  3. Entwicklung
  4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
lgtv
861 Beiträge 113 Kommentatoren 487.5k Aufrufe 69 Beobachtet
  • R roesthod
    @sigi234 Hallo, Ich habe genau das gleich Problem. Das Errorlog sieht wie folgt aus:
    2023-01-28 13:56:39.791 - debug: lgtv.0 (1414) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-01-28 13:56:39.841 - debug: lgtv.0 (1414) Objects client ready ... initialize now
    2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create System PubSub Client
    2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create User PubSub Client
    2023-01-28 13:56:39.958 - debug: lgtv.0 (1414) Objects client initialize lua scripts
    2023-01-28 13:56:39.963 - debug: lgtv.0 (1414) Objects connected to redis: 127.0.0.1:9001
    2023-01-28 13:56:39.964 - silly: lgtv.0 (1414) redis psubscribe cfg.o.system.user.*
    2023-01-28 13:56:40.001 - silly: lgtv.0 (1414) redis psubscribe cfg.o.enum.*
    2023-01-28 13:56:40.004 - silly: lgtv.0 (1414) objectDB connected
    2023-01-28 13:56:40.005 - debug: lgtv.0 (1414) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-01-28 13:56:40.033 - debug: lgtv.0 (1414) States create System PubSub Client
    2023-01-28 13:56:40.034 - debug: lgtv.0 (1414) States create User PubSub Client
    2023-01-28 13:56:40.090 - debug: lgtv.0 (1414) States connected to redis: 127.0.0.1:9000
    2023-01-28 13:56:40.090 - silly: lgtv.0 (1414) statesDB connected
    2023-01-28 13:56:40.474 - info: lgtv.0 (1414) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v16.14.0, js-controller: 4.0.23
    2023-01-28 13:56:40.496 - info: lgtv.0 (1414) Ready. Configured WebOS TV IP: 192.168.1.236
    2023-01-28 13:56:40.497 - debug: lgtv.0 (1414) adapter.config = {"ip":"192.168.1.236","mac":"XX:XX:XX:XX:37:6B","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
    2023-01-28 13:56:40.508 - silly: lgtv.0 (1414) States system redis pmessage system.adapter.lgtv.0.logLevel/system.adapter.lgtv.0.logLevel:{"val":"silly","ack":true,"ts":1674910600499,"q":0,"from":"system.adapter.lgtv.0","lc":1674910600499}
    2023-01-28 13:56:40.516 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
    2023-01-28 13:56:40.523 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: socket hang up
    2023-01-28 13:56:45.523 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
    2023-01-28 13:56:45.526 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: read ECONNRESET
    sigi234S
    sigi234S
    #832
    @roesthod
    IP Richtig? Kannst du den TV via Ping erreichen?
    R 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @roesthod
      R
      R
      roesthod
      #833
      @sigi234 IP ist richtig und ich habe das System jetzt auf den aktuellen Stand gebracht.
      • R roesthod
        R
        R
        roesthod
        #834
        @roesthod Ich habe übrigends zwei von den LG's und beide mit dem identischen Fehlerbild...
        • R roesthod
          sigi234S
          sigi234S
          #835
          @roesthod sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
          Alle mit WLAN verbunden?
          Hatte auch Probleme, mit LAN hat es dann mal nach 20 versuchen funktioniert.
          https://github.com/SebastianSchultz/ioBroker.lgtv/issues/123
          • sigi234S sigi234
            D
            D
            dirkhe
            #836
            @sigi234 Da s sieht wirklich so aus, als wenn der Adapter angepasst werden muss. Ist halt auch schwierig rauszubekommen, welcher TV dann ws und welcher wss braucht. Zur Not müsste man es einstellbar machen..
            • D dirkhe
              R
              R
              roesthod
              #837
              @dirkhe TV's sind über LAN eingebunden...
              • R roesthod
                D
                D
                dirkhe
                #838
                @roesthod das hat mit wlan und lan wahrscheinlich nicht viel zu tun, eher das die mi der neueren firmware ein anderen websocket nutzen, wie in dem issue auf github beschrieben
                • D dirkhe
                  M
                  M
                  michael_4358
                  #839
                  @dirkhe said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                  Meinst du das die .js gelöscht werden muss❓
                  Konnte das wer das Problem schon lösen?
                  • M michael_4358
                    D
                    D
                    dirkhe
                    #840
                    @michael_4358 Schau mal in der oben verlinkten issue, da steht am Ende ein workaround drin, bis zur neuen Version
                    • D dirkhe
                      M
                      M
                      michael_4358
                      #841
                      Das meinte ich 😃 gut wenn es funzt
                      • liv-in-skyL
                        liv-in-skyL
                        #842
                        @dirkhe
                        also ist es im moment nicht ratsam, dem update auf dem lg zuzustimmen ? und lieber warten, bis eine neue adapter version kommt
                        • liv-in-skyL liv-in-sky
                          @dirkhe
                          NashraN
                          NashraN
                          Nashra
                          Most Active Forum Testing
                          #843
                          @liv-in-sky sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                          @dirkhe
                          Tja, nur wenn man einen neuen LG gekauft hat (gestern) mit aktuellstem WebOS will gar nichts mehr :-(
                          Also den workearound durchgeführt und dann klappt es auch teilweise mit dem Neuen.
                          Einige Funktionen wollen zwar nicht bei mir, wie Lautstärke z.B., aber die Sender lassen
                          sich schon mal umschalten.
                          Gruß Ralf
                          • NashraN Nashra
                            @dirkhe
                            liv-in-skyL
                            liv-in-skyL
                            #844
                            @nashra
                            hoffentlich wird der adapter weiter gepflegt - nutze die tv steuerung doch öfters
                            bis jetzt habe ich das update nicht durchgeführt - den workaround muss ich mehr erstmal durchlesen
                              @nashra
                              #845
                              @liv-in-sky
                              hab auf Github gesehen, dass @foxriver76 ihn geforked hat, denke wenn er dazu kommt, gibt's n Release.. aber zur Zeit stehen ja wichtigere Tasks an..
                                @liv-in-sky
                                #846
                                Also ich werd da grad etwas ungeduldig.
                                Open Source hängt leider immer an Personen die das in der Freizeit machen.
                                Der Workaround auf Git ist gelinde gesagt "lästig" will nicht händisch Files austauschen.
                                Wäre echt nett wenn Sebastian den Fix von Foxriver (jscontroller) und den von Setfire (SSL) integrieren würde und ein release rausgibt um es wieder zum laufen zu bekommen.
                                Mag nicht darauf warten, dass er auch Zeit hat die neuen Funktionen einzubauen und erst dann ein neues Release zu veröffentlichen.
                                ? arteckA 2 Antworten Letzte Antwort
                                  #847
                                  @tltm_smarthome
                                  Auf was willst du nicht warten? Verstehe das nicht.. der Adapter laeuft unter js-controller 5.x, und man kann seine LG's damit steuern..
                                  irgendwelche Dateien tauschen muss man schon lange nicht mehr..
                                  Ansonsten, mach n Fork und entwickele selbst, Open Source hängt von der Zusammenarbeit aller ab, nicht von einem alleine! Meinst du, Commerz fixt Fehler schneller? Alter.. da biste aber ganz schön Naiv..
                                  Schau auf Git ..hier ganz runter scrollen, das ist da, wo die Maus aufhört.. :)
                                    @tltm_smarthome
                                    #848
                                    1. Nicht jeder der OpenSource nützt ist gleich ein Entwickler (auch wenn ichs mal im Studium hatte)
                                    2. Mir scheint, es trotzdem, dass noch kein neuer Adapter veröffentlicht wurde (also Installation im Expertenmodus direkt von GIT)
                                    3. "runter scrollen ..." Genau diese schnippischen Antworten in der OpenSource Community sind immer sehr hilfreich!
                                    BTW überleg mit tatsächlich auf ein Kommerzielles Produkt umzusteigen; Da gibt es vl. nicht so oft neue Features, aber Fixes sind schneller, die wollen ja das ihr Produkt weiter gekauft wird.
                                    liv-in-skyL amg_666A 2 Antworten Letzte Antwort
                                      liv-in-skyL
                                      liv-in-skyL
                                      #849
                                      @tltm_smarthome sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                      steht dir frei, dass zu tun - kannst uns dann ja mitteilen, welch große auswahl du hast, einen lg tv einzubinden bei den kommerz. alternativen
                                      @ilovegym sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                      nur zum verständnis - ist der 5er kontroller pflicht ?
                                        #850
                                        @liv-in-sky
                                        Ne läuft auch mit 4er
                                          arteckA
                                          arteckA
                                          arteck
                                          #851
                                          schick ihm 1000€ dann macht er es bestimmt sofort.. wo ist das Problem... ah ja... du willst ja nix für bezahlen ..
                                          aber rum moppern weil es EBEN DAUERT
                                          so mag ich das.. keine kontruktiven Beiträge im Forum.. aber rum mosern weil es "mal bissel länger dauert"
                                          was willst du da per Hand tauschen... GIT installation läuft wie jede andere ab..
                                          84.1k
