  4. Test Adapter melcloud v4.0.x Latest
klimaanlagemelcloudmitsubishitest
243 Beiträge 31 Kommentatoren 79.6k Aufrufe 29 Beobachtet
  • Black ThunderB Black Thunder
    @cookie98 Du müsstest bitte noch vorher die Logstufe auf "Debug" stellen. Unter "Instanzen":
    Sonst fehlen die relevanten Informationen über die Kommunikation mit der Cloud.
    C
    C
    cookie98
    schrieb am zuletzt editiert von cookie98
    #77
    @black-thunder said in Test Adapter melcloud v1.2.x Latest:
    Sry der Schlaf der gerechten hat zu geschlagen
    2022-12-05 12:16:45.235 - debug: melcloud.0 (27796) Trying to get device object with id 57416137...
    2022-12-05 12:16:45.236 - debug: melcloud.0 (27796) Processing command 'getPowerConsumptionReport' with value 'true' for device object with id 57416137 (Wert)...
    2022-12-05 12:16:45.237 - debug: melcloud.0 (27796) Getting power consumption report for 57416137 (Wert)
    2022-12-05 12:16:45.280 - warn: melcloud.0 (27796) No valid start date was provided (format: YYYY-MM-DD). Defaulting to 6 months prior.
    2022-12-05 12:16:45.280 - warn: melcloud.0 (27796) No valid end date was provided (format: YYYY-MM-DD). Defaulting to today.
    2022-12-05 12:16:45.438 - debug: melcloud.0 (27796) Trying to get device object with id 57416137...
    2022-12-05 12:16:45.438 - debug: melcloud.0 (27796) Processing command 'getPowerConsumptionReport' with value 'true' for device object with id 57416137 (Wert)...
    2022-12-05 12:16:45.438 - debug: melcloud.0 (27796) Getting power consumption report for 57416137 (Wert)
    2022-12-05 12:16:45.441 - debug: melcloud.0 (27796) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/EnergyCost/Report (status code: 200 - OK)
    2022-12-05 12:16:45.441 - debug: melcloud.0 (27796) Response from cloud: {"HotWater":[0],"InternalTemperature1":null,"InternalTemperature2":null,"ExternalTemperature":null,"Cooling":[0],"Heating":[93.11],"CoP":[2.0450005369992486],"MissingSampleQuarter":[null,null,null,null],"MissingSampleMonth":[null,null,null,null,null,null,null,null,null,null,null,null],"ProducedHotWater":[0],"ProducedCooling":[0],"ProducedHeating":[190.41000000000003],"TotalHeatingConsumed":93.11,"TotalCoolingConsumed":0,"TotalHotWaterConsumed":0,"TotalHeatingProduced":190.41000000000003,"TotalCoolingProduced":0,"TotalHotWaterProduced":0,"AverageInternalTemperature":0,"AverageExternalTemperature":0,"Status":0,"LabelType":2,"TempLabels":null,"Labels":[12],"HasZone2":false,"CurrencySymbol":"kWh","FromDate":"2022-12-01T00:00:00","ToDate":"2022-12-05T00:00:00","DeviceName":"Wert","BuildingAddress":null,"BuildingCity":null,"BuildingCountry":null,"CustomerName":null,"costs":null,"TotalMinutes":263520,"MissingMinutes":263220}
    2022-12-05 12:16:45.485 - warn: melcloud.0 (27796) No valid start date was provided (format: YYYY-MM-DD). Defaulting to 6 months prior.
    2022-12-05 12:16:45.485 - warn: melcloud.0 (27796) No valid end date was provided (format: YYYY-MM-DD). Defaulting to today.
    2022-12-05 12:16:45.531 - debug: melcloud.0 (27796) Updated report data for device 57416137 (Wert)
    2022-12-05 12:16:45.613 - debug: melcloud.0 (27796) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/EnergyCost/Report (status code: 200 - OK)
    2022-12-05 12:16:45.613 - debug: melcloud.0 (27796) Response from cloud: {"HotWater":[0],"InternalTemperature1":null,"InternalTemperature2":null,"ExternalTemperature":null,"Cooling":[0],"Heating":[93.11],"CoP":[2.0450005369992486],"MissingSampleQuarter":[null,null,null,null],"MissingSampleMonth":[null,null,null,null,null,null,null,null,null,null,null,null],"ProducedHotWater":[0],"ProducedCooling":[0],"ProducedHeating":[190.41000000000003],"TotalHeatingConsumed":93.11,"TotalCoolingConsumed":0,"TotalHotWaterConsumed":0,"TotalHeatingProduced":190.41000000000003,"TotalCoolingProduced":0,"TotalHotWaterProduced":0,"AverageInternalTemperature":0,"AverageExternalTemperature":0,"Status":0,"LabelType":2,"TempLabels":null,"Labels":[12],"HasZone2":false,"CurrencySymbol":"kWh","FromDate":"2022-12-01T00:00:00","ToDate":"2022-12-05T00:00:00","DeviceName":"Wert","BuildingAddress":null,"BuildingCity":null,"BuildingCountry":null,"CustomerName":null,"costs":null,"TotalMinutes":263520,"MissingMinutes":263220}
    2022-12-05 12:16:45.657 - debug: melcloud.0 (27796) Updated report data for device 57416137 (Wert)
    2022-12-05 12:18:00.010 - info: melcloud.0 (27796) Scheduled restart.
    2022-12-05 12:18:00.011 - debug: melcloud.0 (27796) Cleared polling timer.
    2022-12-05 12:18:00.012 - info: melcloud.0 (27796) onUnload(): Cleaned everything up...
    2022-12-05 12:18:00.015 - info: melcloud.0 (27796) terminating
    2022-12-05 12:18:00.016 - info: melcloud.0 (27796) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-12-05 12:18:00.573 - info: host.iobroker-iobroker1 instance system.adapter.melcloud.0 scheduled normal terminated and will be restarted on schedule.
    2022-12-05 12:18:00.574 - info: host.iobroker-iobroker1 Restart adapter system.adapter.melcloud.0 because enabled
    2022-12-05 12:18:01.685 - info: host.iobroker-iobroker1 instance system.adapter.melcloud.0 started with pid 27897
    2022-12-05 12:18:04.852 - debug: melcloud.0 (27897) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-12-05 12:18:04.875 - debug: melcloud.0 (27897) Objects client ready ... initialize now
    2022-12-05 12:18:04.876 - debug: melcloud.0 (27897) Objects create System PubSub Client
    2022-12-05 12:18:04.877 - debug: melcloud.0 (27897) Objects create User PubSub Client
    2022-12-05 12:18:04.900 - debug: melcloud.0 (27897) Objects client initialize lua scripts
    2022-12-05 12:18:04.905 - debug: melcloud.0 (27897) Objects connected to redis: 127.0.0.1:9001
    2022-12-05 12:18:04.920 - debug: melcloud.0 (27897) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-12-05 12:18:04.928 - debug: melcloud.0 (27897) States create System PubSub Client
    2022-12-05 12:18:04.929 - debug: melcloud.0 (27897) States create User PubSub Client
    2022-12-05 12:18:04.980 - debug: melcloud.0 (27897) States connected to redis: 127.0.0.1:9000
    2022-12-05 12:18:05.077 - info: melcloud.0 (27897) starting. Version 1.2.0 (non-npm: Black-Thunder/ioBroker.melcloud) in /opt/iobroker/node_modules/iobroker.melcloud, node: v16.18.1, js-controller: 4.0.23
    2022-12-05 12:18:05.233 - debug: melcloud.0 (27897) Schedule restart: */2 * * * *
    2022-12-05 12:18:05.343 - debug: melcloud.0 (27897) Initializing objects...
    2022-12-05 12:18:05.404 - debug: melcloud.0 (27897) Checking adapter settings...
    2022-12-05 12:18:05.405 - debug: melcloud.0 (27897) Getting current known devices...
    2022-12-05 12:18:05.477 - debug: melcloud.0 (27897) Found known device: 57416137
    2022-12-05 12:18:05.478 - info: melcloud.0 (27897) Connecting initially to MELCloud and retrieving data...
    2022-12-05 12:18:05.479 - debug: melcloud.0 (27897) Fetching context key...
    2022-12-05 12:18:05.479 - debug: melcloud.0 (27897) MELCloud email address: c.schanze@gmx.de - MELCloud password: Jenni1108
    2022-12-05 12:18:05.960 - debug: melcloud.0 (27897) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Login/ClientLogin (status code: 200 - OK)
    2022-12-05 12:18:05.961 - debug: melcloud.0 (27897) Response from cloud: {"ErrorId":null,"ErrorMessage":null,"LoginStatus":0,"UserId":0,"RandomKey":null,"AppVersionAnnouncement":null,"LoginData":{"ContextKey":"7B94C69756DE4520965EC26971B58A","Client":117173,"Terms":1282,"AL":1,"ML":0,"CMI":true,"IsStaff":false,"CUTF":false,"CAA":false,"ReceiveCountryNotifications":false,"ReceiveAllNotifications":false,"CACA":false,"CAGA":false,"MaximumDevices":10,"ShowDiagnostics":false,"Language":4,"Country":85,"RealClient":0,"Name":"Christian Schanze","UseFahrenheit":false,"Duration":525600,"Expiry":"2023-12-05T11:18:05.7","CMSC":false,"PartnerApplicationVersion":null,"EmailSettingsReminderShown":true,"EmailUnitErrors":0,"EmailCommsErrors":0,"ChartSeriesHidden":0,"DeletePending":false,"IsImpersonated":false,"LanguageCode":"de","CountryName":"Deutschland","CurrencySymbol":"€","SupportEmailAddress":null,"DateSeperator":"/","TimeSeperator":":","AtwLogoFile":"ecodan_logo.png","DECCReport":false,"CSVReport1min":false,"HidePresetPanel":false,"EmailSettingsReminderRequired":false,"TermsText":null,"MapView":false,"MapZoom":15,"MapLongitude":8.91480230887504,"MapLatitude":52.24795056737217},"ListPendingInvite":[],"ListOwnershipChangeRequest":[],"ListPendingAnnouncement":[],"LoginMinutes":0,"LoginAttempts":0}
    2022-12-05 12:18:05.962 - debug: melcloud.0 (27897) Login successful. ContextKey: 7B94C69756DE4520965EC26971B58A
    2022-12-05 12:18:05.962 - debug: melcloud.0 (27897) Fetching devices...
    2022-12-05 12:18:06.249 - debug: melcloud.0 (27897) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices (status code: 200 - OK)
    2022-12-05 12:18:06.250 - debug: melcloud.0 (27897) Response from cloud: [{"ID":502693,"Name":"Fg","AddressLine1":"Bb","AddressLine2":null,"City":"Bvl","Postcode":"325","Latitude":51.165691,"Longitude":10.451526,"District":null,"FPDefined":false,"FPEnabled":false,"FPMinTemperature":14,"FPMaxTemperature":16,"HMDefined":false,"HMEnabled":false,"HMStartDate":null,"HMEndDate":null,"BuildingType":1,"PropertyType":8,"DateBuilt":null,"HasGasSupply":true,"LocationLookupDate":"2022-12-02T12:34:22.847","Country":85,"TimeZoneContinent":3,"TimeZoneCity":49,"TimeZone":119,"Location":1351,"CoolingDisabled":false,"Expanded":true,"Structure":{"Floors":[],"Areas":[],"Devices":[{"DeviceID":57416137,"DeviceName":"Wert","BuildingID":502693,"BuildingName":null,"FloorID":null,"FloorName":null,"AreaID":null,"AreaName":null,"ImageID":-1,"InstallationDate":null,"LastServiceDate":null,"Presets":[],"OwnerID":117173,"OwnerName":null,"OwnerEmail":null,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","Zone1Name":null,"Zone2Name":null,"MinTemperature":0,"MaxTemperature":40,"HideVaneControls":false,"HideDryModeControl":false,"HideRoomTemperature":false,"HideSupplyTemperature":false,"HideOutdoorTemperature":false,"BuildingCountry":null,"OwnerCountry":null,"AdaptorType":3,"LinkedDevice":null,"Type":1,"MacAddress":"70:61:be:ef:ce:86","SerialNumber":"2229012156","Device":{"PCycleActual":0,"ErrorMessages":"","DeviceType":1,"FTCVersion":1700,"FTCRevision":"r0","LastFTCVersion":0,"LastFTCRevision":null,"FTCModel":2,"RefridgerentAddress":0,"DipSwitch1":0,"DipSwitch2":160,"DipSwitch3":16,"DipSwitch4":0,"DipSwitch5":0,"DipSwitch6":0,"HasThermostatZone1":true,"HasThermostatZone2":true,"TemperatureIncrement":0.5,"DefrostMode":0,"HeatPumpFrequency":76,"MaxSetTemperature":45,"MinSetTemperature":25,"RoomTemperatureZone1":19,"RoomTemperatureZone2":19,"OutdoorTemperature":1,"FlowTemperature":46,"FlowTemperatureZone1":45.5,"FlowTemperatureZone2":25,"FlowTemperatureBoiler":25,"ReturnTemperature":44,"ReturnTemperatureZone1":38,"ReturnTemperatureZone2":25,"ReturnTemperatureBoiler":25,"BoilerStatus":false,"BoosterHeater1Status":false,"BoosterHeater2Status":false,"BoosterHeater2PlusStatus":false,"ImmersionHeaterStatus":false,"WaterPump1Status":true,"WaterPump2Status":true,"WaterPump3Status":false,"ValveStatus3Way":false,"ValveStatus2Way":true,"WaterPump4Status":false,"ValveStatus2Way2a":false,"ValveStatus2Way2b":false,"TankWaterTemperature":25,"UnitStatus":0,"HeatingFunctionEnabled":true,"ServerTimerEnabled":false,"ThermostatStatusZone1":false,"ThermostatStatusZone2":false,"ThermostatTypeZone1":2,"ThermostatTypeZone2":2,"MixingTankWaterTemperature":0,"CondensingTemperature":0,"DemandPercentage":100,"ConfiguredDemandPercentage":null,"HasDemandSideControl":false,"DailyHeatingEnergyConsumed":31.66,"DailyCoolingEnergyConsumed":0,"DailyHotWaterEnergyConsumed":0,"DailyHeatingEnergyProduced":49.74,"DailyCoolingEnergyProduced":0,"DailyHotWaterEnergyProduced":0,"DailyLegionellaActivationCounter":0,"LastLegionellaActivationTime":"0001-01-01T00:00:00","EffectiveFlags":0,"LastEffectiveFlags":0,"Power":true,"EcoHotWater":false,"OperationMode":2,"OperationModeZone1":0,"OperationModeZone2":2,"SetTemperatureZone1":21,"SetTemperatureZone2":20,"SetTankWaterTemperature":50,"TargetHCTemperatureZone1":21,"TargetHCTemperatureZone2":35,"ForcedHotWaterMode":false,"HolidayMode":false,"ProhibitHotWater":true,"ProhibitHeatingZone1":false,"ProhibitHeatingZone2":false,"ProhibitCoolingZone1":false,"ProhibitCoolingZone2":false,"ServerTimerDesired":false,"SecondaryZoneHeatCurve":false,"SetHeatFlowTemperatureZone1":0,"SetHeatFlowTemperatureZone2":0,"SetCoolFlowTemperatureZone1":0,"SetCoolFlowTemperatureZone2":0,"DECCReport":false,"CSVReport1min":false,"Zone2Master":false,"DailyEnergyConsumedDate":"2022-12-04T00:00:00","DailyEnergyProducedDate":"2022-12-04T00:00:00","CurrentEnergyConsumed":2,"CurrentEnergyProduced":3,"CurrentEnergyMode":null,"HeatingEnergyConsumedRate1":2,"HeatingEnergyConsumedRate2":0,"CoolingEnergyConsumedRate1":0,"CoolingEnergyConsumedRate2":0,"HotWaterEnergyConsumedRate1":0,"HotWaterEnergyConsumedRate2":0,"HeatingEnergyProducedRate1":3,"HeatingEnergyProducedRate2":0,"CoolingEnergyProducedRate1":0,"CoolingEnergyProducedRate2":0,"HotWaterEnergyProducedRate1":0,"HotWaterEnergyProducedRate2":0,"ErrorCode2Digit":0,"SpSubDivisionsToWrite":0,"SpSubDivisionsToRead":0,"SpState":0,"SpSubDivisionsWriteInProgress":0,"SpSubDivisionsReadInProgress":0,"InitialSettingsData":null,"InitialSettingsTimestamp":null,"SupportsHourlyEnergyReport":false,"HasZone2":false,"HasSimplifiedZone2":false,"CanHeat":true,"CanCool":false,"HasHotWaterTank":false,"CanSetTankTemperature":false,"CanSetEcoHotWater":false,"HasEnergyConsumedMeter":true,"HasEnergyProducedMeter":true,"CanMeasureEnergyProduced":false,"CanMeasureEnergyConsumed":false,"Zone1InRoomMode":true,"Zone2InRoomMode":false,"Zone1InHeatMode":true,"Zone2InHeatMode":true,"Zone1InCoolMode":false,"Zone2InCoolMode":false,"AllowDualRoomTemperature":false,"IsGeodan":false,"HasEcoCuteSettings":false,"HasFTC45Settings":true,"HasFTC6Settings":false,"CanEstimateEnergyUsage":true,"CanUseRoomTemperatureCooling":false,"IsFtcModelSupported":true,"MaxTankTemperature":60,"IdleZone1":false,"IdleZone2":true,"MinPcycle":1,"MaxPcycle":1,"MaxOutdoorUnits":255,"MaxIndoorUnits":255,"MaxTemperatureControlUnits":0,"ModelCode":"027a","DeviceID":57416137,"MacAddress":"70:61:be:ef:ce:86","SerialNumber":"2229012156","TimeZoneID":119,"DiagnosticMode":0,"DiagnosticEndDate":null,"ExpectedCommand":1,"Owner":117173,"DetectedCountry":null,"AdaptorType":3,"FirmwareDeployment":null,"FirmwareUpdateAborted":false,"LinkedDevice":null,"WifiSignalStrength":-74,"WifiAdapterStatus":"NORMAL","Position":"Unknown","PCycle":2,"PCycleConfigured":null,"RecordNumMax":1,"LastTimeStamp":"2022-12-05T12:17:00","ErrorCode":8000,"HasError":false,"LastReset":"2022-12-02T13:26:14.809","FlashWrites":2,"Scene":null,"TemperatureIncrementOverride":0,"SSLExpirationDate":"2037-12-31T00:00:00","SPTimeout":1,"Passcode":null,"ServerCommunicationDisabled":false,"ConsecutiveUploadErrors":0,"DoNotRespondAfter":null,"OwnerRoleAccessLevel":1,"OwnerCountry":85,"HideEnergyReport":false,"ExceptionHash":null,"ExceptionDate":null,"ExceptionCount":null,"Rate1StartTime":null,"Rate2StartTime":null,"ProtocolVersion":0,"UnitVersion":0,"FirmwareAppVersion":37000,"FirmwareWebVersion":0,"FirmwareWlanVersion":0,"EffectivePCycle":1,"MqttFlags":9,"HasErrorMessages":false,"Offline":false,"Units":[{"ID":1,"Device":0,"SerialNumber":"1111","ModelNumber":null,"Model":"Ecodan","UnitType":0,"IsIndoor":false},{"ID":2,"Device":0,"SerialNumber":"Jkwl","ModelNumber":195,"Model":"ECOSLIM-150L-PP-MEUK","UnitType":1,"IsIndoor":true}]},"DiagnosticMode":0,"DiagnosticEndDate":null,"Location":1351,"DetectedCountry":null,"Registrations":9,"LocalIPAddress":null,"TimeZone":119,"RegistReason":"STARTUP","ExpectedCommand":1,"RegistRetry":0,"DateCreated":"2022-12-02T12:30:25.176Z","FirmwareDeployment":null,"FirmwareUpdateAborted":false,"Permissions":{"CanSetForcedHotWater":true,"CanSetOperationMode":true,"CanSetPower":true,"CanSetTankWaterTemperature":true,"CanSetEcoHotWater":false,"CanSetFlowTemperature":true,"CanSetTemperatureIncrementOverride":true}}],"Clients":[]},"AccessLevel":4,"DirectAccess":true,"MinTemperature":0,"MaxTemperature":40,"Owner":null,"EndDate":"2500-01-01T00:00:00","iDateBuilt":null,"QuantizedCoordinates":{"Latitude":51.175,"Longitude":10.45}}]
    2022-12-05 12:18:06.251 - debug: melcloud.0 (27897) Got air-to-water device from cloud: 57416137 (Wert)
    2022-12-05 12:18:06.251 - debug: melcloud.0 (27897) Saving device data...
    2022-12-05 12:18:06.502 - debug: melcloud.0 (27897) Created and saved ATW device 57416137 (Wert)
    2022-12-05 12:18:06.559 - debug: melcloud.0 (27897) Updated device data for device 57416137 (Wert)
    2022-12-05 12:18:06.560 - info: melcloud.0 (27897) Connection successful. Starting polling (interval: 5 minute(s))...
    2022-12-05 12:19:59.819 - debug: melcloud.0 (27897) Trying to get device object with id 57416137...
    2022-12-05 12:19:59.820 - debug: melcloud.0 (27897) Processing command 'getPowerConsumptionReport' with value 'true' for device object with id 57416137 (Wert)...
    2022-12-05 12:19:59.821 - debug: melcloud.0 (27897) Getting power consumption report for 57416137 (Wert)
    2022-12-05 12:19:59.862 - warn: melcloud.0 (27897) No valid start date was provided (format: YYYY-MM-DD). Defaulting to 6 months prior.
    2022-12-05 12:19:59.863 - warn: melcloud.0 (27897) No valid end date was provided (format: YYYY-MM-DD). Defaulting to today.
    2022-12-05 12:20:00.009 - info: melcloud.0 (27897) Scheduled restart.
    2022-12-05 12:20:00.011 - debug: melcloud.0 (27897) Cleared polling timer.
    2022-12-05 12:20:00.011 - info: melcloud.0 (27897) onUnload(): Cleaned everything up...
    2022-12-05 12:20:00.037 - debug: melcloud.0 (27897) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/EnergyCost/Report (status code: 200 - OK)
    2022-12-05 12:20:00.038 - info: host.iobroker-iobroker1 instance system.adapter.openweathermap.0 started with pid 28011
    2022-12-05 12:20:00.038 - debug: melcloud.0 (27897) Response from cloud: {"HotWater":[0],"InternalTemperature1":null,"InternalTemperature2":null,"ExternalTemperature":null,"Cooling":[0],"Heating":[93.11],"CoP":[2.0450005369992486],"MissingSampleQuarter":[null,null,null,null],"MissingSampleMonth":[null,null,null,null,null,null,null,null,null,null,null,null],"ProducedHotWater":[0],"ProducedCooling":[0],"ProducedHeating":[190.41000000000003],"TotalHeatingConsumed":93.11,"TotalCoolingConsumed":0,"TotalHotWaterConsumed":0,"TotalHeatingProduced":190.41000000000003,"TotalCoolingProduced":0,"TotalHotWaterProduced":0,"AverageInternalTemperature":0,"AverageExternalTemperature":0,"Status":0,"LabelType":2,"TempLabels":null,"Labels":[12],"HasZone2":false,"CurrencySymbol":"kWh","FromDate":"2022-12-01T00:00:00","ToDate":"2022-12-05T00:00:00","DeviceName":"Wert","BuildingAddress":null,"BuildingCity":null,"BuildingCountry":null,"CustomerName":null,"costs":null,"TotalMinutes":263520,"MissingMinutes":263220}
    2022-12-05 12:20:00.047 - info: melcloud.0 (27897) terminating
    2022-12-05 12:20:00.048 - info: melcloud.0 (27897) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-12-05 12:20:00.099 - debug: melcloud.0 (27897) Updated report data for device 57416137 (Wert)
    2022-12-05 12:20:00.582 - info: host.iobroker-iobroker1 instance system.adapter.melcloud.0 scheduled normal terminated and will be restarted on schedule.
    2022-12-05 12:20:00.582 - info: host.iobroker-iobroker1 Restart adapter system.adapter.melcloud.0 because enabled
    2022-12-05 12:20:01.613 - info: host.iobroker-iobroker1 instance system.adapter.melcloud.0 started with pid 28022
    2022-12-05 12:20:02.079 - info: openweathermap.0 (28011) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v16.18.1, js-controller: 4.0.23
    2022-12-05 12:20:02.284 - debug: melcloud.0 (28022) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-12-05 12:20:02.307 - debug: melcloud.0 (28022) Objects client ready ... initialize now
    2022-12-05 12:20:02.308 - debug: melcloud.0 (28022) Objects create System PubSub Client
    2022-12-05 12:20:02.309 - debug: melcloud.0 (28022) Objects create User PubSub Client
    2022-12-05 12:20:02.330 - debug: melcloud.0 (28022) Objects client initialize lua scripts
    2022-12-05 12:20:02.334 - debug: melcloud.0 (28022) Objects connected to redis: 127.0.0.1:9001
    2022-12-05 12:20:02.350 - debug: melcloud.0 (28022) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-12-05 12:20:02.358 - debug: melcloud.0 (28022) States create System PubSub Client
    2022-12-05 12:20:02.359 - debug: melcloud.0 (28022) States create User PubSub Client
    2022-12-05 12:20:02.410 - debug: melcloud.0 (28022) States connected to redis: 127.0.0.1:9000
    2022-12-05 12:20:02.509 - info: melcloud.0 (28022) starting. Version 1.2.0 (non-npm: Black-Thunder/ioBroker.melcloud) in /opt/iobroker/node_modules/iobroker.melcloud, node: v16.18.1, js-controller: 4.0.23
    2022-12-05 12:20:02.791 - debug: melcloud.0 (28022) Schedule restart: */2 * * * *
    2022-12-05 12:20:02.852 - debug: melcloud.0 (28022) Initializing objects...
    2022-12-05 12:20:02.913 - debug: melcloud.0 (28022) Checking adapter settings...
    2022-12-05 12:20:02.914 - debug: melcloud.0 (28022) Getting current known devices...
    2022-12-05 12:20:02.986 - debug: melcloud.0 (28022) Found known device: 57416137
    2022-12-05 12:20:02.987 - info: melcloud.0 (28022) Connecting initially to MELCloud and retrieving data...
    2022-12-05 12:20:02.987 - debug: melcloud.0 (28022) Fetching context key...
    2022-12-05 12:20:02.987 - debug: melcloud.0 (28022) MELCloud email address: c.schanze@gmx.de - MELCloud password: Jenni1108
    2022-12-05 12:20:03.268 - error: melcloud.0 (28022) No objects for MELCloud devices constructed yet. Try again in a few seconds...
    2022-12-05 12:20:03.393 - error: melcloud.0 (28022) No objects for MELCloud devices constructed yet. Try again in a few seconds...
    2022-12-05 12:20:03.913 - debug: melcloud.0 (28022) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Login/ClientLogin (status code: 200 - OK)
    2022-12-05 12:20:03.914 - debug: melcloud.0 (28022) Response from cloud: {"ErrorId":null,"ErrorMessage":null,"LoginStatus":0,"UserId":0,"RandomKey":null,"AppVersionAnnouncement":null,"LoginData":{"ContextKey":"FC9AEFC79E77465FB961DBC478F819","Client":117173,"Terms":1282,"AL":1,"ML":0,"CMI":true,"IsStaff":false,"CUTF":false,"CAA":false,"ReceiveCountryNotifications":false,"ReceiveAllNotifications":false,"CACA":false,"CAGA":false,"MaximumDevices":10,"ShowDiagnostics":false,"Language":4,"Country":85,"RealClient":0,"Name":"Christian Schanze","UseFahrenheit":false,"Duration":525600,"Expiry":"2023-12-05T11:20:03.18","CMSC":false,"PartnerApplicationVersion":null,"EmailSettingsReminderShown":true,"EmailUnitErrors":0,"EmailCommsErrors":0,"ChartSeriesHidden":0,"DeletePending":false,"IsImpersonated":false,"LanguageCode":"de","CountryName":"Deutschland","CurrencySymbol":"€","SupportEmailAddress":null,"DateSeperator":"/","TimeSeperator":":","AtwLogoFile":"ecodan_logo.png","DECCReport":false,"CSVReport1min":false,"HidePresetPanel":false,"EmailSettingsReminderRequired":false,"TermsText":null,"MapView":false,"MapZoom":15,"MapLongitude":8.91480230887504,"MapLatitude":52.24795056737217},"ListPendingInvite":[],"ListOwnershipChangeRequest":[],"ListPendingAnnouncement":[],"LoginMinutes":0,"LoginAttempts":0}
    2022-12-05 12:20:03.914 - debug: melcloud.0 (28022) Login successful. ContextKey: FC9AEFC79E77465FB961DBC478F819
    2022-12-05 12:20:03.915 - debug: melcloud.0 (28022) Fetching devices...
    2022-12-05 12:20:04.715 - debug: melcloud.0 (28022) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices (status code: 200 - OK)
    2022-12-05 12:20:04.715 - debug: melcloud.0 (28022) Response from cloud: [{"ID":502693,"Name":"Fg","AddressLine1":"Bb","AddressLine2":null,"City":"Bvl","Postcode":"325","Latitude":51.165691,"Longitude":10.451526,"District":null,"FPDefined":false,"FPEnabled":false,"FPMinTemperature":14,"FPMaxTemperature":16,"HMDefined":false,"HMEnabled":false,"HMStartDate":null,"HMEndDate":null,"BuildingType":1,"PropertyType":8,"DateBuilt":null,"HasGasSupply":true,"LocationLookupDate":"2022-12-02T12:34:22.847","Country":85,"TimeZoneContinent":3,"TimeZoneCity":49,"TimeZone":119,"Location":1351,"CoolingDisabled":false,"Expanded":true,"Structure":{"Floors":[],"Areas":[],"Devices":[{"DeviceID":57416137,"DeviceName":"Wert","BuildingID":502693,"BuildingName":null,"FloorID":null,"FloorName":null,"AreaID":null,"AreaName":null,"ImageID":-1,"InstallationDate":null,"LastServiceDate":null,"Presets":[],"OwnerID":117173,"OwnerName":null,"OwnerEmail":null,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","Zone1Name":null,"Zone2Name":null,"MinTemperature":0,"MaxTemperature":40,"HideVaneControls":false,"HideDryModeControl":false,"HideRoomTemperature":false,"HideSupplyTemperature":false,"HideOutdoorTemperature":false,"BuildingCountry":null,"OwnerCountry":null,"AdaptorType":3,"LinkedDevice":null,"Type":1,"MacAddress":"70:61:be:ef:ce:86","SerialNumber":"2229012156","Device":{"PCycleActual":0,"ErrorMessages":"","DeviceType":1,"FTCVersion":1700,"FTCRevision":"r0","LastFTCVersion":0,"LastFTCRevision":null,"FTCModel":2,"RefridgerentAddress":0,"DipSwitch1":0,"DipSwitch2":160,"DipSwitch3":16,"DipSwitch4":0,"DipSwitch5":0,"DipSwitch6":0,"HasThermostatZone1":true,"HasThermostatZone2":true,"TemperatureIncrement":0.5,"DefrostMode":0,"HeatPumpFrequency":74,"MaxSetTemperature":45,"MinSetTemperature":25,"RoomTemperatureZone1":19,"RoomTemperatureZone2":19,"OutdoorTemperature":2,"FlowTemperature":46,"FlowTemperatureZone1":45.5,"FlowTemperatureZone2":25,"FlowTemperatureBoiler":25,"ReturnTemperature":44,"ReturnTemperatureZone1":38,"ReturnTemperatureZone2":25,"ReturnTemperatureBoiler":25,"BoilerStatus":false,"BoosterHeater1Status":false,"BoosterHeater2Status":false,"BoosterHeater2PlusStatus":false,"ImmersionHeaterStatus":false,"WaterPump1Status":true,"WaterPump2Status":true,"WaterPump3Status":false,"ValveStatus3Way":false,"ValveStatus2Way":true,"WaterPump4Status":false,"ValveStatus2Way2a":false,"ValveStatus2Way2b":false,"TankWaterTemperature":25,"UnitStatus":0,"HeatingFunctionEnabled":true,"ServerTimerEnabled":false,"ThermostatStatusZone1":false,"ThermostatStatusZone2":false,"ThermostatTypeZone1":2,"ThermostatTypeZone2":2,"MixingTankWaterTemperature":0,"CondensingTemperature":0,"DemandPercentage":10,"ConfiguredDemandPercentage":null,"HasDemandSideControl":false,"DailyHeatingEnergyConsumed":31.66,"DailyCoolingEnergyConsumed":0,"DailyHotWaterEnergyConsumed":0,"DailyHeatingEnergyProduced":49.74,"DailyCoolingEnergyProduced":0,"DailyHotWaterEnergyProduced":0,"DailyLegionellaActivationCounter":0,"LastLegionellaActivationTime":"0001-01-01T00:00:00","EffectiveFlags":0,"LastEffectiveFlags":0,"Power":true,"EcoHotWater":false,"OperationMode":2,"OperationModeZone1":0,"OperationModeZone2":2,"SetTemperatureZone1":21,"SetTemperatureZone2":20,"SetTankWaterTemperature":50,"TargetHCTemperatureZone1":21,"TargetHCTemperatureZone2":35,"ForcedHotWaterMode":false,"HolidayMode":false,"ProhibitHotWater":true,"ProhibitHeatingZone1":false,"ProhibitHeatingZone2":false,"ProhibitCoolingZone1":false,"ProhibitCoolingZone2":false,"ServerTimerDesired":false,"SecondaryZoneHeatCurve":false,"SetHeatFlowTemperatureZone1":0,"SetHeatFlowTemperatureZone2":0,"SetCoolFlowTemperatureZone1":0,"SetCoolFlowTemperatureZone2":0,"DECCReport":false,"CSVReport1min":false,"Zone2Master":false,"DailyEnergyConsumedDate":"2022-12-04T00:00:00","DailyEnergyProducedDate":"2022-12-04T00:00:00","CurrentEnergyConsumed":2,"CurrentEnergyProduced":3,"CurrentEnergyMode":null,"HeatingEnergyConsumedRate1":2,"HeatingEnergyConsumedRate2":0,"CoolingEnergyConsumedRate1":0,"CoolingEnergyConsumedRate2":0,"HotWaterEnergyConsumedRate1":0,"HotWaterEnergyConsumedRate2":0,"HeatingEnergyProducedRate1":3,"HeatingEnergyProducedRate2":0,"CoolingEnergyProducedRate1":0,"CoolingEnergyProducedRate2":0,"HotWaterEnergyProducedRate1":0,"HotWaterEnergyProducedRate2":0,"ErrorCode2Digit":0,"SpSubDivisionsToWrite":0,"SpSubDivisionsToRead":0,"SpState":0,"SpSubDivisionsWriteInProgress":0,"SpSubDivisionsReadInProgress":0,"InitialSettingsData":null,"InitialSettingsTimestamp":null,"SupportsHourlyEnergyReport":false,"HasZone2":false,"HasSimplifiedZone2":false,"CanHeat":true,"CanCool":false,"HasHotWaterTank":false,"CanSetTankTemperature":false,"CanSetEcoHotWater":false,"HasEnergyConsumedMeter":true,"HasEnergyProducedMeter":true,"CanMeasureEnergyProduced":false,"CanMeasureEnergyConsumed":false,"Zone1InRoomMode":true,"Zone2InRoomMode":false,"Zone1InHeatMode":true,"Zone2InHeatMode":true,"Zone1InCoolMode":false,"Zone2InCoolMode":false,"AllowDualRoomTemperature":false,"IsGeodan":false,"HasEcoCuteSettings":false,"HasFTC45Settings":true,"HasFTC6Settings":false,"CanEstimateEnergyUsage":true,"CanUseRoomTemperatureCooling":false,"IsFtcModelSupported":true,"MaxTankTemperature":60,"IdleZone1":false,"IdleZone2":true,"MinPcycle":1,"MaxPcycle":1,"MaxOutdoorUnits":255,"MaxIndoorUnits":255,"MaxTemperatureControlUnits":0,"ModelCode":"027a","DeviceID":57416137,"MacAddress":"70:61:be:ef:ce:86","SerialNumber":"2229012156","TimeZoneID":119,"DiagnosticMode":0,"DiagnosticEndDate":null,"ExpectedCommand":1,"Owner":117173,"DetectedCountry":null,"AdaptorType":3,"FirmwareDeployment":null,"FirmwareUpdateAborted":false,"LinkedDevice":null,"WifiSignalStrength":-74,"WifiAdapterStatus":"NORMAL","Position":"Unknown","PCycle":2,"PCycleConfigured":null,"RecordNumMax":1,"LastTimeStamp":"2022-12-05T12:19:00","ErrorCode":8000,"HasError":false,"LastReset":"2022-12-02T13:26:14.809","FlashWrites":2,"Scene":null,"TemperatureIncrementOverride":0,"SSLExpirationDate":"2037-12-31T00:00:00","SPTimeout":1,"Passcode":null,"ServerCommunicationDisabled":false,"ConsecutiveUploadErrors":0,"DoNotRespondAfter":null,"OwnerRoleAccessLevel":1,"OwnerCountry":85,"HideEnergyReport":false,"ExceptionHash":null,"ExceptionDate":null,"ExceptionCount":null,"Rate1StartTime":null,"Rate2StartTime":null,"ProtocolVersion":0,"UnitVersion":0,"FirmwareAppVersion":37000,"FirmwareWebVersion":0,"FirmwareWlanVersion":0,"EffectivePCycle":1,"MqttFlags":9,"HasErrorMessages":false,"Offline":false,"Units":[{"ID":1,"Device":0,"SerialNumber":"1111","ModelNumber":null,"Model":"Ecodan","UnitType":0,"IsIndoor":false},{"ID":2,"Device":0,"SerialNumber":"Jkwl","ModelNumber":195,"Model":"ECOSLIM-150L-PP-MEUK","UnitType":1,"IsIndoor":true}]},"DiagnosticMode":0,"DiagnosticEndDate":null,"Location":1351,"DetectedCountry":null,"Registrations":9,"LocalIPAddress":null,"TimeZone":119,"RegistReason":"STARTUP","ExpectedCommand":1,"RegistRetry":0,"DateCreated":"2022-12-02T12:30:25.176Z","FirmwareDeployment":null,"FirmwareUpdateAborted":false,"Permissions":{"CanSetForcedHotWater":true,"CanSetOperationMode":true,"CanSetPower":true,"CanSetTankWaterTemperature":true,"CanSetEcoHotWater":false,"CanSetFlowTemperature":true,"CanSetTemperatureIncrementOverride":true}}],"Clients":[]},"AccessLevel":4,"DirectAccess":true,"MinTemperature":0,"MaxTemperature":40,"Owner":null,"EndDate":"2500-01-01T00:00:00","iDateBuilt":null,"QuantizedCoordinates":{"Latitude":51.175,"Longitude":10.45}}]
    2022-12-05 12:20:04.716 - debug: melcloud.0 (28022) Got air-to-water device from cloud: 57416137 (Wert)
    2022-12-05 12:20:04.717 - debug: melcloud.0 (28022) Saving device data...
    2022-12-05 12:20:04.922 - debug: melcloud.0 (28022) Created and saved ATW device 57416137 (Wert)
    2022-12-05 12:20:04.978 - debug: melcloud.0 (28022) Updated device data for device 57416137 (Wert)
    2022-12-05 12:20:04.978 - info: melcloud.0 (28022) Connection successful. Starting polling (interval: 5 minute(s))...
    2022-12-05 12:20:25.260 - info: openweathermap.0 (28011) Terminated (NO_ERROR): Without reason
    2022-12-05 12:20:25.775 - info: host.iobroker-iobroker1 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    DAs Enddatum ändert sich aktuell auf das aktuelle
    Black ThunderB 1 Antwort Letzte Antwort
    • C cookie98
      Black ThunderB
      Black ThunderB
      Black Thunder
      #78
      @cookie98 Danke, das hilft mir schon mal weiter. Schau ich mir an und geb wieder Bescheid, wenn ich die Anpassungen auf Github hochgeladen hab.
      Bzgl. des Enddatums: Welche Werte sind denn bei "startDate" und "endDate" eingetragen? Laut Log passt hier nämlich das Format nicht und dann wird standardmäßig das heutige Datum als Enddatum genommen.
      C 1 Antwort Letzte Antwort
        C
        C
        cookie98
        #79
        Start war 2022-12-01 End war 2022-12-05
        • C cookie98
          Black ThunderB
          Black ThunderB
          Black Thunder
          #80
          @cookie98 Ah, da hat sich bei meiner letzten Änderung ein kleiner Fehler eingeschlichen. Das korrigiere ich dann gleich zusammen mit den anderen Anpassungen, dann sollte das Datum auch wieder korrekt ausgelesen werden.
            C
            C
            cookie98
            #81
            Bin gespannt
            • C cookie98
              Bin gespannt
              Black ThunderB
              Black ThunderB
              Black Thunder
              #82
              @cookie98 So, ich hab grad die Änderungen hochgeladen. Also bitte nochmal die aktuelle Version von Github installieren. Vor dem Test bitte aber auch den kompletten Objektbaum "melcloud.0.reports" und "melcloud.0.devices.XXXX.reports" löschen, damit das neu erzeugt werden kann.
              Jetzt sollten wieder das Start- und Enddatum korrekt ausgelesen und zusätzlich die für Wärmepumpen relevanten Berichtswerte befüllt werden.
              C 2 Antworten Letzte Antwort
                C
                C
                cookie98
                #83
                Teste ich heute Abend wenn der Nachwuchs im Bett ist.
                  C
                  C
                  cookie98
                  #84
                  Sollte passend
                  Jetzt noch das mir die Tageswerte angezeigt werden dann bin ich zufrieden! Danke für das ganze hier !
                  • C cookie98
                    Sollte passend
                    Black ThunderB
                    Black ThunderB
                    Black Thunder
                    #85
                    @cookie98 Super, freut mich, dass alles soweit klappt. Danke auch fürs immer zügige Feedback. Werde das dann morgen als v1.2.1 freigeben.
                    Bei weiteren Problemen bitte gerne hier posten oder bei Github nen Issue anlegen. DIe Funktionalität rund um Wärmepumpen ist mangels eigenen Geräts bisher nicht so wirklich getestet.
                      C
                      C
                      cookie98
                      #86
                      So bald was ist melde ich es. Aber was mir aufgefallen ist das der Monatverbrauch nicht mehr da ist. Oder habe ich das falsch gesehen bzw verstanden
                      • C cookie98
                        Black ThunderB
                        Black ThunderB
                        Black Thunder
                        #87
                        @cookie98 Ja, das habe ich vor kurzem ausgebaut, da es sehr fehleranfällig war und auch so nicht wirklich genutzt wurde. Stattdessen gibt es ja jetzt die (aggregierten) Verbrauchswerte pro Betriebsmodus, womit sich das ja durch die passende Wahl von Start- und Enddatum beliebig nachstellen lässt. Damit ist der Zeitraum auch nicht mehr so starr auf den Monat beschränkt, sondern lässt sich flexibel anpassen.
                          C
                          C
                          cookie98
                          #88
                          Mmm entweder bin ich zu blöd oder das auslesen der Produzierten menge geht nicht mehr ...
                          Habe aktuell irgendwie Probleme das ganze so zu bekommen das er mir die werte ausliesst
                          • C cookie98
                            Black ThunderB
                            Black ThunderB
                            Black Thunder
                            #89
                            @cookie98 Wird denn in der offiziellen Melcloud-App bzw. Webansicht ein Wert dafür angezeigt, wenn du für den Zeitraum den Bericht abrufst?
                            Falls ja, dann bräuchte ich bitte ein Debug-Log vom Abruf im Adapter, um zu sehen, woran es hängt.
                              C
                              C
                              cookie98
                              #90
                              @black-thunder sry das ich nun erst schreibe.Der Fehler lag an mir. Aber ich habe was neues :)
                              bin auf Raspberry umgestiegen un klappt die installation nicht mehr.Der offiziell adapter lässt sich ohne Probleme installieren und nutzen. Bei deinen bekomme ich die folgende Meldung
                              Bin wohl zu blöd , npm ist laut Status neu und i.o
                              Thomas BraunT Black ThunderB 2 Antworten Letzte Antwort
                              • C cookie98
                                Thomas BraunT
                                Thomas BraunT
                                Most Active Developer
                                #91
                                @cookie98
                                Das ist die ganz normale Meldung bei erfolgreicher Installation.
                                • C cookie98
                                  Black ThunderB
                                  Black ThunderB
                                  Black Thunder
                                  schrieb am zuletzt editiert von Black Thunder
                                  #92
                                  @cookie98 Gut, dass sich das andere Problem geklärt hat. ;)
                                  Wie @Thomas-Braun schon gesagt hat, ist die Meldung völlig normal und die Installation ist erfolgreich gewesen. Du musst nur noch eine Instanz des Adapters hinzufügen (auf das "+"-Symbol in der Adapter-Ansicht).
                                  Abgesehen davon ist die aktuelle Version des Adapters längst im Stable-Repository und kann ganz regulär wie die anderen installiert werden. Sprich du musst nicht über GitHub gehen.
                                    icon
                                    Aktuelle Test Version 4.0.0
                                    Veröffentlichungsdatum 26.08.2026
                                    Github Link https://github.com/Black-Thunder/ioBroker.melcloud
                                    ich möchte euch heute meinen neuen Adapter melcloud vorstellen.
                                    Der Adapter kommuniziert über die offizielle Mitsubishi-Cloud (MELCloud) mit Mitsubishi-Klimaanlagen, -Wärmepumpen und -Lüftungsanlagen. Eine cloudfreie Alternative dazu ist mein Adapter mitsubishi-local-control.
                                    Hier habt ihr die Möglichkeit, euch über alle Themen und Anliegen rund um den Adapter auszutauschen und Unstimmigkeiten zu melden.
                                    Bitte bei Anfragen oder Problemen immer ein vollständiges Debug-Log direkt ab Start des Adapters zur Verfügung stellen. Eine Anleitung dafür ist weiter unten zu finden.
                                    Die aktuelle Dokumentation findet ihr unter folgenden Links:
                                    • Deutsche Beschreibung
                                    • English Description
                                    Highlights der einzelnen Versionen:
                                    • Ab v1.1.0 ist es möglich, die Verbrauchsberichte der Inneneinheiten abzurufen (sofern dies vom jeweiligen Gerät unterstützt wird). Informationen zu den einzelnen Datenpunkten dafür sind wie immer in der Doku zu finden (Links unten).
                                    • Seit v1.2.0 werden auch Luft-Wasser-Wärmepumpen unterstützt. Hier gerne Feedback, ob speziell die Steuerung funktioniert, da ich selbst keine Möglichkeit habe, das zu verifizieren. Zusätzlich können seit dieser Version auch aggregierte Berichte über den Energieverbrauch abgerufen werden.
                                    • Seit v1.2.1 sind auch die Verbrauchsberichte für Luft-Wasser-Wärmepumpen implementiert.
                                    • Seit v1.3.0 gibt es die Möglichkeit, vorhandene Timer der Geräte ein- bzw. auszuschalten. Zusätzlich wird nun im Objekt-Baum des Admin-Adapters der jeweilige Zustand (Verbindung und Fehler) des Geräts farblich und mit Tooltips angezeigt.
                                    • Seit v1.4.0 kann das regelmäßige Abrufen der Daten aus der Cloud komplett deaktiviert werden, falls nicht benötigt
                                    • Seit v3.0.0 werden ERV-Geräte/Lüftungsanlagen experimentell unterstützt. Falls hier jemand testen kann und möchte, gerne Feedback geben.
                                    • Seit v4.0.0 wird der zentrale ioBroker-Credentials-Speicher unterstützt. Bestehende Installationen mit direkt hinterlegter E-Mail-Adresse und Passwort bleiben weiterhin kompatibel.
                                    Das ausführliche Changelog ist immer an dieser Stelle zu finden.
                                    Versionshinweise
                                    • Falls der Fehler "Error: unable to verify the first certificate" auftritt, bitte auf Version 1.4.1 oder höher updaten und die Option "SSL-Fehler ignorieren" in den Adaptereinstellungen (temporär) aktivieren.
                                    • Ab v1.1.1 wurde die Ver-/Entschlüsselung des Passworts geändert. Daher muss einmalig das Passwort erneut in den Adapter-Einstellungen eingeben werden. Ansonsten schlägt die Anmeldung fehl und der Adapter bleibt auf rot!
                                    • Ab v1.1.3 muss mindestens js-controller v3.1 installiert sein
                                    • Bei einem Upgrade auf v1.2.0 (oder höher) bitte einmalig die Objektstrukturen unter "melcloud.X.devices.YYYYY.reports" komplett löschen und den Adapter neustarten, damit diese neu angelegt werden können. In der Dokumentation ist die neue Struktur beschrieben.
                                    • Ab v1.3.6 muss mind. Node.Js 16 verwendet werden
                                    • Ab v1.3.7 ist das minimale Abfrageintervall auf 5 Minuten begrenzt.
                                    • Ab v2.0.0 muss mindestens Node.Js 18, Admin 6 und js-controller 5 verwendet werden.
                                    • Ab v3.0.0 muss mindestens Node.Js 20, Admin 7.4.10 und js-controller 6 verwendet werden.
                                    • Ab v4.0.0 muss mindestens Node.Js 22, Admin 7.9.0 und js-controller 7.2.2 verwendet werden.
                                    Installationshinweise
                                    Inzwischen ist der Adapter regulär im latest und stable Repository gelistet. Bitte daher nur noch Alpha-Versionen von npm installieren.
                                    Aus Latest (Beta-Versionen)
                                    • 'Aktiver Verwahrungsort' in den iobroker.admin-Einstellungen muss auf 'Beta (latest)' stehen
                                    • Unter 'Adapter' nach 'melcloud' filtern und ganz rechts auf das '+'-Symbol ('Instanz hinzufügen') klicken.
                                    • Unter 'Instanzen' die entsprechenden Adapter-Einstellungen eintragen.
                                    Von npm (Alpha-Versionen)
                                    • Expertenansicht des Admin-Adapters aktivieren
                                    • Unter 'Adapter' auf das GitHub-Icon ('Installieren aus eigener URL') klicken.
                                    • 'Benutzerdefiniert' auswählen, "iobroker.melcloud@next" eingeben und auf 'Installieren' klicken.
                                    • Dann unter 'Adapter' den melcloud-Adapter filtern und ganz rechts auf das '+'-Symbol ('Instanz hinzufügen') klicken.
                                    Aus Github (Entwicklungsstand)
                                    Bitte von hier nur nach Aufforderung installieren, da dies u.U. ein instabiler Entwicklungsstand sein kann!
                                    • 'VON GITHUB' auswählen, nach "melcloud [Black-Thunder]" suchen und auf 'Installieren' klicken.
                                    Erzeugen eines Debug-Logs
                                    Hier eine kurze Anleitung, wie man das benötigte Debug-Log erstellt:
                                    1. In der Admin-GUI unter Instanzen die entsprechende melcloud.X-Instanz aufklappen
                                    2. Dort das standardmäßig auf Info eingestellte Loglevel auf Debug ändern. Der Adapter startet automatisch neu.
                                    3. Solange warten, bis der Adapterneustart abgeschlossen und die Fehlersituation aufgetreten ist. Dann in der Admin-GUI über Protokolle -> Log herunterladen -> aktuelles Datum / current das Log anzeigen bzw. herunterladen und den relevanten Teil ab Adapterstart zur Verfügung stellen.
                                    4. Am Schluss das Loglevel wieder zurück auf Info stellen. Ansonsten werden dauerhaft sehr viele Einträge ins Log geschrieben.
                                    Viele Grüße
                                    Dominik
                                    R
                                    R
                                    Ralf_62
                                    #93
                                    @black-thunder
                                    ich habe die neueste Version des Adapters installiert (1.3.0), aber immer noch folgendes Problem.
                                    Unter Objekte werden mir alle Daten der Reports angezeigt:
                                    Will ich jetzt aber die Objekte in der Visu anzeigen, bekomme ich keine Werte, die angezeigt werden sollen:
                                    Hat jemand vielleicht eine Idee, wie ich das Problem lösen kann?
                                    Danke und viele Grüße
                                    Ralf
                                    • R Ralf_62
                                      @black-thunder
                                      Ralf
                                      Black ThunderB
                                      Black ThunderB
                                      Black Thunder
                                      #94
                                      @ralf_62 Hmm... also das ist kein Problem mit meinem Adapter denke ich, da die Daten im Objektbaum korrekt angezeigt werden.
                                      Warum die Objekte dann in der Visualisierung nicht richtig angezeigt werden, kann ich leider nicht sagen. Das ist vermutlich eher ein Issue des betreffenden Visualierungsadapters. Um welche Visu geht es denn? Mit Habpanel und vis hab ich keine Probleme bei der Auswahl und Anzeige der Werte:
                                      Bei dir scheinen ja schon die Anzahl der States im Objektbaum und im Auswahldialog der Visu nicht übereinzustimmen.
                                      R 1 Antwort Letzte Antwort
                                        R
                                        R
                                        Ralf_62
                                        #95
                                        @black-thunder, ich war zu "doof" für die Bedienung. Es gibt zwei Ausgaben der Reportdaten und ich muss die Werte unterhalb der Seriennummer auswählen.
                                        Danke trotzdem! :)
                                        Viele Grüße
                                        Ralf
                                        • O
                                          O
                                          oxident
                                          #96
                                          Also irgendwas ist komisch seit dem Update. Alle meine Klimageräte zeigen "deviceOnline" = false an bis ich sie das erste Mal mit dem Adapter "bediene" (was auch funktioniert). Dann erscheint im Log folgendes:
                                          melcloud.0
                                          2023-03-19 18:14:31.776	info	undefined is not a valid state value for id "melcloud.0.devices.65089022.info.errorMessages"
                                          melcloud.0
                                          2023-03-19 18:14:31.762	info	undefined is not a valid state value for id "melcloud.0.devices.65089022.info.hasError"
                                          melcloud.0
                                          2023-03-19 18:13:53.870	info	Connection successful. Starting polling (interval: 1 minute(s))...
                                          melcloud.0
                                          2023-03-19 18:13:52.645	info	Connecting initially to MELCloud and retrieving data...
                                          ... und kurze Zeit später ist "deviceOnline" wieder false :-(
                                          84.1k
