  4. ZigBee neue Version 1.7.x
    5.9k
1.7backupiconszigbee
217 Beiträge 40 Kommentatoren 48.0k Aufrufe 47 Beobachtet
  • ZarelloZ Zarello
    @arteck Mir ist heute eine Warnung des Zigbee-Adapters im Log aufgefallen (Adapter-Version: 1.8.10):
    2023-01-07 22:32:44.930 - warn: zigbee.0 (1925454) Object 847127fffedd2d01.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-01-07 22:32:44.931 - warn: zigbee.0 (1925454) This object will not be created in future versions. Please report this to the developer.
    2023-01-07 22:32:44.985 - warn: zigbee.0 (1925454) Object 847127fffedd3818.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-01-07 22:32:44.985 - warn: zigbee.0 (1925454) This object will not be created in future versions. Please report this to the developer.
    Das sind zwei schaltbare Steckdosen von IKEA.
    Ich hoffe, damit bin ich hier richtig.
    Geräteinformation:
       model:E1603/E1702/E1708
       description:TRADFRI control outlet
       modelZigbee:TRADFRI control outlet
       type:Router
       nwk:52606
       manuf id:4476
       manufacturer:IKEA of Sweden
       power:Mains (single phase)
       app version:32
       hard version:1
       zcl version:3
       stack version:98
       date code:20191026
       build:2.0.024
       interviewed:true
       configured:false
       endpoint:1
       profile:260
       input clusters:genBasic (0)
       genIdentify (3)
       genGroups (4)
       genScenes (5)
       genOnOff (6)
       genLevelCtrl (8)
       touchlink (4096)
       output clusters:genScenes (5)
       genOta (25)
       genPollCtrl (32)
       touchlink (4096)
       endpoint:242
       profile:41440
       input clusters:greenPower (33)
       output clusters:greenPower (33)
    Objektdaten von zigbee.0.847127fffedd2d01.power_on_behavior:
      "type": "state",
      "common": {
        "name": "Controls the behaviour when the device is powered on",
        "type": "string",
        "states": "off:off;on:on;toggle:toggle;previous:previous",
        "read": true,
        "write": true,
        "role": "state"
      "native": {},
      "_id": "zigbee.0.847127fffedd2d01.power_on_behavior",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "user": "system.user.admin",
      "ts": 1673127882070
    Ich habe einmal ausprobiert, was passiert wenn ich den type von string auf object ändere. Es kam nochmal die gleiche Meldung, diesesmal allerdings von admin.0 statt zigbee.0
    FreunderNachtF Offline
    FreunderNacht
    schrieb am zuletzt editiert von FreunderNacht
    #174
    @Zarello
    solche Meldungen hatte ich auch bekommen.
    Da gibt's auf GitHub ich schon Issue zu.
    Hatte ich weiter oben schon geschrieben.
    Siehe hier
    Intel NUC mit Proxmox
    IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
    Influx DB
    Grafana
    PiHole
    PiVPN
    • ZarelloZ Zarello
      Geräteinformation:
         type:Router
         nwk:52606
         manuf id:4476
         app version:32
         hard version:1
         zcl version:3
         stack version:98
         date code:20191026
         build:2.0.024
         interviewed:true
         configured:false
         endpoint:1
         profile:260
         genIdentify (3)
         genGroups (4)
         genScenes (5)
         genOnOff (6)
         genLevelCtrl (8)
         touchlink (4096)
         genOta (25)
         genPollCtrl (32)
         touchlink (4096)
         endpoint:242
         profile:41440
        "type": "state",
        "common": {
          "type": "string",
          "read": true,
          "write": true,
          "role": "state"
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1673127882070
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #175
      @zarello sagte in ZigBee neue Version 1.7.x:
      Kommt die Meldung regelmässig oder einmalig beim Start des Adapters mit 1.8.10 ?
      A.
      ZarelloZ 2 Antworten Letzte Antwort
      • AsgothianA Asgothian
        A.
        ZarelloZ Offline
        ZarelloZ Offline
        Zarello
        schrieb am zuletzt editiert von Zarello
        #176
        @asgothian Ich hatte direkt davor von 1.8.9 auf 1.8.10 aktualisiert. Beim letzten Adapterstart der 1.8.9 kam diese Meldung noch nicht. Beim Starten der 1.8.10 kam diese Meldung und als ich den Typ des Objekts von string auf object und zurück geändert hatte kam auch jeweils einmal solch eine Meldung, in dem Fall aber von admin.0 und nur für das Objekt, an welchem ich den Type änderte.
        2023-01-07 22:43:56.775  - warn: admin.0 (1924283) Object zigbee.0.847127fffedd2d01.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-01-07 22:43:56.777  - warn: admin.0 (1924283) This object will not be created in future versions. Please report this to the developer.
        2023-01-07 22:44:42.070  - warn: admin.0 (1924283) Object zigbee.0.847127fffedd2d01.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-01-07 22:44:42.070  - warn: admin.0 (1924283) This object will not be created in future versions. Please report this to the developer.
        Seit dem (also die letzten zwei Stunden) gab es keinen weiteren Log-Eintrag diesbezüglich.
        Edit: Wenn ich den Adapter erneut starte, kommt diese Meldung nicht mehr. Sie kam also nur beim ersten Start nach dem Update.
          A.
          ZarelloZ Offline
          ZarelloZ Offline
          Zarello
          #177
          @asgothian Wer lesen kann ist klar im Vorteil :man-facepalming:
          Wenn ich in den Objektdaten die Zeile
          durch
              "states": {
                "off": "off",
                "on": "on",
                "toggle": "toggle",
                "previous": "previous"
          ersetze, dann verschwinden auch die Meldungen im Log.
          Ich bezog die Log-Zeile
          Object zigbee.0.a4c1381432f0b6bb.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
          auf den Typ des Objekts statt auf den Typ des Eintrags obj.common.states.
          Mich wundert jetzt nur noch, dass diese Meldung nur für diese beiden Objekte kam und nicht für die anderen Objekte bei denen obj.common.states mit einem String gesetzt ist - von denen es noch mehrere bei mir im Zigbee-Adapter gibt.
          • arteckA arteck
            Es ist mal wieder Zeit für eine neue Version
            der @Asgothian war mal wieder nicht untätig und hat paar neue Sachen programmiert.. die schon zwr länger im Adapter drin sind aber ich finde man sollte es erwähnen
            Geräte können deaktiviert werden .. somit stören sie das Netz nicht.. nützlich für die Weihnachtsbeleuchtung
            die Kachel wird dann grau
            zum einschalten Kachel drehen
            Die Gruppenfunktionen wurde neu geschrieben und verbessert
            von mir wurden im Admin die fehlenden Icons hinzugefügt. der Adapter lädt diese runter ..
            sollte im Log nach Adapter Start solche Zeile als Warning stehen
            download icon from https://www.zigbee2mqtt.io/images/devices/929002398602.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/929002398602.png
            ist ein manueller upload notwendig
            danach sollte das Icon im Admin zur verfügung stehen
            der Object Baum wird laut dem available status eingefärbt. man kann direkt erkennen welche Geräte offline sind
            die Möglichkeit der Adapter internen Backups wurde hinzugefügt. nützlich wenn man ehh mit dem BackItUp Adapter seine Sicherung regelmässig macht. Falls nicht werden nur die letzten 10 Files behalten..
            für den Rest siehe Readme
            SegwayS Offline
            SegwayS Offline
            Segway
            schrieb am zuletzt editiert von Segway
            #178
            @arteck
            habe die Temperatur / Feuchtigkeitsmessgeräte von TuYa Modell WSD500A jetzt im Einsatz.
            Kann es sein, dass das Bild fehlt ?
            Gruß Dirk
            • SegwayS Segway
              @arteck
              Tschaeens
              schrieb am zuletzt editiert von Tschaeens
              #179
              @Asgothian
              Ich hätte eine kurze Frage. Ich habe Rauchmelder im Einsatz. Mit dem letzten Update 1.8.10 kann ich diese nicht mehr ansprechen. Es kommt folgender Fehler.
              23-01-15 10:01:23.381 - error: zigbee.0 (748) DeviceConfigure:Failed to DeviceConfigure.configure 0x0015bc003100c256 SMSZB-120 (Error: Bind 0x0015bc003100c256/35 genBinaryInput from '0x00124b0021b49875/1' failed (AREQ - ZDO - bindRsp after 10000ms)
              Hast du eine Idee?Verbunden sind sie, weil sie lesen auch die Temperatur aus.
              Jetzt:
              Ich bin auf die 1.8.9 zurück, da geht es wieder. Dennoch kommt folgender Logauszug.
              2023-01-15 10:23:59.344 - warn: zigbee.0 (748) Device '0x0015bc003100c256' announced itself
              2023-01-15 10:23:59.401 - warn: zigbee.0 (748) Object 0015bc003100c256.reliability is invalid: obj.common.states has an invalid type! Expected "object", received "string"
              2023-01-15 10:23:59.401 - warn: zigbee.0 (748) This object will not be created in future versions. Please report this to the developer.
              2023-01-15 10:23:59.403 - warn: zigbee.0 (748) Object zigbee.0.0015bc003100c256.reliability is invalid: obj.common.states has an invalid type! Expected "object", received "string"
              2023-01-15 10:23:59.403 - warn: zigbee.0 (748) This object will not be created in future versions. Please report this to the developer.
              2023-01-15 10:24:10.881 - error: zigbee.0 (748) Failed to interview '0x0015bc003100c256', device has not successfully been paired. undefined
              Gerät lässt sich wieder ansprechen.
              Lg und danke
              ? arteckA T 3 Antworten Letzte Antwort
              • T Tschaeens
                @Asgothian
                Jetzt:
                Lg und danke
                #180
                @tschaeens ist mir auch aufgefallen, muss auch wieder auf die 1.8.9 zurueck, sind noch mehr Devices, die in der 10er nicht gehen oder nicht richtig oder zumindest keinen Battery anzeigen.. Logfile debug kommt noch, ist zur Zeit keine Prio bei mir, hab andere Baustellen..
                  Tschaeens
                  #181
                  @ilovegym
                  danke für die Info. Ich habe jetzt OTA updates angezeigt bekommen. Ich werde diese jetzt mal einspielen. Kann es sein das die Hue Lightstrips keine OTA updates machen können, sondern nur mit der Original bridge?
                  Lg
                  • T Tschaeens
                    @ilovegym
                    Lg
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #182
                    @tschaeens sagte in ZigBee neue Version 1.7.x:
                    doch.. es gibt aber unterschiedliche Modelle ..auch wenn diese alle gleich aussehen
                    • T Tschaeens
                      @Asgothian
                      Jetzt:
                      Lg und danke
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #183
                      @tschaeens dann probier es mit der GIT version... ich halte die immer aktuell..und ja kann sein das der converter da ein BUG hatte..
                      • arteckA arteck
                        Tschaeens
                        #184
                        @arteck danke dir. Ich bekomme bei den Hue Lightstrips immer folgende Meldung.
                        2023-01-15 16:34:54.723 - error: zigbee.0 (2138312) Update of '0x001788010b471d34' failed (Image padding contains invalid bytes)
                        Was bedeutet das? Ich werde morgen mal die git Version testen.
                        • T Tschaeens
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #185
                          @tschaeens da stimmt mit der Version der Firmware nicht..
                          • arteckA arteck
                            Aragon
                            #186
                            @arteck Guten Abend, seit dem neuen Adapterupdate auf 1.8.10 habe ich die Fehlererscheinung, dass wenn ich meinen Zigbee Adapter Neu Starte bei einigen meiner Rollladenschalter die Kopplungs LED / (die LED die Anzeigt das der Rollladen hochgefahren wird) dauerhaft leuchtet. Die LED bekomme ich nur aus, wenn ich den Rolladenschalter neu Kopple.
                            Das passiert nicht bei jedem Neustart des Adapters.
                            Es erscheint auch eine Fehlermeldung im Protokoll:
                            zigbee.0
                            	2023-01-18 18:54:54.130	warn	This object will not be created in future versions. Please report this to the developer.
                            zigbee.0
                            	2023-01-18 18:54:54.130	warn	Object zigbee.XXXXXXXXXXXXXXX.backlight_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                            Bitte um Hilfe, es ist echt nervig jede Woche die Rollläden neu zu Koppeln.
                            GlasfaserG arteckA 2 Antworten Letzte Antwort
                            • A Aragon
                              zigbee.0
                              zigbee.0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #187
                              @aragon sagte in ZigBee neue Version 1.7.x:
                              das hat aber nichts mit dem Koppeln zu tun .
                              Lösche diesen Datenpunkt :
                              und lasse ihn vom Adapter neu anlegen (Neustart des Adapters )
                              • GlasfaserG Glasfaser
                                Aragon
                                #188
                                @glasfaser Vielen Dank für die schnelle Antwort, habe diesen Datenpunkt bei allen Rollladenschaltern, die Fehleranfällig waren gelöscht. Zigbee Adapter Neu gestartet. Werde es mal Testen. Danke
                                • A Aragon
                                  zigbee.0
                                  zigbee.0
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #189
                                  und poste mal das RAW object.. der wird falsch angelegt
                                  • arteckA arteck
                                    Aragon
                                    schrieb am zuletzt editiert von Aragon
                                    #190
                                    @arteck es ist schon wieder passiert, ohne dass ich den Zigbee Adapter neu Gestartet habe.
                                    Bin heute von der Arbeit gekommen und es Leuchteten mal wieder bei vier Rollladenschaltern die Koppel LED´s dauerhaft.
                                    so sehen meine Rollladenschalter eigentlich aus.
                                    Bei dem Obersten Taster leuchtet dann die LED Dauerhaft.
                                    zigbee.0
                                    	2023-01-25 20:16:32.114	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    	2023-01-25 20:16:32.114	warn	Object zigbee.0.xxxxxxxxxxxxxx.backlight_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    	2023-01-25 20:16:32.113	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    	2023-01-25 20:16:32.112	warn	Object zigbee.0.xxxxxxxxxxxxxx.moving is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    	2023-01-25 20:16:32.108	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    	2023-01-25 20:16:32.107	warn	Object zigbee.0.xxxxxxxxxxxxxx.state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    	2023-01-25 20:16:32.066	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    	2023-01-25 20:16:32.065	warn	Object xxxxxxxxxxxxxx.backlight_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    	2023-01-25 20:16:32.065	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    	2023-01-25 20:16:32.064	warn	Object xxxxxxxxxxxxxx.moving is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    	2023-01-25 20:16:32.064	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    	2023-01-25 20:16:32.063	warn	Object xxxxxxxxxxxxxx.state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    	2023-01-25 20:16:32.011	warn	Device 'xxxxxxxxxxxxxx' announced itself
                                    Das wird mir im Protokoll nach dem erneuten Koppeln Angezeigt.
                                    • nukleuzN Offline
                                      nukleuzN Offline
                                      nukleuz
                                      #191
                                      wie kann ich meine Messsteckdosen zurücksetzen (Verbrauchswerte)?
                                      Gibt es hier im Adapter so etwas wie eine DEV-Console?
                                      Hier der Auszug von Z2M:
                                      https://www.zigbee2mqtt.io/devices/TS011F_plug_3.html#reset-energy
                                      Reset energy
                                      To reset "Sum of consumed energy", use the Dev console and execute: Endpoint: 1 Cluster: 0x00 Command: 0 Payload: (don't change this)
                                      Next time the plug gets polled, "Sum of consumed energy" will start from zero again
                                      Danke für Info hierzu...
                                      Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                                      nukleuzN 1 Antwort Letzte Antwort
                                      • nukleuzN nukleuz
                                        Reset energy
                                        nukleuzN Offline
                                        nukleuzN Offline
                                        nukleuz
                                        #192
                                        @nukleuz
                                        Mal wieder... Wer lesen kann und so...
                                        Mit dem zweiten Anlauf hat es dann auch funktioniert - Instanz-Einstellungen-Entwickler:
                                        Danke! :)
                                        • R Offline
                                          rotamint
                                          schrieb am zuletzt editiert von rotamint
                                          #193
                                          Guten Morgen zusammen, bekomme folgende Fehlermeldung (V1.8.10 / Conbee2 V0-0.38.120.0. / rev 0x26780700):
                                          zigbee.0
                                          	2023-01-31 07:32:37.321	warn	This object will not be created in future versions. Please report this to the developer.
                                          zigbee.0
                                          	2023-01-31 07:32:37.320	warn	Object 54ef44100064fdf6.reset_nopresence_status is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                          So sieht der Datenpunkt aus (ist aber dann "ohne Funktion":
                                          Der Datenpunkt mit Funktion (aber dann auch mit o. g. Fehlermeldung, leider aber auch nur bis zum nächsten Adapter-Neustart):
                                          Kann ich den Wert "Reset:Reset" irgendwie "dauerhaft" speichern?
                                          Was kann ich gegen die Fehlermeldung machen?
                                          Danke für Eure Hilfe!
                                          LG S.
