  5. Hs 100 Probleme
Hs 100 Probleme
55 Beiträge 5 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • S Spidermike
    ich muss mich wal wieder melden und zwar habe ich arge Probleme mit dem HS 100 Adapter und ich hoffe ihr könnt mir helfen.
    Der Adapter stürzt immer wieder ab und schreibt folgendes in die Protokolldatei
    host.raspberrypi4-iobroker
    	2022-09-20 15:31:19.212	warn	Do not restart adapter system.adapter.hs100.0 because restart loop detected
    	2022-09-20 15:31:19.212	info	Restart adapter system.adapter.hs100.0 because enabled
    	2022-09-20 15:31:19.212	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    	2022-09-20 15:31:19.212	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
    	2022-09-20 15:31:19.212	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
    	2022-09-20 15:31:19.211	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    	2022-09-20 15:31:19.211	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
    	2022-09-20 15:31:19.211	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
    	2022-09-20 15:31:19.211	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
    	2022-09-20 15:31:19.211	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
    	2022-09-20 15:31:19.210	error	Caught by controller[2]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
    	2022-09-20 15:31:19.210	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
    	2022-09-20 15:31:19.210	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
    	2022-09-20 15:31:19.210	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    	2022-09-20 15:31:19.210	error	Caught by controller[1]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
    	2022-09-20 15:31:19.210	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
    	2022-09-20 15:31:19.210	error	Caught by controller[0]: at processTimers (node:internal/timers:502:7)
    	2022-09-20 15:31:19.209	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:559:17)
    	2022-09-20 15:31:19.209	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
    	2022-09-20 15:31:19.209	error	Caught by controller[0]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
    	2022-09-20 15:31:19.209	error	Caught by controller[0]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
    hs100.0
    	2022-09-20 15:31:18.631	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    hs100.0
    	2022-09-20 15:31:18.629	info	terminating
    hs100.0
    	2022-09-20 15:31:18.628	info	cleaned everything up...
    hs100.0
    	2022-09-20 15:31:18.623	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
    hs100.0
    	2022-09-20 15:31:18.622	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
    hs100.0
    	2022-09-20 15:31:18.621	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
    hs100.0
    	2022-09-20 15:31:18.621	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hs100.0
    	2022-09-20 15:31:17.888	warn	getDevice Socket connection Timeout ip: 192.168.178.94 please reconnect the Device
    hs100.0
    	2022-09-20 15:31:12.895	warn	getDevice Socket connection Timeout ip: 192.168.178.94 please reconnect the Device
    was läuft jetzt wieder schief?
    @spidermike sagte in Hs 100 Probleme:
    Netzwerktrouble.
    Und der Pfad /opt/iobroker/node_modules/tplink-smarthome-api/ kommt mir auch komisch vor. Üblicherweise liegen Deps mindestens eine Ebene tiefer im tree.
    S arteckA 2 Antworten Letzte Antwort
      Netzwerktrouble.
      Spidermike
      schrieb am zuletzt editiert von Spidermike
      danke für deine schnelle Antwort, was muss ich jetzt machen?
      Denn das nervt, denn mein Script für meine Heizstäbe funktioniert dann nicht mehr wenn der Adapter nicht läuft
      Und was hat das mit dem Timeout auf sich?
      • S Spidermike
        @spidermike
        Beim Netzwerktrouble kann man nur sehr eingeschränkt helfen.
        Musst du vor Ort klären. Insbesondere bei WLAN kann das aufwendig sein.
        Zum iobroker:
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        iobroker update
        cd /opt/iobroker
        npm ls
        anschauen.
        • S Spidermike
          Das Gerät hat auf einen 'Anruf' nicht innerhalb von 10 Sekunden reagiert.
            Spidermike
            @thomas-braun sagte in Hs 100 Probleme:
            Kann das sein das die Wlanverbindung zu der steckdose zu schlecht ist?
            Steckdose ist im Keller
            Thomas BraunT S 2 Antworten Letzte Antwort
            • S Spidermike
              Natürlich. Ich sag ja: Netzwerktrouble.
              • S Spidermike
                Spidermike
                @spidermike
                uname -m && type -P nodejs node npm && nodejs -v &&        node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /d        ev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.17.0
                v16.17.0
                8.15.0
                4.0.23
                pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                /home/pi
                OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:4 https://repos.influxdata.com/debian bullseye InRelease
                OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           16.17.0-deb-1nodesource1
                  Installationskandidat: 16.17.0-deb-1nodesource1
                  Versionstabelle:
                 *** 16.17.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                     12.22.12~dfsg-1~deb11u1 500
                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                pi@raspberrypi4-iobroker:~ $ pi@raspberrypi4-iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v &&        node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /d        ev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.17.0
                v16.17.0
                8.15.0
                4.0.23
                pi
                /home/pi
                • S Spidermike
                  @spidermike
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  4.0.23
                  pi
                  /home/pi
                  nodejs:
                    Versionstabelle:
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  4.0.23
                  pi
                  /home/pi
                  @spidermike
                  iobroker update
                  cd /opt/iobroker
                  npm ls
                  noch nachreichen.
                    @spidermike
                    iobroker update
                    cd /opt/iobroker
                    npm ls
                    noch nachreichen.
                    Spidermike
                    @spidermike
                    iobroker update
                    cd /opt/iobroker
                    npm ls
                    noch nachreichen.
                    pi@raspberrypi4-iobroker:~ $ iobroker update
                    Used repository: stable
                    Adapter    "admin"        : 6.2.22   , installed 6.2.22
                    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                    Adapter    "devices"      : 1.0.12   , installed 1.0.12
                    Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                    Adapter    "growatt"      : 1.1.19   , installed 1.1.19
                    Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
                    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                    Adapter    "iot"          : 1.11.9   , installed 1.11.9
                    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
                    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                    Controller "js-controller": 4.0.23   , installed 4.0.23
                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
                    Adapter    "wled"         : 0.6.7    , installed 0.6.7
                    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                    pi@raspberrypi4-iobroker:~ $ cd /opt/iobroker
                    pi@raspberrypi4-iobroker:/opt/iobroker $ cd /opt/iobroker
                    pi@raspberrypi4-iobroker:/opt/iobroker $ npm ls
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├── iobroker.admin@6.2.22
                    ├── iobroker.alexa2@3.19.9
                    ├── iobroker.backitup@2.4.10
                    ├── iobroker.cloud@4.2.2
                    ├── iobroker.deconz@1.3.21
                    ├── iobroker.devices@1.0.12
                    ├── iobroker.discovergy@0.5.8
                    ├── iobroker.discovery@3.0.5
                    ├── iobroker.fb-checkpresence@1.1.19
                    ├── iobroker.fullybrowser@2.1.2
                    ├── iobroker.growatt@1.1.19
                    ├── iobroker.homeconnect@1.0.1
                    ├── iobroker.hs100@2.1.2
                    ├── iobroker.iot@1.11.9
                    ├── iobroker.iqontrol@2.0.0
                    ├── iobroker.javascript@6.0.3
                    ├── iobroker.js-controller@4.0.23
                    ├── iobroker.mqtt@4.0.7
                    ├── iobroker.plenticore@2.2.0
                    ├── iobroker.rpi2@1.3.2
                    ├── iobroker.shelly@6.0.0
                    ├── iobroker.simple-api@2.7.0
                    ├── iobroker.socketio@4.2.0
                    ├── iobroker.telegram@1.14.1
                    ├── iobroker.vis@1.4.15
                    ├── iobroker.web@4.3.0
                    ├── iobroker.whatsapp-cmb@0.2.2
                    ├── iobroker.wled@0.6.7
                    └── iobroker.zigbee@1.7.5
                    • S Spidermike
                      @spidermike
                      iobroker update
                      cd /opt/iobroker
                      npm ls
                      noch nachreichen.
                      @spidermike
                      Das ist alles total i. O.
                      Bleibt dein WLAN.
                        Spidermike
                        habe mal in mein Mesh geschaut, die Steckdose verbindet sich mit einen Repeater der viel zu weit weg ist, kann ich nicht IP adressen direkt an einen Repeater binden ?
                        • S Spidermike
                          @spidermike
                          Keine Ahnung. Was ist denn da für Hardware involviert?
                            @spidermike
                            Bleibt dein WLAN.
                            Spidermike
                            @spidermike
                            Bleibt dein WLAN.
                            Ich habe heute erst alles auf Node.js 16 umgestellt
                              @spidermike
                              Spidermike
                              @spidermike
                              Ich habe eine Fritzbox 7590 als Master und mehrere Repeater in 2 Stockwerken im Haus
                              Muss noch leider alles über Wlan und über Steckdosen laufen lassen da ich kein Netzwerkkabel verbaut hab
                              • Thomas BraunT Online
                                @spidermike
                                Für gewöhnlich organisiert sich so ein Mesh autark. Zumindest in der Theorie.
                                Ich hab selber keins laufen hier, kann also da nicht wirklich weiterhelfen.
                                  @spidermike
                                  Spidermike
                                  ich warte seid 2 Jahren auf LWL im Haus und wollte dann mir Netzwerkkabel verlegen, aber angeblich sollte das dieses Jahr passieren aber die kommen nicht vorwärts.
                                    Netzwerktrouble.
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    das ist richtig so...
                                    @spidermike die Dose antwortet nicht innerhalb der Parameter.. kannst ewtl. mal in der Adapter Einstellugen die Antwortzeit verlängern
                                    • arteckA arteck
                                      Spidermike
                                      @arteck sagte in Hs 100 Probleme:
                                      @spidermike die Dose antwortet nicht innerhalb der Parameter.. kannst ewtl. mal in der Adapter Winstellugen die Antwortzeit verlängern
                                      wie mache ich das?
