  4. Linux/Debian - Grafana-Repo muss aktualisiert werden
151 Beiträge 23 Kommentatoren 48.5k Aufrufe 22 Beobachtet
  • A australien
    Hi thomas
    leider hat das bei mir nichts geholfen :(
    bekomme immer noch die Fehlermeldung
    pi@raspberrypi:/ $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
    Hit:6 https://deb.nodesource.com/node_17.x bullseye InRelease
    Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Fetched 7,022 B in 2s (4,068 B/s)
    Reading package lists... Done
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    @australien
    ls -lAh /etc/apt/sources.list.d/
      @australien
      australien
      pi@raspberrypi:/ $ ls -lAh /etc/apt/sources.list.d/
      total 12K
      -rw-r--r-- 1 root root 101 Jan 27 15:19 influxdb.list
      -rw-r--r-- 1 root root 208 Nov 30 15:57 nodesource.list
      -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
      • A australien
        total 12K
        @australien
        Da mal reingeschaut?
        https://forum.iobroker.net/topic/62271/gelöst-influxdb-upgrade-error/17
          @australien
          australien
          schrieb am zuletzt editiert von australien
          kannte ich nicht, bekomme aber schnell so etwas
          pi@raspberrypi:/ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
          pi@raspberrypi:/ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
          gpg: can't open './influxdata-archive_compat.key': No such file or directory
          pi@raspberrypi:/
          ich werde es morgen wieder versuchen
          • A australien
            pi@raspberrypi:/
            @australien sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
            pi@raspberrypi:/
            Moin,
            schau mal nach dem wget ob Du eine Datei im Verzeichnis liegen hast, wenn nicht, dann Netzwerk prüfen, denn ich kann es genau so wie offiziell von influxDB beschrieben updaten.
            # wget -q https://repos.influxdata.com/influxdata-archive_compat.key
            # ls -la
            # -rw-r--r-- 1 dp20eic dp20eic  1684 Jan 26 22:11 influxdata-archive_compat.key
            Bernd
            P.S.: Du kannst auch auf die Seite Package Pepository gehen und dir die Datei herunterladen, dann auf dein Pi Kopieren und mit gpg weiter machen.
              australien
              @dp20eic
              da ist viel, aber nicht die Datei.
              alles im root, kein Unterverzeichnis
              pi@raspberrypi:/ $ ls -la
              total 68
              drwxr-xr-x  18 root root  4096 Sep 22 05:06 .
              drwxr-xr-x  18 root root  4096 Sep 22 05:06 ..
              lrwxrwxrwx   1 root root     7 Sep 22 04:49 bin -> usr/bin
              drwxr-xr-x   4 root root  4096 Jan  1  1970 boot
              drwxr-xr-x  17 root root  3940 Jan 27 11:31 dev
              drwxr-xr-x  89 root root  4096 Jan 27 14:51 etc
              drwxr-xr-x   4 root root  4096 Nov 15 20:50 home
              lrwxrwxrwx   1 root root     7 Sep 22 04:49 lib -> usr/lib
              drwx------   2 root root 16384 Sep 22 05:05 lost+found
              drwxr-xr-x   2 root root  4096 Sep 22 04:49 media
              drwxr-xr-x   2 root root  4096 Sep 22 04:49 mnt
              drwxr-xr-x   3 root root  4096 Nov 15 20:50 opt
              dr-xr-xr-x 228 root root     0 Jan  1  1970 proc
              drwx------   5 root root  4096 Nov 30 15:18 root
              drwxr-xr-x  26 root root   780 Jan 27 16:27 run
              lrwxrwxrwx   1 root root     8 Sep 22 04:49 sbin -> usr/sbin
              drwxr-xr-x   2 root root  4096 Sep 22 04:49 srv
              dr-xr-xr-x  12 root root     0 Jan  1  1970 sys
              drwxrwxrwt  10 root root  4096 Jan 27 16:07 tmp
              drwxr-xr-x  11 root root  4096 Sep 22 04:49 usr
              drwxr-xr-x  11 root root  4096 Sep 22 05:06 var
              pi@raspberrypi:/ $
              wo soll die datei gespeichert sein?
              Am PC wird die datei geladen.
              • A australien
                @dp20eic
                total 68
                pi@raspberrypi:/ $
                @australien
                Moin,
                du stehst im völlig falschen Verzeichnis, Du must im Home des Privaten Users stehen.
                # cd
                # pwd
                A 2 Antworten Letzte Antwort
                  @australien
                  Moin,
                  # cd
                  # pwd
                  australien
                  @dp20eic
                  pi@raspberrypi:~ $ pwd
                  /home/pi
                  ich hab gerade gesehen, dass es bei den https://repos.influxdata.com eine influxdb2.key gibt. soll ich diese benutzen? hab ja auch influxdb2.
                    @australien
                    Moin,
                    # cd
                    # pwd
                    australien
                    @dp20eic
                    ich dacht ich hab es, aber......
                    pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                    pi@raspberrypi:~ $ ls
                    Abfall.ics  influxdata-archive_compat.key  iobroker       log      node_modules  package-lock.json
                    Calender    iob                            iobroker-data  nbsm.py  package.json  raspberrypi.gpg.key
                    pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                    pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                          9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                    uid                      InfluxData Package Signing Key <support@influxdata.com>
                    pi@raspberrypi:~ $ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                    -bash: $: command not found
                    gpg: no valid OpenPGP data found.
                    pi@raspberrypi:~ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                    pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                    pi@raspberrypi:~ $ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
                    pi@raspberrypi:~ $ sudo apt update
                    Get:5 https://repos.influxdata.com/debian stable InRelease [6,874 B]
                    Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                    Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [3,275 B]
                    Err:7 https://repos.influxdata.com/debian bullseye InRelease
                    Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [1,669 B]
                    Fetched 18.8 kB in 2s (9,253 B/s)
                    pi@raspberrypi:~ $
                    ? 2 Antworten Letzte Antwort
                    • A australien
                      @dp20eic
                      /home/pi
                      Moin,
                      nein, wenn Du jetzt im richtigen Verzeichnis stehst, dann genau so wie influxDB das beschrieben hat. vorhin warst Du im / da darf man nicht schreiben, es sei denn Du hast root Rechte.
                      Bernd
                      • A australien
                        @dp20eic
                        pi@raspberrypi:~ $
                        Moin,
                        das mir zwei $ $ geht nicht, Bash kennt kein $. Falsch kopiert ;)
                        Bernd
                          Moin,
                          Bernd
                          australien
                          @dp20eic
                          das ganze von vorne
                          pi@raspberrypi:~ $ cd
                          /home/pi
                          Hit:1 https://repos.influxdata.com/debian stable InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:7 https://deb.nodesource.com/node_17.x bullseye InRelease
                          Fetched 7,022 B in 2s (3,881 B/s)
                          pi@raspberrypi:~ $
                          • A australien
                            @dp20eic
                            pi@raspberrypi:~ $
                            Moin,
                            lies mal im Thread, den @Thomas-Braun verlinkt hat weiter, dann kommst Du auch auf die Lösung :)
                            Kleiner Tip,
                            # ls -la /etc/apt/sources.list.d/
                            Dann
                            Bernd
                              Moin,
                              Kleiner Tip,
                              Dann
                              Bernd
                              australien
                              @dp20eic
                              DANKE!!!!
                              jetzt hab ich es auch :)
                              • A australien
                                @dp20eic
                                das ganze von vorne
                                /home/pi
                                pi@raspberrypi:~ $
                                das ganze von vorne
                                Moin,
                                warum so ungeduldig?
                                Erst lesen, dann Nachdenken :)
                                Du hast mit Sicherheit mehr Source List Files für influxDB im Verzeichnis, die werden beim apt-get update auch genommen, nur die alten List Files haben keine gültige Signatur mehr.
                                Also immer ganz ruhig junger Padawan :)
                                Bernd
                                  das ganze von vorne
                                  Moin,
                                  Bernd
                                  Marty56
                                  schrieb am zuletzt editiert von Marty56
                                  Danke an alle.
                                  Warum muss Linux immer so eine fürchterlichere Frickelei sein?!
                                  Ich verstehe das nicht.
                                  Ich habe die Befehle vom ersten Post eingetippt.
                                  Und bekomme jetzt folgenden Output.
                                  Hit:1 http://security.debian.org bullseye-security InRelease
                                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                  Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                                  Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
                                  Get:6 https://apt.grafana.com stable InRelease [5984 B]
                                  Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Ign:8 https://apt.tvheadend.org/unstable bullseye InRelease
                                  Hit:9 https://apt.tvheadend.org/unstable bullseye Release
                                  Err:4 https://packages.grafana.com/oss/deb stable InRelease
                                    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  Get:11 https://apt.grafana.com stable/main amd64 Packages [105 kB]
                                  Fetched 118 kB in 1s (80.5 kB/s)
                                  4 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  N: Skipping acquire of configured file 'main/binary-amd64/Packages' as repository 'https://apt.tvheadend.org/unstable bullseye InRelease' doesn't support architecture 'amd64'
                                  W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  apt-key list | grep -i grafana | wc -l
                                  Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                  HW:NUC (16 GB Ram)
                                  OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                  wendy2702W ? 2 Antworten Letzte Antwort
                                  • M Marty56
                                    Danke an alle.
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    @marty56 sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                                    Verstehe nicht was daran Frickelei ist. Blos weil du bei WIndows nicht mitbekommst was die auf deinem Rechner veranstalten ist es nicht besser.
                                    Poste doch bitte mal die vollständige Ausgabe der Eingabe der Befehle aus dem ersten Post.
                                    • M Marty56
                                      Danke an alle.
                                      Moin,
                                      Zu 1: Das hat nichts mit Linux zu tun, sondern mit der Distribution und den 3rd. Party Software Hersteller, die versuchen zu verhinder, das schlechte Menschen, verseuchte Pakete auf Deinen PC installieren können. Jede Distribution kocht da leider ihr eigenes Süppchen.
                                      Zu 2. Dann musst Du dir mal ein gutes Buch zu Linux kaufen und lesen, dann wird vieles klar :)
                                      Zu 3. immer nur Befehle, die ein anderer hier eintippt blindlings zu kopieren und sich dann zu wundern wieso geht das bei mir nicht, ist auch nicht so klug.
                                      Hatte ich ja schon weiter oben geschrieben, Lesen (Bildet) dann nachdenken, dann handeln.
                                      Wenn Du auf die Seite von Grafana gehst, steht genau beschrieben was zu tun ist, um die neuen Signaturen in sein System zu bekommen.
                                      Bernd
                                        Moin,
                                        Bernd
                                        Marty56
                                        @dp20eic Sehr hilfreich. Leider habe ich überhaupt keinen Bock, Bücher über Linux zu lesen und Frickelkönig zu werden.
                                        HW:NUC (16 GB Ram)
                                        ? Thomas BraunT ChaotC 3 Antworten Letzte Antwort
                                        -4
                                        • M Marty56
                                          Moin,
                                          ist doch eine Aussage, kann ich mit leben, ob Du damit leben kannst und ob Du mit dieser Einstellung Hilfe bekommst, kann ich Dir nur wünschen. Ich bin dann mal weg.
                                          Bernd
