  4. Warnmeldungen bei Adapterinstallation
    5.4k
4 Beiträge 2 Kommentatoren 475 Aufrufe 1 Beobachtet
  • L Offline
    loverz
    Hi zusammen,
    bei mir dauert es ewig bis neue Adapter oder Updates installiert werden.
    Folgende Meldungen werden angezeigt:
    npm WARN skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
    npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    Kann das damit zusammenhängen?
    • L loverz
      Hi zusammen,
      @loverz sagte in Warnmeldungen bei Adapterinstallation:
      Und wie sieht deine nodejs-Umgebung aus?
      Die Summary von
      iob diag
      sagt z.B.?
      Die Meldung selber sind allerdings harmlos.
      L 1 Antwort Letzte Antwort
        Die Summary von
        iob diag
        sagt z.B.?
        loverz
        @thomas-braun iob Diag:
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start [all|<adapter>.<instance>]                    Starts the js-con        troller or a specified adapter instance
          iobroker stop [<adapter>.<instance>]                         stops the js-cont        roller or a specified adapter instance
          iobroker restart [<adapter>.<instance>]                      Restarts js-contr        oller or a specified adapter instance  [aliases: r]
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
          iobroker info                                                Shows the host in        fo
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter  [aliases: a]
          iobroker install <adapter>                                   Installs a specif        ied adapter  [aliases: i]
          iobroker rebuild [<module>]                                  Rebuild all nativ        e modules or path
          iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter an        d all instances from this host  [aliases: delete]
          iobroker del <adapter>.<instance>                            Remove adapter in        stance  [aliases: delete]
          iobroker update [<repositoryUrl>]                            Update repository        and list adapters
          iobroker upgrade                                             Upgrade managemen        t
          iobroker upload [all|<adapter>]                              Upload management        [aliases: u]
          iobroker object                                              Object management        [aliases: o]
          iobroker state                                               State management        [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
          iobroker list <type> [<filter>]                              List all entries,        like objects
          iobroker chmod <mode> <file>                                 Change file right        s
          iobroker chown <user> <group> <file>                         Change file owner        ship
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given        hostname
          iobroker set <adapter>.<instance>                            Change settings o        f adapter config
          iobroker license <license.file or license.text>              Update license by        given file
          iobroker cert                                                Certificate manag        ement
          iobroker clean <yes>                                         Clears all object        s and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specifi        ed backup
          iobroker validate <backup name or path>                      Validate a specif        ied backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance  [aliases: isrun]
          iobroker repo [<name>]                                       Show repo informa        tion
          iobroker uuid                                                Show uuid of the        installation  [aliases: id]
          iobroker unsetup                                             Reset license, in        stallation secret and language
          iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
          iobroker multihost                                           Multihost managem        ent
          iobroker compact                                             compact group man        agement
          iobroker plugin                                              Plugin management
          iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter  [aliases: v]
        Options:
          --help  Show help  [boolean]
        Nodejs:
        • L loverz
          iobroker [command]
          Commands:
          Options:
          Nodejs:
          @loverz
          iob stop
          iob fix
          iob start
          WARTEN
          iob diag
