  4. NPM AUDIT FIX?
    5.4k
NPM AUDIT FIX?
24 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • L loverz
    @thomas-braun ich bin doch als User angemeldet.
    Standarduser "Pi" von der ioBroker Installation.
    Also einfach stehen lassen die "Fehler"?
    @loverz
    Dann bitte vollständige Ein- und Ausgabezeilen posten, nix weg lassen.
    L 1 Antwort Letzte Antwort
    • L loverz
      Hallo, wenn ich etwas über NPM installieren möchte sagt er immer, dass ich "npm audit fix --force" ausführen soll
      Nach der Ausführug kommt aber immer nur das hier:
      # npm audit report
      lodash  <=4.17.20
      Severity: critical
      Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advisories/GHSA-x5rq-j2xg-h7qm
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-4xc9-xhrj-v574
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-fvqr-27wr-82fm
      Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advisories/GHSA-29mw-wpgm-hmr9
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-jf85-cpcp-j695
      Command Injection in lodash - https://github.com/advisories/GHSA-35jh-r3h4-6jhm
      Prototype Pollution in lodash - https://github.com/advisories/GHSA-p6mc-m468-83gw
      fix available via `npm audit fix --force`
      Will install iobroker.knx@2.0.18, which is a breaking change
      node_modules/machina/node_modules/lodash
      node_modules/xml2js-xpath/node_modules/lodash
        machina  0.3.7 - 2.0.2
        Depends on vulnerable versions of lodash
          iobroker.knx  <=0.8.6
          Depends on vulnerable versions of machina
          Depends on vulnerable versions of xml2js
          Depends on vulnerable versions of xml2js-xpath
          node_modules/iobroker.knx
        xml2js-xpath  <=0.9.0
      xml2js  <=0.4.23
      Severity: high
      xml2js is vulnerable to prototype pollution  - https://github.com/advisories/GHSA-776f-qx25-q3cc
      node_modules/iobroker.knx/node_modules/xml2js
      5 vulnerabilities (4 high, 1 critical)
      To address all issues (including breaking changes), run:
      Ab und zu kommen 5 vulnerabilities, manchmal nur 4. Aber weg gehen sie nicht...
      Außerdem frage ich mich, wieso er KNX <=0.8.6 bemängelt, obwohl ich 2.0.13 installiert habe!
      GlasfaserG Offline
      GlasfaserG Offline
      @loverz sagte in NPM AUDIT FIX?:
      Wäre noch ein
      iob diag
      wie hier noch offen
      https://forum.iobroker.net/topic/63771/warnmeldungen-bei-adapterinstallation
      Ich vermute mal dein System ist strubbelig
      und warum per npm installieren
      knx@2.0.18
      ist im Beta Repo vorhanden
      • GlasfaserG Glasfaser
        Wäre noch ein
        iob diag
        wie hier noch offen
        knx@2.0.18
        loverz
        @glasfaser hab das per NPM gemacht, weil ich es in der Weboberfläche nicht gesehen habe und von Linux so gut wie keine Ahnung habe.
        Wie man das Beta Repo lädt weiß ich allerdings, das hätte ich machen können.
        Mache gleich mal ein Fix
        • L loverz
          Gib mal die Ausgabe vom iob diag danach. Da scheint mir noch mehr krumm zu sein.
          GlasfaserG L 2 Antworten Letzte Antwort
            GlasfaserG Offline
            GlasfaserG Offline
            @thomas-braun sagte in NPM AUDIT FIX?:
            Ist wohl Geheim ... :)
              @loverz
              loverz
              @loverz
              login as: pi
              pi@192.168.1.166's password:
              Linux ioBroker-RasPi4 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
              permitted by applicable law.
              Last login: Sun Apr  9 20:55:43 2023 from 192.168.1.152
              pi@ioBroker-RasPi4:~ $ npm audit fix --force
              npm WARN using --force Recommended protections disabled.
              npm WARN audit Updating iobroker.knx to 2.0.18, which is a SemVer major change.
              npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in        0.5.0
              added 189 packages, removed 14 packages, changed 2 packages, and audited 205 packages in 46s
              38 packages are looking for funding
                run `npm fund` for details
              # npm audit report
              class-validator  <0.14.0
              Severity: critical
              SQL Injection and Cross-site Scripting in class-validator - https://github.com/advisories/GHSA-fj58-h2fr-3pp2
              Will install iobroker.knx@0.8.6, which is a breaking change
              node_modules/javascript-obfuscator/node_modules/class-validator
                javascript-obfuscator  0.7.0-dev.1 - 4.0.0
                Depends on vulnerable versions of class-validator
                  iobroker.knx  >=0.8.0
                  Depends on vulnerable versions of javascript-obfuscator
                  Depends on vulnerable versions of jsonwebtoken
                  Depends on vulnerable versions of xmldom
              jsonwebtoken  <=8.5.1
              Severity: moderate
              jsonwebtoken unrestricted key type could lead to legacy keys usage  - https://github.com/advisories/GHSA-8cf7-32gw-wr33
              jsonwebtoken's insecure implementation of key retrieval function could lead to Forgeable Public/Private Tokens from RSA to HMAC - https://github.com/advisories/GHSA-hjrf-2m68-5959
              jsonwebtoken vulnerable to signature validation bypass due to insecure default algorithm in jwt.verify() - https://github.com/advisories/GHSA-qwph-4952-7xr6
              node_modules/jsonwebtoken
              xmldom  *
              Severity: critical
              Misinterpretation of malicious XML input - https://github.com/advisories/GHSA-5fg8-2547-mr8q
              Misinterpretation of malicious XML input - https://github.com/advisories/GHSA-h6q6-9hqw-rwfv
              xmldom allows multiple root nodes in a DOM - https://github.com/advisories/GHSA-crh6-fp67-6883
              node_modules/xmldom
              5 vulnerabilities (1 moderate, 4 critical)
              • L loverz
                @loverz
                login as: pi
                # npm audit report
                Severity: critical
                Severity: moderate
                xmldom  *
                Severity: critical
                node_modules/xmldom
                GlasfaserG Offline
                GlasfaserG Offline
                @loverz
                und wo ist
                iob diag
                  loverz
                  schrieb am zuletzt editiert von loverz
                  @Glasfaser
                  Skript v.2023-04-02
                  *** BASE SYSTEM ***
                  Model           : Raspberry Pi 4 Model B Rev 1.2
                  Architecture    : armv7l
                  Docker          : false
                  Virtualization  : none
                  Distributor ID: Raspbian
                  Description:    Raspbian GNU/Linux 10 (buster)
                  Release:        10
                  Codename:       buster
                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="10"
                  VERSION="10 (buster)"
                  VERSION_CODENAME=buster
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                  Systemuptime and Load:
                   21:02:19 up 9 days, 22:30,  1 user,  load average: 4.32, 3.95, 4.36
                  CPU threads: 4
                  *** Time and Time Zones ***
                                 Local time: Sun 2023-04-09 21:02:19 CEST
                             Universal time: Sun 2023-04-09 19:02:19 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:           3.9G        1.7G        756M         28M        1.5G        2.3G
                  Swap:          511M        161M        350M
                  Total:         4.4G        1.8G        1.1G
                           3888 M total memory
                           1651 M used memory
                            558 M active memory
                           2381 M inactive memory
                            756 M free memory
                            271 M buffer memory
                           1209 M swap cache
                            511 M total swap
                            161 M used swap
                            350 M free swap
                  *** FILESYSTEM ***
                  /dev/root      ext4      118G   16G   97G  14% /
                  devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                  tmpfs          tmpfs     1.9G   58M  1.9G   3% /run
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                  /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                  [Thu Mar 30 22:31:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:86:53:AE vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [Thu Mar 30 22:31:54 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                  [Thu Mar 30 22:31:54 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Thu Mar 30 22:31:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600
                  TARGET        SOURCE         FSTYPE OPTIONS
                  /             /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                  |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                  `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  3.8G    /var/
                  2.9G    /var/cache/apt
                  2.9G    /var/cache
                  2.8G    /var/cache/apt/archives
                  399M    /var/lib
                  /opt/iobroker/backups:
                  3.6G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  402M    /opt/iobroker/iobroker-data/
                  183M    /opt/iobroker/iobroker-data/files
                  147M    /opt/iobroker/iobroker-data/backup-objects
                  72M     /opt/iobroker/iobroker-data/files/telegram.admin
                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                  20M     /opt/iobroker/iobroker-data/objects.jsonl
                  15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                  14M     /opt/iobroker/iobroker-data/objects.json.migrated
                  14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  13M     /opt/iobroker/iobroker-data/objects.json.old
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v16.19.1
                  /usr/bin/node           v16.19.1
                  /usr/bin/npm            8.19.3
                  /usr/bin/npx            8.19.3
                  nodejs:
                    Installed: 16.19.1-deb-1nodesource1
                    Candidate: 16.19.1-deb-1nodesource1
                    Version table:
                   *** 16.19.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u3 500
                  No problems detected
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  4.0.24
                  admin:          6.3.5
                  javascript:     6.1.4
                  npm ERR! code ELSPROBLEMS
                  npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                  npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                  npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                  npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                  npm ERR! invalid: iobroker.sourceanalytix@0.4.14 /opt/iobroker/node_modules/iobroker.sourceanalytix
                  npm ERR! invalid: iobroker.yahka@1.0.3 /opt/iobroker/node_modules/iobroker.yahka
                  npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                  npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                  npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                  npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                  npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                  npm ERR!     /home/pi/.npm/_logs/2023-04-09T19_02_36_936Z-debug-0.log
                  Adapters from github:   2
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : Host-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : Host-ioBroker                           -  enabled
                  + system.adapter.backitup.0               : backitup              : Host-ioBroker                           -  enabled
                    system.adapter.daswetter.0              : daswetter             : Host-ioBroker                           -  enabled
                  + system.adapter.deconz.0                 : deconz                : Host-ioBroker                           -  enabled, port: 80
                    system.adapter.easee.0                  : easee                 : Host-ioBroker                           - disabled
                    system.adapter.hmip.0                   : hmip                  : Host-ioBroker                           - disabled
                  + system.adapter.hs100.0                  : hs100                 : Host-ioBroker                           -  enabled
                  + system.adapter.hue.0                    : hue                   : Host-ioBroker                           -  enabled, port: 443
                  + system.adapter.influxdb.0               : influxdb              : Host-ioBroker                           -  enabled, port: 8086
                  + system.adapter.info.0                   : info                  : Host-ioBroker                           -  enabled
                  + system.adapter.javascript.0             : javascript            : Host-ioBroker                           -  enabled
                  + system.adapter.km200.0                  : km200                 : Host-ioBroker                           -  enabled
                  + system.adapter.knx.0                    : knx                   : Host-ioBroker                           -  enabled, bind: 192.168.1.166
                    system.adapter.mydlink.0                : mydlink               : Host-ioBroker                           - disabled
                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : Host-ioBroker                           -  enabled
                  + system.adapter.philips-tv.0             : philips-tv            : Host-ioBroker                           -  enabled
                  + system.adapter.ping.0                   : ping                  : Host-ioBroker                           -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : Host-ioBroker                           -  enabled
                  + system.adapter.shelly.0                 : shelly                : Host-ioBroker                           -  enabled, port: 1882, bind: 192.168.1.166
                    system.adapter.solarmanpv.0             : solarmanpv            : Host-ioBroker                           -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : Host-ioBroker                           -  enabled
                  + system.adapter.telegram.0               : telegram              : Host-ioBroker                           -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : Host-ioBroker                           -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.yahka.0                  : yahka                 : Host-ioBroker                           -  enabled
                  + system.adapter.yahka.3                  : yahka                 : Host-ioBroker                           -  enabled
                    system.adapter.yeelight-2.0             : yeelight-2            : Host-ioBroker                           - disabled
                  + instance is alive
                  ioBroker-Repositories
                  latest        : http://iobroker.live/repo/sources-dist-latest.json
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                  Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
                  Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                  Adapter    "easee"        : 1.0.7    , installed 1.0.7
                  Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                  Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                  Adapter    "hue"          : 3.7.1    , installed 3.7.1
                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                  Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                  Adapter    "km200"        : 2.0.3    , installed 2.0.3
                  Adapter    "knx"          : 2.0.17   , installed 2.0.18
                  Adapter    "mydlink"      : 1.1.12   , installed 1.2.1
                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                  Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                  Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                  Adapter    "solarmanpv"   : 0.3.2    , installed 0.3.2
                  Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                  Adapter    "yahka"        : 0.17.0   , installed 1.0.3
                  Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
                  Objects and States
                  Objects:        10649
                  States:         9196
                  Hit:1 http://phoscon.de/apt/deconz buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://repos.influxdata.com/debian stretch InRelease
                  Hit:4 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:5 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
                  Hit:7 https://repo.homebridge.io stable InRelease
                  Reading package lists...
                  Pending Updates: 8
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18151      329/deCONZ
                  tcp        0      0 127.0.0.1:45203         0.0.0.0:*               LISTEN      1001       37357329   27699/io.yahka.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17042      724/sshd
                  tcp        0      0 127.0.0.1:40471         0.0.0.0:*               LISTEN      1001       37358987   27825/io.yahka.3
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15030      715/influxd
                  tcp        0      0 127.0.0.1:37529         0.0.0.0:*               LISTEN      1001       37356391   27825/io.yahka.3
                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15429      329/deCONZ
                  tcp        0      0 127.0.0.1:46237         0.0.0.0:*               LISTEN      110        22065772   26253/homebridge
                  tcp        0      0 0.0.0.0:45667           0.0.0.0:*               LISTEN      1001       37358314   27699/io.yahka.0
                  tcp        0      0 0.0.0.0:33987           0.0.0.0:*               LISTEN      1001       37358946   27825/io.yahka.3
                  tcp        0      0 127.0.0.1:44003         0.0.0.0:*               LISTEN      110        37122721   26253/homebridge
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37351791   26616/iobroker.js-c
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37350710   26616/iobroker.js-c
                  tcp        0      0 127.0.0.1:44015         0.0.0.0:*               LISTEN      1001       37357336   27699/io.yahka.0
                  tcp        0      0 127.0.0.1:33487         0.0.0.0:*               LISTEN      110        30844253   26253/homebridge
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37349193   26658/io.admin.0
                  tcp6       0      0 :::51442                :::*                    LISTEN      110        22066377   26253/homebridge
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        15257      715/influxd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17044      724/sshd
                  tcp6       0      0 :::3000                 :::*                    LISTEN      109        18727      709/grafana
                  tcp6       0      0 :::8581                 :::*                    LISTEN      110        16144      1285/hb-service
                  udp        0      0 192.168.1.166:51103     0.0.0.0:*                           1001       37362469   27037/io.knx.0
                  udp        0      0 0.0.0.0:1982            0.0.0.0:*                           110        22066375   26253/homebridge
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37352880   26913/io.shelly.0
                  udp        0      0 0.0.0.0:32831           0.0.0.0:*                           108        14734      340/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16583      706/dhcpcd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        20695      1285/hb-service
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14732      340/avahi-daemon: r
                  udp        0      0 192.168.1.166:37733     0.0.0.0:*                           1001       37351127   27037/io.knx.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       37354334   27260/io.deconz.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15432      329/deCONZ
                  udp6       0      0 :::546                  :::*                                0          2341956    706/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        14733      340/avahi-daemon: r
                  udp6       0      0 :::47388                :::*                                108        14735      340/avahi-daemon: r
                  udp6       0      0 :::1900                 :::*                                1001       37354337   27260/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       37354336   27260/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       37354335   27260/io.deconz.0
                  2023-04-09 21:01:46.004  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
                  2023-04-09 21:01:46.087  - warn: km200.0 (27476) Object system.holidayModes.hm5.hcMode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                  2023-04-09 21:01:46.087  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
                  2023-04-09 21:01:46.768  - warn: km200.0 (27476) Object system.systemType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                  2023-04-09 21:01:46.769  - warn: km200.0 (27476) This object will not be created in future versions. Please report this to the developer.
                  2023-04-09 21:01:46.874  - info: km200.0 (27476) KM200 found 122 states, get their values now.
                  2023-04-09 21:01:46.889  - info: km200.0 (27476) Interval=30 min, Norm-list: dhwCircuits.dhw1.charge,dhwCircuits.dhw1.chargeDuration,dhwCircuits.dhw1.holidayMode.activated,dhwCircuits.dhw1.operationMode,dhwCircuits.dhw1.singleChargeSetpoint,dhwCircuits.dhw1.status,dhwCircuits.dhw1.temperatureLevels.high,dhwCircuits.dhw1.temperatureLevels.off,dhwCircuits.dhw1.waterFlow,dhwCircuits.dhw1.workingTime,heatSources.CHpumpModulation,heatSources.ChimneySweeper,heatSources.actualCHPower,heatSources.actualDHWPower,heatSources.applianceSupplyTemperature,heatSources.burnerModulationSetpoint,heatSources.burnerPowerSetpoint,heatSources.energyMonitoring.consumption,heatSources.energyMonitoring.correctionFactor,heatSources.energyMonitoring.maxTankLevel,heatSources.energyMonitoring.minTankLevel,heatSources.energyMonitoring.startDateTime,heatSources.energyMonitoring.tankLevel,heatSources.fanSpeed_setpoint,heatSources.gasAirPressure,heatSources.hs1.info,heatSources.hs1.type,heatSources.info,heatSources.nominalCHPower,heatSources.nominalDHWPower,heatSources.numberOfStarts,heatSources.powerSetpoint,heatSources.returnTemperature,heatSources.systemPressure,heatSources.workingTime.centralHeating,heatSources.workingTime.secondBurner,heatSources.workingTime.totalSystem,heatingCircuits.hc1.activeSwitchProgram,heatingCircuits.hc1.currentRoomSetpoint,heatingCircuits.hc1.currentSuWiMode,heatingCircuits.hc1.fastHeatupFactor,heatingCircuits.hc1.holidayMode.activated,heatingCircuits.hc1.operationMode,heatingCircuits.hc1.status,heatingCircuits.hc1.suWiSwitchMode,heatingCircuits.hc1.suWiThreshold,heatingCircuits.hc1.switchProgramMode,heatingCircuits.hc1.switchPrograms.A,heatingCircuits.hc1.switchPrograms.B,heatingCircuits.hc1.temperatureLevels.comfort2,heatingCircuits.hc1.temperatureLevels.eco,heatingCircuits.hc1.temporaryRoomSetpoint,notifications,recordings.dhwCircuits.dhw1.actualTemp._Hours,recordings.heatSources.actualCHPower._Hours,recordings.heatSources.actualDHWPower._Hours,recordings.heatSources.actualPower._Hours,recordings.heatSources.hs1.actualPower._Hours,recordings.heatingCircuits.hc1.roomtemperature._Hours,recordings.system.heatSources.hs1.actualPower._Hours,recordings.system.sensors.temperatures.outdoor_t1._Hours,system.brand,system.bus,system.healthStatus,system.holidayModes.hm1.assignedTo,system.holidayModes.hm1.dhwMode,system.holidayModes.hm1.hcMode,system.holidayModes.hm1.startStop,system.holidayModes.hm2.assignedTo,system.holidayModes.hm2.dhwMode,system.holidayModes.hm2.hcMode,system.holidayModes.hm2.startStop,system.holidayModes.hm3.assignedTo,system.holidayModes.hm3.dhwMode,system.holidayModes.hm3.hcMode,system.holidayModes.hm3.startStop,system.holidayModes.hm4.assignedTo,system.holidayModes.hm4.dhwMode,system.holidayModes.hm4.hcMode,system.holidayModes.hm4.startStop,system.holidayModes.hm5.assignedTo,system.holidayModes.hm5.dhwMode,system.holidayModes.hm5.hcMode,system.holidayModes.hm5.startStop,system.info,system.minOutdoorTemp,system.systemType
                  2023-04-09 21:01:46.890  - info: km200.0 (27476) Fast Interval=1 min, Fast-List: dhwCircuits.dhw1.actualTemp,dhwCircuits.dhw1.currentSetpoint,heatSources.actualModulation,heatSources.actualPower,heatSources.actualSupplyTemperature,heatSources.flameStatus,heatSources.hs1.actualModulation,heatSources.hs1.actualPower,heatSources.hs1.flameStatus,heatSources.supplyTemperatureSetpoint,heatingCircuits.hc1.actualSupplyTemperature,heatingCircuits.hc1.pumpModulation,heatingCircuits.hc1.supplyTemperatureSetpoint,system.appliance.actualSupplyTemperature,system.sensors.temperatures.hotWater_t2,system.sensors.temperatures.outdoor_t1,system.sensors.temperatures.return,system.sensors.temperatures.supply_t1,system.sensors.temperatures.supply_t1_setpoint
                  2023-04-09 21:01:46.891  - info: km200.0 (27476) Slow Interval=6 hours, Slow-List: recordings.dhwCircuits.dhw1.actualTemp._Days,recordings.dhwCircuits.dhw1.actualTemp._Months,recordings.heatSources.actualCHPower._Days,recordings.heatSources.actualCHPower._Months,recordings.heatSources.actualDHWPower._Days,recordings.heatSources.actualDHWPower._Months,recordings.heatSources.actualPower._Days,recordings.heatSources.actualPower._Months,recordings.heatSources.hs1.actualPower._Days,recordings.heatSources.hs1.actualPower._Months,recordings.heatingCircuits.hc1.roomtemperature._Days,recordings.heatingCircuits.hc1.roomtemperature._Months,recordings.system.heatSources.hs1.actualPower._Days,recordings.system.heatSources.hs1.actualPower._Months,recordings.system.sensors.temperatures.outdoor_t1._Days,recordings.system.sensors.temperatures.outdoor_t1._Months
                  2023-04-09 21:02:16.083  - info: km200.0 (27476) Set km200.0.heatingCircuits.hc1.activeSwitchProgram to 0
                  2023-04-09 21:02:17.519  - info: km200.0 (27476) Adapter km200 initialization finished with 122 states.
                  2023-04-09 21:02:18.093  - info: km200.0 (27476) Update {'heatingCircuits.hc1.activeSwitchProgram': {type: 'state',id: 'heatingCircuits.hc1.activeSwitchProgram',common: {id: 'heatingCircuits.hc1.activeSwitchProgram',name: 'heatingCircuits.hc1.activeSwitchProgram',type: 'number',unit: '',read: true,write: true,role: 'level',states: '0:A;1:B',min: 0,max: 1,native: [Object]},native: { km200: [Object] }}}
                  2023-04-09 21:02:32.156  - info: alexa2.0 (26960) Unknown Device, but enabling commands, Try it and report back if commands work.
                  2023-04-09 21:02:32.157  - info: alexa2.0 (26960) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                  2023-04-09 21:02:32.157  - info: alexa2.0 (26960)     Device-type:AH6MYEHSW61SM - Sebastian's L67 (L67) (MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,SLEEP,DREAM_TRAINING,APPLE_MUSIC,AMAZON_MUSIC,KINDLE_BOOKS,ASCENDING_ALARM_VOLUME,CHANGE_NAME,MICROPHONE,TUNE_IN,MUSIC_SKILL,PERSISTENT_CONNECTION,TIDAL,TOUCH_INITIATED,SUPPORTS_LOCALE,DEEZER,DEREGISTER_DEVICE,AUDIBLE,CUSTOM_ALARM_TONE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,SET_TIME_ZONE,AUDIO_PLAYER,ADAPTIVE_LISTENING,SOUND_SETTINGS,SUPPORTS_LOCALE_SWITCH,GOLDFISH,REMINDERS,DIALOG_INTERFACE_VERSION,SPEECH_RECOGNIZER_USS,I_HEART_RADIO,SET_LOCALE,TIMERS_AND_ALARMS,EARCONS)
                  2023-04-09 21:02:41.868  - info: alexa2.0 (26960) No smart home devices to query
                  2023-04-09 21:02:44.026  - info: alexa2.0 (26960) Subscribing to states...
                  2023-04-09 21:02:44.032  - info: alexa2.0 (26960) Deleting the following states: ["Echo-Devices.G070L81484841U54.Preferences.defaultAlarmNotificationSound"]
                  2023-04-09 21:02:46.303  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 10s
                  2023-04-09 21:02:56.825  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 15s
                  2023-04-09 21:03:11.843  - info: alexa2.0 (26960) Initialization Done ...
                  2023-04-09 21:03:12.437  - info: alexa2.0 (26960) Alexa-Push-Connection disconnected - retry: Retry Connection in 20s
                  • L loverz
                    # npm audit report
                    lodash  <=4.17.20
                    Severity: critical
                    xml2js  <=0.4.23
                    Severity: high
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    npm audit fix
                    ist eigentlich nur für den package verwalter/maintainer gedacht. dadurch kann er sich pakete aktualisieren lassen, die sein eigenes programm/package verwendet, welche security probleme haben.
                    da man sich dadurch aber inkonsistenzen reinholen kann und man danach ausführlich sein system testen muss, ist das nicht für den normalnutzer gedacht
                    Meine Adapter und Widgets
                    Links im Profil
                    • L loverz
                      @Glasfaser
                      Skript v.2023-04-02
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        10
                      Codename:       buster
                      VERSION_ID="10"
                      ID=raspbian
                      ID_LIKE=debian
                      CPU threads: 4
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                               3888 M total memory
                               1651 M used memory
                                558 M active memory
                                756 M free memory
                                271 M buffer memory
                               1209 M swap cache
                                511 M total swap
                                161 M used swap
                                350 M free swap
                      *** FILESYSTEM ***
                      /var:
                      3.8G    /var/
                      2.9G    /var/cache/apt
                      2.9G    /var/cache
                      399M    /var/lib
                      /usr/bin/npm            8.19.3
                      /usr/bin/npx            8.19.3
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        10649
                      States:         9196
                      Pending Updates: 8
                      buster
                      Beerdigen, ist verstorben.
                      Installier da den Nachfolger Debian 11 / Bullseye
                      • OliverIOO OliverIO
                        npm audit fix
                        loverz
                        @oliverio ok danke
                        • L loverz
                          @oliverio ok danke
                          @loverz
                          Die Adapter nochmal installieren, da klemmt es:
                            buster
                            loverz
                            @thomas-braun heißt?
                            Geht das nicht via
                            sudo apt-get update && sudo apt-get upgrade -y
                            Das führe ich regelmäßig aus.
                            Würde gerne mal eine komplette Neuinstallation machen und danach mein Backitup einspielen, aber das klappt bei mir nicht, hab das mal mit nem zweiten Raspberry probiert.
                              @loverz
                              loverz
                              @loverz
                              Einfach "drüberbügeln"?
                              Oder vorher löschen? Dann wären halt meine Einstellungen von YAHKA weg!
                              • L loverz
                                Geht das nicht via
                                Damit bleibst du immer in einem Release.
                                Ein Releasewechsel muss/kann so vorgenommen werden:
                                https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                                • L loverz
                                  Geht das nicht via
                                  Dann ist dein System krumm. Das klappt nämlich bei 'ordentlichen' Installationen.
                                    loverz
                                    @thomas-braun hab eine neue SD genommen und eine Neuinstallation gemacht.
                                    Die Backups laufen einwandfrei durch. Weiß echt nicht, woran das liegt :(
                                    Danke für die Anleitung. Ich denke, wenn ich das Backup-Problem löse, dann kann ich damit auch gleich auf ein neues Release und eine saubere Neuinstallation umziehen.
                                    • L loverz
                                      @loverz
                                      Hab noch eine Kinke gefunden:
                                      Muss auf buster lauten, bzw. nach dem erfolgten Upgrade natürlich auf 'bullseye'.
                                        @loverz
                                        loverz
                                        @thomas-braun was meinst du damit? Dass ich Influx nach dem Upgrade auf Bullseye abändern muss?
                                        Soll ich die beiden fehlerhaften Adapter "drüberbügeln"?
                                        • L loverz
                                          Ich würde es jetzt (im file /etc/apt/sources.list.d/influxIRGENDWAS.list) auf buster ändern.
                                          Wenn du nach meiner Anleitung zum Upgrade auf Bullseye vorgehst wird das dann gleich automatisch richtig gemacht.
