    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • D danny_v1
    So ich habe gerade alles nach Anleitung installiert. Ich habe das PanelTs ohne Beispiele verwendet und bekomme beim Start des Skriptes folgende Fehlermeldung:
    javascript.0 (13719) script.js.common.NSPanel_DEV.NSPanelTs: TypeScript compilation failed: await createAliasAsync(config.weatherEntity + '.ICON', 'accuweather.0.Current.WeatherIcon', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ICON' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP', 'accuweather.0.Current.Temperature', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature', name: 'TEMP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MIN', 'accuweather.0.Daily.Day1.Temperature.Minimum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.forecast.0', name: 'TEMP_MIN' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MAX', 'accuweather.0.Daily.Day1.Temperature.Maximum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.max.forecast.0', name: 'TEMP_MAX' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.SET', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.SET', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.ACTUAL', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.SET', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'ipAddress.ACTUAL', NSPanel_Path + 'NSPanel_ipAddress', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.BerryDriver.ACTUAL', NSPanel_Path + 'Berry_Driver.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Uptime.ACTUAL', NSPanel_Path + 'Tasmota.Uptime', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Version.ACTUAL', NSPanel_Path + 'Tasmota.Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Hardware.ACTUAL', NSPanel_Path + 'Tasmota.Hardware', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.AP.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.AP', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.SSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.SSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.BSSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.BSSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Channel.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Channel', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Mode.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Mode', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.RSSI.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.RSSI', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Signal.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Signal', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.TFTVersion.ACTUAL', NSPanel_Path + 'Display_Firmware.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.Model.ACTUAL', NSPanel_Path + 'NSPanel_Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.Player.currentAlbum', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.Player.currentArtist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.Player.currentTitle', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.Player.controlNext', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.Player.controlPrevious', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.Player.controlPlay', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.Player.controlPause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.Commands.deviceStop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.Player.currentState', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + 'player.album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + 'player.artistName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + 'player.trackName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + 'player.contextDescription', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + 'player.skipPlus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + 'player.skipMinus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + 'player.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + 'player.isPlaying', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.current_album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.current_artist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.current_title', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + '.current_station', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.next', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.prev', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.stop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.state_simple', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Sensor.ANALOG.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ANALOG.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Sensor.ESP32.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ESP32.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'.
    leigt bestimmt am anlegen der Wetterdatenpunkte.
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #659
    @danny_v1
    Nein, liegt daran, dass du die TS-Version 3.5.0.5 benutzt, aber nicht den JavaScript-Adapter in der Version 6.1.3
    • J jprisum.de
      wie kann ich Berry-Driver Update durchführen?
      Ein Click auf ja langt nicht, es verschwindet zwar die Anzeige aber ein paar Std später ist es wieder da.
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      #660
      @jprisum-de
      Manuelle Updates auf false stellen (oben im Script) oder in der 0_userdata.0. eine 4 eintragen...
      D J 2 Antworten Letzte Antwort
      • ArmilarA Armilar
        @jprisum-de
        danny_v1
        #661
        @armilar ich hab javaskript 6.0.3. Zeigt mir auch keine Aktualisierung an.
        denk manuelle updates sind aus
        let manually_Update = false;
        aber die Datenpunkte aus deinem Bild existieren bei mir nicht.
        • D danny_v1
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #662
          @danny_v1 nee, für dich war nicht der Post mit den manuellen Updates
          Sie mal ein paar Posts zurück. Da steht was über das Beta-Repository
          https://forum.iobroker.net/post/890251
          • ArmilarA Armilar
            danny_v1
            schrieb am zuletzt editiert von danny_v1
            #663
            @armilar ok mit dem update vom skriptadapter läufts! Aber der Nextion editor warte immer noch auf content
            Edit: hab gerade gemerkt mit fehlt der Datenpunkt customSend.
            Edit2: Datenpunkt ist jetzt angelegt, jetzt kommt der Berry-Driver Update Bildschirm aber agal was ich mache "ja", "nein" oder "x" nichts passiert
            Edit3: Nextion Editor neu gestartet jetzt hab ich wieder Waiting for content und im CustomSend steht Timeout 20
            • D danny_v1
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #664
              @danny_v1 diese Lösung steht 4 Posts zurück
              • ArmilarA Armilar
                danny_v1
                #665
                @armilar ok 4 ist eingetragen, aber ich hänge mal wieder im waiting for content
                • D danny_v1
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #666
                  @danny_v1
                  Ich habe die Vermutung, dass deine autoexec.be im Tasmota auf 0 kb steht. Sieh mal nach und wenn es so ist, dann erneuere sie nochmals
                  • ArmilarA Armilar
                    @danny_v1
                    danny_v1
                    #667
                    @armilar autoexec.be steht auf 3720 aber ich spiel sie noch mal neu ein
                    • D danny_v1
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #668
                      @danny_v1
                      Moment bist du mit der Emu unterwegs oder mit dem Original-Panel? Das sind zwei unterschiedliche Berry Treiber
                      Der wäre für das Original-Panel
                      https://github.com/joBr99/nspanel-lovelace-ui/blob/main/tasmota/autoexec.be
                      Der nachfolgende für die Emulation:
                      # Nextion Serial Protocol driver by joBr99 + nextion upload protocol 1.2 (the fast one yay) implementation using http range and tcpclient
                      # based on;
                      # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
                      class Nextion : Driver
                          var ser
                      	var flash_size
                      	var flash_mode
                      	var flash_skip
                      	var flash_current_byte
                      	var tftd
                      	var progress_percentage_last
                      	static header = bytes('55BB')
                          def init()
                              log("NSP: Initializing Driver")
                              self.ser = serial(3, 1, 115200, serial.SERIAL_8N1)
                              self.flash_mode = 0
                      		self.flash_skip = false
                      		tasmota.add_driver(self)
                          end
                          def crc16(data, poly)
                            if !poly  poly = 0xA001 end
                            # CRC-16 MODBUS HASHING ALGORITHM
                            var crc = 0xFFFF
                            for i:0..size(data)-1
                              crc = crc ^ data[i]
                              for j:0..7
                                if crc & 1
                                  crc = (crc >> 1) ^ poly
                                else
                                  crc = crc >> 1
                                end
                              end
                            end
                            return crc
                          end
                          def split_55(b)
                            var ret = []
                            var s = size(b)
                            var i = s-2   # start from last
                            while i > 0
                              if b[i] == 0x55 && b[i+1] == 0xBB
                                ret.push(b[i..s-1]) # push last msg to list
                                b = b[(0..i-1)]   # write the rest back to b
                              end
                              i -= 1
                            end
                            ret.push(b)
                            return ret
                          end
                      	# encode using custom protocol 55 BB [payload length] [payload] [crc] [crc]
                          def encode(payload)
                            var b = bytes()
                            b += self.header
                            b.add(size(payload), 2)   # add size as 1 byte
                            b += bytes().fromstring(payload)
                            var msg_crc = self.crc16(b)
                            b.add(msg_crc, 2)       # crc 2 bytes, little endian
                            return b
                          end
                      	# send a nextion payload
                      	def encodenx(payload)
                      		var b = bytes().fromstring(payload)
                      		b += bytes('FFFFFF')
                      		return b
                      	end
                      	def sendnx(payload)
                      		var payload_bin = self.encodenx(payload)
                      		self.ser.write(payload_bin)
                      		 print("NSP: Sent =", payload_bin)
                      		log("NSP: Nextion command sent = " + str(payload_bin), 3)
                      	end
                          def send(payload)
                              var payload_bin = self.encode(payload)
                              if self.flash_mode==1
                                  log("NSP: skipped command becuase still flashing", 3)
                              else
                                  log("NSP: payload sent = " + str(payload_bin), 3)
                              end
                          end
                      	def every_100ms()
                              import string
                              if self.ser.available() > 0
                                  var msg = self.ser.read()
                                  if size(msg) > 0
                                      print("NSP: Received Raw =", msg)
                                          log("no flashing in this version")
                                      else
                      					# Recive messages using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
                      					if msg[0..1] == self.header
                      						var lst = self.split_55(msg)
                      						for i:0..size(lst)-1
                      							msg = lst[i]
                      							#var j = msg[2]+2
                      							var j = size(msg) - 3
                      							msg = msg[4..j]
                      							if size(msg) > 2
                      								var jm = string.format("{\"CustomRecv\":\"%s\"}",msg.asstring())
                      								tasmota.publish_result(jm, "RESULT")
                      							end
                      						end
                      					elif msg == bytes('000000FFFFFF88FFFFFF')
                      						log("NSP: Screen Initialized")
                      					else
                                              var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                      					end
                                      end
                                  end
                              end
                          end
                      end
                      var nextion = Nextion()
                      def send_cmd(cmd, idx, payload, payload_json)
                          nextion.sendnx(payload)
                          tasmota.resp_cmnd_done()
                      end
                      tasmota.add_cmd('Nextion', send_cmd)
                      def send_cmd2(cmd, idx, payload, payload_json)
                          nextion.send(payload)
                      end
                      tasmota.add_cmd('CustomSend', send_cmd2)
                      • ArmilarA Armilar
                        @danny_v1
                        # based on;
                            var ser
                        	var flash_size
                        	var flash_mode
                        	var flash_skip
                        	var tftd
                            def init()
                                self.flash_mode = 0
                            end
                              var crc = 0xFFFF
                                crc = crc ^ data[i]
                                for j:0..7
                                  if crc & 1
                                  else
                                    crc = crc >> 1
                                  end
                                end
                              end
                              return crc
                            end
                            def split_55(b)
                              var ret = []
                              var s = size(b)
                              while i > 0
                                end
                                i -= 1
                              end
                              ret.push(b)
                              return ret
                            end
                            def encode(payload)
                              var b = bytes()
                              b += self.header
                              return b
                            end
                        		return b
                        	end
                        	def sendnx(payload)
                        	end
                            def send(payload)
                                else
                                end
                            end
                        	def every_100ms()
                                import string
                                    if size(msg) > 0
                                        else
                        							msg = lst[i]
                        							#var j = msg[2]+2
                        							msg = msg[4..j]
                        							if size(msg) > 2
                        							end
                        						end
                        					else
                        					end
                                        end
                                    end
                                end
                            end
                        end
                        end
                        end
                        danny_v1
                        #669
                        @armilar ne bin noch im emu
                        • D danny_v1
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #670
                          @danny_v1
                          Emu im Nextion-Editor?
                            danny_v1
                            #671
                            @armilar richtig. Autoexec.be passt hab deine noch mal kopiert und komme wieder auf 3720
                            • ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #672
                              @danny_v1
                              Im Nextion-Editor unter Debug:
                              Dort unten links von Keyboard Input auf User MCU Input umstellen, den COM-Port des ESP auswählen und die Baud-Rate auf 115200 stellen. Mit Start verbindet man sich nun zum ESP.
                              • ArmilarA Armilar
                                @danny_v1
                                danny_v1
                                #673
                                @armilar ja hab ich es kommt auch event startup 44 an
                                • D danny_v1
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #674
                                  @danny_v1
                                  Läuft also?
                                  • ArmilarA Armilar
                                    @danny_v1
                                    Läuft also?
                                    danny_v1
                                    #675
                                    @armilar Verbindung ja aber steht immernoch auf waiting for content. Hab das Skript ohne Beispiele aber sollte ja zumindest in den Screensaver mit dem Wetter gehen oder?
                                    • D danny_v1
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #676
                                      @danny_v1
                                      ESP ist über USB verbunden und MQTT korrekt eingerichtet?
                                      https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation#4-mqtt-tasmota-config
                                      Punkt 4 und 6.
                                      Liegt häufig daran, dass die MQTT-Verbindung zwischen CustomSend (häufig noch über Mosquitto) zum NSPanel nicht korrekt konfiguriert ist. Das Panel kommuniziert in beide Richtungen
                                      • ArmilarA Armilar
                                        @danny_v1
                                        Punkt 4 und 6.
                                        danny_v1
                                        #677
                                        @armilar ja kofig hab ich genauso gemacht, hab in der mqtt instanz den timeout mal hoch gesetzt. aber ansonsten so wie beschrieben, der adapter sagt auch verbunden mit NSPanel_DEV
                                        • D danny_v1
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #678
                                          @danny_v1
                                          Dann zeige mal den CustomSend im MQTT und in der Script-Config
