  4. Test Adapter zigbee2mqtt
    2.6k
    4.6k
    4.0k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 196.3k Aufrufe 45 Beobachtet
  • T toralt
    @IdleBit Nach Update auf Zigbee2mqtt 1.30.0 (Docker MACVLAN) bekomme ich diese Fehler. Nehme ich wieder den Docker mit 1.29.2, keine Probleme.
    Adapter Version ist die 2.7.2.
    Gerade im Docker, da das Verzeichnis gleich bleibt, sollte sich da ja eigentlich nichts relevantes ändern, oder? Oder gibt es da einen Fehler im Image?
    zigbee2mqtt.0
    2023-02-06 13:48:24.993	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2023-02-06 13:48:24.937	error	Cannot set properties of undefined (setting 'prop')
    zigbee2mqtt.0
    2023-02-06 13:48:24.937	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
    zigbee2mqtt.0
    2023-02-06 13:48:24.936	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
    zigbee2mqtt.0
    2023-02-06 13:48:24.936	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee2mqtt.0
    2023-02-06 13:47:52.296	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee2mqtt.0
    2023-02-06 13:47:51.929	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2023-02-06 13:47:51.862	error	Cannot set properties of undefined (setting 'prop')
    zigbee2mqtt.0
    2023-02-06 13:47:51.861	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
    zigbee2mqtt.0
    2023-02-06 13:47:51.860	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
    zigbee2mqtt.0
    2023-02-06 13:47:51.860	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee2mqtt.0
    2023-02-06 13:47:19.522	error	DB closed
    zigbee2mqtt.0
    2023-02-06 13:47:19.521	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    zigbee2mqtt.0
    2023-02-06 13:47:19.521	error	unhandled promise rejection: DB closed
    zigbee2mqtt.0
    2023-02-06 13:47:19.521	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee2mqtt.0
    2023-02-06 13:47:19.517	warn	get state error: Connection is closed.
    zigbee2mqtt.0
    2023-02-06 13:47:19.511	warn	redis get zigbee2mqtt.0.group_905.brightness_move, error - Connection is closed.
    zigbee2mqtt.0
    2023-02-06 13:47:19.006	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee2mqtt.0
    2023-02-06 13:47:18.318	warn	Start try again in 1 seconds...
    IdleBitI Offline
    IdleBitI Offline
    IdleBit
    schrieb am zuletzt editiert von IdleBit
    #303
    @toralt
    Ich hatte auch Zigbee2mqtt 1.30.0 und nun 1.30.1 beides ebenfalls in Docker MACVLAN und habe keine Probleme, ich denke da hast du was im Argen in deiner Docker Umgebung.
    T 2 Antworten Letzte Antwort
    • IdleBitI IdleBit
      @toralt
      T Nicht stören
      T Nicht stören
      toralt
      #304
      @idlebit Ich habe auch die Befürchtung, aber ich verstehe nicht, was da nicht stimmt, da ja der Ordner gleich bleibt. Seltsam. Aber wenn es bei Dir läuft weiß ich immerhin das es gehen muss. Ich suche mal weiter.
      Danke Dir!
      << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
      • IdleBitI IdleBit
        @toralt
        T Nicht stören
        T Nicht stören
        toralt
        #305
        @idlebit Also Zigbee2mqtt 1.30.1 im Docker läuft problemlos. Ich kann alle meine Geräte via Weboberfläche steuern, der mqtt client adapter im ioBroker kann sich auch verbinden. Irgendwas scheint in der neuen Version anders zu sein was die Fehler verursacht wenn der Zigbee2mqtt Adapter sich zu verbinden versucht.
        • T Nicht stören
          T Nicht stören
          toralt
          #306
          @idlebit Ich weiß ich nerve :) Bei dem Roborock-Adapter, der scheinbar auch via MQTT kommuniziert, hatte ein user auch diese seltsamen Fehlermeldungen, da wurde scheinbar was am Adapter angepasst. Da ich nun leider absolut keinen Dunst davon habe, was da eigentlich schief läuft, kann ich auch nicht deuten ob das jetzt 100% das gleiche Problem ist.
          https://github.com/copystring/ioBroker.roborock/issues/27
          IdleBitI 1 Antwort Letzte Antwort
          • T toralt
            IdleBitI Offline
            IdleBitI Offline
            IdleBit
            #307
            @toralt Mein Adapter abreitet über Websocket, MQTT ist nur Experimentell und nicht voll getestet!
            Also wenn Du MQTT nutzten solltest stell das erstmal um.
            • IdleBitI IdleBit
              T Nicht stören
              T Nicht stören
              toralt
              #308
              @idlebit nope, bin auf websocket, ganz nach Empfehlung.
              • NoosiN Noosi
                Ach so! Ich dachte Dein Adapter wertet die mqtt msgs aus um die Datenpunkte zu erzeugen. Also kommuniziert er direkt mit zigbee2mqtt und "sendet" bei Änderungen an den Datenpunkten diese per mqtt?
                Aragon
                schrieb am zuletzt editiert von Aragon
                #309
                @idlebit
                Guten Morgen,
                ich will auf zigbee2mqtt umsteigen habe Folgendes Problem mit dem Aqara presence detector FP1 RTCZCGQ11LM in Verbindung mit dem zigbee2mqtt Adapter.
                Bei Z2M bekomme ich folgende Warnung nach/während dem Koppeln.
                warning 2023-02-18 10:22:24zigbee-herdsman-converters:xiaomi:aqara_fp1: Unknown key 0x010c = 3
                Iobroker Protokoll:
                host.AndCom
                	2023-02-18 10:23:39.276	info	"system.adapter.zigbee2mqtt.0" disabled
                host.AndCom
                	2023-02-18 10:23:30.137	warn	Do not restart adapter system.adapter.zigbee2mqtt.0 because restart loop detected
                host.AndCom
                	2023-02-18 10:23:30.137	info	Restart adapter system.adapter.zigbee2mqtt.0 because enabled
                host.AndCom
                	2023-02-18 10:23:30.136	error	instance system.adapter.zigbee2mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                zigbee2mqtt.0
                	2023-02-18 10:23:29.580	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee2mqtt.0
                	2023-02-18 10:23:29.579	info	terminating
                zigbee2mqtt.0
                	2023-02-18 10:23:29.568	warn	Start try again in 1 seconds...
                zigbee2mqtt.0
                	2023-02-18 10:23:29.546	error	Cannot set properties of undefined (setting 'prop')
                zigbee2mqtt.0
                	2023-02-18 10:23:29.546	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
                zigbee2mqtt.0
                	2023-02-18 10:23:29.544	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
                zigbee2mqtt.0
                	2023-02-18 10:23:29.544	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                Der Z2M Adapter wird Rot, wenn ich den FP1 lösche, dann wird die Instanz wieder Grün.
                Fehler tritt mit Conbee2 und Zonoff Stick auf.
                Bitte um Hilfe, sonst lohnt sich der umstieg für mich nicht, habe mehrere FP1 im einsatz.
                IdleBitI arteckA 2 Antworten Letzte Antwort
                • A Aragon
                  @idlebit
                  Guten Morgen,
                  Iobroker Protokoll:
                  host.AndCom
                  host.AndCom
                  host.AndCom
                  host.AndCom
                  zigbee2mqtt.0
                  zigbee2mqtt.0
                  zigbee2mqtt.0
                  zigbee2mqtt.0
                  zigbee2mqtt.0
                  zigbee2mqtt.0
                  zigbee2mqtt.0
                  IdleBitI Offline
                  IdleBitI Offline
                  IdleBit
                  #310
                  @aragon
                  Ich bin grad unterwegs, daher nur kurz und knapp.
                  Hier kann ich so grundsätzlich nicht viel machen und muss auf zigbee2mqtt verweisen.
                  Aber das der Adapter dann abstürzt ist nicht ok und das werde ich mir natürlich ansehen.
                  @andre hattest du nicht auch den FP1 im Einsatz?
                  A andreA 2 Antworten Letzte Antwort
                  • IdleBitI IdleBit
                    @aragon
                    Aragon
                    #311
                    @idlebit Vielen Dank für die schnelle Antwort und deine Mühe
                    • A Aragon
                      @idlebit
                      Guten Morgen,
                      Iobroker Protokoll:
                      host.AndCom
                      host.AndCom
                      host.AndCom
                      host.AndCom
                      zigbee2mqtt.0
                      zigbee2mqtt.0
                      zigbee2mqtt.0
                      zigbee2mqtt.0
                      zigbee2mqtt.0
                      zigbee2mqtt.0
                      zigbee2mqtt.0
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #312
                      @aragon sagte in Test Adapter zigbee2mqtt:
                      aqara_fp1
                      der hat noch ein paar probleme .. hab ich gerade festgestellt.. musst du abwarten
                      • IdleBitI IdleBit
                        @aragon
                        andreA Offline
                        andreA Offline
                        andre
                        schrieb am zuletzt editiert von andre
                        #313
                        @idlebit sagte in Test Adapter zigbee2mqtt:
                        Ich hab den auch im Einsatz. Pairing war problemlos. Meldungen im Log habe ich nicht. Coordinator ist ein Sonoff ZBDongle-E.
                        Derzeit verwende ich nur den Datenpunkt "presence" über verschiedene scripte. Das tut zuverlässig, sonst hätte ich schon Probleme mit der Frau... ;)
                        [EDIT] Mal bei zigbee2mqtt geschaut? Da scheint es Einschränkungen zu geben was Zigbee Channel und Firmware angeht...
                        https://www.zigbee2mqtt.io/devices/RTCZCGQ11LM.html
                        MfG,
                        André
                        • andreA andre
                          MfG,
                          André
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #314
                          @andre ne du der macht allgemein noch probleme...
                          da werden nicht alle exposes gezogen... hab mal ein Fix auf Github gestellt
                          • arteckA arteck
                            IdleBitI Offline
                            IdleBitI Offline
                            IdleBit
                            #315
                            @arteck Hast mal nen Link für mich?
                            • A Aragon
                              IdleBitI Offline
                              IdleBitI Offline
                              IdleBit
                              #316
                              @aragon Kannst du mal aus dem Git installieren?
                              Jetzt sollte maximal "nur" noch ein Warning auftauchen, und wenn du auf Debug stellst sollte es noch mehr Infos über das Problem kommen...
                              Könntest Du mir die mal zu Verfügung stellen?
                              @toralt das könnte auch mit deinen Problem zusammenhängen also nen Versuch wert ;)
                              • IdleBitI IdleBit
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #317
                                @idlebit schau dir die exposes an
                                https://github.com/Koenkk/zigbee-herdsman-converters/blob/7e504f2e80beaf25b19372c3ea41585db5b9c1af/devices/xiaomi.js#L1770
                                • arteckA arteck
                                  Aragon
                                  #318
                                  @idlebit
                                  Ich hoffe ich habe alles richtig gemacht.
                                  Hier die aktuelle Ausgabe im Protokoll. Die Instanz wird Rot.
                                  host.AndCom
                                  	2023-02-18 14:27:49.105	info	"system.adapter.zigbee2mqtt.0" disabled
                                  host.AndCom
                                  	2023-02-18 14:27:42.918	info	Restart adapter system.adapter.zigbee2mqtt.0 because enabled
                                  host.AndCom
                                  	2023-02-18 14:27:42.917	error	instance system.adapter.zigbee2mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  mqtt.0
                                  	2023-02-18 14:27:42.457	info	Server: Changed type of "mqtt.0.zigbee2mqtt.0x54ef4410006492a3" from "number" to "string"
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.360	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.358	info	terminating
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.350	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.318	warn	Start try again in 1 seconds...
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.304	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.291	error	Cannot set properties of undefined (setting 'prop')
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.290	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.289	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.288	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.287	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","status":"started"},"type":"device_interview"}'
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.272	info	Starting interview of '0x54ef4410006492a3'
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.270	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}'
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.264	error	Cannot set properties of undefined (setting 'prop')
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.264	error	TypeError: Cannot set properties of undefined (setting 'prop') at createDeviceFromExposes (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/exposes.js:970:29) at DeviceController.createDeviceDefinitions (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/lib/deviceController.js:30:39) at Zigbee2mqtt.messageParse (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:154:40) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee2mqtt/main.js:125:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1180:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:541:14) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:459:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:158:22)
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.261	error	unhandled promise rejection: Cannot set properties of undefined (setting 'prop')
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.260	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:42.234	info	Device '0x54ef4410006492a3' joined
                                  zigbee2mqtt.0
                                  	2023-02-18 14:27:29.384	info	MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"1t5n7-4"}'
                                  • A Aragon
                                    @idlebit
                                    host.AndCom
                                    host.AndCom
                                    host.AndCom
                                    mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    zigbee2mqtt.0
                                    IdleBitI Offline
                                    IdleBitI Offline
                                    IdleBit
                                    #319
                                    Das scheint aber nicht die aktuelle Version vom git zu sein.
                                    Wie bist du vorgegangen?
                                    • IdleBitI IdleBit
                                      Aragon
                                      #320
                                      @idlebit
                                      Instanz entfernt
                                      Expertenmodus eingeschaltet
                                      auf die Katze geklickt
                                      dann von Github geklickt
                                      Adapter aus Liste ausgesucht und installiert
                                      Anschließend Adapter installiert
                                      • A Aragon
                                        @idlebit
                                        Instanz entfernt
                                        IdleBitI Offline
                                        IdleBitI Offline
                                        IdleBit
                                        #321
                                        @aragon Entfernen musst du nichts, aber der Rest passt .. komisch ich prüfe ..
                                        • IdleBitI IdleBit
                                          Aragon
                                          #322
                                          @idlebit
                                          Mein Fehler hatte in den Einstellungen unter Repositories auf Beta stehen, umgestellt auf Stable.
                                          Jetzt siehts anders aus, Instanz bleibt GRÜN.
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.474	debug	{"date_code":"20210121","definition":{"description":"Aqara presence detector FP1","exposes":[{"access":5,"description":"Indicates whether the device detected presence","name":"presence","property":"presence","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Temperature of the device","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Number of power outages (since last pairing)","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"description":"Presence events: \"enter\", \"leave\", \"left_enter\", \"right_leave\", \"right_enter\", \"left_leave\", \"approach\", \"away\"","name":"presence_event","property":"presence_event","type":"enum","values":["enter","leave","left_enter","right_leave","right_enter","left_leave","approach","away"]},{"access":7,"description":"Monitoring mode with or without considering right and left sides","name":"monitoring_mode","property":"monitoring_mode","type":"enum","values":["undirected","left_right"]},{"access":7,"description":"The distance at which the sensor detects approaching","name":"approach_distance","property":"approach_distance","type":"enum","values":["far","medium","near"]},{"access":7,"description":"Different sensitivities means different static human body recognition rate and response speed of occupied","name":"motion_sensitivity","property":"motion_sensitivity","type":"enum","values":["low","medium","high"]},{"access":2,"description":"Reset the status of no presence","name":"reset_nopresence_status","property":"reset_nopresence_status","type":"enum","values":[""]},{"access":1,"description":"Most recent region event. Event template is \"region_<REGION_ID>_<EVENT_TYPE>\", where <REGION_ID> is region number (1-10), <EVENT_TYPE> is one of \"enter\", \"leave\", \"occupied\", \"unoccupied\". \"enter\" / \"leave\" events are usually triggered first, followed by \"occupied\" / \"unoccupied\" after a couple of seconds.","name":"action","property":"action","type":"enum","values":["region_*_enter","region_*_leave","region_*_occupied","region_*_unoccupied"]},{"access":2,"description":"Definition of a new region to be added (or replace existing one). Creating or modifying a region requires you to define which zones of a 7x4 detection grid should be active for that zone. Regions can overlap, meaning that a zone can be defined in more than one region (eg. \"zone x = 1 & y = 1\" can be added to region 1 & 2). \"Zone x = 1 & y = 1\" is the nearest zone on the right (from sensor's perspective, along the detection path).","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1},{"access":2,"item_type":{"features":[{"access":2,"name":"x","property":"x","type":"numeric","value_max":4,"value_min":1},{"access":2,"name":"y","property":"y","type":"numeric","value_max":7,"value_min":1}],"name":"zone_position","type":"composite"},"name":"zones","property":"zones","type":"list"}],"name":"region_upsert","property":"region_upsert","type":"composite"},{"access":2,"description":"Region definition to be deleted from the device.","features":[{"access":2,"name":"region_id","property":"region_id","type":"numeric","value_max":10,"value_min":1}],"name":"region_delete","property":"region_delete","type":"composite"},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"RTCZCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":true,"vendor":"Xiaomi"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","aqaraOpple"],"output":["genIdentify","genOta"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3","interview_completed":false,"interviewing":false,"manufacturer":"aqara","model_id":"lumi.motion.ac01","network_address":58871,"power_source":"DC Source","software_build_id":"","supported":true,"type":"EndDevice"}
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.473	warn	Cannot 0x54ef4410006492a3 create Device from Exposes!
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.464	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.463	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                          zigbee2mqtt.0
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.462	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                          zigbee2mqtt.0
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.461	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                          zigbee2mqtt.0
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.460	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                          zigbee2mqtt.0
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.459	debug	Device: 0x54ef4410006492a3 not found, queue state in incStatsQueue!
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.445	info	Starting interview of '0x54ef4410006492a3'
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.433	info	MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef4410006492a3","ieee_address":"0x54ef4410006492a3"},"type":"device_joined"}'
                                          zigbee2mqtt.0
                                          	2023-02-18 14:53:17.428	debug	TypeError: Cannot set properties of undefined (setting 'prop')
