  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. CC2652RB Zigbee Confiiguration Error
    5.2k
24 Beiträge 3 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • arteckA arteck
    @rctomcat dann lern den nochmal an.. ohne den zu löschen... und schau nochmal.. manchmal ist das so...
    ansonten könntest du nochmal in der Kachel von dem Gerät im Admin den rekonfuguration button drücken
    RcTomcat
    @arteck Also nochmals anlernen führt leider zu keiner Besserung.
    Reconfigure ebenso.
    zigbee.1
    	2023-01-12 14:59:00.192	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
    zigbee.1
    	2023-01-12 14:58:50.152	info	Configuring 0x60a423fffe61de63 TS0121
    zigbee.1
    	2023-01-12 14:58:31.106	info	Zigbee: stop joining
    zigbee.1
    	2023-01-12 14:58:14.424	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
    zigbee.1
    	2023-01-12 14:58:04.368	info	Configuring 0x60a423fffe61de63 TS0121
    zigbee.1
    	2023-01-12 14:58:04.363	info	Device '0x60a423fffe61de63' is supported, identified as: TuYa 10A UK or 16A EU smart plug (TS0121_plug)
    zigbee.1
    	2023-01-12 14:58:04.362	info	Successfully interviewed '0x60a423fffe61de63', device has successfully been paired
    • R RcTomcat
      Reconfigure ebenso.
      zigbee.1
      zigbee.1
      zigbee.1
      zigbee.1
      zigbee.1
      zigbee.1
      zigbee.1
      arteckA Offline
      arteckA Offline
      arteck
      @rctomcat ok dann anders.. installier die GIT version.. und schau nochmal.. ich meine da war was mit den teilen
      R 1 Antwort Letzte Antwort
      • arteckA arteck
        RcTomcat
        @arteck Installation via Git wurde eben durchgeführt, der Adapter entsprechend geupdated.
        Das Problem besteht leider immer noch :(
        R arteckA 2 Antworten Letzte Antwort
        • R RcTomcat
          RcTomcat
          Hat noch jemand eine Idee?
          • R RcTomcat
            arteckA Offline
            arteckA Offline
            arteck
            @rctomcat nochmal angelernt ?
            • arteckA arteck
              RcTomcat
              @arteck Ja, habe ich. Keine Besserung. Habe sogar nochmals den Adapter komplett entfernt und danach mehrfach versucht die Steckdose anzulernen (teils ohne sie zu löschen) und zu konfigurieren. Das Thema scheint bei mir auch nur die Steckdosen vom Typ TS0121_plug zu betreffen. Ein Würfel vom Typ MFKZQ01LM wurde problemlos erkannt und konfiguriert.
              Beide Geräte funktionieren am CC253, am CC2652RB nur der Würfel.
              • R RcTomcat
                arteckA Offline
                arteckA Offline
                arteck
                @rctomcat sagte in CC2652RB Zigbee Confiiguration Error:
                am was ???? cc2531 ???..dann verigss es direkt
                • arteckA arteck
                  RcTomcat
                  @arteck Sorry, da wurde die 1 abgeschnitten.
                  Alter Zigbee Stick: CC2531 -> Steckdose TS0121_plug funktioniert, Würfel und andere Geräte funktioneren.
                  Der CC2531 soll aber wie in Eingangspost erwähnt durch den CC2652RB ersetzt werden.
                  Neuer Zigbee Stick: CC2652RB -> Steckdose TS0121_plug funktioniert nicht, Configuration Error. Andere Geräte wie z.b. der Würfel funktionieren
                  Warum das Thema vergessen?
                  • R RcTomcat
                    arteckA Offline
                    arteckA Offline
                    arteck
                    ich habs andersrum verstanden...
                    welche firmware ist auf dem CC2652RB
                    R 2 Antworten Letzte Antwort
                    • arteckA arteck
                      RcTomcat
                      @arteck
                      Firmware:
                      CC2531
                          type:zStack12
                          version:2-0.2.6.3.
                          revision:20201127
                          port:/dev/ttyACM0
                          channel:11
                      CC2652RB
                        type:zStack3x0
                          version:2-1.2.7.1.
                          revision:20220219
                          port:/dev/ttyUSB0
                          channel:11
                      • arteckA arteck
                        RcTomcat
                        @arteck Firmware sollte die neuste verfügbare sein soweit ich das nachvollziehen kann
                        • R RcTomcat
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @rctomcat den plug hab ich auch...
                          zeigmal die ersten 10 zeilen nach adapter start..
                          • arteckA arteck
                            RcTomcat
                            @arteck das sieht so aus:
                            zigbee.1
                            	2023-01-23 10:54:09.005	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
                            zigbee.1
                            	2023-01-23 10:53:58.845	info	Zigbee started
                            zigbee.1
                            	2023-01-23 10:53:58.841	info	0x00158d000278d8fc (addr 41493): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                            zigbee.1
                            	2023-01-23 10:53:58.806	info	0x60a423fffe61de63 (addr 23258): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Unknown)
                            zigbee.1
                            	2023-01-23 10:53:58.789	info	Configuring 0x60a423fffe61de63 TS0121
                            zigbee.1
                            	2023-01-23 10:53:58.697	info	Currently 2 devices are joined:
                            zigbee.1
                            	2023-01-23 10:53:58.674	info	--> transmitPower : normal
                            zigbee.1
                            	2023-01-23 10:53:58.612	info	Unable to disable LED, unsupported function.
                            zigbee.1
                            	2023-01-23 10:53:58.597	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                            zigbee.1
                            	2023-01-23 10:53:47.595	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.1
                            	2023-01-23 10:53:45.297	info	Starting Zigbee npm ...
                            zigbee.1
                            	2023-01-23 10:53:44.873	info	starting. Version 1.8.10 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.8.0, js-controller: 4.0.23
                            host.raspberrypi
                            	2023-01-23 10:53:23.930	info	instance system.adapter.zigbee.1 started with pid 16659
                            host.raspberrypi
                            	2023-01-23 10:53:22.092	info	instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            host.raspberrypi
                            	2023-01-23 10:53:20.702	info	stopInstance system.adapter.zigbee.1 killing pid 21317
                            zigbee.1
                            	2023-01-23 10:53:20.201	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            arteckA Thomas BraunT 2 Antworten Letzte Antwort
                            • R RcTomcat
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              zigbee.1
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              zigbee.1
                              arteckA Offline
                              arteckA Offline
                              arteck
                              das ist nicht die GIT Version.. die da gezogen wird
                              nochmal installiere die GIT version https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                              • R RcTomcat
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                zigbee.1
                                node: v18.8.0
                                Ist nicht die derzeitig empfohlene nodejs-Version.
                                Und wenn es schon warum auch immer 18 sein muss:
                                18.13.0 ist da aktueller Stand.
                                • arteckA arteck
                                  RcTomcat
                                  @arteck ist nach wie vor das selbe Thema:
                                  zigbee.1
                                  	2023-01-23 16:06:06.479	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
                                  zigbee.1
                                  	2023-01-23 16:05:56.294	info	Zigbee started
                                  zigbee.1
                                  	2023-01-23 16:05:56.289	info	0x00158d000278d8fc (addr 41493): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                  zigbee.1
                                  	2023-01-23 16:05:56.252	info	0x60a423fffe61de63 (addr 23258): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Unknown)
                                  zigbee.1
                                  	2023-01-23 16:05:56.235	info	Configuring 0x60a423fffe61de63 TS0121
                                  zigbee.1
                                  	2023-01-23 16:05:56.131	info	Currently 2 devices are joined:
                                  zigbee.1
                                  	2023-01-23 16:05:56.102	info	--> transmitPower : normal
                                  zigbee.1
                                  	2023-01-23 16:05:56.029	info	Unable to disable LED, unsupported function.
                                  zigbee.1
                                  	2023-01-23 16:05:56.012	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                                  zigbee.1
                                  	2023-01-23 16:05:44.890	info	Installed Version: ioBroker/ioBroker.zigbee#050a845a81c8162245e962a9cf1fb0817392dea0
                                  Ich hatte zwischendurch den Adapter nochmals gelöscht und regulär neu installiert, daher war das wieder die Nicht-Git Version
                                  @Thomas-Braun das Problem besteht sowohl mit nodejs 16 als auch 18
                                  starting. Version 1.8.10 (non-npm: ioBroker/ioBroker.zigbee#050a845a81c8162245e962a9cf1fb0817392dea0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
                                  • R RcTomcat
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    zigbee.1
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @rctomcat an node liegts es nicht
                                    da funktioniert die konfiguration nicht.. warum auch immer
                                    • arteckA arteck
                                      RcTomcat
                                      @arteck so scheint es ^^.
                                      Wenn keiner mehr eine Idee hat werde ich eben leider beim CC2531 bleiben (zumindest was die beiden Steckdosen angeht)
                                      • arteckA arteck
                                        RcTomcat
                                        @arteck also das Problem besteht scheinbar auch bei einer TS011F_plug_1 Steckdose.
                                        Selbes Spiel: Am alten Zigbee Stick klappt alles, am neuen Device Configure failed
                                        	DeviceConfigure:Failed to DeviceConfigure.configure 0xa4c13815a387d1a7 TS011F (Error: Read 0xa4c13815a387d1a7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 37808 - 1 - 17 - 0 - 1 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7))
                                        • R RcTomcat
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @rctomcat aktualisiere mal den adapter von GIT... da gabs ein Problem mit den tuya gedönz
