883  - info: host.iobroker iobroker upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                    2023-05-09 10:14:22.908  - info: host.iobroker iobroker exit 0
                    2023-05-09 10:17:37.229  - warn: zigbee.0 (7491) DeviceAvailability:Stopping to ping 0xa4c138f6ce64ab7a TS011F after 564 ping attempts
                    Dann werde ich nodejs und npm mal angehen.
                    • P PROcrastinator
                      Skript v.2023-04-15
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        22.04
                      Codename:       jammy
                      NAME="Ubuntu"
                      VERSION_ID="22.04"
                      ID=ubuntu
                      ID_LIKE=debian
                      CPU threads: 3
                                       RTC time: n/a
                                RTC in local TZ: no
                      root
                      /root
                      root
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                               4096 M total memory
                               1526 M used memory
                               2241 M free memory
                                  0 M buffer memory
                                328 M swap cache
                               2048 M total swap
                                723 M used swap
                               1324 M free swap
                      *** FILESYSTEM ***
                      /var:
                      621M    /var/
                      243M    /var/cache
                      239M    /var/lib
                      237M    /var/cache/apt
                      /usr/bin/npm            8.19.4
                      /usr/bin/npx            8.19.4
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        8692
                      States:         7586
                      Pending Updates: 1
                      Thomas BraunT
                      Thomas BraunT
                      @procrastinator
                      Und hampel im Container nicht als root herum.
                        @procrastinator
                        P
                        P
                        PROcrastinator
                        @thomas-braun nodejs ist jetzt bei 18.16.0, npm 9.5.1, neuer User ist abgelegt.
                        Ist das Boot target ein Problem? Muss ich da was ändern?
                        Leider lassen sich immer noch keine Kommandos an die Zigbee Geräte senden:
                        error	Send command to 0xa4c138afffcf7a65 failed with no error code (no response received)
                        • P PROcrastinator
                          Thomas BraunT
                          Thomas BraunT
                          Das war auch nicht anders zu erwarten. Die getätigten Korrekturen sind eher grundsätzlicher Art.
                          Ich vermute hier eher Probleme im ZigBee-Netzwerk, die Geräte dürften schlicht und einfach nicht erreichbar sein.
                            P
                            P
                            PROcrastinator
                            @thomas-braun Von meinem Testen habe ich die Ahnung, dass der Stick zwar Daten von den Geräten empfängt, aber keine Daten senden kann. Einstellungen an den Steckdosen werden zwar auf der Zigbee Oberfläche angezeigt, kommen aber nicht an den Geräten an.
                            Hat jemand eine Lösung, sonst bleibt mir nur die komplette Maschine neu zu machen.
                            • P PROcrastinator
                              Moin,
                              ist einen Versuch Wert, zieh die Steckdose doch mal ab, Stromlos machen, einige Zeit warten und wieder einstecken, die sollte sich dann ja wieder im ZigBee Netzwerk anmelden und noch mal versuchen.
                              Wenn ich mir diese Seite anschaue, dann hat dieses Device so einige Probleme, ob das etwas mit Deinen zu tun hat, kann ich nicht sagen, da mir dazu die Informationen fehlen.
                              https://www.zigbee2mqtt.io/devices/TS011F_plug_1.html
                              Vielleicht musst Du da mal schauen, welche Firmware drauf ist und Up-/Down Graden.
                              Bernd
                                Moin,
                                Bernd
                                P
                                P
                                PROcrastinator
                                @dp20eic Moin, ich hab jetzt nochmal eine Steckdose vom Netz genommen und wieder angeschlossen, dann wird sie als verbunden angezeigt, allerdings war sie heute wieder nicht erreichbar. Da ioBroker die Geräte nicht pingen kann wechselt der Zustand anscheinend je nachdem ob die Geräte von sich aus ein Lebenszeichen senden.
                                Mir fällt nun nicht mehr ein, außer die Installation entweder auf eine neu aufgesetzte LXC oder direkt auf eine VM zu portieren.
                                Mit den Steckdosen hatte ich bisher überhaupt keine Probleme, die Variante des Herstellers (NOUS) sendet auch immer noch automatisch die Werte. Firmwareupgrade habe ich auch nicht gemacht. Nur die Updates im Proxmox bevor das Problem anfing.
                                • P PROcrastinator
                                  Moin,
                                  bin nicht alle Posts durchgegangen, aber Ich nutze den Conbee 2 mit Zigbee Adapter (v1.8.10) das ist noch aktuell? Kannst Du mal auf die Version 1.8.11 gehen über
                                  oder
                                  Betrifft das alle Geräte, dieses Typs?
                                  Hast Du mal die Position zum Zigbee Stick geändert, ein Zigbee Netzwerk braucht so seine Zeit um das Mesh aufzubauen, verbinden sich denn andere Zigbee Geräte an die Steckdose, da die ja auch gleichzeitig Repeater sind?
                                  Beispiel
                                  Ich wüsste nicht, was sich daran dann ändern sollte, außer dass Du alles neu anlernen musst.
                                  Ich mache täglich Updates, sollten welche da sein, von Proxmox und auch in den LXC Containern oder Office-PCs und bei mir funktioniert Zigbee und Zwave, Tasmota usw. ohne Probleme.
                                  Leider besitze ich keine diese Steckdosen, um da mehr sagen zu können, ich würde mal eine, so es ein Firmware Update gibt, flashen und schauen wie es sich verhält.
                                  Und den Zigbee-Adapter mal auf die 1.8.11 bringen.
                                  Bernd
                                    Moin,
                                    oder
                                    Beispiel
                                    Bernd
                                    P
                                    P
                                    PROcrastinator
                                    @dp20eic Also mit Version 1.8.11 hat es auch nicht funktioniert. Das Phänomen betrifft generell alle Geräte, nicht nur Steckdosen. Meine Thermometer (mit Display) zeigen auch an, dass sie nicht verbunden sind und keine Zeitinformationen vom Server bekommen. Ich kann auch keine neuen Geräte hinzufügen (eben nochmal probiert) und das log ist voll von den Meldungen, dass die Geräte nicht gepingt werden können. Die Befehle des Sticks kommen einfach nicht bei den Geräten an, bzw. können nicht gesendet werden. Geräte in unmittelbarer Nähe des Sticks funktionieren auch nicht.
                                    Da das Problem abrupt nach einem Update von Proxmox auftrat, denke ich das es da einen Zusammenhang gibt. In einer schnell gebastelten VM mit HomeAsstant wurden alle Geräte erkannt und ich konnte sich auch steuern. An der Hardware sollte es also nicht liegen. Evtl. ist beim Update was schief gelaufen und eine neue VM oder LXC löst das Problem. So lange wie ich damit schon rumhantiere bin ich langsam ratlos.
                                    So sieht meiner Netzwerkkarte aus:
                                    • P PROcrastinator
                                      @procrastinator
                                      Moin,
                                      Du kannst ja ein Issue auf Github https://github.com/ioBroker/ioBroker.zigbee/issues anlegen, oder schauen, ob da noch jemand ein Problem hat.
                                      Bernd
                                      P.S.: Oder Du setzt mal auf die Kombination mqtt, zigbee2mqtt und zigbee2mqtt-Adapter (ioBroker)
                                      Bei mir ist
                                      • mqtt (mosquito) -> Docker Synology
                                      • LXC Container mit
                                        • zigbee2mqtt <- https://www.zigbee2mqtt.io/guide/getting-started/
                                        • ioBroker(Test) mit
                                          • zigbee2mqtt Adapter
                                      • P
                                        P
                                        PROcrastinator
                                        @dp20eic Ich habe mal ein Issue auf Github aufgemacht. Nachdem ich die Version von Github installiert habe, kommt nun die Fehlermeldung
                                        Device 0xa4c138af5361218a "A1Z" not described in statesMapping.
                                        in der Datei tuya.js sind die Geräte und der Hersteller aber eingetragen. Nachdem ich zurück auf 1.8.10 gegangen bin geht es wieder.
                                        Einen Umweg über mqtt möchte ich eigentlich nicht unbedingt gehen, da bisher ja alles gut lief, werde ich aber im Hinterkopf behalten, danke!
                                          tuya
                                          Moin,
                                          wenn ich Tuya lese, dann kommt mir auch noch der Tuya-Adapter in den Sinn :)
                                          Bernd
                                          84.0k
