  3. Entwicklung
  4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
lgtv
861 Beiträge 113 Kommentatoren 386.5k Aufrufe 69 Beobachtet
  • E Eugene
    Hallo Leute,
    ich habe einen tolles neues TV, aber leider kann ich den LG WebOS Adapter nicht installieren. Da ich sonst keine Probleme mit dem IOBroker habe, liegt es wohl am Adapter. Mit Admin v6.3.5 und Node.js v16.15.0 und dazu passendem npm 8.5.5 lässt sich der Adapter nicht installieren. Folgende Fehlermeldung erscheint:
    Installing SebastianSchultz/ioBroker.lgtv... (System call)
    npm ERR! code 1
    npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@8.4.1
    npm ERR! gyp info using node@16.15.0 | linux | armnpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python Python is not set from command line or npm configurationnpm ERR! gyp ERR! find Python Python is not set from environment variable PYTHONnpm ERR! gyp ERR! find Python checking if "python3" can be usednpm ERR! gyp ERR! find Python - executable path is "/usr/bin/python3"npm ERR! gyp ERR! find Python - version is "3.5.3"npm ERR! gyp ERR! find Python - version is 3.5.3 - should be >=3.6.0npm ERR! gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTEDnpm ERR! gyp ERR! find Python checking if "python" can be usednpm ERR! gyp ERR! find Python - executable path is "/usr/bin/python"npm ERR! gyp ERR! find Python - version is "2.7.13"npm ERR! gyp ERR! find Python - version is 2.7.13 - should be >=3.6.0npm ERR! gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTEDnpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python **********************************************************npm ERR! gyp ERR! find Python You need to install the latest version of Python.npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,npm ERR! gyp ERR! find Python you can try one of the following options:npm ERR! gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)npm ERR! gyp ERR! find Python - Set the environment variable PYTHONnpm ERR! gyp ERR! find Python - Set the npm configuration variable python:npm ERR! gyp ERR! find Python npm config set python "/path/to/pythonexecutable"
    npm ERR! /home/iobroker/.npm/_logs/2022-12-15T14_38_49_292Z-debug-0.log
    host.ioBroker-Tinker Cannot install SebastianSchultz/ioBroker.lgtv: 1
    ERROR: Process exited with code 25
    Sollte jemand eine Idee haben, bin ich für einen Hinweis dankbar!
    Euch allen schöne Feiertage und Gruß aus der Eifel
    Eugen
    dirkhe
    #821
    @eugene also irgendwas ist mit deiner python version schief, hast du vlt. 2 und 3 gleichzeitig installiert? In dem bereicn solltest du mal suchen
    E 1 Antwort Letzte Antwort
    • E Eugene
      Hallo Leute,
      npm ERR! code 1
      Eugen
      #822
      @eugene sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
      Vermutlich ein veraltetes Betriebssystem. Aktuelles Zeuch kommt mit passenden Versionen daher.
      • D dirkhe
        Eugene
        #823
        @dirkhe
        Alte Duster Version auf dem Tinker Board. Hab's platt gemacht und ein sauberes neues Armbian installiert.
        Natürlich geht jetzt alles.....
        Danke für Euren Tipp und frohe Weihnachten
        Eugen
        ioBroker auf Mac Mini und Raspi3 - CCU2 - Hue - Harmony - 2 Dot - 1 Echo - Sonos - Lightify
        • Maschine20M Maschine20
          @tofriedrich said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
          Guten Morgen, hat noch jemand das Problem keine Verbindung herstellen zu können? Ich habe mir einen LG C1 gegönnt. Nach Einrichtung habe ich direkt den Adapter installiert und die IP eingetragen. Auf dem TV kommt keine Anfrage die man akzeptieren kann. Ich würde den Adapter gerne nutzen.
          Edit:
          Über einen Umweg habe ich das Ganze ans laufen bekommen. Ich habe diese Version installiert:
          https://github.com/SebastianSchultz/ioBroker.lgtv/tree/lgtv_test alles eingerichtet und ein Update auf die aktuelle Stable Version gemacht. Es wurde mehrfach eine Pairing-Anfrage geschickt. Im Moment läuft es. Vielleicht hilft das jemandem.
          danke für deine Editierung. Ich hatte das selbe Problem und mir hatte es sehr geholfen.
          Wie oft kam so circa die pairing Anfrage bei dir?
          Grüße M20
          Dado
          #824
          @maschine20 Moin, sory für die Noob-Frage, aber wie genau hast Du das installiert? Ich kenne nur die Möglichkeit, aus dem Repo zu installieren. Danke
          Maschine20M 1 Antwort Letzte Antwort
          • D Dado
            Maschine20M Offline
            Maschine20M Offline
            Maschine20
            schrieb am zuletzt editiert von Maschine20
            #825
            @dado Hi, ich habe aus dem git https://github.com/SebastianSchultz/ioBroker.lgtv/tree/lgtv_test den link kopiert und dann im Expertenmodus den Adapter aus der github Quelle installiert.
            Unter dem Button Code kann man den link kopieren für den Adapter.
            V 1 Antwort Letzte Antwort
              V Offline
              V Offline
              Vopi69
              schrieb am zuletzt editiert von Vopi69
              #826
              Seit heute habe ich ein Update für meinen LG OLED55G29LA bekommen. Seitdem verbindet sich der Adapter nicht mehr mit dem Fernseher und ich habe beim Neustarten des Adapters:
              2023-01-25 13:10:38.212 - info: host.iobroker stopInstance system.adapter.lgtv.0 (force=false, process=true)
              2023-01-25 13:10:38.215 - info: lgtv.0 (14518) Got terminate signal TERMINATE_YOURSELF
              2023-01-25 13:10:38.217 - info: lgtv.0 (14518) terminating
              2023-01-25 13:10:38.218 - info: lgtv.0 (14518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-01-25 13:10:38.257 - info: host.iobroker stopInstance system.adapter.lgtv.0 send kill signal
              2023-01-25 13:10:38.772 - info: host.iobroker instance system.adapter.lgtv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-01-25 13:10:41.269 - info: host.iobroker instance system.adapter.lgtv.0 started with pid 15224
              2023-01-25 13:10:41.815 - info: lgtv.0 (15224) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v16.19.0, js-controller: 4.0.24
              2023-01-25 13:10:41.825 - info: lgtv.0 (15224) Ready. Configured WebOS TV IP: 192.168.0.80
              Weiß jemand woran das liegt?
              Gruß Stefan
                dirkhe
                #827
                @vopi69 ohne debug log sieht man gar nichts
                  Denzel1994
                  schrieb am zuletzt editiert von Denzel1994
                  #828
                  Adapter verbindet sich mit meinem CS9 seit Firmware 03.30.16 nicht mehr:
                  lgtv.0 2023-01-27 22:37:11.349	debug	Error on connecting or sending command to WebOS TV: Error: socket hang up
                  lgtv.0 2023-01-27 22:37:11.340	debug	Connecting to WebOS TV: ws://192.168.XX.XX:3000
                  lgtv.0 2023-01-27 22:37:11.298	debug	TV is off
                  lgtv.0 2023-01-27 22:37:06.338	debug	Error on connecting or sending command to WebOS TV: Error: read ECONNRESET
                  lgtv.0 2023-01-27 22:37:06.325	debug	Connecting to WebOS TV: ws://192.168.XX.XX:3000
                  lgtv.0 2023-01-27 22:37:01.323	debug	Error on connecting or sending command to WebOS TV: Error: socket hang up
                  lgtv.0 2023-01-27 22:37:01.293	debug	Connecting to WebOS TV: ws://192.168.XX.XX:3000
                  • D Denzel1994
                    sigi234S Online
                    sigi234S Online
                    #829
                    @denzel1994
                    Ist eine Verbindungsanfrage am TV gekommen?
                    R 1 Antwort Letzte Antwort
                    • sigi234S sigi234
                      @denzel1994
                      roesthod
                      #830
                      @sigi234 Hallo, Ich habe genau das gleich Problem. Das Errorlog sieht wie folgt aus:
                      2023-01-28 13:56:39.791 - debug: lgtv.0 (1414) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-01-28 13:56:39.841 - debug: lgtv.0 (1414) Objects client ready ... initialize now
                      2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create System PubSub Client
                      2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create User PubSub Client
                      2023-01-28 13:56:39.958 - debug: lgtv.0 (1414) Objects client initialize lua scripts
                      2023-01-28 13:56:39.963 - debug: lgtv.0 (1414) Objects connected to redis: 127.0.0.1:9001
                      2023-01-28 13:56:39.964 - silly: lgtv.0 (1414) redis psubscribe cfg.o.system.user.*
                      2023-01-28 13:56:40.001 - silly: lgtv.0 (1414) redis psubscribe cfg.o.enum.*
                      2023-01-28 13:56:40.004 - silly: lgtv.0 (1414) objectDB connected
                      2023-01-28 13:56:40.005 - debug: lgtv.0 (1414) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-01-28 13:56:40.033 - debug: lgtv.0 (1414) States create System PubSub Client
                      2023-01-28 13:56:40.034 - debug: lgtv.0 (1414) States create User PubSub Client
                      2023-01-28 13:56:40.090 - debug: lgtv.0 (1414) States connected to redis: 127.0.0.1:9000
                      2023-01-28 13:56:40.090 - silly: lgtv.0 (1414) statesDB connected
                      2023-01-28 13:56:40.474 - info: lgtv.0 (1414) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v16.14.0, js-controller: 4.0.23
                      2023-01-28 13:56:40.496 - info: lgtv.0 (1414) Ready. Configured WebOS TV IP: 192.168.1.236
                      2023-01-28 13:56:40.497 - debug: lgtv.0 (1414) adapter.config = {"ip":"192.168.1.236","mac":"XX:XX:XX:XX:37:6B","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
                      2023-01-28 13:56:40.508 - silly: lgtv.0 (1414) States system redis pmessage system.adapter.lgtv.0.logLevel/system.adapter.lgtv.0.logLevel:{"val":"silly","ack":true,"ts":1674910600499,"q":0,"from":"system.adapter.lgtv.0","lc":1674910600499}
                      2023-01-28 13:56:40.516 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
                      2023-01-28 13:56:40.523 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: socket hang up
                      2023-01-28 13:56:45.523 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
                      2023-01-28 13:56:45.526 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: read ECONNRESET
                      Thomas BraunT sigi234S 2 Antworten Letzte Antwort
                      • R roesthod
                        #831
                        @roesthod sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                        Vom konkreten Problem abgesehen:
                        Halt die Kiste auf Stand.
                        • R roesthod
                          sigi234S Online
                          sigi234S Online
                          #832
                          @roesthod
                          IP Richtig? Kannst du den TV via Ping erreichen?
                          • sigi234S sigi234
                            @roesthod
                            roesthod
                            #833
                            @sigi234 IP ist richtig und ich habe das System jetzt auf den aktuellen Stand gebracht.
                            • R roesthod
                              roesthod
                              #834
                              @roesthod Ich habe übrigends zwei von den LG's und beide mit dem identischen Fehlerbild...
                              • R roesthod
                                sigi234S Online
                                sigi234S Online
                                #835
                                Alle mit WLAN verbunden?
                                Hatte auch Probleme, mit LAN hat es dann mal nach 20 versuchen funktioniert.
                                https://github.com/SebastianSchultz/ioBroker.lgtv/issues/123
                                • sigi234S sigi234
                                  dirkhe
                                  #836
                                  @sigi234 Da s sieht wirklich so aus, als wenn der Adapter angepasst werden muss. Ist halt auch schwierig rauszubekommen, welcher TV dann ws und welcher wss braucht. Zur Not müsste man es einstellbar machen..
                                  • D dirkhe
                                    roesthod
                                    #837
                                    @dirkhe TV's sind über LAN eingebunden...
                                    • R roesthod
                                      dirkhe
                                      #838
                                      @roesthod das hat mit wlan und lan wahrscheinlich nicht viel zu tun, eher das die mi der neueren firmware ein anderen websocket nutzen, wie in dem issue auf github beschrieben
                                      • D dirkhe
                                        michael_4358
                                        #839
                                        @dirkhe said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                        Meinst du das die .js gelöscht werden muss❓
                                        Konnte das wer das Problem schon lösen?
                                        • M michael_4358
                                          dirkhe
                                          #840
                                          @michael_4358 Schau mal in der oben verlinkten issue, da steht am Ende ein workaround drin, bis zur neuen Version
