  4. [gelöst] Canvas - compiled against a different Node.js vers,
    1.0k
103 Beiträge 4 Kommentatoren 22.2k Aufrufe 3 Beobachtet
  • A anno171986
    @mickym said in Canvas -> compiled against a different Node.js version:
    sudo netstat -tulpen
    Jup, das scheint zu stimmen:
    pi@raspberrypi:~$ sudo netstat -tulpen
    Aktive Internetverbindungen (Nur Server)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          16392      753/python3
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1666679    18855/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1667670    18855/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12785      567/sshd: /usr/sbin
    tcp        0      0 192.168.178.12:8087     0.0.0.0:*               LISTEN      1001       1670571    19450/io.simple-api
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          15566      381/connmand
    tcp        0      0 0.0.0.0:52050           0.0.0.0:*               LISTEN      1000       12926      393/MyMediaForAlexa
    tcp        0      0 0.0.0.0:52051           0.0.0.0:*               LISTEN      1000       12922      393/MyMediaForAlexa
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1668091    19115/io.mqtt.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          701845     15500/cupsd
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        11727      665/mariadbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12795      567/sshd: /usr/sbin
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12740      557/xrdp-sesman
    tcp6       0      0 :::3389                 :::*                    LISTEN      110        14899      599/xrdp
    tcp6       0      0 :::4369                 :::*                    LISTEN      0          13938      1/init
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          701844     15500/cupsd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1668847    19370/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1666752    18887/io.admin.0
    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          15570      381/connmand
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1668351    18984/io.mihome-vac
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14047      378/avahi-daemon: r
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          15558      381/connmand
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12164      452/dhcpcd
    udp        0      0 0.0.0.0:51299           0.0.0.0:*                           0          15890      381/connmand
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          703638     15501/cups-browsed
    udp        0      0 0.0.0.0:49800           0.0.0.0:*                           108        14049      378/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14048      378/avahi-daemon: r
    udp6       0      0 :::58705                :::*                                108        14050      378/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16390      452/dhcpcd
    udp6       0      0 ::1:53                  :::*                                0          15562      381/connmand
    mickymM Online
    mickymM Online
    mickym
    @anno171986 ja schaut gut aus. Für mich ist das ein Berechtigungsproblem. Entweder passt das Passwort im Adapter nicht, oder der Benutzer ist limitiert.
    • A anno171986
      @mickym Ich ahbe im SQl Adapter mal meine RPI Adresse 192.168.178.12 durch die 127.0.0.1 ersetzt, jetzt funktioniert es.
      mickymM Online
      mickymM Online
      mickym
      @anno171986 sagte in Canvas -> compiled against a different Node.js version:
      Na dann ist hat der User nur das Recht sich nur Lokal anzumelden. Dann solltest nun am wieder deine Verlaufsdaten sehen. Glückwunsch
      A 2 Antworten Letzte Antwort
      • mickymM mickym
        anno171986
        @mickym 📈
        eChart funktioniert, und noch viel wichtiger: Ich habe gerade das Bild per Telegram bekommen 🍾
        • A anno171986
          @mickym 📈
          mickymM Online
          mickymM Online
          mickym
          @mickym 📈
          Na dann haben sich die Mühen doch letztlich ausgezahlt. Dann sofort das Image sichern und Dein System lieber regelmäßig aktuell halten.
          • mickymM mickym
            anno171986
            @mickym Jetzt ist die Frage wie ich das mit den recht wieder ändere. Mit HeidiSQL kann ich nämlich immer noch nicht drauf zugreifen.
            • mickymM mickym
              @mickym 📈
              anno171986
              @mickym mit den aktuell hatte ich ja soweit, nur dass ich quasi das OS nicht geupdated hatte, hatte das nicht auf den Plan, wie man das macht und wusste auch nicht, dass es überhaupt eine neue Version gibt.
              • A anno171986
                mickymM Online
                mickymM Online
                mickym
                @anno171986 na ich würde halt mit dem Root User nun einen neuen Admin auf der Kommandozeile definieren, der sich von überall anmelden kann und den für die HeidiSql Anmeldung verwenden.
                • A anno171986
                  @anno171986
                  Dann kannst du ja jetzt auch den Desktop-Quatsch auf dem Server ausschalten.
                    @anno171986
                    anno171986
                    @thomas-braun said in [gelöst] Canvas - compiled against a different Node.js vers,:
                    @anno171986
                    Was genau meinst du damit?
                    Zur Info: Ich programmiere ab- und zu was via python auf dem RPi und dazu benutze ich die remotedesktopverbindung.
                    • mickymM mickym
                      anno171986
                      schrieb am zuletzt editiert von anno171986
                      @mickym Ich habe für die DB eigentlich einen root User, mit dem kann ich mich auch nicht einloggen. Vlt ist die maximale Userzahl auf 1 zurückgesetzt?
                      Edit: Ok das ist nicht der Fall, kann mich mit mehrenen Instanzen via Konsole verbinden.
                      • A anno171986
                        @anno171986
                        @anno171986 sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
                        Genau die meine ich.
                        Macht man nicht, braucht man nicht, sorgt nur für Probleme.
                        • A anno171986
                          mickymM Online
                          mickymM Online
                          mickym
                          Na das denke ich ist das Problem. Ich kann mich leider nicht mehr richtig erinnern. Aber schau mal im Netz wie du den sql Root zurücksetzen kannst.
                          • mickymM mickym
                            anno171986
                            @mickym Ich musste was in der DB Konfiguration ändern Anleitung
                            Jetzt geht es auch wiedder mit HeidiSQL über meinen Windows PC. Jetzt heißt es die eCharts zu erstellen.
                            Vielen Dank nochmal für deine Hilfe!!!!
                              anno171986
                              Ich hatte mal probiert, das programmieren auf meinen Windows-PC zu machen, aber dann konnte ich das nicht testen, da es ja eine ganz anderen Umgebung ist (ich benutze z.B. die GPIO Leiste in meinem Prgramm).
                              Hast du einen Tipp wie man das machen kann?
                              • A anno171986
                                mickymM Online
                                mickymM Online
                                mickym
                                #66
                                Na dann viel Spaß. ✌️
                                • A anno171986
                                  #67
                                  @anno171986
                                  Mit einem Editor in der Konsole?
                                  Per z.B. Powershell/SSH vom Hauptrechner aus?
                                  Mach ich bei Shell-Skripten so.
                                    @anno171986
                                    Diamand2k22
                                    #68
                                    Irgendwie werd ich aus diesem thread nicht schlau 😀
                                    Hab das gleiche Problem mit:
                                    Status Ecovacs Deebot:The module /opt/iobroker/node_modules/canvas/build/Release/canvas.node
                                    was compiled against a different Node.js version using
                                    NODE_MODULE_VERSION 108. This version of Node.js requires
                                    NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
                                    the module (for instance, using npm rebuild or npm install).
                                    Mein ssh Ausgabe sagt:
                                    pi4b@pi4b:~$ cd /opt/iobroker
                                    pi4b@pi4b:/opt/iobroker$ npm ls canvas
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    └─┬ iobroker.ecovacs-deebot@1.4.15
                                      └─┬ ecovacs-deebot@0.9.6-beta.3
                                        └── canvas@2.10.2
                                    Wie bekomm ich den Fehler weg?
                                    System ist uptodate.
                                    • D Diamand2k22
                                          └── canvas@2.10.2
                                      #69
                                      @diamand2k22
                                      canvas muss neu gegen NODE_MODULE_VERSION 115 gebaut werden. Sollte eigentlich automatisch passieren.
                                      Entweder iobroker.ecovacs-deebot nochmal frisch installieren oder canvas direkt im entsprechenden Verzeichnis nochmal bauen lassen.
                                        Diamand2k22
                                        #70
                                        Hast du da auf die Schnelle einen Befehl bevor ich mir wieder meinen npm tree zerstrubbel?
                                        • D Diamand2k22
                                          #71
                                          @diamand2k22
                                          iob upgrade iobroker.ecovacs-deebot@1.4.15
                                          Edit: Kommando berichtigt.
