  4. NPM AUDIT FIX?
    5.4k
NPM AUDIT FIX?
24 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • L loverz
    Hallo, wenn ich etwas über NPM installieren möchte sagt er immer, dass ich "npm audit fix --force" ausführen soll
    Nach der Ausführug kommt aber immer nur das hier:
    # npm audit report
    lodash  <=4.17.20
    Severity: critical
    Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advisories/GHSA-x5rq-j2xg-h7qm
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-4xc9-xhrj-v574
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-fvqr-27wr-82fm
    Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advisories/GHSA-29mw-wpgm-hmr9
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-jf85-cpcp-j695
    Command Injection in lodash - https://github.com/advisories/GHSA-35jh-r3h4-6jhm
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-p6mc-m468-83gw
    fix available via `npm audit fix --force`
    Will install iobroker.knx@2.0.18, which is a breaking change
    node_modules/machina/node_modules/lodash
    node_modules/xml2js-xpath/node_modules/lodash
      machina  0.3.7 - 2.0.2
      Depends on vulnerable versions of lodash
        iobroker.knx  <=0.8.6
        Depends on vulnerable versions of machina
        Depends on vulnerable versions of xml2js
        Depends on vulnerable versions of xml2js-xpath
        node_modules/iobroker.knx
      xml2js-xpath  <=0.9.0
    xml2js  <=0.4.23
    Severity: high
    xml2js is vulnerable to prototype pollution  - https://github.com/advisories/GHSA-776f-qx25-q3cc
    node_modules/iobroker.knx/node_modules/xml2js
    5 vulnerabilities (4 high, 1 critical)
    To address all issues (including breaking changes), run:
    Ab und zu kommen 5 vulnerabilities, manchmal nur 4. Aber weg gehen sie nicht...
    Außerdem frage ich mich, wieso er KNX <=0.8.6 bemängelt, obwohl ich 2.0.13 installiert habe!
    GlasfaserG Offline
    GlasfaserG Offline
    @loverz sagte in NPM AUDIT FIX?:
    Wäre noch ein
    iob diag
    wie hier noch offen
    https://forum.iobroker.net/topic/63771/warnmeldungen-bei-adapterinstallation
    Ich vermute mal dein System ist strubbelig
    und warum per npm installieren
    knx@2.0.18
    ist im Beta Repo vorhanden
    L 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      Wäre noch ein
      iob diag
      wie hier noch offen
      knx@2.0.18
      loverz
      @glasfaser hab das per NPM gemacht, weil ich es in der Weboberfläche nicht gesehen habe und von Linux so gut wie keine Ahnung habe.
      Wie man das Beta Repo lädt weiß ich allerdings, das hätte ich machen können.
      Mache gleich mal ein Fix
      • L loverz
        Gib mal die Ausgabe vom iob diag danach. Da scheint mir noch mehr krumm zu sein.
        GlasfaserG L 2 Antworten Letzte Antwort
          GlasfaserG Offline
          GlasfaserG Offline
          @thomas-braun sagte in NPM AUDIT FIX?:
          Ist wohl Geheim ... :)
            @loverz
            Dann bitte vollständige Ein- und Ausgabezeilen posten, nix weg lassen.
            loverz
            @loverz
            login as: pi
            pi@192.168.1.166's password:
            Linux ioBroker-RasPi4 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
            permitted by applicable law.
            Last login: Sun Apr  9 20:55:43 2023 from 192.168.1.152
            pi@ioBroker-RasPi4:~ $ npm audit fix --force
            npm WARN using --force Recommended protections disabled.
            npm WARN audit Updating iobroker.knx to 2.0.18, which is a SemVer major change.
            npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in        0.5.0
            added 189 packages, removed 14 packages, changed 2 packages, and audited 205 packages in 46s
            38 packages are looking for funding
              run `npm fund` for details
            # npm audit report
            class-validator  <0.14.0
            Severity: critical
            SQL Injection and Cross-site Scripting in class-validator - https://github.com/advisories/GHSA-fj58-h2fr-3pp2
            Will install iobroker.knx@0.8.6, which is a breaking change
            node_modules/javascript-obfuscator/node_modules/class-validator
              javascript-obfuscator  0.7.0-dev.1 - 4.0.0
              Depends on vulnerable versions of class-validator
                iobroker.knx  >=0.8.0
                Depends on vulnerable versions of javascript-obfuscator
                Depends on vulnerable versions of jsonwebtoken
                Depends on vulnerable versions of xmldom
            jsonwebtoken  <=8.5.1
            Severity: moderate
            jsonwebtoken unrestricted key type could lead to legacy keys usage  - https://github.com/advisories/GHSA-8cf7-32gw-wr33
            jsonwebtoken's insecure implementation of key retrieval function could lead to Forgeable Public/Private Tokens from RSA to HMAC - https://github.com/advisories/GHSA-hjrf-2m68-5959
            jsonwebtoken vulnerable to signature validation bypass due to insecure default algorithm in jwt.verify() - https://github.com/advisories/GHSA-qwph-4952-7xr6
            node_modules/jsonwebtoken
            xmldom  *
            Severity: critical
            Misinterpretation of malicious XML input - https://github.com/advisories/GHSA-5fg8-2547-mr8q
            Misinterpretation of malicious XML input - https://github.com/advisories/GHSA-h6q6-9hqw-rwfv
            xmldom allows multiple root nodes in a DOM - https://github.com/advisories/GHSA-crh6-fp67-6883
            node_modules/xmldom
            5 vulnerabilities (1 moderate, 4 critical)
            • L loverz
              @loverz
              login as: pi
              # npm audit report
              Severity: critical
              Severity: moderate
              xmldom  *
              Severity: critical
              node_modules/xmldom
              GlasfaserG Offline
              GlasfaserG Offline
              @loverz
              und wo ist
              iob diag
                loverz
                schrieb am zuletzt editiert von loverz
                @Glasfaser
                Skript v.2023-04-02
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Architecture    : armv7l
                Docker          : false
                Virtualization  : none
                Distributor ID: Raspbian
                Description:    Raspbian GNU/Linux 10 (buster)
                Release:        10
                Codename:       buster
                PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                NAME="Raspbian GNU/Linux"
                VERSION_ID="10"
                VERSION="10 (buster)"
                VERSION_CODENAME=buster
                ID=raspbian
                ID_LIKE=debian
                HOME_URL="http://www.raspbian.org/"
                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                Systemuptime and Load:
                 21:02:19 up 9 days, 22:30,  1 user,  load average: 4.32, 3.95, 4.36
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Sun 2023-04-09 21:02:19 CEST
                           Universal time: Sun 2023-04-09 19:02:19 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           3.9G        1.7G        756M         28M        1.5G        2.3G
                Swap:          511M        161M        350M
                Total:         4.4G        1.8G        1.1G
                         3888 M total memory
                         1651 M used memory
                          558 M active memory
                         2381 M inactive memory
                          756 M free memory
                          271 M buffer memory
                         1209 M swap cache
                          511 M total swap
                          161 M used swap
                          350 M free swap
                *** FILESYSTEM ***
                /dev/root      ext4      118G   16G   97G  14% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     1.9G   58M  1.9G   3% /run
                tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                [Thu Mar 30 22:31:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:86:53:AE vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [Thu Mar 30 22:31:54 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Thu Mar 30 22:31:54 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Thu Mar 30 22:31:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600
                TARGET        SOURCE         FSTYPE OPTIONS
                /             /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                3.8G    /var/
                2.9G    /var/cache/apt
                2.9G    /var/cache
                2.8G    /var/cache/apt/archives
                399M    /var/lib
                /opt/iobroker/backups:
                3.6G    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                402M    /opt/iobroker/iobroker-data/
                183M    /opt/iobroker/iobroker-data/files
                147M    /opt/iobroker/iobroker-data/backup-objects
                72M     /opt/iobroker/iobroker-data/files/telegram.admin
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                20M     /opt/iobroker/iobroker-data/objects.jsonl
                15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                14M     /opt/iobroker/iobroker-data/objects.json.migrated
                14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                13M     /opt/iobroker/iobroker-data/objects.json.old
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v16.19.1
                /usr/bin/node           v16.19.1
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Installed: 16.19.1-deb-1nodesource1
                  Candidate: 16.19.1-deb-1nodesource1
                  Version table:
                 *** 16.19.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                     10.24.0~dfsg-1~deb10u3 500
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  4.0.24
                admin:          6.3.5
                javascript:     6.1.4
                npm ERR! code ELSPROBLEMS
                npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                npm ERR! invalid: iobroker.sourceanalytix@0.4.14 /opt/iobroker/node_modules/iobroker.sourceanalytix
                npm ERR! invalid: iobroker.yahka@1.0.3 /opt/iobroker/node_modules/iobroker.yahka
                npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                npm ERR!     /home/pi/.npm/_logs/2023-04-09T19_02_36_936Z-debug-0.log
                Adapters from github:   2
                Adapter State
                + system.adapter.admin.0                  : admin                 : Host-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : Host-ioBroker                           -  enabled
                + system.adapter.backitup.0               : backitup              : Host-ioBroker                           -  enabled
                  system.adapter.daswetter.0              : daswetter             : Host-ioBroker                           -  enabled
                + system.adapter.deconz.0                 : deconz                : Host-ioBroker                           -  enabled, port: 80
                  system.adapter.easee.0                  : easee                 : Host-ioBroker                           - disabled
                  system.adapter.hmip.0                   : hmip                  : Host-ioBroker                           - disabled
                + system.adapter.hs100.0                  : hs100                 : Host-ioBroker                           -  enabled
                + system.adapter.hue.0                    : hue                   : Host-ioBroker                           -  enabled, port: 443
                + system.adapter.influxdb.0               : influxdb              : Host-ioBroker                           -  enabled, port: 8086
                + system.adapter.info.0                   : info                  : Host-ioBroker                           -  enabled
                + system.adapter.javascript.0             : javascript            : Host-ioBroker                           -  enabled
                + system.adapter.km200.0                  : km200                 : Host-ioBroker                           -  enabled
                + system.adapter.knx.0                    : knx                   : Host-ioBroker                           -  enabled, bind: 192.168.1.166
                  system.adapter.mydlink.0                : mydlink               : Host-ioBroker                           - disabled
                  system.adapter.netatmo-crawler.0        : netatmo-crawler       : Host-ioBroker                           -  enabled
                + system.adapter.philips-tv.0             : philips-tv            : Host-ioBroker                           -  enabled
                + system.adapter.ping.0                   : ping                  : Host-ioBroker                           -  enabled
                + system.adapter.rpi2.0                   : rpi2                  : Host-ioBroker                           -  enabled
                + system.adapter.shelly.0                 : shelly                : Host-ioBroker                           -  enabled, port: 1882, bind: 192.168.1.166
                  system.adapter.solarmanpv.0             : solarmanpv            : Host-ioBroker                           -  enabled
                + system.adapter.sourceanalytix.0         : sourceanalytix        : Host-ioBroker                           -  enabled
                + system.adapter.telegram.0               : telegram              : Host-ioBroker                           -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.telegram.1               : telegram              : Host-ioBroker                           -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.yahka.0                  : yahka                 : Host-ioBroker                           -  enabled
                + system.adapter.yahka.3                  : yahka                 : Host-ioBroker                           -  enabled
                  system.adapter.yeelight-2.0             : yeelight-2            : Host-ioBroker                           - disabled
                + instance is alive
                ioBroker-Repositories
                latest        : http://iobroker.live/repo/sources-dist-latest.json
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
                Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                Adapter    "easee"        : 1.0.7    , installed 1.0.7
                Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                Adapter    "hue"          : 3.7.1    , installed 3.7.1
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Adapter    "km200"        : 2.0.3    , installed 2.0.3
                Adapter    "knx"          : 2.0.17   , installed 2.0.18
                Adapter    "mydlink"      : 1.1.12   , installed 1.2.1
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                Adapter    "solarmanpv"   : 0.3.2    , installed 0.3.2
                Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                Adapter    "yahka"        : 0.17.0   , installed 1.0.3
                Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
                Objects and States
                Objects:        10649
                States:         9196
                Hit:1 http://phoscon.de/apt/deconz buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:3 https://repos.influxdata.com/debian stretch InRelease
                Hit:4 https://packages.grafana.com/oss/deb stable InRelease
                Hit:5 http://archive.raspberrypi.org/debian buster InRelease
                Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
                Hit:7 https://repo.homebridge.io stable InRelease
                Reading package lists...
                Pending Updates: 8
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18151      329/deCONZ
                tcp        0      0 127.0.0.1:45203         0.0.0.0:*               LISTEN      1001       37357329   27699/io.yahka.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17042      724/sshd
                tcp        0      0 127.0.0.1:40471         0.0.0.0:*               LISTEN      1001       37358987   27825/io.yahka.3
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15030      715/influxd
                tcp        0      0 127.0.0.1:37529         0.0.0.0:*               LISTEN      1001       37356391   27825/io.yahka.3
                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15429      329/deCONZ
                tcp        0      0 127.0.0.1:46237         0.0.0.0:*               LISTEN      110        22065772   26253/homebridge
                tcp        0      0 0.0.0.0:45667           0.0.0.0:*               LISTEN      1001       37358314   27699/io.yahka.0
                tcp        0      0 0.0.0.0:33987           0.0.0.0:*               LISTEN      1001       37358946   27825/io.yahka.3
                tcp        0      0 127.0.0.1:44003         0.0.0.0:*               LISTEN      110        37122721   26253/homebridge
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37351791   26616/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37350710   26616/iobroker.js-c
                tcp        0      0 127.0.0.1:44015         0.0.0.0:*               LISTEN      1001       37357336   27699/io.yahka.0
                tcp        0      0 127.0.0.1:33487         0.0.0.0:*               LISTEN      110        30844253   26253/homebridge
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37349193   26658/io.admin.0
                tcp6       0      0 :::51442                :::*                    LISTEN      110        22066377   26253/homebridge
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        15257      715/influxd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          17044      724/sshd
                tcp6       0      0 :::3000                 :::*                    LISTEN      109        18727      709/grafana
                tcp6       0      0 :::8581                 :::*                    LISTEN      110        16144      1285/hb-service
                udp        0      0 192.168.1.166:51103     0.0.0.0:*                           1001       37362469   27037/io.knx.0
                udp        0      0 0.0.0.0:1982            0.0.0.0:*                           110        22066375   26253/homebridge
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37352880   26913/io.shelly.0
                udp        0      0 0.0.0.0:32831           0.0.0.0:*                           108        14734      340/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16583      706/dhcpcd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        20695      1285/hb-service
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14732      340/avahi-daemon: r
                udp        0      0 192.168.1.166:37733     0.0.0.0:*                           1001       37351127   27037/io.knx.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       37354334   27260/io.deconz.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15432      329/deCONZ
                udp6       0      0 :::546                  :::*                                0          2341956    706/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        14733      340/avahi-daemon: r
                udp6       0      0 :::47388                :::*                                108        14735      340/avahi-daemon: r
                udp6       0      0 :::1900                 :::*                                1001       37354337   27260/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       37354336   27260/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       37354335   27260/io.deconz.0
                2023-04-09 21:01:46.004  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
                2023-04-09 21:01:46.087  - warn: km200.0 (27476) Object system.holidayModes.hm5.hcMode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                2023-04-09 21:01:46.087  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
                2023-04-09 21:01:46.768  - warn: km200.0 (27476) Object system.systemType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                2023-04-09 21:01:46.769  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
                2023-04-09 21:01:46.874  - info: km200.0 (27476) KM200 found 122 states, get their values now.
                2023-04-09 21:01:46.889  - info: km200.0 (27476) Interval=30 min, Norm-list: dhwCircuits.dhw1.charge,dhwCircuits.dhw1.chargeDuration,dhwCircuits.dhw1.holidayMode.activated,dhwCircuits.dhw1.operationMode,dhwCircuits.dhw1.singleChargeSetpoint,dhwCircuits.dhw1.status,dhwCircuits.dhw1.temperatureLevels.high,dhwCircuits.dhw1.temperatureLevels.off,dhwCircuits.dhw1.waterFlow,dhwCircuits.dhw1.workingTime,heatSources.CHpumpModulation,heatSources.ChimneySweeper,heatSources.actualCHPower,heatSources.actualDHWPower,heatSources.applianceSupplyTemperature,heatSources.burnerModulationSetpoint,heatSources.burnerPowerSetpoint,heatSources.energyMonitoring.consumption,heatSources.energyMonitoring.correctionFactor,heatSources.energyMonitoring.maxTankLevel,heatSources.energyMonitoring.minTankLevel,heatSources.energyMonitoring.startDateTime,heatSources.energyMonitoring.tankLevel,heatSources.fanSpeed_setpoint,heatSources.gasAirPressure,heatSources.hs1.info,heatSources.hs1.type,heatSources.info,heatSources.nominalCHPower,heatSources.nominalDHWPower,heatSources.numberOfStarts,heatSources.powerSetpoint,heatSources.returnTemperature,heatSources.systemPressure,heatSources.workingTime.centralHeating,heatSources.workingTime.secondBurner,heatSources.workingTime.totalSystem,heatingCircuits.hc1.activeSwitchProgram,heatingCircuits.hc1.currentRoomSetpoint,heatingCircuits.hc1.currentSuWiMode,heatingCircuits.hc1.fastHeatupFactor,heatingCircuits.hc1.holidayMode.activated,heatingCircuits.hc1.operationMode,heatingCircuits.hc1.status,heatingCircuits.hc1.suWiSwitchMode,heatingCircuits.hc1.suWiThreshold,heatingCircuits.hc1.switchProgramMode,heatingCircuits.hc1.switchPrograms.A,heatingCircuits.hc1.switchPrograms.B,heatingCircuits.hc1.temperatureLevels.comfort2,heatingCircuits.hc1.temperatureLevels.eco,heatingCircuits.hc1.temporaryRoomSetpoint,notifications,recordings.dhwCircuits.dhw1.actualTemp._Hours,recordings.heatSources.actualCHPower._Hours,recordings.heatSources.actualDHWPower._Hours,recordings.heatSources.actualPower._Hours,recordings.heatSources.hs1.actualPower._Hours,recordings.heatingCircuits.hc1.roomtemperature._Hours,recordings.system.heatSources.hs1.actualPower._Hours,recordings.system.sensors.temperatures.outdoor_t1._Hours,system.brand,system.bus,system.healthStatus,system.holidayModes.hm1.assignedTo,system.holidayModes.hm1.dhwMode,system.holidayModes.hm1.hcMode,system.holidayModes.hm1.startStop,system.holidayModes.hm2.assignedTo,system.holidayModes.hm2.dhwMode,system.holidayModes.hm2.hcMode,system.holidayModes.hm2.startStop,system.holidayModes.hm3.assignedTo,system.holidayModes.hm3.dhwMode,system.holidayModes.hm3.hcMode,system.holidayModes.hm3.startStop,system.holidayModes.hm4.assignedTo,system.holidayModes.hm4.dhwMode,system.holidayModes.hm4.hcMode,system.holidayModes.hm4.startStop,system.holidayModes.hm5.assignedTo,system.holidayModes.hm5.dhwMode,system.holidayModes.hm5.hcMode,system.holidayModes.hm5.startStop,system.info,system.minOutdoorTemp,system.systemType
                2023-04-09 21:01:46.890  - info: km200.0 (27476) Fast Interval=1 min, Fast-List: dhwCircuits.dhw1.actualTemp,dhwCircuits.dhw1.currentSetpoint,heatSources.actualModulation,heatSources.actualPower,heatSources.actualSupplyTemperature,heatSources.flameStatus,heatSources.hs1.actualModulation,heatSources.hs1.actualPower,heatSources.hs1.flameStatus,heatSources.supplyTemperatureSetpoint,heatingCircuits.hc1.actualSupplyTemperature,heatingCircuits.hc1.pumpModulation,heatingCircuits.hc1.supplyTemperatureSetpoint,system.appliance.actualSupplyTemperature,system.sensors.temperatures.hotWater_t2,system.sensors.temperatures.outdoor_t1,system.sensors.temperatures.return,system.sensors.temperatures.supply_t1,system.sensors.temperatures.supply_t1_setpoint
                2023-04-09 21:01:46.891  - info: km200.0 (27476) Slow Interval=6 hours, Slow-List: recordings.dhwCircuits.dhw1.actualTemp._Days,recordings.dhwCircuits.dhw1.actualTemp._Months,recordings.heatSources.actualCHPower._Days,recordings.heatSources.actualCHPower._Months,recordings.heatSources.actualDHWPower._Days,recordings.heatSources.actualDHWPower._Months,recordings.heatSources.actualPower._Days,recordings.heatSources.actualPower._Months,recordings.heatSources.hs1.actualPower._Days,recordings.heatSources.hs1.actualPower._Months,recordings.heatingCircuits.hc1.roomtemperature._Days,recordings.heatingCircuits.hc1.roomtemperature._Months,recordings.system.heatSources.hs1.actualPower._Days,recordings.system.heatSources.hs1.actualPower._Months,recordings.system.sensors.temperatures.outdoor_t1._Days,recordings.system.sensors.temperatures.outdoor_t1._Months
                2023-04-09 21:02:16.083  - info: km200.0 (27476) Set km200.0.heatingCircuits.hc1.activeSwitchProgram to 0
                2023-04-09 21:02:17.519  - info: km200.0 (27476) Adapter km200 initialization finished with 122 states.
                2023-04-09 21:02:18.093  - info: km200.0 (27476) Update {'heatingCircuits.hc1.activeSwitchProgram': {type: 'state',id: 'heatingCircuits.hc1.activeSwitchProgram',common: {id: 'heatingCircuits.hc1.activeSwitchProgram',name: 'heatingCircuits.hc1.activeSwitchProgram',type: 'number',unit: '',read: true,write: true,role: 'level',states: '0:A;1:B',min: 0,max: 1,native: [Object]},native: { km200: [Object] }}}
                2023-04-09 21:02:32.156  - info: alexa2.0 (26960) Unknown Device, but enabling commands, Try it and report back if commands work.
                2023-04-09 21:02:32.157  - info: alexa2.0 (26960) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                2023-04-09 21:02:32.157  - info: alexa2.0 (26960)     Device-type:AH6MYEHSW61SM - Sebastian's L67 (L67) (MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,SLEEP,DREAM_TRAINING,APPLE_MUSIC,AMAZON_MUSIC,KINDLE_BOOKS,ASCENDING_ALARM_VOLUME,CHANGE_NAME,MICROPHONE,TUNE_IN,MUSIC_SKILL,PERSISTENT_CONNECTION,TIDAL,TOUCH_INITIATED,SUPPORTS_LOCALE,DEEZER,DEREGISTER_DEVICE,AUDIBLE,CUSTOM_ALARM_TONE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,SET_TIME_ZONE,AUDIO_PLAYER,ADAPTIVE_LISTENING,SOUND_SETTINGS,SUPPORTS_LOCALE_SWITCH,GOLDFISH,REMINDERS,DIALOG_INTERFACE_VERSION,SPEECH_RECOGNIZER_USS,I_HEART_RADIO,SET_LOCALE,TIMERS_AND_ALARMS,EARCONS)
                2023-04-09 21:02:41.868  - info: alexa2.0 (26960) No smart home devices to query
                2023-04-09 21:02:44.026  - info: alexa2.0 (26960) Subscribing to states...
                2023-04-09 21:02:44.032  - info: alexa2.0 (26960) Deleting the following states: ["Echo-Devices.G070L81484841U54.Preferences.defaultAlarmNotificationSound"]
                2023-04-09 21:02:46.303  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 10s
                2023-04-09 21:02:56.825  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 15s
                2023-04-09 21:03:11.843  - info: alexa2.0 (26960) Initialization Done ...
                2023-04-09 21:03:12.437  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 20s
                • L loverz
                  # npm audit report
                  lodash  <=4.17.20
                  Severity: critical
                  xml2js  <=0.4.23
                  Severity: high
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  npm audit fix
                  ist eigentlich nur für den package verwalter/maintainer gedacht. dadurch kann er sich pakete aktualisieren lassen, die sein eigenes programm/package verwendet, welche security probleme haben.
                  da man sich dadurch aber inkonsistenzen reinholen kann und man danach ausführlich sein system testen muss, ist das nicht für den normalnutzer gedacht
                  Meine Adapter und Widgets
                  Links im Profil
                  • L loverz
                    @Glasfaser
                    Skript v.2023-04-02
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        10
                    Codename:       buster
                    VERSION_ID="10"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                             3888 M total memory
                             1651 M used memory
                              558 M active memory
                              756 M free memory
                              271 M buffer memory
                             1209 M swap cache
                              511 M total swap
                              161 M used swap
                              350 M free swap
                    *** FILESYSTEM ***
                    /var:
                    3.8G    /var/
                    2.9G    /var/cache/apt
                    2.9G    /var/cache
                    399M    /var/lib
                    /usr/bin/npm            8.19.3
                    /usr/bin/npx            8.19.3
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        10649
                    States:         9196
                    Pending Updates: 8
                    buster
                    Beerdigen, ist verstorben.
                    Installier da den Nachfolger Debian 11 / Bullseye
                    • OliverIOO OliverIO
                      npm audit fix
                      loverz
                      @oliverio ok danke
                      • L loverz
                        @oliverio ok danke
                        @loverz
                        Die Adapter nochmal installieren, da klemmt es:
                          buster
                          loverz
                          @thomas-braun heißt?
                          Geht das nicht via
                          sudo apt-get update && sudo apt-get upgrade -y
                          Das führe ich regelmäßig aus.
                          Würde gerne mal eine komplette Neuinstallation machen und danach mein Backitup einspielen, aber das klappt bei mir nicht, hab das mal mit nem zweiten Raspberry probiert.
                            @loverz
                            loverz
                            @loverz
                            Einfach "drüberbügeln"?
                            Oder vorher löschen? Dann wären halt meine Einstellungen von YAHKA weg!
                            • L loverz
                              Geht das nicht via
                              Damit bleibst du immer in einem Release.
                              Ein Releasewechsel muss/kann so vorgenommen werden:
                              https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                              • L loverz
                                Geht das nicht via
                                Dann ist dein System krumm. Das klappt nämlich bei 'ordentlichen' Installationen.
                                  loverz
                                  @thomas-braun hab eine neue SD genommen und eine Neuinstallation gemacht.
                                  Die Backups laufen einwandfrei durch. Weiß echt nicht, woran das liegt :(
                                  Danke für die Anleitung. Ich denke, wenn ich das Backup-Problem löse, dann kann ich damit auch gleich auf ein neues Release und eine saubere Neuinstallation umziehen.
                                  • L loverz
                                    @loverz
                                    Hab noch eine Kinke gefunden:
                                    Muss auf buster lauten, bzw. nach dem erfolgten Upgrade natürlich auf 'bullseye'.
                                      @loverz
                                      loverz
                                      @thomas-braun was meinst du damit? Dass ich Influx nach dem Upgrade auf Bullseye abändern muss?
                                      Soll ich die beiden fehlerhaften Adapter "drüberbügeln"?
                                      • L loverz
                                        Ich würde es jetzt (im file /etc/apt/sources.list.d/influxIRGENDWAS.list) auf buster ändern.
                                        Wenn du nach meiner Anleitung zum Upgrade auf Bullseye vorgehst wird das dann gleich automatisch richtig gemacht.
                                        • L loverz
                                          Ja, mit
                                          iobroker upgrade ADAPTER@VERSION
