  4. Test Adapter TP-Link Tapo
887 Beiträge 123 Kommentatoren 452.6k Aufrufe 107 Beobachtet
  • surfer09S surfer09
    kann mir vielleicht jemand sagen was das hier bedeutet?
    2022-10-08 20:40:50.999 - debug: tapo.0 (2548) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-10-08 20:40:51.017 - debug: tapo.0 (2548) Objects client ready ... initialize now
    2022-10-08 20:40:51.018 - debug: tapo.0 (2548) Objects create System PubSub Client
    2022-10-08 20:40:51.018 - debug: tapo.0 (2548) Objects create User PubSub Client
    2022-10-08 20:40:51.035 - debug: tapo.0 (2548) Objects client initialize lua scripts
    2022-10-08 20:40:51.038 - debug: tapo.0 (2548) Objects connected to redis: 0.0.0.0:9001
    2022-10-08 20:40:51.047 - debug: tapo.0 (2548) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-10-08 20:40:51.052 - debug: tapo.0 (2548) States create System PubSub Client
    2022-10-08 20:40:51.052 - debug: tapo.0 (2548) States create User PubSub Client
    2022-10-08 20:40:51.060 - debug: tapo.0 (2548) States connected to redis: 0.0.0.0:9000
    2022-10-08 20:40:51.084 - debug: tapo.0 (2548) Plugin sentry Initialize Plugin (enabled=true)
    2022-10-08 20:40:51.226 - info: tapo.0 (2548) starting. Version 0.0.1 (non-npm: TA2k/ioBroker.tapo#82a8e2866ca61d44b4f161a50bdb84a76babe589) in I:/ioBroker/node_modules/iobroker.tapo, node: v16.17.0, js-controller: 4.0.23
    2022-10-08 20:40:51.237 - info: tapo.0 (2548) Login tp TAPO App
    2022-10-08 20:40:51.240 - debug: tapo.0 (2548) ZJuNCLuRtvbRimn148tJig==
    2022-10-08 20:40:51.417 - debug: tapo.0 (2548) {"error_code":-10306,"msg":"Access denied request in blackList"}
    2022-10-08 20:40:51.417 - error: tapo.0 (2548) {"error_code":-10306,"msg":"Access denied request in blackList"}
    Ich bekomme den Adapter nicht mehr gestartet...
    T
    T
    tombox
    @surfer09 bitte mal 0.0.3 probieren
    surfer09S mrbungle64M 2 Antworten Letzte Antwort
    • T tombox
      surfer09S
      surfer09S
      surfer09
      @tombox Gibt es da auch einen Link zu?
        T
        T
        tombox
        @surfer09 Entweder unter Adapter via GitHub oder npm installieren
        surfer09S 1 Antwort Letzte Antwort
        • T tombox
          surfer09S
          surfer09S
          surfer09
          @tombox Über Github kann ich "tapo" gar nicht finden. Wie gehe ich über npm vor, damit ich die 0.0.3 installieren kann?
          • T tombox
            mrbungle64M
            mrbungle64M
            mrbungle64
            schrieb am zuletzt editiert von mrbungle64
            @tombox
            Ich habe eben die 0.0.4 installiert (via GitHub) - leider wird seitdem nichts mehr aktualisiert (nur noch beim Neustart) ...
            Edit: mit der der Version 0.0.3 (via npm) scheint alles soweit zu gehen.
            surfer09S T 2 Antworten Letzte Antwort
            • mrbungle64M mrbungle64
              @tombox
              surfer09S
              surfer09S
              surfer09
              @mrbungle64 Kannst du mir vielleicht einmal den npm Befehl nennen?
              mrbungle64M 1 Antwort Letzte Antwort
                @tombox
                T
                T
                tombox
                @mrbungle64 Bitte 0.0.5 probieren
                surfer09S mrbungle64M CodierknechtC 3 Antworten Letzte Antwort
                  mrbungle64M
                  mrbungle64M
                  mrbungle64
                  @surfer09 sagte in Test Adapter TP-Link Tapo:
                  Das x mit der gewünschten Version ersetzen
                  /opt/iobroker $ npm install iobroker.tapo@0.0.x
                  • T tombox
                    surfer09S
                    surfer09S
                    surfer09
                    schrieb am zuletzt editiert von surfer09
                    @tombox Also mit der 0.0.5 funktioniert zumindest der Adapterstart wieder bei mir. :-)
                    • T tombox
                      mrbungle64M
                      mrbungle64M
                      mrbungle64
                      #66
                      @tombox sagte in Test Adapter TP-Link Tapo:
                      Sieht mit der 0.0.5 wieder besser aus 👍
                        surfer09S
                        surfer09S
                        surfer09
                        #67
                        Passt alles wieder, vielen Dank @tombox 👍
                        • T tombox
                          CodierknechtC
                          CodierknechtC
                          Codierknecht
                          #68
                          Die 0.0.5 scheint deutlich stabiler zu sein und funktioniert allem Anschein nach wesentlich besser.
                          Brauchst Du aktuell noch meinen Account?
                          Bernd
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • CodierknechtC Codierknecht
                            Bernd
                            T
                            T
                            tombox
                            #69
                            @codierknecht Erstmal nicht wenn es keine Anmerkungen gibt
                            • T tombox
                              Hi ich habe ein neuen Adapter für TP-Link die mit der Tapo App überwacht werden können, geschrieben.
                              Der Adapter loggt sich über die Cloud ein um alle Geräte mit IP zu finden
                              Wenn das Gerät nicht als online erkannt wird kann manuell die IP gesetzt wird.
                              tapo.0.id.ip
                              Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
                              Aktuelle Werte:
                              tapo.0.id
                              Motion Detection funktioniert mit Stream User und Password
                              Minimum Node v14 muss installiert sein, sonst bekommt man exit code 25 beim installieren
                              Zum Installieren:
                              https://github.com/TA2k/ioBroker.tapo
                              Loginablauf:
                              Die Tapo App Zugangsdaten eingeben
                              Steuern
                              tapo.0.id.remote auf true setzen steuert den jeweiligen Befehl
                              Steckdose und Kamerasteuerung aktivieren
                              App auf Handy aufrufen
                              "ich" (rechts unten) aufrufen
                              "Dienste"
                              "Dienste von Drittanbietern"
                              "Kompatibilität mit Drittanbietern" auf "ON"
                              M
                              M
                              mblass
                              #70
                              @tombox Hallo, erstmal vielen Dank für Deine Mühe. Auf einen Tapo-Adapter habe ich schon lange gehofft. Ich habe zwei 310-Kameras und keinen kostenpflichtigen Account bei Tapo. Die Login-Daten zur App funktionieren. Username und Passwort habe ich in den Adapter eingegeben, login war erfolgreich. Außer info.connection = true und einem leeren Datenpunkt devicelist bekomme ich aber keine Datenpunkte. Manuelles Anlegen und Füllen des DP id.ip hat auch nichts Sichtbares gebracht. Die Log-Einträge nach Adapterstart sind:
                              tapo.0 2022-10-11 19:50:47.028 info Wait for connections
                              tapo.0 2022-10-11 19:50:47.022 info Found 0 devices
                              tapo.0 2022-10-11 19:50:46.435 info Login tp TAPO App
                              Mache ich was falsch oder kann das in meiner Konstellation gar nicht funktionieren?
                              • M mblass
                                T
                                T
                                tombox
                                #71
                                @mblass Adapter wurde nicht mit Kameras getestet. Ich schreibe dich mal privat an
                                • M
                                  M
                                  muhma
                                  #72
                                  @tombox Huhu
                                  Habe gerade 0.0.5 installiert. Logindaten eingegeben. Das passte auch soweit. Mail kam bzgl. des Logins also ist das PW richtig. Jedoch sehe ich im Log nur:
                                  tapo.0 	2022-10-13 21:13:16.555	info	Wait for connections
                                  tapo.0 	2022-10-13 21:13:16.548	warn	Login failed using cached device list
                                  tapo.0 	2022-10-13 21:13:16.548	error	{"error_code":0,"result":{"accountId":"XXX","regionCode":"DE","regTime":"2021-12-28 11:49:13","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","riskDetected":0,"nickname":"XXX","errorCode":"0","email":"XXX.de","token":"XXX","refreshToken":"XXX"}}
                                  tapo.0 	2022-10-13 21:13:16.548	error	Login failed
                                  tapo.0 	2022-10-13 21:13:16.122	info	Login tp TAPO App
                                  tapo.0 	2022-10-13 21:13:16.052	info	starting. Version 0.0.5 (non-npm: TA2k/ioBroker.tapo#c97e8184bb58450f803d59cebba6d5f7cfb67dc9) in /opt/iobroker/node_modules/iobroker.tapo, node: v14.20.0, js-controller: 4.0.23```
                                  code_text
                                  Mache ich irgendwas falsch? Eine vorherige Version (glaube 0.0.3) lief noch problemlos. Dann hatte ich heute diesen Blacklist Fehler und habe deswegen mal ein Update reingeworfen
                                  CodierknechtC T 2 Antworten Letzte Antwort
                                  • M muhma
                                    @tombox Huhu
                                    code_text
                                    CodierknechtC
                                    CodierknechtC
                                    Codierknecht
                                    #73
                                    @muhma sagte in Test Adapter TP-Link Tapo:
                                    Blacklist könnte bedeuten, dass Du (dein Account oder Deine IP) vom Anbieter gesperrt sind.
                                    Da würde eine neue Version nicht wirklich weiterhelfen.
                                    • M muhma
                                      @tombox Huhu
                                      code_text
                                      T
                                      T
                                      tombox
                                      #74
                                      @muhma #probier nochmal via GitHub zu installieren.
                                      Die Blacklist war weil ich beim login die gleiche Zufalls id verwendet haben jetzt ist sie richtig zufällig
                                      • M
                                        M
                                        muhma
                                        #75
                                        Ok jetzt sieht es gut aus.
                                        Kann es daran liegen das ich die Instanz vorher nicht gelöscht habe? Das der da noch was im Cache hatte?
                                        • M muhma
                                          T
                                          T
                                          tombox
                                          #76
                                          @muhma Nein Programmierfehler bei mir
                                          83.9k
