  4. Täglich Fehler im Log - connect ECONNREFUSED 127.0.0.1:9001
30 Beiträge 2 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • D derroadrunner
    roadrunner@piroadrunner:~ $ sudo apt-key del 05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
    rm /etc/apt/sources.list.d/infl*
    wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
    export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
    echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    gpg: key "E0C5" not found: Not found
    gpg: E0C5: delete key failed: Not found
    rm: remove write-protected regular file '/etc/apt/sources.list.d/influxdb.list'? y
    rm: cannot remove '/etc/apt/sources.list.d/influxdb.list': Permission denied
    File '/usr/share/keyrings/influxdb.gpg' exists. Overwrite? (y/N) y
    roadrunner@piroadrunner:~ $ sudo apt update
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Reading package lists... Done
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @derroadrunner
    ls -lAh /etc/apt/sources.list.d/
      @derroadrunner
      D
      D
      derroadrunner
      roadrunner@piroadrunner:~ $ ls -lAh /etc/apt/sources.list.d/
      total 16K
      -rw-r--r-- 1 root root  53 Feb  5 00:20 grafana.list
      -rw-r--r-- 1 root root 101 Apr  1 21:59 influxdb.list
      -rw-r--r-- 1 root root 208 Feb  4 22:58 nodesource.list
      -rw-r--r-- 1 root root 191 Sep 22  2022 raspi.list
      Raspberry Pi 3+
      • D derroadrunner
        total 16K
        Thomas BraunT
        Thomas BraunT
        @derroadrunner sagte in Täglich Fehler im Log - connect ECONNREFUSED 127.0.0.1:9001:
        cat /etc/apt/sources.list.d/influxdb.list
          D
          D
          derroadrunner
          roadrunner@piroadrunner:~ $ cat /etc/apt/sources.list.d/influxdb.list
          deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
          Raspberry Pi 3+
          • D derroadrunner
            Thomas BraunT
            Thomas BraunT
            @derroadrunner
            Ändere die Zeile ab, die muss so aussehen:
            deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian stable main
              @derroadrunner
              D
              D
              derroadrunner
              Jetzt geht es schon los
              Was muss ich da genau tun?
              Raspberry Pi 3+
              • D derroadrunner
                Thomas BraunT
                Thomas BraunT
                @derroadrunner
                Mit einem Editor wie nano die Datei bearbeiten.
                Oder damit:
                sudo rm /etc/apt/sources.list.d/infl*
                wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                sudo apt update
                  @derroadrunner
                  Oder damit:
                  sudo apt update
                  D
                  D
                  derroadrunner
                  roadrunner@piroadrunner:~ $ sudo rm /etc/apt/sources.list.d/infl*
                  sudo apt update
                  influxdata-archive_compat.key: OK
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Get:5 https://repos.influxdata.com/debian stable InRelease [6,883 B]
                  Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Hit:7 https://packages.grafana.com/oss/deb stable InRelease
                  Get:8 https://repos.influxdata.com/debian stable/main armhf Packages [2,218 B]
                  Get:9 https://repos.influxdata.com/debian stable/main arm64 Packages [3,834 B]
                  Fetched 12.9 kB in 4s (3,644 B/s)
                  33 packages can be upgraded. Run 'apt list --upgradable' to see them.
                  roadrunner@piroadrunner:~ $ apt list --upgradable
                  Listing... Done
                  grafana/stable 9.4.7 arm64 [upgradable from: 9.4.1]
                  influxdb/unknown 1.8.10-1 arm64 [upgradable from: 1.6.7~rc0-1+b5]
                  libcamera-apps/stable 0~git20230301+54a781d-1 arm64 [upgradable from: 0~git20230125+9f08463-1]
                  libcamera-tools/stable 0~git20230302+923f5d70-1 arm64 [upgradable from: 0~git20230124+9b860a66-1]
                  libcamera0/stable 0~git20230302+923f5d70-1 arm64 [upgradable from: 0~git20230124+9b860a66-1]
                  libvlc-bin/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  libvlc5/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  libvlccore9/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  linux-libc-dev/stable 1:1.20230317-1 arm64 [upgradable from: 1:1.20230106-1]
                  python3-libcamera/stable 0~git20230302+923f5d70-1 arm64 [upgradable from: 0~git20230124+9b860a66-1]
                  python3-picamera2/stable,stable 0.3.9-1 all [upgradable from: 0.3.8-1]
                  python3-v4l2/stable,stable 0.3.2-1 all [upgradable from: 0.3.1-1]
                  raspberrypi-bootloader/stable 1:1.20230317-1 arm64 [upgradable from: 1:1.20230106-1]
                  raspberrypi-kernel/stable 1:1.20230317-1 arm64 [upgradable from: 1:1.20230106-1]
                  realvnc-vnc-server/stable 7.0.1.49073 arm64 [upgradable from: 6.10.1.47571]
                  rp-prefapps/stable 0.46 arm64 [upgradable from: 0.45]
                  tzdata/stable-updates,stable-updates 2021a-1+deb11u9 all [upgradable from: 2021a-1+deb11u8]
                  vlc-data/stable,stable 3.0.18-0+rpt3+deb11u1 all [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-l10n/stable,stable 3.0.18-0+rpt3+deb11u1 all [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-access-extra/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-base/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-notify/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-qt/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-samba/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-skins2/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-video-output/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-video-splitter/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc-plugin-visualization/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  vlc/stable 3.0.18-0+rpt3+deb11u1 arm64 [upgradable from: 3.0.18-0+rpt2+deb11u1]
                  xserver-common/stable,stable 2:1.20.11-1+rpt3+deb11u6 all [upgradable from: 2:1.20.11-1+rpt1+deb11u5]
                  xserver-xorg-core/stable 2:1.20.11-1+rpt3+deb11u6 arm64 [upgradable from: 2:1.20.11-1+rpt1+deb11u5]
                  xwayland/stable 2:1.20.11-1+rpt3+deb11u6 arm64 [upgradable from: 2:1.20.11-1+rpt1+deb11u5]
                  Raspberry Pi 3+
                  • D derroadrunner
                    sudo apt update
                    Listing... Done
                    Thomas BraunT
                    Thomas BraunT
                    @derroadrunner
                    Dann ran da.
                    sudo apt full-upgrade
                    sudo reboot
                    Und Server werden OHNE graphische Oberfläche betrieben...
                    Ist vermutlich ein Überrest von einer Installation mit Desktop.
                      @derroadrunner
                      Dann ran da.
                      sudo reboot
                      D
                      D
                      derroadrunner
                      Die graphische Oberfläche hatte ich eigentlich ausgeschaltet. Das Check ich nochmal
                      jetzt habe ich statt full upgrade ___ sudo apt upgrade eingegeben, ist das ein Problem?
                      Er steht auch seit 5 min. hier
                      Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
                      Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
                      Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
                      Unpacking raspberrypi-bootloader (1:1.20230317-1) over (1:1.20230106-1) ...
                      Preparing to unpack .../21-realvnc-vnc-server_7.0.1.49073_arm64.deb ...
                      Unpacking realvnc-vnc-server (7.0.1.49073) over (6.10.1.47571) ...
                      Progress: [ 32%] [########################........................
                      Raspberry Pi 3+
                      • D derroadrunner
                        Thomas BraunT
                        Thomas BraunT
                        Ja, die ist ausgeschaltet, die entsprechenden Pakete schleppst du natürlich dennoch weiter.
                        Nein. Ist meistens bei einfachen updates nicht relevant. Kannste aber mit
                        noch nachholen. Da war ein Kernel-Upgrade dabei, hier unbedingt die Kiste neustarten.
                        sudo reboot
                        Abwarten... Mit 1GB RAM musst du halt Geduld haben.
                        D 2 Antworten Letzte Antwort
                          sudo reboot
                          D
                          D
                          derroadrunner
                          Okay, dann werde ich den Stromstecker noch nicht abziehen 😁
                          Wenn das durchgelaufen ist, gebe ich Bescheid, wie der Stand ist.
                          Vielen Dank schon mal
                          Raspberry Pi 3+
                            sudo reboot
                            D
                            D
                            derroadrunner
                            Hallo, so sieht es jetzt nach dem update aus
                            Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                            Hit:5 https://repos.influxdata.com/debian stable InRelease
                            Get:6 https://packages.grafana.com/oss/deb stable InRelease [5,983 B]
                            Fetched 50.0 kB in 4s (13.1 kB/s)
                            All packages are up to date.
                            Raspberry Pi 3+
                            • D derroadrunner
                              Thomas BraunT
                              Thomas BraunT
                              @derroadrunner
                              Ja, dann kannst du jetzt nodejs auf die derzeitig empfohlene Version 18 bringen.
                                @derroadrunner
                                D
                                D
                                derroadrunner
                                Nehme ich da am Besten deine Anleitung?
                                Teil 1.1 Node-Upgrade/ Wechsel der nodejs-Version:
                                Raspberry Pi 3+
                                • D derroadrunner
                                  Thomas BraunT
                                  Thomas BraunT
                                  Ich bin da vermutlich nicht neutral...
                                  Also ich würde es danach machen. :-)
                                    D
                                    D
                                    derroadrunner
                                    Das Ergebnis ist wichtig, Hauptsache es funktioniert
                                    Dann muss ich in meine nodesource.list diese zwei Zeilen rein kopieren
                                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                                    Das steht in meiner aktuell:
                                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                                    Raspberry Pi 3+
                                    • D derroadrunner
                                      Thomas BraunT
                                      Thomas BraunT
                                      Richtig.
                                        Richtig.
                                        D
                                        D
                                        derroadrunner
                                        Passt das jetzt so?
                                        Skript v.2023-01-02
                                        *** BASE SYSTEM ***
                                        Model           : Raspberry Pi 3 Model B Plus Rev 1.3
                                        Architecture:   aarch64
                                        Docker:         false
                                        Virtualization: none
                                        Distributor ID: Debian
                                        Description:    Debian GNU/Linux 11 (bullseye)
                                        Release:        11
                                        Codename:       bullseye
                                        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                        NAME="Debian GNU/Linux"
                                        VERSION_ID="11"
                                        VERSION="11 (bullseye)"
                                        VERSION_CODENAME=bullseye
                                        ID=debian
                                        HOME_URL="https://www.debian.org/"
                                        SUPPORT_URL="https://www.debian.org/support"
                                        BUG_REPORT_URL="https://bugs.debian.org/"
                                        Systemuptime and Load:
                                         12:17:27 up 11:52,  1 user,  load average: 1.72, 1.20, 0.91
                                        CPU threads: 4
                                        *** Time and Time Zones ***
                                        Sun Apr  2 10:17:27 UTC 2023
                                        Sun Apr  2 12:17:27 CEST 2023
                                        CEST +0200
                                        Europe/Berlin
                                        *** User and Groups ***
                                        roadrunner
                                        /home/roadrunner
                                        roadrunner adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            909M        602M         92M        0.0K        214M        229M
                                        Swap:            99M         57M         42M
                                        Total:          1.0G        660M        134M
                                                  909 M total memory
                                                  602 M used memory
                                                  378 M active memory
                                                  320 M inactive memory
                                                   92 M free memory
                                                    8 M buffer memory
                                                  206 M swap cache
                                                   99 M total swap
                                                   57 M used swap
                                                   42 M free swap
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  6.9G   21G  25% /
                                        devtmpfs       devtmpfs  325M     0  325M   0% /dev
                                        tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                        tmpfs          tmpfs     182M 1016K  181M   1% /run
                                        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                        tmpfs          tmpfs      91M   16K   91M   1% /run/user/1000
                                        Messages in dmesg:
                                        [Sun Apr  2 00:24:32 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bbd52884-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Sun Apr  2 00:24:35 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Sun Apr  2 00:24:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Sun Apr  2 00:24:38 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        2.4G    /var/
                                        1.4G    /var/log
                                        1.3G    /var/log/journal/34cd765a0cf6423881a2b2f74173496c
                                        709M    /var/cache
                                        /opt/iobroker/backups:
                                        23M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        168M    /opt/iobroker/iobroker-data/
                                        133M    /opt/iobroker/iobroker-data/files
                                        51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        48M     /opt/iobroker/iobroker-data/files/telegram.admin
                                        32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                                        7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                                        7.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                        6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
                                        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v18.15.0
                                        /usr/bin/node           v18.15.0
                                        /usr/bin/npm            9.5.0
                                        /usr/bin/npx            9.5.0
                                        nodejs:
                                          Installed: 18.15.0-deb-1nodesource1
                                          Candidate: 18.15.0-deb-1nodesource1
                                          Version table:
                                         *** 18.15.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                             16.19.1-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                             12.22.12~dfsg-1~deb11u3 500
                                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                             12.22.5~dfsg-2~11u1 500
                                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  4.0.24
                                        admin:          6.3.5
                                        javascript:     6.1.4
                                        Adapters from github:   0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : piroadrunner                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.backitup.0               : backitup              : piroadrunner                             -  enabled
                                          system.adapter.discovery.0              : discovery             : piroadrunner                             - disabled
                                        + system.adapter.influxdb.0               : influxdb              : piroadrunner                             -  enabled, port: 8086
                                        + system.adapter.javascript.0             : javascript            : piroadrunner                             -  enabled
                                        + system.adapter.shelly.0                 : shelly                : piroadrunner                             -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonoff.0                 : sonoff                : piroadrunner                             -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.telegram.0               : telegram              : piroadrunner                             -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.vis.0                    : vis                   : piroadrunner                             - disabled
                                          system.adapter.web.0                    : web                   : piroadrunner                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                                        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                                        Objects and States
                                        Objects:        808
                                        States:         716
                                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Hit:6 https://repos.influxdata.com/debian stable InRelease
                                        Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       122557     10344/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123328     10344/iobroker.js-c
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16429      523/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        16458      514/influxd
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       123477     10417/io.sonoff.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       123508     10432/io.shelly.0
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15423      494/cupsd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          16431      523/sshd: /usr/sbin
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15422      494/cupsd
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      117        13746      507/grafana
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       124013     10365/io.admin.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      116        13778      514/influxd
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16453      547/cups-browsed
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12246      353/avahi-daemon: r
                                        udp        0      0 0.0.0.0:35124           0.0.0.0:*                           108        12248      353/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15428      489/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        12247      353/avahi-daemon: r
                                        udp6       0      0 :::46626                :::*                                108        12249      353/avahi-daemon: r
                                        2023-04-02 12:15:17.964  - info: javascript.0 (10395) received all states
                                        2023-04-02 12:15:18.254  - info: javascript.0 (10395) Start javascript script.js.common.Spuelmaschine_fertig
                                        2023-04-02 12:15:18.738  - info: javascript.0 (10395) script.js.common.Spuelmaschine_fertig: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        2023-04-02 12:15:18.789  - info: javascript.0 (10395) Start javascript script.js.Tasmota.Tasmota_reset
                                        2023-04-02 12:15:18.820  - info: javascript.0 (10395) script.js.Tasmota.Tasmota_reset: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        2023-04-02 12:15:18.838  - info: javascript.0 (10395) Start javascript script.js.common.Trockner_fertig
                                        2023-04-02 12:15:18.862  - info: javascript.0 (10395) script.js.common.Trockner_fertig: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        2023-04-02 12:15:18.879  - info: javascript.0 (10395) Start javascript script.js.common.Stehlampe_Ein
                                        2023-04-02 12:15:18.905  - info: javascript.0 (10395) script.js.common.Stehlampe_Ein: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        2023-04-02 12:15:18.908  - info: javascript.0 (10395) Start javascript script.js.common.Wama_Test_1
                                        2023-04-02 12:15:18.940  - info: javascript.0 (10395) script.js.common.Wama_Test_1: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        2023-04-02 12:15:19.697  - info: telegram.0 (10410) starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.15.0, js-controller: 4.0.24
                                        2023-04-02 12:15:21.607  - info: shelly.0 (10432) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.15.0, js-controller: 4.0.24
                                        2023-04-02 12:15:21.894  - info: shelly.0 (10432) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                                        2023-04-02 12:15:24.598  - info: backitup.0 (10451) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.24
                                        2023-04-02 12:15:24.883  - info: backitup.0 (10451) [iobroker] backup was activated at 00:15 every 5 day(s)
                                        2023-04-02 12:15:33.387  - info: shelly.0 (10432) [MQTT] Device with client id "shellyplus1-7c87ce58f3e4" connected!
                                        2023-04-02 12:15:56.934  - info: sonoff.0 (10417) Client [Trockner] connected with secret 1680430556906_941
                                        2023-04-02 12:15:59.187  - info: sonoff.0 (10417) Client [Stehlampe] connected with secret 1680430559183_5922
                                        2023-04-02 12:15:59.995  - info: sonoff.0 (10417) Client [Spühlmaschine] connected with secret 1680430559993_985
                                        2023-04-02 12:16:01.256  - info: sonoff.0 (10417) Client [Max-Zimmer] connected with secret 1680430561254_8812
                                        2023-04-02 12:16:01.545  - info: sonoff.0 (10417) Client [DVES_801B4D] connected with secret 1680430561541_8124
                                        2023-04-02 12:16:03.436  - info: sonoff.0 (10417) Client [Waschmaschine] connected with secret 1680430563432_9878
                                        2023-04-02 12:16:19.056  - info: admin.0 (10365) ==> Connected system.user.admin from ::ffff:192.168.10.101
                                        2023-04-02 12:17:00.981  - info: admin.0 (10365) <== Disconnect system.user.admin from ::ffff:192.168.10.101 admin
                                        Raspberry Pi 3+
                                        • D derroadrunner
                                          Passt das jetzt so?
                                          Skript v.2023-01-02
                                          *** BASE SYSTEM ***
                                          Docker:         false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                          CEST +0200
                                          Europe/Berlin
                                          roadrunner
                                          /home/roadrunner
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M         57M         42M
                                                    909 M total memory
                                                    602 M used memory
                                                    378 M active memory
                                                     92 M free memory
                                                      8 M buffer memory
                                                    206 M swap cache
                                                     99 M total swap
                                                     57 M used swap
                                                     42 M free swap
                                          *** FILESYSTEM ***
                                          Messages in dmesg:
                                          /var:
                                          2.4G    /var/
                                          1.4G    /var/log
                                          709M    /var/cache
                                          /usr/bin/npm            9.5.0
                                          /usr/bin/npx            9.5.0
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          javascript:     6.1.4
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        808
                                          States:         716
                                          Pending Updates: 0
                                          Thomas BraunT
                                          Thomas BraunT
                                          @derroadrunner
                                          Ja, jetzt ist es schön.
                                          33.2k
                                          84.4k
