  4. Linux/Debian - Grafana-Repo muss aktualisiert werden
151 Beiträge 23 Kommentatoren 48.5k Aufrufe 22 Beobachtet
  • L lessthanmore
    @Thomas-Braun
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 http://ftp.debian.org/debian bullseye-backports InRelease
    Get:7 http://security.debian.org/debian-security bullseye-security/main Sources [176 kB]
    Get:8 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [214 kB]
    Err:5 https://repos.influxdata.com/debian stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
    Fetched 438 kB in 1s (825 kB/s)
    Reading package lists... Done
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hmm, irgendwas habe ich mir da gerade verbaut (main vs InRelease).
    @lessthanmore
    echad@chet:~ $ cat /etc/apt/sources.list.d/influxdb.list
    deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
    Ist bei mir schon auf die neue Struktur umgestellt. Der Key ist auch nicht mehr im Schlüsselbund:
    echad@chet:~ $ apt-key list | grep influx | wc -l
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    L 1 Antwort Letzte Antwort
      @lessthanmore
      lessthanmore
      schrieb am zuletzt editiert von lessthanmore
      @thomas-braun Bei mir heißt die influxdata.list.
      Gibt es da eine Anleitung?
      Hätte auch gedacht dass der key influxdb2.key ist.
      Welche influxdb Version hast du oder spielt das keine Rolle hier?
      Wie kann ich das bei mir korrigieren? Kannst du mir da bitte helfen?
      • L lessthanmore
        @lessthanmore
        Key löschen. Geht wie oben:
        sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
        Die /etc/apt/sources.list.d/influxdata.list löschen.
        Aktuelles Setup für influxdb:
        wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
        export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
        echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
        L A S 3 Antworten Letzte Antwort
          @lessthanmore
          lessthanmore
          @thomas-braun Lieben Dank, läuft wieder bzw. keine Fehler- bzw. Warnmeldungen mehr.
          • N Naturfreund
            @negalein 👍 😇
            Hallo @naturfreund,
            ein Tipp am Rande, wenn Dir ein Befehl, den Du auf der Kommandozeile eingeben sollst, fremd ist oder dich die Neugierde umtreibt, dann kann Du auf der Kommandozeile ja mal folgendes eintippen ;)
            # man "befehl"   <- für befehl den einsetzen, den Du nicht kennst
            z.B.:
            # man wc
            NAME
                   wc - print newline, word, and byte counts for each file
            SYNOPSIS
                   wc [OPTION]... [FILE]...
                   wc [OPTION]... --files0-from=F
            DESCRIPTION
                   Print newline, word, and byte counts for each FILE, and a total line if more than one FILE is speci‐
                   fied.  A word is a non-zero-length sequence of printable characters delimited by white space.
                   With no FILE, or when FILE is -, read standard input.
                   The options below may be used to select which counts are printed, always  in  the  following  order:
                   newline, word, character, byte, maximum line length.
                   -c, --bytes
                          print the byte counts
                   -m, --chars
                          print the character counts
                   -l, --lines
                          print the newline counts
                   --files0-from=F
                          read  input  from  the files specified by NUL-terminated names in file F; If F is - then read
                          names from standard input
                   -L, --max-line-length
                          print the maximum display width
                   -w, --words
                          print the word counts
                   --help display this help and exit
                   --version
                          output version information and exit
            AUTHOR
                   Written by Paul Rubin and David MacKenzie.
            REPORTING BUGS
                   GNU coreutils online help: <https://www.gnu.org/software/coreutils/>
                   Report any translation bugs to <https://translationproject.org/team/>
            So kannst Du für fast jeden Konsolen Befehl eine kurze Beschreibung und eine Liste der Parameter, kompakter geht es mit,
            # wc --help
            1 dp20eic@yoga-3 ~ % wc --help
            Aufruf: wc [OPTION]... [DATEI]...
              oder: wc [OPTION]... --files0-from=DL
            Zeilen‐, Wort‐ und Byteanzahl für jede DATEI ausgeben und eine Zeile mit der
            Gesamtsumme, wenn mehr als eine DATEI angegeben wurde. Ohne DATEI, oder wenn
            DATEI „-“ ist, wird von der Standardeingabe gelesen. Ein Wort ist eine nicht
            leere Folge von darstellbaren Zeichen, die durch Leerzeichen begrenzt wird.
            Ohne DATEI oder wenn DATEI „-“ ist, Standardeingabe lesen.
            Die unten angeführten Optionen erlauben es, die auszugebenden Zähler
            auszuwählen, wobei sie immer in dieser Reihenfolge ausgegeben werden:
            Zeilen, Wörter, Zeichen, Bytes, größte Zeilenlänge.
              -c, --bytes            Byteanzahl ausgeben
              -m, --chars            Zeichenanzahl ausgeben
              -l, --lines            Zeilenanzahl ausgeben
                  --files0-from=D    Eingabe aus den Dateien lesen, die mit NULL
                                     terminiert in der Datei D stehen;
                                     ist D „-“, so wird aus der Standardeingabe gelesen
              -L, --max-line-length  die Länge der längsten Zeile ausgeben
              -w, --words            Wortanzahl ausgeben
                  --help        diese Hilfe anzeigen und beenden
                  --version     Versionsinformation anzeigen und beenden
            Onlinehilfe für GNU coreutils: <https://www.gnu.org/software/coreutils/>
            Melden Sie Übersetzungsfehler für %s an <translation-team-de@lists.sourceforge.net>
            Die vollständige Dokumentation ist hier: <https://www.gnu.org/software/coreutils/wc>
            oder auch lokal mittels „info '(coreutils) wc invocation'“
            Somit lernt man Stück für Stück Linux und Tippt/Kopiert nicht nur blind Befehle ab :)
            Bernd
              @lessthanmore
              australien
              Hi thomas
              leider hat das bei mir nichts geholfen :(
              bekomme immer noch die Fehlermeldung
              pi@raspberrypi:/ $ sudo apt update
              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
              Hit:6 https://deb.nodesource.com/node_17.x bullseye InRelease
              Err:5 https://repos.influxdata.com/debian bullseye InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              Fetched 7,022 B in 2s (4,068 B/s)
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              • A australien
                Hi thomas
                @australien
                ls -lAh /etc/apt/sources.list.d/
                  @australien
                  australien
                  pi@raspberrypi:/ $ ls -lAh /etc/apt/sources.list.d/
                  total 12K
                  -rw-r--r-- 1 root root 101 Jan 27 15:19 influxdb.list
                  -rw-r--r-- 1 root root 208 Nov 30 15:57 nodesource.list
                  -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
                  • A australien
                    total 12K
                    @australien
                    Da mal reingeschaut?
                    https://forum.iobroker.net/topic/62271/gelöst-influxdb-upgrade-error/17
                      @australien
                      australien
                      schrieb am zuletzt editiert von australien
                      kannte ich nicht, bekomme aber schnell so etwas
                      pi@raspberrypi:/ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                      pi@raspberrypi:/ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                      gpg: can't open './influxdata-archive_compat.key': No such file or directory
                      pi@raspberrypi:/
                      ich werde es morgen wieder versuchen
                      • A australien
                        pi@raspberrypi:/
                        @australien sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                        pi@raspberrypi:/
                        Moin,
                        schau mal nach dem wget ob Du eine Datei im Verzeichnis liegen hast, wenn nicht, dann Netzwerk prüfen, denn ich kann es genau so wie offiziell von influxDB beschrieben updaten.
                        # wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                        # ls -la
                        # -rw-r--r-- 1 dp20eic dp20eic  1684 Jan 26 22:11 influxdata-archive_compat.key
                        Bernd
                        P.S.: Du kannst auch auf die Seite Package Pepository gehen und dir die Datei herunterladen, dann auf dein Pi Kopieren und mit gpg weiter machen.
                          australien
                          @dp20eic
                          da ist viel, aber nicht die Datei.
                          alles im root, kein Unterverzeichnis
                          pi@raspberrypi:/ $ ls -la
                          total 68
                          drwxr-xr-x  18 root root  4096 Sep 22 05:06 .
                          drwxr-xr-x  18 root root  4096 Sep 22 05:06 ..
                          lrwxrwxrwx   1 root root     7 Sep 22 04:49 bin -> usr/bin
                          drwxr-xr-x   4 root root  4096 Jan  1  1970 boot
                          drwxr-xr-x  17 root root  3940 Jan 27 11:31 dev
                          drwxr-xr-x  89 root root  4096 Jan 27 14:51 etc
                          drwxr-xr-x   4 root root  4096 Nov 15 20:50 home
                          lrwxrwxrwx   1 root root     7 Sep 22 04:49 lib -> usr/lib
                          drwx------   2 root root 16384 Sep 22 05:05 lost+found
                          drwxr-xr-x   2 root root  4096 Sep 22 04:49 media
                          drwxr-xr-x   2 root root  4096 Sep 22 04:49 mnt
                          drwxr-xr-x   3 root root  4096 Nov 15 20:50 opt
                          dr-xr-xr-x 228 root root     0 Jan  1  1970 proc
                          drwx------   5 root root  4096 Nov 30 15:18 root
                          drwxr-xr-x  26 root root   780 Jan 27 16:27 run
                          lrwxrwxrwx   1 root root     8 Sep 22 04:49 sbin -> usr/sbin
                          drwxr-xr-x   2 root root  4096 Sep 22 04:49 srv
                          dr-xr-xr-x  12 root root     0 Jan  1  1970 sys
                          drwxrwxrwt  10 root root  4096 Jan 27 16:07 tmp
                          drwxr-xr-x  11 root root  4096 Sep 22 04:49 usr
                          drwxr-xr-x  11 root root  4096 Sep 22 05:06 var
                          pi@raspberrypi:/ $
                          wo soll die datei gespeichert sein?
                          Am PC wird die datei geladen.
                          • A australien
                            @dp20eic
                            total 68
                            pi@raspberrypi:/ $
                            @australien
                            Moin,
                            du stehst im völlig falschen Verzeichnis, Du must im Home des Privaten Users stehen.
                            # cd
                            # pwd
                            A 2 Antworten Letzte Antwort
                              @australien
                              Moin,
                              # cd
                              # pwd
                              australien
                              @dp20eic
                              pi@raspberrypi:~ $ pwd
                              /home/pi
                              ich hab gerade gesehen, dass es bei den https://repos.influxdata.com eine influxdb2.key gibt. soll ich diese benutzen? hab ja auch influxdb2.
                                @australien
                                Moin,
                                # cd
                                # pwd
                                australien
                                @dp20eic
                                ich dacht ich hab es, aber......
                                pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                pi@raspberrypi:~ $ ls
                                Abfall.ics  influxdata-archive_compat.key  iobroker       log      node_modules  package-lock.json
                                Calender    iob                            iobroker-data  nbsm.py  package.json  raspberrypi.gpg.key
                                pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                                pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                                      9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                                uid                      InfluxData Package Signing Key <support@influxdata.com>
                                pi@raspberrypi:~ $ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                -bash: $: command not found
                                gpg: no valid OpenPGP data found.
                                pi@raspberrypi:~ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                pi@raspberrypi:~ $ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
                                pi@raspberrypi:~ $ sudo apt update
                                Get:5 https://repos.influxdata.com/debian stable InRelease [6,874 B]
                                Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                                Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [3,275 B]
                                Err:7 https://repos.influxdata.com/debian bullseye InRelease
                                Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [1,669 B]
                                Fetched 18.8 kB in 2s (9,253 B/s)
                                pi@raspberrypi:~ $
                                ? 2 Antworten Letzte Antwort
                                • A australien
                                  @dp20eic
                                  /home/pi
                                  Moin,
                                  nein, wenn Du jetzt im richtigen Verzeichnis stehst, dann genau so wie influxDB das beschrieben hat. vorhin warst Du im / da darf man nicht schreiben, es sei denn Du hast root Rechte.
                                  Bernd
                                  • A australien
                                    @dp20eic
                                    pi@raspberrypi:~ $
                                    Moin,
                                    das mir zwei $ $ geht nicht, Bash kennt kein $. Falsch kopiert ;)
                                    Bernd
                                      Moin,
                                      Bernd
                                      australien
                                      @dp20eic
                                      das ganze von vorne
                                      pi@raspberrypi:~ $ cd
                                      /home/pi
                                      Hit:1 https://repos.influxdata.com/debian stable InRelease
                                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                      Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                                      Hit:7 https://deb.nodesource.com/node_17.x bullseye InRelease
                                      Fetched 7,022 B in 2s (3,881 B/s)
                                      pi@raspberrypi:~ $
                                      • A australien
                                        @dp20eic
                                        pi@raspberrypi:~ $
                                        Moin,
                                        lies mal im Thread, den @Thomas-Braun verlinkt hat weiter, dann kommst Du auch auf die Lösung :)
                                        Kleiner Tip,
                                        # ls -la /etc/apt/sources.list.d/
                                        Dann
                                        Bernd
                                          Moin,
                                          Kleiner Tip,
                                          Dann
                                          Bernd
                                          australien
                                          @dp20eic
                                          DANKE!!!!
                                          jetzt hab ich es auch :)
