  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. CC2652RB Zigbee Confiiguration Error
    5.1k
24 Beiträge 3 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • R RcTomcat
    @arteck 1.8.10, latest available
    arteckA Offline
    arteckA Offline
    arteck
    @rctomcat dann lern den nochmal an.. ohne den zu löschen... und schau nochmal.. manchmal ist das so...
    ansonten könntest du nochmal in der Kachel von dem Gerät im Admin den rekonfuguration button drücken
    R 1 Antwort Letzte Antwort
    • arteckA arteck
      RcTomcat
      @arteck Also nochmals anlernen führt leider zu keiner Besserung.
      Reconfigure ebenso.
      zigbee.1
      	2023-01-12 14:59:00.192	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
      zigbee.1
      	2023-01-12 14:58:50.152	info	Configuring 0x60a423fffe61de63 TS0121
      zigbee.1
      	2023-01-12 14:58:31.106	info	Zigbee: stop joining
      zigbee.1
      	2023-01-12 14:58:14.424	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
      zigbee.1
      	2023-01-12 14:58:04.368	info	Configuring 0x60a423fffe61de63 TS0121
      zigbee.1
      	2023-01-12 14:58:04.363	info	Device '0x60a423fffe61de63' is supported, identified as: TuYa 10A UK or 16A EU smart plug (TS0121_plug)
      zigbee.1
      	2023-01-12 14:58:04.362	info	Successfully interviewed '0x60a423fffe61de63', device has successfully been paired
      • R RcTomcat
        Reconfigure ebenso.
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        zigbee.1
        arteckA Offline
        arteckA Offline
        arteck
        @rctomcat ok dann anders.. installier die GIT version.. und schau nochmal.. ich meine da war was mit den teilen
        • arteckA arteck
          RcTomcat
          @arteck Installation via Git wurde eben durchgeführt, der Adapter entsprechend geupdated.
          Das Problem besteht leider immer noch :(
          R arteckA 2 Antworten Letzte Antwort
          • R RcTomcat
            RcTomcat
            Hat noch jemand eine Idee?
            • R RcTomcat
              arteckA Offline
              arteckA Offline
              arteck
              @rctomcat nochmal angelernt ?
              • arteckA arteck
                RcTomcat
                @arteck Ja, habe ich. Keine Besserung. Habe sogar nochmals den Adapter komplett entfernt und danach mehrfach versucht die Steckdose anzulernen (teils ohne sie zu löschen) und zu konfigurieren. Das Thema scheint bei mir auch nur die Steckdosen vom Typ TS0121_plug zu betreffen. Ein Würfel vom Typ MFKZQ01LM wurde problemlos erkannt und konfiguriert.
                Beide Geräte funktionieren am CC253, am CC2652RB nur der Würfel.
                • R RcTomcat
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @rctomcat sagte in CC2652RB Zigbee Confiiguration Error:
                  am was ???? cc2531 ???..dann verigss es direkt
                  • arteckA arteck
                    RcTomcat
                    @arteck Sorry, da wurde die 1 abgeschnitten.
                    Alter Zigbee Stick: CC2531 -> Steckdose TS0121_plug funktioniert, Würfel und andere Geräte funktioneren.
                    Der CC2531 soll aber wie in Eingangspost erwähnt durch den CC2652RB ersetzt werden.
                    Neuer Zigbee Stick: CC2652RB -> Steckdose TS0121_plug funktioniert nicht, Configuration Error. Andere Geräte wie z.b. der Würfel funktionieren
                    Warum das Thema vergessen?
                    • R RcTomcat
                      arteckA Offline
                      arteckA Offline
                      arteck
                      ich habs andersrum verstanden...
                      welche firmware ist auf dem CC2652RB
                      R 2 Antworten Letzte Antwort
                      • arteckA arteck
                        RcTomcat
                        @arteck
                        Firmware:
                        CC2531
                            type:zStack12
                            version:2-0.2.6.3.
                            revision:20201127
                            port:/dev/ttyACM0
                            channel:11
                        CC2652RB
                          type:zStack3x0
                            version:2-1.2.7.1.
                            revision:20220219
                            port:/dev/ttyUSB0
                            channel:11
                        • arteckA arteck
                          RcTomcat
                          @arteck Firmware sollte die neuste verfügbare sein soweit ich das nachvollziehen kann
                          • R RcTomcat
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @rctomcat den plug hab ich auch...
                            zeigmal die ersten 10 zeilen nach adapter start..
                            • arteckA arteck
                              RcTomcat
                              @arteck das sieht so aus:
                              zigbee.1
                              	2023-01-23 10:54:09.005	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
                              zigbee.1
                              	2023-01-23 10:53:58.845	info	Zigbee started
                              zigbee.1
                              	2023-01-23 10:53:58.841	info	0x00158d000278d8fc (addr 41493): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              zigbee.1
                              	2023-01-23 10:53:58.806	info	0x60a423fffe61de63 (addr 23258): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Unknown)
                              zigbee.1
                              	2023-01-23 10:53:58.789	info	Configuring 0x60a423fffe61de63 TS0121
                              zigbee.1
                              	2023-01-23 10:53:58.697	info	Currently 2 devices are joined:
                              zigbee.1
                              	2023-01-23 10:53:58.674	info	--> transmitPower : normal
                              zigbee.1
                              	2023-01-23 10:53:58.612	info	Unable to disable LED, unsupported function.
                              zigbee.1
                              	2023-01-23 10:53:58.597	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                              zigbee.1
                              	2023-01-23 10:53:47.595	info	Installed Version: ioBroker/ioBroker.zigbee
                              zigbee.1
                              	2023-01-23 10:53:45.297	info	Starting Zigbee npm ...
                              zigbee.1
                              	2023-01-23 10:53:44.873	info	starting. Version 1.8.10 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.8.0, js-controller: 4.0.23
                              host.raspberrypi
                              	2023-01-23 10:53:23.930	info	instance system.adapter.zigbee.1 started with pid 16659
                              host.raspberrypi
                              	2023-01-23 10:53:22.092	info	instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              host.raspberrypi
                              	2023-01-23 10:53:20.702	info	stopInstance system.adapter.zigbee.1 killing pid 21317
                              zigbee.1
                              	2023-01-23 10:53:20.201	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              arteckA Thomas BraunT 2 Antworten Letzte Antwort
                              • R RcTomcat
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                zigbee.1
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                zigbee.1
                                arteckA Offline
                                arteckA Offline
                                arteck
                                das ist nicht die GIT Version.. die da gezogen wird
                                nochmal installiere die GIT version https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                                • R RcTomcat
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  zigbee.1
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  zigbee.1
                                  node: v18.8.0
                                  Ist nicht die derzeitig empfohlene nodejs-Version.
                                  Und wenn es schon warum auch immer 18 sein muss:
                                  18.13.0 ist da aktueller Stand.
                                  • arteckA arteck
                                    RcTomcat
                                    @arteck ist nach wie vor das selbe Thema:
                                    zigbee.1
                                    	2023-01-23 16:06:06.479	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x60a423fffe61de63 TS0121 (Error: Bind 0x60a423fffe61de63/1 genOnOff from '0x00124b001936a498/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:564:17) at processTimers (node:internal/timers:507:7))
                                    zigbee.1
                                    	2023-01-23 16:05:56.294	info	Zigbee started
                                    zigbee.1
                                    	2023-01-23 16:05:56.289	info	0x00158d000278d8fc (addr 41493): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                    zigbee.1
                                    	2023-01-23 16:05:56.252	info	0x60a423fffe61de63 (addr 23258): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Unknown)
                                    zigbee.1
                                    	2023-01-23 16:05:56.235	info	Configuring 0x60a423fffe61de63 TS0121
                                    zigbee.1
                                    	2023-01-23 16:05:56.131	info	Currently 2 devices are joined:
                                    zigbee.1
                                    	2023-01-23 16:05:56.102	info	--> transmitPower : normal
                                    zigbee.1
                                    	2023-01-23 16:05:56.029	info	Unable to disable LED, unsupported function.
                                    zigbee.1
                                    	2023-01-23 16:05:56.012	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                                    zigbee.1
                                    	2023-01-23 16:05:44.890	info	Installed Version: ioBroker/ioBroker.zigbee#050a845a81c8162245e962a9cf1fb0817392dea0
                                    Ich hatte zwischendurch den Adapter nochmals gelöscht und regulär neu installiert, daher war das wieder die Nicht-Git Version
                                    @Thomas-Braun das Problem besteht sowohl mit nodejs 16 als auch 18
                                    starting. Version 1.8.10 (non-npm: ioBroker/ioBroker.zigbee#050a845a81c8162245e962a9cf1fb0817392dea0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
                                    • R RcTomcat
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      zigbee.1
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @rctomcat an node liegts es nicht
                                      da funktioniert die konfiguration nicht.. warum auch immer
                                      • arteckA arteck
                                        RcTomcat
                                        @arteck so scheint es ^^.
                                        Wenn keiner mehr eine Idee hat werde ich eben leider beim CC2531 bleiben (zumindest was die beiden Steckdosen angeht)
                                        • arteckA arteck
                                          RcTomcat
                                          @arteck also das Problem besteht scheinbar auch bei einer TS011F_plug_1 Steckdose.
                                          Selbes Spiel: Am alten Zigbee Stick klappt alles, am neuen Device Configure failed
                                          	DeviceConfigure:Failed to DeviceConfigure.configure 0xa4c13815a387d1a7 TS011F (Error: Read 0xa4c13815a387d1a7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 37808 - 1 - 17 - 0 - 1 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7))
