[Frage] Xiaomi Vacuum cleaner
Ich möchte gerade einen 2. Roboter einrichten. Der erste läuft wunderbar über ioBroker, wenn ich aber einen weiteren Adapter hinzufüge, bekomme ich Fehler.
Habt ihr eine Idee wo der Fehler liegen könnte?
host.raspberrypi 2017-06-30 12:35:21.521 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:35:21.521 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:35:20.137 info instance system.adapter.mihome-vacuum.1 started with pid 1660 host.raspberrypi 2017-06-30 12:34:50.118 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:34:50.117 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:34:48.726 info instance system.adapter.mihome-vacuum.1 started with pid 1646 host.raspberrypi 2017-06-30 12:34:18.707 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:34:18.706 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:34:17.326 info instance system.adapter.mihome-vacuum.1 started with pid 1635 host.raspberrypi 2017-06-30 12:33:47.307 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:33:47.306 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:33:45.929 info instance system.adapter.mihome-vacuum.1 started with pid 1621 host.raspberrypi 2017-06-30 12:33:15.910 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:33:15.910 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:33:14.468 info instance system.adapter.mihome-vacuum.1 started with pid 1608 host.raspberrypi 2017-06-30 12:32:44.447 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:32:44.447 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:32:43.076 info instance system.adapter.mihome-vacuum.1 started with pid 1592 host.raspberrypi 2017-06-30 12:32:13.058 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2017-06-30 12:32:13.058 error instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK) host.raspberrypi 2017-06-30 12:32:11.646 info instance system.adapter.mihome-vacuum.1 started with pid 1580Das kommt immer und immer wieder. Wie gesagt, mit dem anderen Adapter und Mi Roboter klappt alles wunderbar.
Lieben Gruß, Karim.
Lieben Gruß, Karim. `
Hast du den eigenen Port geändert? Wenn du zwei im Einsatz hast, muss es über zwei unterschiedliche ports laufeGesendet von meinem Handy
Ah okay, danke! Nein das habe ich natürlich nicht gemacht ;)
Wie finde ich denn den 2. Port heraus, oder kann ich da irgendwas eintragen?
Lieben Gruß, Karim.
Edit: Danke, habe es einfach mal versucht und nun klappt es :) Habe einfach den eigenen Port geändert, Danke :)
Hast Du in der mihome App einen Namen für Deinen Sauger vergeben? Such den mal mit der Suchfunktion Deines Editors in der squite Datei `
Ja das hab ich gemacht, ich habe den Sauger RobiSaugi genannt und in der suche oder in einem SQLite Viewer finde ich ebenfalls nichts -.- Ich versteh garnicht das ich der einzige bin der das Problem hat, habe es sogar alles auf Mac und Windows probiert
so ich glaube ich bin mit der neuen version Fertig, wäre super wenn ich mindestens von zwei Leuten Rückmeldung bekommen könnte, da doch einiges geändert wurde, Also bei mir läuft er nun seit ca einer Woche Fehlerfrei auf windows, raspberry2 mit jessie und odroid mit ubuntu alles mit unterschiedlichen node versionen, also sollte eigentlich nix mehr schief gehen.
https://github.com/MeisterTR/ioBroker.m … m/tree/new
1768_2017-07-01_06h56_45.png -
so ich glaube ich bin mit der neuen version Fertig, wäre super wenn ich mindestens von zwei Leuten Rückmeldung bekommen könnte, da doch einiges geändert wurde, Also bei mir läuft er nun seit ca einer Woche Fehlerfrei auf windows, raspberry2 mit jessie und odroid mit ubuntu alles mit unterschiedlichen node versionen, also sollte eigentlich nix mehr schief gehen. `
Hallo Meistertr,
vielen Dank für deinen Einsatz. Leider kann ich dir noch kein Feedback geben weil mein Xiaomi erst nächste Woche (hoffentlich) kommt.
Ich finde aber deinen View schon mal klasse für den Roboter. Wärst du bereit diesen zu exportieren und der Allgemeinheit zur Verfügung zu stellen?
Beste Grüße
Alex
Hi Meister,
die Installation von GIT hat nicht geklappt:
! $ ./iobroker url "https://github.com/MeisterTR/ioBroker.m … m/tree/new" --debug
! install https://github.com/MeisterTR/ioBroker.m ... all/master
! npm install https://github.com/MeisterTR/ioBroker.m ... all/master --production --prefix "/opt/iobroker" (System call)
! npm
! ERR! fetch failed https://github.com/MeisterTR/ioBroker.m ... all/master
! npm
! WARN retry will retry, error on last attempt: Error: fetch failed with status code 404
Ich habe es dann manuell durchgeführt. Hat soweit dann geklappt.Die Fortschreibung der Historie habe ich nicht als Objekt (JSON). Ich nehme an, dass du das selber machst oder sollte ich ein objekt mit einer json Tabelle haben ?
Noch eine Bitte; Koenntest du deine View posten ? Wuerde bestimmt einigen und mir Arbeit ersparen ;)
vG Looxer
Hi Meister,
! npm
! npm
vG Looxer `
Du musst die ZIP von git downloaden entpacken und in das Verzeichnis node-Module/mihome-vacuum rein kopieren dann noch einmal im Terminal iobroker upload mihome-vacuum dann sollte es gehen. Der ist noch nicht mein npmGesendet von meinem Handy
jap, das hatte ich gemacht. Das meinte ich mit "manuell"
ich habe mir die states code io.package.jason angesehen. Die wurden nicht angelegt.
Schaue ich mir nochmal an.
vG Looxer `
die muss auf jedefall die neue version haben, dann sollte in den instanzen 0.5.5 stehen bei installierter version. Dann solltest du wie auf dem bild zu sehen die objekte mit json, und html table sehen
1768_unbenannt.png -
Ich habe das gemacht, während der robby arbeitete.
Die States werden fortgeschrieben. Sieht alles gut aus.
Abfrageintervall habe ich auf 1000 ms gestellt.
Hierzu ein kleines Feedback. Das Intervall hatte keinen Vorgabewert. Waere gut, wenn es einen Defaultwert dazu gaebe.
vG Looxer
Die historie sollte sich nach dem saugen neu aufbauen und dann sollte alles drin sein. Default ist 10000 da viele Anfragen mit Wartezeit gesendet werden. Bei unter 10 sec nimmt er automatisch 10 sec an. `
kurze RueckmeldungLief alles sauber durch. Die Historie Json ist komplett.
Die Json historie faengt am 15.06 an und die html Historie am 19.06. Beide enthalten den neuesten Eintrag.
Vielen Dank fuer deinen Einsatz hier. Super Arbeit.
vG Looxer
