  4. NPM AUDIT FIX?
    5.4k
NPM AUDIT FIX?
24 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    @loverz sagte in NPM AUDIT FIX?:
    Mache gleich mal ein Fix
    Gib mal die Ausgabe vom iob diag danach. Da scheint mir noch mehr krumm zu sein.
    GlasfaserG Offline
    GlasfaserG Offline
    @thomas-braun sagte in NPM AUDIT FIX?:
    Ist wohl Geheim ... :)
      @loverz
      Dann bitte vollständige Ein- und Ausgabezeilen posten, nix weg lassen.
      loverz
      @loverz
      login as: pi
      pi@192.168.1.166's password:
      Linux ioBroker-RasPi4 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
      permitted by applicable law.
      Last login: Sun Apr  9 20:55:43 2023 from 192.168.1.152
      pi@ioBroker-RasPi4:~ $ npm audit fix --force
      npm WARN using --force Recommended protections disabled.
      npm WARN audit Updating iobroker.knx to 2.0.18, which is a SemVer major change.
      npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in        0.5.0
      added 189 packages, removed 14 packages, changed 2 packages, and audited 205 packages in 46s
      38 packages are looking for funding
        run `npm fund` for details
      # npm audit report
      class-validator  <0.14.0
      Severity: critical
      SQL Injection and Cross-site Scripting in class-validator - https://github.com/advisories/GHSA-fj58-h2fr-3pp2
      fix available via `npm audit fix --force`
      Will install iobroker.knx@0.8.6, which is a breaking change
      node_modules/javascript-obfuscator/node_modules/class-validator
        javascript-obfuscator  0.7.0-dev.1 - 4.0.0
        Depends on vulnerable versions of class-validator
          iobroker.knx  >=0.8.0
          Depends on vulnerable versions of javascript-obfuscator
          Depends on vulnerable versions of jsonwebtoken
          Depends on vulnerable versions of xmldom
          node_modules/iobroker.knx
      jsonwebtoken  <=8.5.1
      Severity: moderate
      jsonwebtoken unrestricted key type could lead to legacy keys usage  - https://github.com/advisories/GHSA-8cf7-32gw-wr33
      jsonwebtoken's insecure implementation of key retrieval function could lead to Forgeable Public/Private Tokens from RSA to HMAC - https://github.com/advisories/GHSA-hjrf-2m68-5959
      jsonwebtoken vulnerable to signature validation bypass due to insecure default algorithm in jwt.verify() - https://github.com/advisories/GHSA-qwph-4952-7xr6
      node_modules/jsonwebtoken
      xmldom  *
      Severity: critical
      Misinterpretation of malicious XML input - https://github.com/advisories/GHSA-5fg8-2547-mr8q
      Misinterpretation of malicious XML input - https://github.com/advisories/GHSA-h6q6-9hqw-rwfv
      xmldom allows multiple root nodes in a DOM - https://github.com/advisories/GHSA-crh6-fp67-6883
      node_modules/xmldom
      5 vulnerabilities (1 moderate, 4 critical)
      To address all issues (including breaking changes), run:
      • L loverz
        @loverz
        login as: pi
        # npm audit report
        Severity: critical
        Severity: moderate
        xmldom  *
        Severity: critical
        node_modules/xmldom
        GlasfaserG Offline
        GlasfaserG Offline
        @loverz
        und wo ist
        iob diag
          loverz
          schrieb am zuletzt editiert von loverz
          @Glasfaser
          Skript v.2023-04-02
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Architecture    : armv7l
          Docker          : false
          Virtualization  : none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 10 (buster)
          Release:        10
          Codename:       buster
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           21:02:19 up 9 days, 22:30,  1 user,  load average: 4.32, 3.95, 4.36
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Sun 2023-04-09 21:02:19 CEST
                     Universal time: Sun 2023-04-09 19:02:19 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           3.9G        1.7G        756M         28M        1.5G        2.3G
          Swap:          511M        161M        350M
          Total:         4.4G        1.8G        1.1G
                   3888 M total memory
                   1651 M used memory
                    558 M active memory
                   2381 M inactive memory
                    756 M free memory
                    271 M buffer memory
                   1209 M swap cache
                    511 M total swap
                    161 M used swap
                    350 M free swap
          *** FILESYSTEM ***
          /dev/root      ext4      118G   16G   97G  14% /
          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
          tmpfs          tmpfs     1.9G   58M  1.9G   3% /run
          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
          [Thu Mar 30 22:31:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:86:53:AE vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Thu Mar 30 22:31:54 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Mar 30 22:31:54 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Mar 30 22:31:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime,commit=600
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.8G    /var/
          2.9G    /var/cache/apt
          2.9G    /var/cache
          2.8G    /var/cache/apt/archives
          399M    /var/lib
          /opt/iobroker/backups:
          3.6G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          402M    /opt/iobroker/iobroker-data/
          183M    /opt/iobroker/iobroker-data/files
          147M    /opt/iobroker/iobroker-data/backup-objects
          72M     /opt/iobroker/iobroker-data/files/telegram.admin
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          20M     /opt/iobroker/iobroker-data/objects.jsonl
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          14M     /opt/iobroker/iobroker-data/objects.json.migrated
          14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          13M     /opt/iobroker/iobroker-data/objects.json.old
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.19.1
          /usr/bin/node           v16.19.1
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Installed: 16.19.1-deb-1nodesource1
            Candidate: 16.19.1-deb-1nodesource1
            Version table:
           *** 16.19.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
          npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
          npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
          npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
          npm ERR! invalid: iobroker.sourceanalytix@0.4.14 /opt/iobroker/node_modules/iobroker.sourceanalytix
          npm ERR! invalid: iobroker.yahka@1.0.3 /opt/iobroker/node_modules/iobroker.yahka
          npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
          npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
          npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
          npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
          npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
          npm ERR!     /home/pi/.npm/_logs/2023-04-09T19_02_36_936Z-debug-0.log
          Adapters from github:   2
          Adapter State
          + system.adapter.admin.0                  : admin                 : Host-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : Host-ioBroker                           -  enabled
          + system.adapter.backitup.0               : backitup              : Host-ioBroker                           -  enabled
            system.adapter.daswetter.0              : daswetter             : Host-ioBroker                           -  enabled
          + system.adapter.deconz.0                 : deconz                : Host-ioBroker                           -  enabled, port: 80
            system.adapter.easee.0                  : easee                 : Host-ioBroker                           - disabled
            system.adapter.hmip.0                   : hmip                  : Host-ioBroker                           - disabled
          + system.adapter.hs100.0                  : hs100                 : Host-ioBroker                           -  enabled
          + system.adapter.hue.0                    : hue                   : Host-ioBroker                           -  enabled, port: 443
          + system.adapter.influxdb.0               : influxdb              : Host-ioBroker                           -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : Host-ioBroker                           -  enabled
          + system.adapter.javascript.0             : javascript            : Host-ioBroker                           -  enabled
          + system.adapter.km200.0                  : km200                 : Host-ioBroker                           -  enabled
          + system.adapter.knx.0                    : knx                   : Host-ioBroker                           -  enabled, bind: 192.168.1.166
            system.adapter.mydlink.0                : mydlink               : Host-ioBroker                           - disabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : Host-ioBroker                           -  enabled
          + system.adapter.philips-tv.0             : philips-tv            : Host-ioBroker                           -  enabled
          + system.adapter.ping.0                   : ping                  : Host-ioBroker                           -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : Host-ioBroker                           -  enabled
          + system.adapter.shelly.0                 : shelly                : Host-ioBroker                           -  enabled, port: 1882, bind: 192.168.1.166
            system.adapter.solarmanpv.0             : solarmanpv            : Host-ioBroker                           -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : Host-ioBroker                           -  enabled
          + system.adapter.telegram.0               : telegram              : Host-ioBroker                           -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : Host-ioBroker                           -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.yahka.0                  : yahka                 : Host-ioBroker                           -  enabled
          + system.adapter.yahka.3                  : yahka                 : Host-ioBroker                           -  enabled
            system.adapter.yeelight-2.0             : yeelight-2            : Host-ioBroker                           - disabled
          + instance is alive
          ioBroker-Repositories
          latest        : http://iobroker.live/repo/sources-dist-latest.json
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
          Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "easee"        : 1.0.7    , installed 1.0.7
          Adapter    "hmip"         : 1.20.0   , installed 1.20.0
          Adapter    "hs100"        : 2.1.2    , installed 2.1.2
          Adapter    "hue"          : 3.7.1    , installed 3.7.1
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Adapter    "km200"        : 2.0.3    , installed 2.0.3
          Adapter    "knx"          : 2.0.17   , installed 2.0.18
          Adapter    "mydlink"      : 1.1.12   , installed 1.2.1
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Adapter    "shelly"       : 6.3.1    , installed 6.3.1
          Adapter    "solarmanpv"   : 0.3.2    , installed 0.3.2
          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
          Adapter    "yahka"        : 0.17.0   , installed 1.0.3
          Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
          Objects and States
          Objects:        10649
          States:         9196
          Hit:1 http://phoscon.de/apt/deconz buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://repos.influxdata.com/debian stretch InRelease
          Hit:4 https://packages.grafana.com/oss/deb stable InRelease
          Hit:5 http://archive.raspberrypi.org/debian buster InRelease
          Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
          Hit:7 https://repo.homebridge.io stable InRelease
          Reading package lists...
          Pending Updates: 8
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18151      329/deCONZ
          tcp        0      0 127.0.0.1:45203         0.0.0.0:*               LISTEN      1001       37357329   27699/io.yahka.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17042      724/sshd
          tcp        0      0 127.0.0.1:40471         0.0.0.0:*               LISTEN      1001       37358987   27825/io.yahka.3
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15030      715/influxd
          tcp        0      0 127.0.0.1:37529         0.0.0.0:*               LISTEN      1001       37356391   27825/io.yahka.3
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15429      329/deCONZ
          tcp        0      0 127.0.0.1:46237         0.0.0.0:*               LISTEN      110        22065772   26253/homebridge
          tcp        0      0 0.0.0.0:45667           0.0.0.0:*               LISTEN      1001       37358314   27699/io.yahka.0
          tcp        0      0 0.0.0.0:33987           0.0.0.0:*               LISTEN      1001       37358946   27825/io.yahka.3
          tcp        0      0 127.0.0.1:44003         0.0.0.0:*               LISTEN      110        37122721   26253/homebridge
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37351791   26616/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37350710   26616/iobroker.js-c
          tcp        0      0 127.0.0.1:44015         0.0.0.0:*               LISTEN      1001       37357336   27699/io.yahka.0
          tcp        0      0 127.0.0.1:33487         0.0.0.0:*               LISTEN      110        30844253   26253/homebridge
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37349193   26658/io.admin.0
          tcp6       0      0 :::51442                :::*                    LISTEN      110        22066377   26253/homebridge
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15257      715/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17044      724/sshd
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        18727      709/grafana
          tcp6       0      0 :::8581                 :::*                    LISTEN      110        16144      1285/hb-service
          udp        0      0 192.168.1.166:51103     0.0.0.0:*                           1001       37362469   27037/io.knx.0
          udp        0      0 0.0.0.0:1982            0.0.0.0:*                           110        22066375   26253/homebridge
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37352880   26913/io.shelly.0
          udp        0      0 0.0.0.0:32831           0.0.0.0:*                           108        14734      340/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16583      706/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        20695      1285/hb-service
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14732      340/avahi-daemon: r
          udp        0      0 192.168.1.166:37733     0.0.0.0:*                           1001       37351127   27037/io.knx.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       37354334   27260/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15432      329/deCONZ
          udp6       0      0 :::546                  :::*                                0          2341956    706/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14733      340/avahi-daemon: r
          udp6       0      0 :::47388                :::*                                108        14735      340/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       37354337   27260/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       37354336   27260/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       37354335   27260/io.deconz.0
          2023-04-09 21:01:46.004  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
          2023-04-09 21:01:46.087  - warn: km200.0 (27476) Object system.holidayModes.hm5.hcMode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
          2023-04-09 21:01:46.087  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
          2023-04-09 21:01:46.768  - warn: km200.0 (27476) Object system.systemType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
          2023-04-09 21:01:46.769  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
          2023-04-09 21:01:46.874  - info: km200.0 (27476) KM200 found 122 states, get their values now.
          2023-04-09 21:01:46.889  - info: km200.0 (27476) Interval=30 min, Norm-list: dhwCircuits.dhw1.charge,dhwCircuits.dhw1.chargeDuration,dhwCircuits.dhw1.holidayMode.activated,dhwCircuits.dhw1.operationMode,dhwCircuits.dhw1.singleChargeSetpoint,dhwCircuits.dhw1.status,dhwCircuits.dhw1.temperatureLevels.high,dhwCircuits.dhw1.temperatureLevels.off,dhwCircuits.dhw1.waterFlow,dhwCircuits.dhw1.workingTime,heatSources.CHpumpModulation,heatSources.ChimneySweeper,heatSources.actualCHPower,heatSources.actualDHWPower,heatSources.applianceSupplyTemperature,heatSources.burnerModulationSetpoint,heatSources.burnerPowerSetpoint,heatSources.energyMonitoring.consumption,heatSources.energyMonitoring.correctionFactor,heatSources.energyMonitoring.maxTankLevel,heatSources.energyMonitoring.minTankLevel,heatSources.energyMonitoring.startDateTime,heatSources.energyMonitoring.tankLevel,heatSources.fanSpeed_setpoint,heatSources.gasAirPressure,heatSources.hs1.info,heatSources.hs1.type,heatSources.info,heatSources.nominalCHPower,heatSources.nominalDHWPower,heatSources.numberOfStarts,heatSources.powerSetpoint,heatSources.returnTemperature,heatSources.systemPressure,heatSources.workingTime.centralHeating,heatSources.workingTime.secondBurner,heatSources.workingTime.totalSystem,heatingCircuits.hc1.activeSwitchProgram,heatingCircuits.hc1.currentRoomSetpoint,heatingCircuits.hc1.currentSuWiMode,heatingCircuits.hc1.fastHeatupFactor,heatingCircuits.hc1.holidayMode.activated,heatingCircuits.hc1.operationMode,heatingCircuits.hc1.status,heatingCircuits.hc1.suWiSwitchMode,heatingCircuits.hc1.suWiThreshold,heatingCircuits.hc1.switchProgramMode,heatingCircuits.hc1.switchPrograms.A,heatingCircuits.hc1.switchPrograms.B,heatingCircuits.hc1.temperatureLevels.comfort2,heatingCircuits.hc1.temperatureLevels.eco,heatingCircuits.hc1.temporaryRoomSetpoint,notifications,recordings.dhwCircuits.dhw1.actualTemp._Hours,recordings.heatSources.actualCHPower._Hours,recordings.heatSources.actualDHWPower._Hours,recordings.heatSources.actualPower._Hours,recordings.heatSources.hs1.actualPower._Hours,recordings.heatingCircuits.hc1.roomtemperature._Hours,recordings.system.heatSources.hs1.actualPower._Hours,recordings.system.sensors.temperatures.outdoor_t1._Hours,system.brand,system.bus,system.healthStatus,system.holidayModes.hm1.assignedTo,system.holidayModes.hm1.dhwMode,system.holidayModes.hm1.hcMode,system.holidayModes.hm1.startStop,system.holidayModes.hm2.assignedTo,system.holidayModes.hm2.dhwMode,system.holidayModes.hm2.hcMode,system.holidayModes.hm2.startStop,system.holidayModes.hm3.assignedTo,system.holidayModes.hm3.dhwMode,system.holidayModes.hm3.hcMode,system.holidayModes.hm3.startStop,system.holidayModes.hm4.assignedTo,system.holidayModes.hm4.dhwMode,system.holidayModes.hm4.hcMode,system.holidayModes.hm4.startStop,system.holidayModes.hm5.assignedTo,system.holidayModes.hm5.dhwMode,system.holidayModes.hm5.hcMode,system.holidayModes.hm5.startStop,system.info,system.minOutdoorTemp,system.systemType
          2023-04-09 21:01:46.890  - info: km200.0 (27476) Fast Interval=1 min, Fast-List: dhwCircuits.dhw1.actualTemp,dhwCircuits.dhw1.currentSetpoint,heatSources.actualModulation,heatSources.actualPower,heatSources.actualSupplyTemperature,heatSources.flameStatus,heatSources.hs1.actualModulation,heatSources.hs1.actualPower,heatSources.hs1.flameStatus,heatSources.supplyTemperatureSetpoint,heatingCircuits.hc1.actualSupplyTemperature,heatingCircuits.hc1.pumpModulation,heatingCircuits.hc1.supplyTemperatureSetpoint,system.appliance.actualSupplyTemperature,system.sensors.temperatures.hotWater_t2,system.sensors.temperatures.outdoor_t1,system.sensors.temperatures.return,system.sensors.temperatures.supply_t1,system.sensors.temperatures.supply_t1_setpoint
          2023-04-09 21:01:46.891  - info: km200.0 (27476) Slow Interval=6 hours, Slow-List: recordings.dhwCircuits.dhw1.actualTemp._Days,recordings.dhwCircuits.dhw1.actualTemp._Months,recordings.heatSources.actualCHPower._Days,recordings.heatSources.actualCHPower._Months,recordings.heatSources.actualDHWPower._Days,recordings.heatSources.actualDHWPower._Months,recordings.heatSources.actualPower._Days,recordings.heatSources.actualPower._Months,recordings.heatSources.hs1.actualPower._Days,recordings.heatSources.hs1.actualPower._Months,recordings.heatingCircuits.hc1.roomtemperature._Days,recordings.heatingCircuits.hc1.roomtemperature._Months,recordings.system.heatSources.hs1.actualPower._Days,recordings.system.heatSources.hs1.actualPower._Months,recordings.system.sensors.temperatures.outdoor_t1._Days,recordings.system.sensors.temperatures.outdoor_t1._Months
          2023-04-09 21:02:16.083  - info: km200.0 (27476) Set km200.0.heatingCircuits.hc1.activeSwitchProgram to 0
          2023-04-09 21:02:17.519  - info: km200.0 (27476) Adapter km200 initialization finished with 122 states.
          2023-04-09 21:02:18.093  - info: km200.0 (27476) Update {'heatingCircuits.hc1.activeSwitchProgram': {type: 'state',id: 'heatingCircuits.hc1.activeSwitchProgram',common: {id: 'heatingCircuits.hc1.activeSwitchProgram',name: 'heatingCircuits.hc1.activeSwitchProgram',type: 'number',unit: '',read: true,write: true,role: 'level',states: '0:A;1:B',min: 0,max: 1,native: [Object]},native: { km200: [Object] }}}
          2023-04-09 21:02:32.156  - info: alexa2.0 (26960) Unknown Device, but enabling commands, Try it and report back if commands work.
          2023-04-09 21:02:32.157  - info: alexa2.0 (26960) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
          2023-04-09 21:02:32.157  - info: alexa2.0 (26960)     Device-type:AH6MYEHSW61SM - Sebastian's L67 (L67) (MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,SLEEP,DREAM_TRAINING,APPLE_MUSIC,AMAZON_MUSIC,KINDLE_BOOKS,ASCENDING_ALARM_VOLUME,CHANGE_NAME,MICROPHONE,TUNE_IN,MUSIC_SKILL,PERSISTENT_CONNECTION,TIDAL,TOUCH_INITIATED,SUPPORTS_LOCALE,DEEZER,DEREGISTER_DEVICE,AUDIBLE,CUSTOM_ALARM_TONE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,SET_TIME_ZONE,AUDIO_PLAYER,ADAPTIVE_LISTENING,SOUND_SETTINGS,SUPPORTS_LOCALE_SWITCH,GOLDFISH,REMINDERS,DIALOG_INTERFACE_VERSION,SPEECH_RECOGNIZER_USS,I_HEART_RADIO,SET_LOCALE,TIMERS_AND_ALARMS,EARCONS)
          2023-04-09 21:02:41.868  - info: alexa2.0 (26960) No smart home devices to query
          2023-04-09 21:02:44.026  - info: alexa2.0 (26960) Subscribing to states...
          2023-04-09 21:02:44.032  - info: alexa2.0 (26960) Deleting the following states: ["Echo-Devices.G070L81484841U54.Preferences.defaultAlarmNotificationSound"]
          2023-04-09 21:02:46.303  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 10s
          2023-04-09 21:02:56.825  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 15s
          2023-04-09 21:03:11.843  - info: alexa2.0 (26960) Initialization Done ...
          2023-04-09 21:03:12.437  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 20s
          • L loverz
            Hallo, wenn ich etwas über NPM installieren möchte sagt er immer, dass ich "npm audit fix --force" ausführen soll
            Nach der Ausführug kommt aber immer nur das hier:
            # npm audit report
            lodash  <=4.17.20
            Severity: critical
            Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advisories/GHSA-x5rq-j2xg-h7qm
            Prototype Pollution in lodash - https://github.com/advisories/GHSA-4xc9-xhrj-v574
            Prototype Pollution in lodash - https://github.com/advisories/GHSA-fvqr-27wr-82fm
            Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advisories/GHSA-29mw-wpgm-hmr9
            Prototype Pollution in lodash - https://github.com/advisories/GHSA-jf85-cpcp-j695
            Command Injection in lodash - https://github.com/advisories/GHSA-35jh-r3h4-6jhm
            Prototype Pollution in lodash - https://github.com/advisories/GHSA-p6mc-m468-83gw
            Will install iobroker.knx@2.0.18, which is a breaking change
            node_modules/machina/node_modules/lodash
            node_modules/xml2js-xpath/node_modules/lodash
              machina  0.3.7 - 2.0.2
              Depends on vulnerable versions of lodash
                iobroker.knx  <=0.8.6
                Depends on vulnerable versions of machina
                Depends on vulnerable versions of xml2js
                Depends on vulnerable versions of xml2js-xpath
              xml2js-xpath  <=0.9.0
            xml2js  <=0.4.23
            Severity: high
            xml2js is vulnerable to prototype pollution  - https://github.com/advisories/GHSA-776f-qx25-q3cc
            node_modules/iobroker.knx/node_modules/xml2js
            5 vulnerabilities (4 high, 1 critical)
            Ab und zu kommen 5 vulnerabilities, manchmal nur 4. Aber weg gehen sie nicht...
            Außerdem frage ich mich, wieso er KNX <=0.8.6 bemängelt, obwohl ich 2.0.13 installiert habe!
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            npm audit fix
            ist eigentlich nur für den package verwalter/maintainer gedacht. dadurch kann er sich pakete aktualisieren lassen, die sein eigenes programm/package verwendet, welche security probleme haben.
            da man sich dadurch aber inkonsistenzen reinholen kann und man danach ausführlich sein system testen muss, ist das nicht für den normalnutzer gedacht
            Meine Adapter und Widgets
            Links im Profil
            L 1 Antwort Letzte Antwort
            • L loverz
              @Glasfaser
              Skript v.2023-04-02
              *** BASE SYSTEM ***
              Docker          : false
              Release:        10
              Codename:       buster
              VERSION_ID="10"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
                       3888 M total memory
                       1651 M used memory
                        558 M active memory
                        756 M free memory
                        271 M buffer memory
                       1209 M swap cache
                        511 M total swap
                        161 M used swap
                        350 M free swap
              *** FILESYSTEM ***
              /var:
              3.8G    /var/
              2.9G    /var/cache/apt
              2.9G    /var/cache
              399M    /var/lib
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        10649
              States:         9196
              Pending Updates: 8
              buster
              Beerdigen, ist verstorben.
              Installier da den Nachfolger Debian 11 / Bullseye
              • OliverIOO OliverIO
                npm audit fix
                loverz
                @oliverio ok danke
                • L loverz
                  @oliverio ok danke
                  @loverz
                  Die Adapter nochmal installieren, da klemmt es:
                    buster
                    loverz
                    @thomas-braun heißt?
                    Geht das nicht via
                    sudo apt-get update && sudo apt-get upgrade -y
                    Das führe ich regelmäßig aus.
                    Würde gerne mal eine komplette Neuinstallation machen und danach mein Backitup einspielen, aber das klappt bei mir nicht, hab das mal mit nem zweiten Raspberry probiert.
                      @loverz
                      loverz
                      @loverz
                      Einfach "drüberbügeln"?
                      Oder vorher löschen? Dann wären halt meine Einstellungen von YAHKA weg!
                      • L loverz
                        Geht das nicht via
                        Damit bleibst du immer in einem Release.
                        Ein Releasewechsel muss/kann so vorgenommen werden:
                        https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                        • L loverz
                          Geht das nicht via
                          Dann ist dein System krumm. Das klappt nämlich bei 'ordentlichen' Installationen.
                            loverz
                            @thomas-braun hab eine neue SD genommen und eine Neuinstallation gemacht.
                            Die Backups laufen einwandfrei durch. Weiß echt nicht, woran das liegt :(
                            Danke für die Anleitung. Ich denke, wenn ich das Backup-Problem löse, dann kann ich damit auch gleich auf ein neues Release und eine saubere Neuinstallation umziehen.
                            • L loverz
                              @loverz
                              Hab noch eine Kinke gefunden:
                              Muss auf buster lauten, bzw. nach dem erfolgten Upgrade natürlich auf 'bullseye'.
                                @loverz
                                loverz
                                @thomas-braun was meinst du damit? Dass ich Influx nach dem Upgrade auf Bullseye abändern muss?
                                Soll ich die beiden fehlerhaften Adapter "drüberbügeln"?
                                • L loverz
                                  Ich würde es jetzt (im file /etc/apt/sources.list.d/influxIRGENDWAS.list) auf buster ändern.
                                  Wenn du nach meiner Anleitung zum Upgrade auf Bullseye vorgehst wird das dann gleich automatisch richtig gemacht.
                                  • L loverz
                                    Ja, mit
                                    iobroker upgrade ADAPTER@VERSION
