  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
    @nhet
    iob upgrade bluelink --debug
    Damit sollte man mehr sehen.
    N Offline
    N Offline
    nhet
    #703
    leider nein
    pi@raspberrypi:~ $ iob upgrade bluelink --debug
    This upgrade of "bluelink" will at least introduce the following changes:
    -> 2.2.6:
    fix / extend clima & errorcounter
    Would you like to upgrade bluelink from @2.2.5 to @2.2.6 now? [(y)es, (n)o]: y
    Update bluelink from @2.2.5 to @2.2.6
    NPM version: 8.19.2
    Installing iobroker.bluelink@2.2.6... (System call)
    up to date in 11s
    152 packages are looking for funding
      run `npm fund` for details
    upload [5] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/admin.d.ts admin.d.ts video/mp2t
    upload [4] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
    upload [3] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink_old.png bluelink_old.png image/png
    upload [2] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/index_m.html index_m.html text/html
    upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/style.css style.css text/css
    upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/words.js words.js application/javascript
    pi@raspberrypi:~ $ iob update
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "backitup"     : 2.5.5    , installed 2.5.5
    Adapter    "bluelink"     : 2.2.6    , installed 2.2.5  [Updatable]
    arteckA Meister MopperM 2 Antworten Letzte Antwort
    • N nhet
      leider nein
      -> 2.2.6:
      NPM version: 8.19.2
      up to date in 11s
      arteckA Offline
      arteckA Offline
      arteck
      #704
      @nhet ja da ist im npm was fratze bei dir..
      install den adapter mal von GIT..einmalig
      • N nhet
        leider nein
        -> 2.2.6:
        NPM version: 8.19.2
        up to date in 11s
        Meister MopperM Online
        Meister Mopper
        #705
        @nhet
        Ich vermute mal, Du hast das npm 8 Problem und kannst gar keine Adapter aktualisieren.
        Mittlerweile ist das hier im Forum mehrfach dokumentiert. Da liegen irgendwelche Geisterverzeichnisse im System.
        Proxmox und HA ...
        Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
        Thomas BraunT N 2 Antworten Letzte Antwort
          @nhet
          #706
          @meister-mopper
          Das müsste sich aber bei --debug dann anders darstellen.
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
          Würde die aber ausspucken.
            @meister-mopper
            Meister Mopper
            #707
            Tatsächlich hatte ich mit --debug auch keine Auffälligkeiten, trotzdem wurde kein Adapter angehoben.
            Proxmox und HA ...
              @nhet
              N Offline
              N Offline
              nhet
              #708
              @meister-mopper, ich sag mal: alle anderen Adapter werden korrekt geupdatet.
              Thomas BraunT Meister MopperM 4 Antworten Letzte Antwort
              • N nhet
                #709
                @nhet
                Check es mit der Befehlszeile von oben.
                • N nhet
                  Meister Mopper
                  #710
                  @nhet
                  Okay, dann muss es etwas anderes sein. Bei mir ließ sich nichts aktualisieren.
                  Proxmox und HA ...
                  • N nhet
                    #711
                    @nhet
                    Schau mal node/npm an:
                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    • N nhet
                      #712
                      @nhet
                      Da stimmt was in den release-Dateien nicht.
                      Auf meinem System:
                      2022-11-14 18:58:44.556  - info: host.chet iobroker Installing iobroker.bluelink@2.2.6... (System call)
                      2022-11-14 18:59:00.352  - info: host.chet iobroker npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      2022-11-14 18:59:04.288  - info: host.chet iobroker added 44 packages, removed 1018 packages, and changed 1 package in 19s
                      2022-11-14 18:59:04.294  - info: host.chet iobroker
                      2022-11-14 18:59:04.295  - info: host.chet iobroker 88 packages are looking for funding  run `npm fund` for details
                      2022-11-14 18:59:04.370  - info: host.chet iobroker host.chet install adapter bluelink
                      Aber sofort wird der Adapter zum Update vorgeschlagen:
                      echad@chet:~ $ iobroker update -u
                      Used repository: beta
                      Und oh wunder...
                      https://github.com/Newan/ioBroker.bluelink/issues/59
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        #713
                        @thomas-braun hab ich doch schon oben geschrieben
                          @arteck
                          Hi, vielen Dank fuer deinen Brunch, hab mal getestet ( Ioniq5), leider bricht der Adapter mit Fehlermeldung ab, schau mal, denke das wird so nicht gehen..:
                          Mit der App aufm Smartphone funktioniert alles wie gehabt.. also die Fehlermeldung von wegen Service not available .. mal wieder fuern ... du weisst schon.. wie bei Hyundai ueblich.. :D
                          2022-11-03 11:06:41.838  - info: bluelink.0 (1043039) Starting clima for vehicle
                          2022-11-03 11:06:41.961  - error: bluelink.0 (1043039) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2022-11-03 11:06:41.962  - error: bluelink.0 (1043039) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/-bb06-4f2800241850/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"066d4e84-2e21-4c30-8677-db67b6e6145b"}
                          2022-11-03 11:06:41.962  - error: bluelink.0 (1043039) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/-4f2800241850/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"066d4e84-2e21-4c30-8677-db67b6e6145b"}
                              at U (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:11700)
                              at G.<anonymous> (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:16700)
                              at Generator.throw (<anonymous>)
                              at a (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
                              at processTicksAndRejections (node:internal/process/task_queues:96:5)
                          2022-11-03 11:06:41.963  - error: bluelink.0 (1043039) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/-479d-bb06-4f2800241850/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"066d4e84-2e21-4c30-8677-db67b6e6145b"}
                          2022-11-03 11:06:41.964  - info: bluelink.0 (1043039) Adapter bluelink cleaned up everything...
                          2022-11-03 11:06:41.965  - info: bluelink.0 (1043039) terminating
                          2022-11-03 11:06:41.967  - warn: bluelink.0 (1043039) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2022-11-03 11:06:42.514  - info: simple-api.0 (1176) State value to set for "javascript.0.Wetterstation.Info.Hitzeindex" has to be type "number" but received type "string"
                          2022-11-03 11:06:43.020  - error: host.VMC123-iobroker instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2022-11-03 11:06:43.021  - info: host.VMC123-iobroker Restart adapter system.adapter.bluelink.0 because enabled
                          #714
                          @ilovegym @arteck
                          ich habe es auch mal mit meinem IONIQ 5 getestet in der Version 2.2.6 und ich habe das gleiche Problem wie @ilovegym . (Weil ich mir die Funktionserweiterung beim Fernklimatisieren auch sehr Wünsche)
                          2022-11-16 10:54:33.825 - info: bluelink.0 (2012726) Login to api
                          2022-11-16 10:54:38.340 - info: bluelink.0 (2012726) 1 Vehicles found
                          2022-11-16 10:54:52.136 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
                          2022-11-16 10:54:52.183 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
                          2022-11-16 10:54:52.189 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
                          2022-11-16 10:54:52.196 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
                          2022-11-16 10:54:52.261 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
                          2022-11-16 10:54:57.137 - info: bluelink.0 (2012726) Starting clima for vehicle
                          2022-11-16 10:54:57.292 - error: bluelink.0 (2012726) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2022-11-16 10:54:57.293 - error: bluelink.0 (2012726) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
                          2022-11-16 10:54:57.295 - error: bluelink.0 (2012726) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
                          at G. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:16700)
                          at Generator.throw ()
                          at runMicrotasks ()
                          at processTicksAndRejections (internal/process/task_queues.js:95:5)
                          2022-11-16 10:54:57.297 - error: bluelink.0 (2012726) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
                          2022-11-16 10:54:57.310 - info: bluelink.0 (2012726) Adapter bluelink cleaned up everything...
                          2022-11-16 10:54:57.312 - info: bluelink.0 (2012726) terminating
                          2022-11-16 10:54:57.315 - warn: bluelink.0 (2012726) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          In Version 2.2.3., die ich davor (und auch nach dem Test wieder) genutzt habe, habe ich das Problem nicht.
                            @ilovegym @arteck
                            at runMicrotasks ()
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #715
                            @williwilliwilli sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                            im ernst...
                            • arteckA arteck
                              im ernst...
                              #716
                              @arteck ja, denn der Fehler kommt immer! hab ich auch. In der App funktionierts ja.
                              Mit der vorigen Version des Adapters gehts. ( halt ohne die Temp zu setzen etc.)
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #717
                                @ilovegym installier mal meine version
                                https://github.com/arteck/ioBroker.bluelink
                                und mach nochmal.. dann log schauen nach -->
                                ? ? 2 Antworten Letzte Antwort
                                • arteckA arteck
                                  #718
                                  @arteck
                                  Hello, gemacht, Adapter zeigt Version 2.2.3 an.
                                  Steuern der Clima geht nicht, wenn ich auf start clima druecke, kommt ein undefined. Ein Lock/Unlock funktioniert, der vorige Fehler von Version 2.2.6 ist weg.
                                  ilovegym@VMC123-iobroker /opt/iobroker $ iob logs --watch | grep bluelink.0
                                  2022-11-17 08:32:13.914  - info: host.VMC123-iobroker iobroker Update "system.adapter.bluelink.0"
                                  2022-11-17 08:32:13.922  - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 (force=false, process=true)
                                  2022-11-17 08:32:13.923  - info: bluelink.0 (635883) Got terminate signal TERMINATE_YOURSELF
                                  2022-11-17 08:32:13.924  - info: bluelink.0 (635883) Adapter bluelink cleaned up everything...
                                  2022-11-17 08:32:13.924  - info: bluelink.0 (635883) terminating
                                  2022-11-17 08:32:13.924  - info: bluelink.0 (635883) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2022-11-17 08:32:13.925  - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 send kill signal
                                  2022-11-17 08:32:14.723  - info: host.VMC123-iobroker instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2022-11-17 08:32:17.191  - info: host.VMC123-iobroker instance system.adapter.bluelink.0 started with pid 687175
                                  2022-11-17 08:32:18.289  - info: bluelink.0 (687175) starting. Version 2.2.3 (non-npm: arteck/ioBroker.bluelink#f3613b00ef64bb48fe5c5568a146f79bfbc18c81) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.18.1, js-controller: 4.0.23
                                  2022-11-17 08:32:18.302  - info: bluelink.0 (687175) Login to api
                                  2022-11-17 08:32:23.123  - info: bluelink.0 (687175) 1 Vehicles found
                                  2022-11-17 08:34:00.504  - info: bluelink.0 (687175) Starting clima for vehicle
                                  2022-11-17 08:34:00.506  - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl
                                  2022-11-17 08:34:00.506  - info: bluelink.0 (687175) --> airTemp KMHKR81AFNU0.control.set.airTemp
                                  2022-11-17 08:34:00.507  - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost
                                  2022-11-17 08:34:00.507  - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating
                                  2022-11-17 08:34:00.639  - error: bluelink.0 (687175) undefined
                                  2022-11-17 08:35:34.601  - info: bluelink.0 (687175) Starting unlock for vehicle
                                  2022-11-17 08:35:34.763  - info: bluelink.0 (687175) Unlock successful
                                  2022-11-17 08:35:54.255  - info: bluelink.0 (687175) Starting lock for vehicle
                                  2022-11-17 08:35:54.395  - info: bluelink.0 (687175) Lock successful
                                  2022-11-17 08:36:02.288  - info: bluelink.0 (687175) Starting clima for vehicle
                                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl
                                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> airTemp KMHKR81AFN.control.set.airTemp
                                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost
                                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating
                                  2022-11-17 08:36:02.414  - error: bluelink.0 (687175) undefined
                                  Ein komplettes Debuglog kann ich dir gerne per Mail senden...??
                                  • arteckA arteck
                                    #719
                                    @arteck
                                    same here
                                    2022-11-17 08:43:04.526 - info: bluelink.0 (2076917) Starting clima for vehicle
                                    2022-11-17 08:43:04.534 - info: bluelink.0 (2076917) --> airCtrl KMHKR81XXXXXXXXX.control.set.airCtrl
                                    2022-11-17 08:43:04.535 - info: bluelink.0 (2076917) --> airTemp KMHKR81XXXXXXXXX.control.set.airTemp
                                    2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> defrost KMHKR81XXXXXXXXX.control.set.defrost
                                    2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> heating KMHKR81XXXXXXXXX.control.set.heating
                                    2022-11-17 08:43:04.982 - error: bluelink.0 (2076917) undefined
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #720
                                      man sollte nix neben bei machen
                                      installiert nochmal..ich will mal schauen ob die zahlen richtig übernommen werden
                                      • arteckA arteck
                                        #721
                                        @arteck
                                        da kommt jetzt:
                                        2022-11-17 10:10:59.095  - debug: bluelink.0 (823776) New Event for state: {"val":true,"ack":false,"ts":1668676259094,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1667470001835}
                                        2022-11-17 10:10:59.095  - debug: bluelink.0 (823776) ID: "bluelink.0.KMHKR.control.start"
                                        2022-11-17 10:10:59.095  - info: bluelink.0 (823776) Starting clima for vehicle
                                        2022-11-17 10:10:59.097  - info: bluelink.0 (823776) --> [object Object]
                                        2022-11-17 10:10:59.098  - info: bluelink.0 (823776) --> [object Object]
                                        2022-11-17 10:10:59.238  - error: bluelink.0 (823776) {"source":{"name":"HTTPError","hostname":"prd.eu-ccapi.hyundai.com","method":
                                        und zum schluss im text wieder Service temporary unavalable... ist anscheinend die allgemeine Fehlermeldung, wenn sonst nix passt... ??
                                          @arteck
                                          da kommt jetzt:
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #722
                                          @ilovegym installier nochmal..bitää
