  4. Test Adapter renault v0.0.x für myRenault und myDacia
387 Beiträge 59 Kommentatoren 100.1k Aufrufe 56 Beobachtet
  • HumidorH Humidor
    @tombox Hi, bei mir fkt. er gerade nicht, ist das bekannt?
    renault.0
    2023-01-04 12:02:55.583	error	{"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
    renault.0
    2023-01-04 12:02:55.583	error	AxiosError: Request failed with status code 500
    renault.0
    2023-01-04 12:02:55.582	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v1/cars/xxx/location?country=de
    renault.0
    2023-01-04 12:02:45.763	error	{"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
    renault.0
    2023-01-04 12:02:45.762	error	AxiosError: Request failed with status code 500
    renault.0
    2023-01-04 12:02:45.762	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-status?country=de
    renault.0
    2023-01-04 12:02:39.724	error	{"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
    renault.0
    2023-01-04 12:02:39.724	error	AxiosError: Request failed with status code 500
    renault.0
    2023-01-04 12:02:39.720	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v2/cars/xxx/cockpit?country=de
    gerade gesehen, die App fkt. auch nicht richtig
    HumidorH Offline
    HumidorH Offline
    Humidor
    #182
    wo findet sich der letzte Timestamp der letzten Aktualisierung?
    was ich meine, wann wurden zum letzten Mal Daten empfangen, dient mir als Anhaltspunkt wo die aktuelle Ladung sein könnte, ich möchte nicht auf 100% laden.
    BG
    • HumidorH Humidor
      #183
      @humidor
      renault.0.XXX.battery-status.timestamp
      renault.0.XXX.battery-status.batteryLevel
      Oder ich hbae die Frage nicht verstanden.
      HumidorH 1 Antwort Letzte Antwort
      • JLegJ Offline
        JLegJ Offline
        JLeg
        schrieb am zuletzt editiert von JLeg
        #184
        @humidor sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
        Hm, was genau meinst du? Unsere ZOE lädt normalerweise auch nur bis 80% :-) - dazu fragt ein Blockly den Status
        renault.0.VFxxx.battery-status.batteryLevel ab. Klappt eigentlich immer mit max. 1-2%-Punkten zuviel.
        Ansonsten - auch dieser Datenpunkt hat natürlich zwei Timestamps (letzte Änderung, letzter "Kontakt") - damit könnte man vermutlich das machen, was du vorhast?
        Edit: Ups, Dreisteins Antwort ist erst nach Absenden "erschienen"; ja der DP "timestamp" sollte auch gehen, entspricht wohl mehr oder weniger dem o.g. für "letzte Änderung"...
          @humidor
          HumidorH Offline
          HumidorH Offline
          Humidor
          #185
          @dreistein wird so sein, danke
          mir gehts nicht darum mit Blockly abzuschalten, das mache ich ja, es geht darum wenn die Ladung läuft, aber der Adapter nicht aktualisiert, dann läuft die Ladung weiter bis 100%.
          Es gäbe auch die Vorgabe wieviel kWh man laden will, aber dazu bin ich noch nicht gekommen
          BG
          • HumidorH Humidor
            #186
            @humidor
            Wie wäre es, die Restliche Ladezeit - x Minuten zu verwenden ?
            Mit :
            renault.0.XXX.battery-status.chargingRemainingTime
            und
            renault.0.XXX.battery-status.chargingInstantaneousPower
            kann man mit einer Total Geheimen Geheim Formel sicher was machen.
            Wenn Adapter aktualisiert, alles gut.
            Wenn nicht, Ladung eben x Minuten vor dem Ende Unterbrechen.
              @humidor
              Mit :
              und
              HumidorH Offline
              HumidorH Offline
              Humidor
              #187
              @dreistein da stellt sich die Frage, was einfacher ist. KIS
              denke die zu ladenden kWh sind schneller berechnet
              BG
              • HumidorH Humidor
                #188
                @humidor
                Da fehlt ein "S". K.I.S.S.
                Keep it super* simple
                *stupid
                  @humidor
                  *stupid
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  #189
                  @dreistein wollte nicht super oder stupid anfügen, die Sache ist ja nicht trivial 😁
                  BG
                    KremmyMa
                    #190
                    @tombox Möchte gern den Reanault adapter für den Megane e tech testen. Wo muss ich die VIN eingeben? Es werden auch keine weiteren Objekte angelegt. Ich dehr im Prokolle folgende Fehlermeldungen: 45fa2f69-5125-47ff-a7cb-0b530677dda0-image.png
                    myRenault Registrierung ist erfolgt und API key ist auch aktualisiert.
                    Was mache ich verkehrt?
                    • K KremmyMa
                      KremmyMa
                      #191
                      @kremmyma hab es gerade selber gefunden:
                      Nach dem Eintragen vom Land = DE kamen dann auch schob die entsprechenden Objekt einschließlich der VIN automatisch.
                      Also der ADAPTER liest auch die werte vom Renault Megane E Tech.
                      Bin gespannt was so alles geht damit.
                      Erstmal ein Dankeschön an den Entwickler!!
                      • K KremmyMa
                        tombox
                        #192
                        @kremmyma
                        Wie hast du den Etech gepairt?
                        Welche app nutzt du
                        Welche Werte werden im iobroker angezeigt?
                          KremmyMa
                          schrieb am zuletzt editiert von KremmyMa
                          #193
                          @tombox Was meins Du mit Etech gepairt ?
                          Ich nutze den account von myRenault
                          Folgende Werte kann ich im ioBroker zur Zeit auslesen:
                          • K KremmyMa
                            tombox
                            #194
                            @kremmyma Etech hat Android Automotive welches bei Volvo ein sehr komplexes pairing/verknüpfungs verfahren hat. Aber wenn er einfach im account ist dann ist das ja sehr gut.
                            Holger Dietrich 0H M K M 4 Antworten Letzte Antwort
                            • T tombox
                              Holger Dietrich 0H Offline
                              Holger Dietrich 0
                              #195
                              @tombox
                              Hi
                              ich bekomme folgende Fehlermeldung
                              No valid response1 from getKamereonAccount service
                              der API key ist dieser
                              Ae9FDWugRxZQAGm3Sxgk7uJn6Q4CGEA2
                              kann mir jemand hier weiterhelfen?
                              caravandriverC 1 Antwort Letzte Antwort
                              • Holger Dietrich 0H Holger Dietrich 0
                                @tombox
                                Hi
                                caravandriverC Offline
                                caravandriver
                                schrieb am zuletzt editiert von caravandriver
                                #196
                                Kann es sein, das der Adapter seit gestern nicht mehr läuft.
                                Ich erhalte "No account found" im Log.
                                Die Handyapp läuft mit den Zugangsdaten.
                                Da diverse Automatisierungen in Sachen Solarinsel von den Daten abhängen habe ich hier eine Erkennung gebaut ob die Daten aktuell sind. Vielleicht hilft es jemandem.
                                Auf den gesetzten Schalter reagiere ich dann mit den Regelungsscripten. So ist sichergestellt, das dass Auto auch morgens einsatzbereit ist.
                                • O Online
                                  O Online
                                  Oli
                                  schrieb am zuletzt editiert von Oli
                                  #197
                                  @tombox
                                  erstmal wieder ein dickes Dankeschön für den Adapter.
                                  Gibt es eine Möglichkeit den nächsten Wartungstermin aus der App mit auszulesen?
                                  Oliver
                                  Marcus HamburgM 1 Antwort Letzte Antwort
                                  • O Oli
                                    @tombox
                                    Marcus HamburgM Offline
                                    Marcus Hamburg
                                    #198
                                    Hallo, ich muss aktuell mein Iobroker neu aufbauen und scheitere gerade am Renault Adapter. Wir haben seit kurzen einen neuen Duster (und wer es nicht weiß, ausserhalb der EU von Renault vertrieben). Wenn ich den Adapter mit mein Renault Account einrichte, dann erscheint jetzt nur noch der Duster - aber wo ist unser ZOE. Der Duster interessiert nicht wirklich, will ja sehe wie voll die Zoe ist. Hat noch jemand das Problem oder wurde das Problem mal gefixt?
                                    • Marcus HamburgM Marcus Hamburg
                                      tombox
                                      #199
                                      @marcus-hamburg wenn ein Dacia und ein Renault auf einem account läuft ist es schwierig besser ist dafür sperrte emails zu verwenden
                                      • T tombox
                                        Mike Hellracer
                                        schrieb am zuletzt editiert von Mike Hellracer
                                        #200
                                        @tombox
                                        Hi ich kann mache, was ich will ich bekomme im wrong API Key.
                                        was mache ich blos falsch. bzw. kann mir jemand den richtigen geben? probiert habe ich alle möglichen.
                                        Edit: ich habe gefunden im Adapter steht als Land "Deutschland"
                                        richtig wäre aber DE oder de
                                        • T tombox
                                          KremmyMa
                                          #201
                                          @tombox Hallo ich bekomme von meinem Megane über den Renault Adapter etliche Datenpunkte, aber leider keinen um den maximalen Ladestand z.B auf 80% zu begrenzen. Gibt es den nicht remote ?
