Test Adapter zigbee2mqtt
@IdleBit Nach Update auf Zigbee2mqtt 1.30.0 (Docker MACVLAN) bekomme ich diese Fehler. Nehme ich wieder den Docker mit 1.29.2, keine Probleme.
Adapter Version ist die 2.7.2.
Gerade im Docker, da das Verzeichnis gleich bleibt, sollte sich da ja eigentlich nichts relevantes ändern, oder? Oder gibt es da einen Fehler im Image?zigbee2mqtt.0 2023-02-06 13:48:24.993 warn Start try again in 1 seconds... zigbee2mqtt.0 2023-02-06 13:48:24.937 error Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-06 13:48:24.937 error TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22) zigbee2mqtt.0 2023-02-06 13:48:24.936 error unhandled promise rejection: Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-06 13:48:24.936 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee2mqtt.0 2023-02-06 13:47:52.296 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee2mqtt.0 2023-02-06 13:47:51.929 warn Start try again in 1 seconds... zigbee2mqtt.0 2023-02-06 13:47:51.862 error Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-06 13:47:51.861 error TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22) zigbee2mqtt.0 2023-02-06 13:47:51.860 error unhandled promise rejection: Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-06 13:47:51.860 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee2mqtt.0 2023-02-06 13:47:19.522 error DB closed zigbee2mqtt.0 2023-02-06 13:47:19.521 error Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12) zigbee2mqtt.0 2023-02-06 13:47:19.521 error unhandled promise rejection: DB closed zigbee2mqtt.0 2023-02-06 13:47:19.521 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee2mqtt.0 2023-02-06 13:47:19.517 warn get state error: Connection is closed. zigbee2mqtt.0 2023-02-06 13:47:19.511 warn redis get zigbee2mqtt.0.group_905.brightness_move, error - Connection is closed. zigbee2mqtt.0 2023-02-06 13:47:19.006 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee2mqtt.0 2023-02-06 13:47:18.318 warn Start try again in 1 seconds... -
@toralt
Ich hatte auch Zigbee2mqtt1.30.0und nun1.30.1beides ebenfalls in Docker MACVLAN und habe keine Probleme, ich denke da hast du was im Argen in deiner Docker Umgebung. -
@toralt
Ich hatte auch Zigbee2mqtt1.30.0und nun1.30.1beides ebenfalls in Docker MACVLAN und habe keine Probleme, ich denke da hast du was im Argen in deiner Docker Umgebung.@idlebit Also Zigbee2mqtt 1.30.1 im Docker läuft problemlos. Ich kann alle meine Geräte via Weboberfläche steuern, der mqtt client adapter im ioBroker kann sich auch verbinden. Irgendwas scheint in der neuen Version anders zu sein was die Fehler verursacht wenn der Zigbee2mqtt Adapter sich zu verbinden versucht.
@idlebit Ich weiß ich nerve :) Bei dem Roborock-Adapter, der scheinbar auch via MQTT kommuniziert, hatte ein user auch diese seltsamen Fehlermeldungen, da wurde scheinbar was am Adapter angepasst. Da ich nun leider absolut keinen Dunst davon habe, was da eigentlich schief läuft, kann ich auch nicht deuten ob das jetzt 100% das gleiche Problem ist.
@toralt Mein Adapter abreitet über Websocket, MQTT ist nur Experimentell und nicht voll getestet!
Also wenn Du MQTT nutzten solltest stell das erstmal um. -
Ach so! Ich dachte Dein Adapter wertet die mqtt msgs aus um die Datenpunkte zu erzeugen. Also kommuniziert er direkt mit zigbee2mqtt und "sendet" bei Änderungen an den Datenpunkten diese per mqtt?
@idlebit
Guten Morgen,
ich will auf zigbee2mqtt umsteigen habe Folgendes Problem mit dem Aqara presence detector FP1 RTCZCGQ11LM in Verbindung mit dem zigbee2mqtt Adapter.
Bei Z2M bekomme ich folgende Warnung nach/während dem Koppeln.warning 2023-02-18 10:22:24zigbee-herdsman-converters:xiaomi:aqara_fp1: Unknown key 0x010c = 3Iobroker Protokoll:
host.AndCom 2023-02-18 10:23:39.276 info "system.adapter.zigbee2mqtt.0" disabled host.AndCom 2023-02-18 10:23:30.137 warn Do not restart adapter system.adapter.zigbee2mqtt.0 because restart loop detected host.AndCom 2023-02-18 10:23:30.137 info Restart adapter system.adapter.zigbee2mqtt.0 because enabled host.AndCom 2023-02-18 10:23:30.136 error instance system.adapter.zigbee2mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION) zigbee2mqtt.0 2023-02-18 10:23:29.580 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee2mqtt.0 2023-02-18 10:23:29.579 info terminating zigbee2mqtt.0 2023-02-18 10:23:29.568 warn Start try again in 1 seconds... zigbee2mqtt.0 2023-02-18 10:23:29.546 error Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-18 10:23:29.546 error TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22) zigbee2mqtt.0 2023-02-18 10:23:29.544 error unhandled promise rejection: Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-18 10:23:29.544 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().Der Z2M Adapter wird Rot, wenn ich den FP1 lösche, dann wird die Instanz wieder Grün.
Fehler tritt mit Conbee2 und Zonoff Stick auf.
Bitte um Hilfe, sonst lohnt sich der umstieg für mich nicht, habe mehrere FP1 im einsatz. -
@idlebit
Guten Morgen,
Bitte um Hilfe, sonst lohnt sich der umstieg für mich nicht, habe mehrere FP1 im einsatz.Ich bin grad unterwegs, daher nur kurz und knapp.
warning 2023-02-18 10:22:24zigbee-herdsman-converters:xiaomi:aqara_fp1: Unknown key 0x010c = 3Hier kann ich so grundsätzlich nicht viel machen und muss auf zigbee2mqtt verweisen.
Aber das der Adapter dann abstürzt ist nicht ok und das werde ich mir natürlich ansehen.
@andre hattest du nicht auch den FP1 im Einsatz?
@idlebit
Guten Morgen,
Bitte um Hilfe, sonst lohnt sich der umstieg für mich nicht, habe mehrere FP1 im einsatz.@aragon sagte in Test Adapter zigbee2mqtt:
aqara_fp1
der hat noch ein paar probleme .. hab ich gerade festgestellt.. musst du abwarten
@idlebit sagte in Test Adapter zigbee2mqtt:
Ich hab den auch im Einsatz. Pairing war problemlos. Meldungen im Log habe ich nicht. Coordinator ist ein Sonoff ZBDongle-E.
Derzeit verwende ich nur den Datenpunkt "presence" über verschiedene scripte. Das tut zuverlässig, sonst hätte ich schon Probleme mit der Frau... ;)[EDIT] Mal bei zigbee2mqtt geschaut? Da scheint es Einschränkungen zu geben was Zigbee Channel und Firmware angeht...
https://www.zigbee2mqtt.io/devices/RTCZCGQ11LM.htmlMfG,
André -
André -
@andre ne du der macht allgemein noch probleme...
da werden nicht alle exposes gezogen... hab mal ein Fix auf Github gestellt -
@aragon Kannst du mal aus dem Git installieren?
Jetzt sollte maximal "nur" noch ein Warning auftauchen, und wenn du auf Debug stellst sollte es noch mehr Infos über das Problem kommen...Könntest Du mir die mal zu Verfügung stellen?
@toralt das könnte auch mit deinen Problem zusammenhängen also nen Versuch wert ;)
@idlebit
Ich hoffe ich habe alles richtig gemacht.
Hier die aktuelle Ausgabe im Protokoll. Die Instanz wird Rot.host.AndCom 2023-02-18 14:27:49.105 info "system.adapter.zigbee2mqtt.0" disabled host.AndCom 2023-02-18 14:27:42.918 info Restart adapter system.adapter.zigbee2mqtt.0 because enabled host.AndCom 2023-02-18 14:27:42.917 error instance system.adapter.zigbee2mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION) mqtt.0 2023-02-18 14:27:42.457 info Server: Changed type of "mqtt.0.zigbee2mqtt.0x54ef4410006492a3" from "number" to "string" zigbee2mqtt.0 2023-02-18 14:27:42.360 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee2mqtt.0 2023-02-18 14:27:42.358 info terminating zigbee2mqtt.0 2023-02-18 14:27:42.350 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } zigbee2mqtt.0 2023-02-18 14:27:42.318 warn Start try again in 1 seconds... zigbee2mqtt.0 2023-02-18 14:27:42.304 debug Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } zigbee2mqtt.0 2023-02-18 14:27:42.291 error Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-18 14:27:42.290 error TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22) zigbee2mqtt.0 2023-02-18 14:27:42.289 error unhandled promise rejection: Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-18 14:27:42.288 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee2mqtt.0 2023-02-18 14:27:42.287 info MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","status":"started"},"type":"device_interview"}' zigbee2mqtt.0 2023-02-18 14:27:42.272 info Starting interview of '0x54ef4410006492a3' zigbee2mqtt.0 2023-02-18 14:27:42.270 info MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}' zigbee2mqtt.0 2023-02-18 14:27:42.264 error Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-18 14:27:42.264 error TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22) zigbee2mqtt.0 2023-02-18 14:27:42.261 error unhandled promise rejection: Cannot set properties of undefined (setting 'prop') zigbee2mqtt.0 2023-02-18 14:27:42.260 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee2mqtt.0 2023-02-18 14:27:42.234 info Device '0x54ef4410006492a3' joined zigbee2mqtt.0 2023-02-18 14:27:29.384 info MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"1t5n7-4"}' -
@idlebit
@idlebit
Instanz entfernt
Expertenmodus eingeschaltet
auf die Katze geklickt
dann von Github geklickt
Adapter aus Liste ausgesucht und installiert
Anschließend Adapter installiert
