  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • apollon77A apollon77
    @micw42 Also im log steht das iobroker gestartet ist und zu dem Zeitopunkt im Log war keine DB locked ...
    micw42
    #276
    Also wenn ich den iobroker-log und den System-log zusammenfasse:
    2022-11-21 08:17:22.426 - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-11-21 08:17:22.433 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-11-21 08:17:22.434 - info: host.raspberrypi hostname: raspberrypi, node: v14.20.0
    2022-11-21 08:17:22.435 - info: host.raspberrypi ip addresses: 192.168.178.56 fd00::85ce:9c7a:3bcd:95ac fe80::3782:4c12:e099:c79e
    2022-11-21 08:17:24.559 - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Nov 21 08:17:24 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=24/n/a
    Nov 21 08:17:24 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Nov 21 08:17:27 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
    Nov 21 08:17:27 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
    Nov 21 08:17:27 raspberrypi systemd[1]: Stopped ioBroker Server.
    Nov 21 08:17:27 raspberrypi systemd[1]: Started ioBroker Server.
    2022-11-21 08:17:29.145 - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-11-21 08:17:29.153 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-11-21 08:17:29.153 - info: host.raspberrypi hostname: raspberrypi, node: v14.20.0
    2022-11-21 08:17:29.154 - info: host.raspberrypi ip addresses: 192.168.178.56 fd00::85ce:9c7a:3bcd:95ac fe80::3782:4c12:e099:c79e
    2022-11-21 08:17:31.270 - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Nov 21 08:17:31 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=24/n/a
    Nov 21 08:17:31 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Nov 21 08:17:34 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
    Nov 21 08:17:34 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2.
    Nov 21 08:17:34 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
    Nov 21 08:17:34 raspberrypi systemd[1]: Stopped ioBroker Server.
    Nov 21 08:17:34 raspberrypi systemd[1]: Started ioBroker Server.
    Es sieht doch für mich so aus, als wenn der pi (aus welchem Grund auch immer) neu gestartet ist, der iobroker aber wegen des DB locks nicht starten konnte?
    Erst mit Ziehen des Steckers und nochmaligem Neustart lief wieder alles.
    Oder sehe ich das komplett falsch?
    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
    • M micw42
      #277
      @micw42 sagte in Server Cannot start inMem-objects on port 9001:
      ???? Nie einfach den Stecker ziehen!
      systemctl status iobroker
      sagt? Bitte in CodeTags eingebettet posten.
      • M micw42
        apollon77A Online
        apollon77A Online
        #278
        @micw42 Also ja ok ... hatte nicht gesehen das der eine Start 1h später war.
        Das interessante ist das das letze im Log der "dritte "Started" ist und dann weder im syslog oder woanders nochwas kommt. Und wenn du auch sagst das SSH nicht mehr ging dann hat das system irgendwas. Weil dann ist das ja scheinbar komplett hängen geblieben - keine AHung ob es nicht auch passiert wäre wenn iobroker gestartet wäre.
        Aber ja es kann sein das bei so einem harten restart vom host das DLB Lock file noch da ist und es so beim Reboot zu diesem Fehler kommt weil halt das lock File der DB noch da ist ... das expired glaube ich 5 Minuten später oder so. Aber normalerweise gibt das dann einfach mehrere Startversuche bis dann einer tut.
        Das komisch bei dir ist das der rechner komplett nach 2 versuchen einfriert (weil SSH ja auch nicht geht) ... also da ist was anderes als ioBroker im Argen.
        Und dein Problem ist daher definitiv was anderes
          micw42
          #279
          @apollon77 Danke für die Hilfe! Ich muss also "nur" rausfinden, warum sich der pi rebootet ...
          • M micw42
            apollon77A Online
            apollon77A Online
            #280
            @micw42 ja damit würde ich starten ;-)) sorry das ich da nicht mehr helfen kann. Ich persönlich würde mit dem Netzteil anfangen.
            • W Offline
              W Offline
              woehrer
              #281
              ich habe jetzt hier schon einiges gelesen aber leider war die richtige Lösung für mich noch nicht greifbar. Habe natürlich auch schon das ein oder andere versucht.
              woehrer@iobrokerifa:/opt/iobroker/iobroker-data$ cd ..
              woehrer@iobrokerifa:/opt/iobroker$ iob version
              4.0.23
              woehrer@iobrokerifa:/opt/iobroker$ iob status
              Objects type: jsonl
              States  type: jsonl
              woehrer@iobrokerifa:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
              2022-12-22 08:42:12.631  - info: host.iobrokerifa iobroker.js-controller version 4.0.23 js-controller starting
              2022-12-22 08:42:12.635  - info: host.iobrokerifa Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
              2022-12-22 08:42:12.636  - info: host.iobrokerifa hostname: iobrokerifa, node: v14.21.1
              2022-12-22 08:42:12.636  - info: host.iobrokerifa ip addresses: 192.168.20.70 fe80::11:32ff:fe27:dee
              2022-12-22 08:42:14.720  - error: host.iobrokerifa-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
              woehrer@iobrokerifa:/opt/iobroker$ node -v
              v14.21.1
              woehrer@iobrokerifa:/opt/iobroker$ npm -v
              6.14.17
              woehrer@iobrokerifa:/opt/iobroker$ sudo ss -tulpn | grep LISTEN
              tcp   LISTEN 0      511             127.0.0.1:9000       0.0.0.0:*    users:(("iobroker.js-con",pid=672,fd=26))
              tcp   LISTEN 0      511             127.0.0.1:9001       0.0.0.0:*    users:(("iobroker.js-con",pid=672,fd=20))
              tcp   LISTEN 0      511               0.0.0.0:50001      0.0.0.0:*    users:(("io.sia.0",pid=1748,fd=26))
              tcp   LISTEN 0      4096        127.0.0.53%lo:53         0.0.0.0:*    users:(("systemd-resolve",pid=654,fd=14))
              tcp   LISTEN 0      128               0.0.0.0:22         0.0.0.0:*    users:(("sshd",pid=720,fd=3))
              tcp   LISTEN 0      511                     *:8082             *:*    users:(("io.web.0",pid=1152,fd=27))
              tcp   LISTEN 0      128                  [::]:22            [::]:*    users:(("sshd",pid=720,fd=4))
              tcp   LISTEN 0      511                     *:8087             *:*    users:(("io.simple-api.0",pid=1863,fd=26))
              Wäre echt super wenn mir da noch jemand ein Tipp hätte.
              • W woehrer
                4.0.23
                Objects type: jsonl
                States  type: jsonl
                v14.21.1
                6.14.17
                #282
                @woehrer sagte in Server Cannot start inMem-objects on port 9001:
                ein Tipp hätte.
                NodeJS v16 fahren.
                W 1 Antwort Letzte Antwort
                • W woehrer
                  4.0.23
                  Objects type: jsonl
                  States  type: jsonl
                  v14.21.1
                  6.14.17
                  apollon77A Online
                  apollon77A Online
                  #283
                  @woehrer Also als allererstes:
                  • iob stop
                  • 1 Minute warten
                  • iob fix - dort dann vor allem bitte schauen bei "Step 3" und Ausgabe posten bzw sagen wie lang das bedauert hat
                  • iob start
                  tuts dann?
                  • W Offline
                    W Offline
                    woehrer
                    #284
                    @apollon77 :
                    Der komplette fix ist in ca 15 Sekunden durchgelaufen. Das hatte ich schon versucht. Läuft leider trotzdem nicht.
                    woehrer@iobrokerifa:/opt/iobroker$ iobroker fix
                    library: loaded
                    Library version=2022-12-09
                        Welcome to the ioBroker installation fixer!
                        Script version: 2022-12-09
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/4)
                    [sudo] password for woehrer:
                    OK:1 https://deb.nodesource.com/node_14.x focal InRelease
                    OK:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                    Holen:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                    Holen:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [99,8 kB]
                    Holen:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                    Es wurden 324 kB in 1 s geholt (501 kB/s).
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/4)
                        Database maintenance (3/4)
                    Checking for uncompressed JSONL databases... This might take a while!
                    npx: Installierte 12 in 4.456s
                    No path given, using /opt/iobroker/iobroker-data
                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                    Compressed 2 JSONL files. Done
                        Checking autostart (4/4)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                      ein Tipp hätte.
                      NodeJS v16 fahren.
                      W Offline
                      W Offline
                      woehrer
                      #285
                      Bin jetzt mal hoch auf v16
                      v16.19.0
                      8.19.3
                      library: loaded
                      OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                      Holen:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                      OK:3 https://deb.nodesource.com/node_16.x jammy InRelease
                      Es wurden 324 kB in 1 s geholt (576 kB/s).
                      Installed gcc-c++
                      Autostart enabled!
                      Bekomme immernoch die Fehlermeldung und der admin Adapter startet weiterhin nicht. Alles andere scheint aber zu laufen
                      Thomas BraunT crunchipC W 3 Antworten Letzte Antwort
                      • W woehrer
                        v16.19.0
                        8.19.3
                        library: loaded
                        Installed gcc-c++
                        Autostart enabled!
                        #286
                        @woehrer
                        iobroker diag
                        ausführen und Ergebnisse bekannt geben.
                        • W woehrer
                          v16.19.0
                          8.19.3
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #287
                          iob logs --watch
                          iob list instances
                          • W woehrer
                            v16.19.0
                            8.19.3
                            library: loaded
                            Installed gcc-c++
                            Autostart enabled!
                            W Offline
                            W Offline
                            woehrer
                            schrieb am zuletzt editiert von woehrer
                            #288
                            @woehrer
                                                    v.2022-12-13
                            Operatingsystem:        Ubuntu 22.04.1 LTS
                            Installation:           microsoft
                            Timezone:               Europe/Berlin
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                            Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                                    /usr/bin/node           v16.19.0
                                                    /usr/bin/npm            8.19.3
                            ioBroker Core:          js-controller           4.0.23
                                                    admin                   6.3.3
                            Objects type: jsonl
                            States  type: jsonl
                            Pending iob updates:    2
                            Active repo(s): stable
                            Objects:                6726
                            States:                 6193
                            Size of iob-Database:
                            7.5M    /opt/iobroker/iobroker-data/objects.jsonl
                            4.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                            4.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            5.0M    /opt/iobroker/iobroker-data/states.jsonl
                            1.2M    /opt/iobroker/iobroker-data/states.json.migrated
                            1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            ====================== END OF SUMMARY ==================
                            2022-12-22 09:47:26.773  - info: host.iobrokerifa instance system.adapter.admin.0 started with pid 3788
                            2022-12-22 09:47:27.787  - info: admin.0 (3788) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
                            2022-12-22 09:47:27.814  - info: admin.0 (3788) requesting all states
                            2022-12-22 09:47:27.816  - info: admin.0 (3788) requesting all objects
                            2022-12-22 09:47:27.956  - warn: admin.0 (3788) Cannot check node.js versions: Error: unexpected end of file
                            2022-12-22 09:47:28.326  - info: admin.0 (3788) received all objects
                            2022-12-22 09:47:28.438  - info: admin.0 (3788) Request actual repository...
                            2022-12-22 09:47:28.523  - info: admin.0 (3788) http server listening on port 8081
                            2022-12-22 09:47:28.523  - info: admin.0 (3788) Use link "http://localhost:8081" to configure.
                            2022-12-22 09:47:28.527  - info: admin.0 (3788) socket.io server listening on port 8081
                            2022-12-22 09:47:28.539  - error: admin.0 (3788) uncaught exception: Cannot read properties of null (reading '_acl')
                            2022-12-22 09:47:28.539  - error: admin.0 (3788) TypeError: Cannot read properties of null (reading '_acl')
                                at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                                at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                                at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                                at processImmediate (node:internal/timers:468:21)
                            2022-12-22 09:47:28.540  - error: admin.0 (3788) Cannot read properties of null (reading '_acl')
                            2022-12-22 09:47:28.556  - info: admin.0 (3788) terminating http server on port 8081
                            2022-12-22 09:47:28.560  - info: admin.0 (3788) terminating
                            2022-12-22 09:47:28.561  - warn: admin.0 (3788) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2022-12-22 09:47:28.779  - info: host.iobrokerifa Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
                            2022-12-22 09:47:28.814  - error: host.iobrokerifa instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2022-12-22 09:47:28.814  - info: host.iobrokerifa Restart adapter system.adapter.admin.0 because enabled
                            • W woehrer
                              @woehrer
                                                      v.2022-12-13
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            8.19.3
                                                      admin                   6.3.3
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                6726
                              States:                 6193
                              #289
                              @woehrer
                              Das ist WSL2 oder sowas?
                                @woehrer
                                W Offline
                                W Offline
                                woehrer
                                #290
                                Das ist eine virtuelle Maschine in der Ubuntu 22 läuft
                                • W woehrer
                                  #291
                                  virtuelle Maschine
                                  Welche?
                                  • crunchipC Abwesend
                                    crunchipC Abwesend
                                    #292
                                    @woehrer selbiges ist auch hier
                                    https://forum.iobroker.net/post/914523
                                    • W woehrer
                                      @woehrer
                                                              v.2022-12-13
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            8.19.3
                                                              admin                   6.3.3
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                6726
                                      States:                 6193
                                      apollon77A Online
                                      apollon77A Online
                                      #293
                                      @woehrer Admin 6.3.5 installieren!
                                        Karl 1
                                        #294
                                        Bei mir ist ein ähnliches Problem aufgetreten wie bei bischemer am 14. März 2022 und bei offensichtlich mehreren anderen.
                                        Ich habe den RPI mit sudo shutdown -h 0 runtergefahren, die Stromversorgung abgeklemmt und mit Win32DiskImager die SD auf eine Backup Platte kopiert.
                                        Nach dem erneuten Einlegen der SD und Anlegen der Versorgungsspannung startet der RPI und auch der ioBroker, der Zugriff über das Web Interface und Vis ist nicht mehr möglich.
                                        Den gleichen Effekt hatte ich schon vor einigen Wochen, ich habe mich damit beholfen, dass ich mit einem früheren Backup alle zwischenzeitlichen Änderungen nachgezogen habe (was man einmal machen kann, was aber keine Dauerlösung ist).
                                        Da der Effekt m.E. entweder mit dem Shutdown oder dem Abklemmen der Versorgung zu tun hat, kann dieses Problem immer wieder auftauchen, sei es bei einem regulären Backup oder bei einem Spannungsausfall im Versorgungsnetz.
                                        Ich habe alles hier Geschriebene gelesen und nachvollzogen aber keine Lösung für mich gefunden!
                                        Angefügt einige Infos zu meinem Problem:
                                        pi@raspberrypi:~ $ iob info
                                        2023-01-02 19:09:42.694  - error: host.raspberrypi No connection to databases possible, restart
                                        2023-01-02 19:09:42.748  - info: host.raspberrypi iobroker _restart
                                        2023-01-02 19:09:48.841  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                                        2023-01-02 19:09:48.862  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                        2023-01-02 19:09:48.865  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
                                        2023-01-02 19:09:48.867  - info: host.raspberrypi ip addresses: 192.168.178.43 2003:ea:f10:b800:e3c1:cab5:4a9b:7a32 fe80::78fb:de3d:17ae:be62
                                        2023-01-02 19:10:18.939  - error: host.raspberrypi No connection to databases possible, restart
                                        ```pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -l
                                        insgesamt 529504
                                        drwxrwxrwx+   2 iobroker iobroker      4096 Mai  2  2022 backitup
                                        drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 09:26 backup-objects
                                        drwxrwxrwx+  21 iobroker iobroker      4096 Nov 26 11:59 files
                                        drwxrwxrwx+ 185 iobroker iobroker     12288 Jan  2 00:02 history
                                        -rw-rwxrw-+   1 iobroker iobroker      4715 Mai  2  2022 iobroker.json
                                        -rw-rw-rw-+   1 iobroker iobroker         3 Jan  2 11:11 notifications.json
                                        -rw-rw-rw-+   1 iobroker iobroker   3715730 Mai  2  2022 objects.json.bak.migrated
                                        -rw-rw-rw-+   1 iobroker iobroker 524134421 Jan  2 10:52 objects.jsonl
                                        drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 19:44 objects.jsonl.lock
                                        -rw-rw-rw-+   1 iobroker iobroker   3718224 Mai  2  2022 objects.json.migrated
                                        -rw-rw-rw-+   1 iobroker iobroker    442833 Mai  2  2022 states.json.bak.migrated
                                        -rw-rw-rw-+   1 iobroker iobroker   9691615 Jan  2 11:11 states.jsonl
                                        -rw-rw-rw-+   1 iobroker iobroker    442977 Mai  2  2022 states.json.migrated
                                        • K Karl 1
                                          insgesamt 529504
                                          apollon77A Online
                                          apollon77A Online
                                          #295
                                          @karl-1 Dann fang doch mal mit "iob fix" an ... danach sollte deine objects.jsonl kleiner sein ... gehts dann besser?
