  4. [Problem] Dream btw. Enigma2 Adapter
739 Beiträge 82 Kommentatoren 326.9k Aufrufe 15 Beobachtet
  • Matten MattenM
    Matten MattenM
    Matten Matten
    #105
    hmmm… bei mir hat er das nicht gemacht.
    bei mir startet der Adapter so:
    enigma2.0	2017-09-08 19:44:53.218	info	starting Polling every 3000 ms
    enigma2.0	2017-09-08 19:44:53.214	info	starting. Version 0.0.3 in E:/Programme/ioBroker/node_modules/iobroker.enigma2, node: v4.5.0
    Non	2017-09-08 19:44:53.017	info	npm module. No package.json
    2017-09-08 19:44:52.508	info	instance system.adapter.enigma2.0 started with pid 9588
    2017-09-08 19:44:50.012	info	instance system.adapter.enigma2.0 terminated with code null ()
    2017-09-08 19:44:50.011	warn	instance system.adapter.enigma2.0 terminated due to SIGTERM
    2017-09-08 19:44:49.997	info	stopInstance system.adapter.enigma2.0 killing pid 2476
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
    • kmxakK
      kmxakK
      kmxak
      #106
      beim deinstallieren:
      host.ioBroker	2017-09-08 19:46:55.688	error	Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/enigma2.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node
      host.ioBroker	2017-09-08 19:46:55.687	error	Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/enigma2/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modul
      iobroker	2017-09-08 19:46:55.254	info	exit 22
      host.ioBroker	2017-09-08 19:46:55.049	info	object deleted system.adapter.enigma2.0
      host.ioBroker	2017-09-08 19:46:55.049	info	object change system.adapter.enigma2.0
      neuer fehler:
      host.ioBroker	2017-09-08 19:47:35.278	info	Restart adapter system.adapter.enigma2.0 because enabled
      host.ioBroker	2017-09-08 19:47:35.277	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
      enigma2.0	2017-09-08 19:47:34.799	error	TypeError: Cannot read property '0' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:240:87) at /opt/iobroker/node_modules/iobroker.enigma2/enigm
      enigma2.0	2017-09-08 19:47:34.799	error	uncaught exception: Cannot read property '0' of undefined
      enigma2.0	2017-09-08 19:47:31.600	info	starting Polling every 3000 ms
      enigma2.0	2017-09-08 19:47:31.593	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v6.11.3
      Non	2017-09-08 19:47:31.344	info	npm module. No package.json
      Gruß Alex
      • Matten MattenM
        Matten MattenM
        Matten Matten
        #107
        kann das an den unterschiedlichen Versionen von Node liegen?
        ich hab node: v4.5.0 und node: v6.11.2
        • Matten MattenM
          Matten MattenM
          Matten Matten
          #108
          ich hab es jetzt auch nochmal auf meinem RPI3 geladen und gestartet. ohne probleme…..
          enigma2.0	2017-09-08 18:06:00.136	info	starting Polling every 3000 ms
          enigma2.0	2017-09-08 18:06:00.110	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v6.11.2
          Non	2017-09-08 18:05:58.869	info	npm module. No package.json
          host.raspberrypi	2017-09-08 18:05:57.037	info	instance system.adapter.enigma2.0 started with pid 19724
          host.raspberrypi	2017-09-08 18:05:55.094	info	instance system.adapter.enigma2.0 terminated with code 0 (OK)
          enigma2.0	2017-09-08 18:05:55.030	info	terminating
          host.raspberrypi	2017-09-08 18:05:54.516	info	stopInstance system.adapter.enigma2.0 killing pid 19712
          host.raspberrypi	2017-09-08 18:05:54.515	info	stopInstance system.adapter.enigma2.0
          Ich habe das sogar mit dream-webIf und mit openweb If getestet.
          da muss ich noch mal genauer schauen.
          • Matten MattenM
            Matten MattenM
            Matten Matten
            #109
            @kmxak:
            so ganz rund läuft es noch nicht. bekomme folgende fehler:
            <code>host.ioBroker	2017-09-08 15:19:28.716	info	Restart adapter system.adapter.enigma2.0 because enabled
            host.ioBroker	2017-09-08 15:19:28.715	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
            enigma2.0	2017-09-08 15:19:28.515	debug	using no authorization
            enigma2.0	2017-09-08 15:19:28.515	debug	creating request for command 'GETCURRENT' (deviceId: 1, host: 192.168.2.55, port: 80, path: '/web/getcurrent')
            enigma2.0	2017-09-08 15:19:28.515	debug	creating request for command 'GETVOLUME' (deviceId: 1, host: 192.168.2.55, port: 80, path: '/web/vol')
            bekommst du die Fehler auch wenn du den vuplus Adapter von "vader722" installierst und startest?</code>
            • kmxakK
              kmxakK
              kmxak
              #110
              Den hatte ich gar nicht installiert bekommen
              Gesendet von meinem SM-G930F mit Tapatalk
              Gruß Alex
              • rantanplanR
                rantanplanR
                rantanplan
                #111
                @kmxak:
                so ganz rund läuft es noch nicht. bekomme folgende fehler: `
                Hallo kmxak
                Bitte den Code-Tag zusätzlich in einen Spoiler-Tag packen.
                Rantanplan
                • DutchmanD
                  DutchmanD
                  Dutchman
                  #112
                  @Matten Matten:
                  ok hab noch was geändert -> https://www.dropbox.com/s/ybu1j2h7490s1 … 2.rar?dl=0
                  Hast du den adapter inzwischen auch auf git gestellt das macht installieren nach aenderungen doch um so einiges leichter :)
                  blicke jetzt nicht ganz durch ob ich dein dropbox pakket nehmen sollte oder den gitlink von vader722 : https://github.com/vader722/ioBroker.vu … its/master
                  ~Dutch
                  • Matten MattenM
                    Matten MattenM
                    Matten Matten
                    #113
                    https://github.com/Matten-Matten/iobroker.enigma2
                    • N
                      N
                      NightWatcher
                      #114
                      Was genau hast du vor? Das, was du dort absetzt, ist eine Nachricht an die VU+.
                      Aber kein Befehl.
                      Möchtest du per Klick auf den Homematic Button den Sender wechseln?
                      Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
                      • Matten MattenM
                        Matten MattenM
                        Matten Matten
                        #115
                        @Matten Matten:
                        hab noch nie was auf github hochgeladen (kein Plan wie) :roll: :?:
                        deshalb den Dropbox Link bitte.
                        https://www.dropbox.com/s/ybu1j2h7490s1 … 2.rar?dl=0 `
                        UPDATE auf Version 0.0.4!!!
                        hab noch ein paar sachen hinzugefügt und die Konfigurationsmaske optimiert.
                        https://www.dropbox.com/s/oklkr9tiem7xh … 2.rar?dl=0
                        • kmxakK
                          kmxakK
                          kmxak
                          #116
                          GIT wäre aber trotzdem am besten aus der DropBox ist das sehr umständlich.
                          Schau mal hier: https://www.youtube.com/playlist?list=P … _0Uy0YLdHW
                          GitHub ist kein Hexenwerk
                          Gruß Alex
                          • Matten MattenM
                            Matten MattenM
                            Matten Matten
                            #117
                            @kmxak:
                            GitHub ist kein Hexenwerk `
                            ok, danke für den link :) das werde ich mir heute Nacht mal reinziehen vielleicht hab ich's ja bis morgen früh auf github.
                            mit freundlichen Grüßen
                            Matze
                            • Matten MattenM
                              Matten MattenM
                              Matten Matten
                              #118
                              • HomoranH
                                #119
                                Guten Morgen ;-)
                                @Matten Matten:
                                vielleicht hab ich's ja bis morgen früh auf github. `
                                Super Arbeit!
                                • G
                                  G
                                  gst666
                                  #120
                                  Konnte den Adapter leider nicht installieren:
                                  $ ./iobroker url "https://github.com/Matten-Matten/iobroker.enigma2"
                                  install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master
                                  npm install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master --production --prefix "/opt/iobroker" (System call)
                                  npm
                                   WARN excluding symbolic link node_modules/request/node_modules/.bin/har-validator -> ../har-validator/bin/har-validatornpm WARN excluding symbolic link node_modules/request/node_modules/.bin/uuid -> ../node-uuid/bin/uuid
                                  npm ERR! Linux 4.4.0-89-genericnpm ERR! argv "/root/.nvm/versions/node/v6.11.0/bin/node" "/root/.nvm/versions/node/v6.11.0/bin/npm" "install" "https://github.com/Matten-Matten/iobroker.enigma2/tarball/master" "--production" "--prefix" "/opt/iobroker"
                                  npm ERR! node v6.11.0
                                  npm ERR! npm  v3.10.10
                                  npm ERR! path /tmp/npm-13415-92695ca7/unpack-1811fc56/package.json
                                  npm ERR! code ENOENT
                                  npm ERR! errno -2
                                  npm ERR! syscall open
                                  npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-13415-92695ca7/unpack-1811fc56/package.json'
                                  npm ERR! enoent This is most likely not a problem with npm itself
                                  npm ERR! enoent and is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR! Please include the following file with any support request:npm
                                  ERR!     /opt/npm-debug.log
                                  ERROR: host.automation Cannot install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master: 254
                                  • Matten MattenM
                                    Matten MattenM
                                    Matten Matten
                                    #121
                                    @gst666:
                                    npm
                                    npm ERR! errno -2
                                    npm ERR! enoent
                                    so hab ich es auch nicht installiert bekommen. deshalb hab ich den ganzen Ordner immer in ioBroker\node_modules eingefügt.
                                    ich hab auch nicht die Programmier Kenntnisse um so ein Fehler zu beheben. sry :(
                                    • N
                                      N
                                      NightWatcher
                                      #122
                                      Es wäre vorteilhafter, wenn du den original Adapter geforked hättest und per push request der eigentliche Entwickler deine Änderungen in den richtigen Adapter einfügt.
                                      Dein Adapter basiert nämlich auf einer alten Version des originals.
                                      • Matten MattenM
                                        Matten MattenM
                                        Matten Matten
                                        #123
                                        @NightWatcher:
                                        Dein Adapter basiert nämlich auf einer alten Version des originals. `
                                        Wie gesagt ich bin eigentlich nur Anwender. Hab lediglich für mich ein paar Veränderungen hinzugefügt und wollte es hier teilen. Hab den Adapter nur für mich in Enigma2 umbenannt, da er ja mit alle Boxen (webif oder openwebif ) funktioniert. Ich hab gesehen, dass du bereits Veränderungen am vuplus Adapter vorgenommen hast, sonst nimm doch alles nützliche aus meinen Veränderungen und füge die dem vuplus Adapter hinzu.
                                        (Hatte den vuplus Adapter nach deinen Veränderungen nochmals versucht übers iobroker.admin webif zu installieren aber ohne erfolg. auch wenn ich den manuell in den Ordner schiebe und hochlade, kann ich zwar den Adapter einrichten und starten, jedoch steigt er gleich mit Fehlermeldung aus und stoppt.)
                                        • N
                                          N
                                          NightWatcher
                                          #124
                                          Okay, dass mein Adapter nen Fehler bringt, ist mir bisher nicht bekannt.
                                          Bei mir läuft er super. Was für ein Fehler kommt denn im Log? Vorher braucht man ja auch noch nicht drüber nachdenken, die beiden Adapter zusammenzulegen, sonst holt man den Fehler ggf. noch mit.
                                          84.2k
