  4. Probleme mit zigbee
Probleme mit zigbee
18 Beiträge 5 Kommentatoren 1.7k Aufrufe 2 Beobachtet
  • Horst BöttcherH Offline
    Horst Böttcher
    schrieb am zuletzt editiert von Horst Böttcher
    Systemdata Bitte Ausfüllen
    Hardwaresystem: PI 4 B / Model : Cortex-A72
    Arbeitsspeicher: 4GB
    Festplattenart: USB Stick 64GB
    Betriebssystem: Bullseye Ligt 64bit
    Node-Version: v16.19.1
    Nodejs-Version: v16.19.1
    NPM-Version: 8.19.3
    Installationsart: Skript
    zigbee.0
    2023-02-28 13:34:23.209	error	Send command to 0xbc33acfffec7fd3f failed with no error code (no response received)
    zigbee.0
    2023-02-28 13:34:23.205	error	Send command to 0xbc33acfffec7fd3f failed with no error code (no response received)
    zigbee.0
    2023-02-28 13:34:07.626	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2407723","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2407723-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
    zigbee.0
    2023-02-28 13:30:04.990	error	No converter available for 'E1525/E1745' with key 'occupancy'
    zigbee.0
    2023-02-28 13:15:31.051	error	Send command to 0xbc33acfffec7fd3f failed with no error code (no response received)
    zigbee.0
    2023-02-28 13:11:28.023	error	Send command to 0xbc33acfffec7fd3f failed with no error code (no response received)
    zigbee.0
    2023-02-28 13:03:54.083	error	Send command to 0xbc33acfffec7fd3f failed with no error code (no response received)
    zigbee.0
    2023-02-28 13:02:02.086	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2407723","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2407723-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • arteckA Offline
      arteckA Offline
      arteck
      oooohhh ahhhh.. Gerät antwortet nicht
      • Horst BöttcherH Horst Böttcher
        NPM-Version: 8.19.3
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        haselchenH Offline
        haselchenH Offline
        haselchen
        @horst-böttcher
        Was @arteck Dir zu sagen versucht ist, ein paar Infos zu Deinem Problem bitte.
        Horst BöttcherH 1 Antwort Letzte Antwort
        • haselchenH haselchen
          @horst-böttcher
          Horst Böttcher
          @haselchen sagte in Probleme mit zigbee:
          @horst-böttcher
          @arteck sagte in Probleme mit zigbee:
          das ist eine gute frage wie bekommt mann das raus
          Folgende Geräte sind an ZigBee
          1c05ee02-592f-43fc-9b1a-0511aacb7052-image.png IKEA TRÅDFRI:
          d0cc0556-a71b-4094-bbd6-43ecad7808be-image.png SILVERCREST Steckerleiste Zigbee Smart Home
          ecde4c0c-708e-4887-a7b3-a34efcfe92eb-image.png Philips Hue Dimmer Switch V2
          und alle sind grün
            @horst-böttcher
            und alle sind grün
            arteckA Offline
            arteckA Offline
            arteck
            @horst-böttcher sagte in Probleme mit zigbee:
            was den für eine Frage ... das war die Antwort auf dein Problem....
            ansonsten die üblichen Verdächtigen .. firmware auf dem conbee aktuell ?? welcher kanal ist eingestellt ?? gibt es WIFI in der nähe was stören konnte
            • arteckA arteck
              Horst Böttcher
              Ja conbee Sick hat aktuelle Firmenware
              Kanal ist 15
              und ja auch der Wlan Router ist in der nähe ca 50 cm
                Kanal ist 15
                arteckA Offline
                arteckA Offline
                arteck
                @horst-böttcher welcher zigbee kanal ?
                wo steckt der conbee drin ?
                • arteckA arteck
                  Horst Böttcher
                  im Pi
                  FabioF 1 Antwort Letzte Antwort
                    im Pi
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    schrieb am zuletzt editiert von Fabio
                    @horst-böttcher evtl. hift das weiter https://phoscon.de/de/support#conbee2-connection-issues ansonsten kann auch ein aktiver USB Port da helfen.
                    Iobroker:
                    • Matter over Thread Hilfe
                    • FabioF Fabio
                      frajop
                      @fa-bio sagte in Probleme mit zigbee:
                      @horst-böttcher evtl. hift das weiter https://phoscon.de/de/support#conbee2-connection-issues iver USB Port da helfen.
                      DAS hat bei mir geholfen. Seither läuft zigbee total stabil
                      • F frajop
                        Horst Böttcher
                        naja dem ich das System neu aufgesetzt habe
                        Wird der Stick gefunden Toll :-)
                        doch wenn ich koppeln will läuft keine Zeit ab es steht nur da Pairing started
                        ist es möglich das der Stick schrott ist oder würde dann nix gehen
                        das sagt der Log
                        zigbee.0
                        2023-03-08 20:58:42.652	info	Zigbee: allowing new devices to join.
                        zigbee.0
                        2023-03-08 20:57:51.248	info	Zigbee started
                        zigbee.0
                        2023-03-08 20:57:51.247	info	Currently no devices.
                        zigbee.0
                        2023-03-08 20:57:51.244	info	Unable to set transmit power, unsupported function.
                        zigbee.0
                        2023-03-08 20:57:51.083	info	--> transmitPower : low
                        zigbee.0
                        2023-03-08 20:57:51.033	info	Unable to disable LED, unsupported function.
                        zigbee.0
                        2023-03-08 20:57:47.988	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                        zigbee.0
                        2023-03-08 20:57:47.956	info	Installed Version: iobroker.zigbee@1.8.10
                        zigbee.0
                        2023-03-08 20:57:47.296	info	Starting Zigbee npm ...
                        zigbee.0
                        2023-03-08 20:57:47.293	info	delete old Backup files. keep only last 10
                        zigbee.0
                        2023-03-08 20:57:47.157	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                        zigbee.0
                        2023-03-08 20:57:39.632	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        zigbee.0
                        2023-03-08 20:57:39.630	info	terminating
                        zigbee.0
                        2023-03-08 20:57:39.132	info	Zigbee: disabling joining new devices.
                        zigbee.0
                        2023-03-08 20:57:39.130	info	cleaned everything up...
                        zigbee.0
                        2023-03-08 20:57:39.128	info	Got terminate signal TERMINATE_YOURSELF
                          das sagt der Log
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          @horst-böttcher versuche das anlernen über die Phoscon App. Hast du den Stick am USB Port verlängert wie ich dir das emphohlen habe?
                          Iobroker:
                          • FabioF Fabio
                            Horst Böttcher
                            hab jetzt 2 Pi an laufen
                            einmal mit und einmal ohne Deconz app der stick würd jedes mal erkannt
                            findet aber keine Lampen
                            versuche gerade den stick zurückzusetzen über die conbeeapp
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              @horst-böttcher noch mal zum letzten mal frage ich das jetzt:
                              Iobroker:
                              • FabioF Fabio
                                Horst Böttcher
                                @fa-bio ja habe ich
                                ich habe auch schon kontakt mit dem decoz support
                                wir haben die firemware neu eingespielt und suchen weiter nach einer lösung
                                  @fa-bio ja habe ich
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  @horst-böttcher super das freut mich, halt uns auf dem laufenden wenn es dann klappt. Mich würde das sehr interessieren warum du nichts anlernen kannst.
                                  Was du evtl. noch probieren kannst ein neues Orginal Netzteil für den Raspi falls du keins hast und einen aktiven USB HUB wo du dann den Stick reinsteckst.
                                  Fabio
                                  Iobroker:
                                  • FabioF Fabio
                                    Fabio
                                    Horst Böttcher
                                    Fabio
                                    habe bereits ein orginal netzteil bestellt ich hoffe das es dann besser wird
                                      Fabio
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      @horst-böttcher bin gespannt. 👍
                                      Iobroker:
                                      82.9k
