  4. Container ohne Volumen zu C. mit Volumen migrieren | Yahka
    5.8k
28 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • S sascho
    @glasfaser
    Er bleibt dann aktuell in diesem Status stehen.
    Das Protokoll ist wahrscheinlich nicht vollständig, da im Terminal des Synology Dockers nicht hochgescrollt werden kann.
    2022-09-17 18:36:56.240  - info: backitup.0 (2861) Got terminate signal TERMINATE_YOURSELF
    2022-09-17 18:36:56.241  - info: backitup.0 (2861) cleaned everything up...
    2022-09-17 18:36:56.242  - info: backitup.0 (2861) terminating
    2022-09-17 18:36:56.242  - info: backitup.0 (2861) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-09-17 18:36:56.279  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 send kill signal
    2022-09-17 18:36:56.765  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-17 18:36:59.301  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 started with pid 2889
    2022-09-17 18:37:00.052  - info: backitup.0 (2889) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.17.0, js-controller: 4.0.23
    2022-09-17 18:37:00.084  - info: backitup.0 (2889) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-09-17 18:37:04.913  - info: admin.0 (2600) <== Disconnect system.user.admin from ::ffff:192.168.178.32
    2022-09-17 18:37:04.986  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
    2022-09-17 18:38:07.743  - info: host.iobroker_2022-09-17 received SIGTERM
    2022-09-17 18:38:07.744  - info: host.iobroker_2022-09-17 stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-09-17 18:38:07.744  - info: host.iobroker_2022-09-17 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-09-17 18:38:07.744  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-09-17 18:38:07.745  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.0 (force=false, process=true)
    2022-09-17 18:38:07.745  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.1 (force=false, process=true)
    2022-09-17 18:38:07.749  - info: discovery.0 (2545) Got terminate signal TERMINATE_YOURSELF
    2022-09-17 18:38:07.750  - info: discovery.0 (2545) terminating
    2022-09-17 18:38:07.751  - info: discovery.0 (2545) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason2022-09-17 18:38:07.761  - info: yahka.0 (2755) cleaned up ...
    2022-09-17 18:38:07.761  - info: yahka.0 (2755) terminating
    2022-09-17 18:38:07.762  - info: yahka.0 (2755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-09-17 18:38:07.754  - info: yahka.1 (2809) cleaning up ...
    2022-09-17 18:38:07.754  - info: yahka.1 (2809) cleaned up ...
    2022-09-17 18:38:07.754  - info: yahka.1 (2809) terminating
    2022-09-17 18:38:07.755  - info: yahka.1 (2809) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-09-17 18:38:07.756  - info: backitup.0 (2889) Got terminate signal TERMINATE_YOURSELF
    2022-09-17 18:38:07.757  - info: backitup.0 (2889) cleaned everything up...
    2022-09-17 18:38:07.757  - info: backitup.0 (2889) terminating
    2022-09-17 18:38:07.758  - info: backitup.0 (2889) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-09-17 18:38:07.749  - info: admin.0 (2600) terminating http server on port 8081
    2022-09-17 18:38:07.768  - info: admin.0 (2600) terminating
    2022-09-17 18:38:07.768  - info: admin.0 (2600) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-09-17 18:38:07.788  - info: host.iobroker_2022-09-17 stopInstance system.adapter.admin.0 send kill signal
    2022-09-17 18:38:07.789  - info: host.iobroker_2022-09-17 stopInstance system.adapter.discovery.0 send kill signal
    2022-09-17 18:38:07.789  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 send kill signal
    2022-09-17 18:38:07.789  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.0 send kill signal
    2022-09-17 18:38:07.789  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.1 send kill signal
    2022-09-17 18:38:08.286  - info: host.iobroker_2022-09-17 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-17 18:38:08.294  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-17 18:38:08.315  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-17 18:38:08.354  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-17 18:38:08.357  - info: host.iobroker_2022-09-17 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-17 18:38:08.357  - info: host.iobroker_2022-09-17 All instances are stopped.
    2022-09-17 18:38:08.575  - info: host.iobroker_2022-09-17 terminated
    GlasfaserG Offline
    GlasfaserG Offline
    @sascho sagte in Container ohne Volumen zu C. mit Volumen migrieren | Yahka:
    Dann zeige mal im Terminal :
    iobroker logs --watch
    • GlasfaserG Glasfaser
      sascho
      schrieb am zuletzt editiert von sascho
      @glasfaser
      Im Post vorher ist der letzte Teil des Terminal LOGs in der Synology Docker App. Irgendwie kann man da nicht weiter nach oben scrollen bzw. kopieren, daher hier noch aus der Exec Konsole des Portainers das komplette Protokoll:
      2022-09-17 18:32:50.604  - info: host.iobroker_2022-09-17 iobroker.js-controller version 4.0.23 js-controller starting
      2022-09-17 18:32:50.607  - info: host.iobroker_2022-09-17 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-09-17 18:32:50.608  - info: host.iobroker_2022-09-17 hostname: iobroker_2022-09-17, node: v16.17.0
      2022-09-17 18:32:50.608  - info: host.iobroker_2022-09-17 ip addresses: 192.168.178.100
      2022-09-17 18:32:50.893  - info: host.iobroker_2022-09-17 connected to Objects and States
      2022-09-17 18:32:50.905  - info: host.iobroker_2022-09-17 Node.js version has changed from unknown to 16.17.0
      2022-09-17 18:32:50.937  - info: host.iobroker_2022-09-17 added notifications configuration of host
      2022-09-17 18:32:51.091  - info: host.iobroker_2022-09-17 3 instances found
      2022-09-17 18:32:51.096  - info: host.iobroker_2022-09-17 starting 3 instances
      2022-09-17 18:32:51.126  - info: host.iobroker_2022-09-17 instance system.adapter.admin.0 started with pid 2336
      2022-09-17 18:32:51.229  - info: host.iobroker_2022-09-17 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-09-17 18:32:51.262  - info: host.iobroker_2022-09-17 Created UUID: e4b33fe6-cfe0-4ce2-bf47-7e6620012e8e
      2022-09-17 18:32:51.943  - info: admin.0 (2336) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:32:51.966  - info: admin.0 (2336) requesting all states
      2022-09-17 18:32:51.966  - info: admin.0 (2336) requesting all objects
      2022-09-17 18:32:52.014  - info: admin.0 (2336) received all objects
      2022-09-17 18:32:52.030  - info: admin.0 (2336) Request actual repository...
      2022-09-17 18:32:52.037  - info: host.iobroker_2022-09-17 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-09-17 18:32:52.042  - info: admin.0 (2336) http server listening on port 8081
      2022-09-17 18:32:52.042  - info: admin.0 (2336) Use link "http://localhost:8081" to configure.
      2022-09-17 18:32:52.155  - warn: admin.0 (2336) Repository cannot be read: Active repo - stable
      2022-09-17 18:32:52.156  - warn: admin.0 (2336) Active repository "stable cannot be read
      2022-09-17 18:32:54.113  - info: admin.0 (2336) Repository received successfully.
      2022-09-17 18:32:55.119  - info: host.iobroker_2022-09-17 instance system.adapter.discovery.0 started with pid 2352
      2022-09-17 18:32:55.806  - info: discovery.0 (2352) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:32:59.120  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 started with pid 2367
      2022-09-17 18:32:59.901  - info: backitup.0 (2367) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:32:59.933  - info: backitup.0 (2367) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-09-17 18:33:54.923  - info: host.iobroker_2022-09-17 iobroker upgrade backitup@2.4.10
      2022-09-17 18:33:55.756  - info: host.iobroker_2022-09-17 iobroker Update backitup from @2.4.9 to @2.4.10
      2022-09-17 18:33:55.767  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 Adapter "system.adapter.backitup.0" is stopped.
      2022-09-17 18:33:55.774  - info: host.iobroker_2022-09-17 "system.adapter.backitup.0" disabled
      2022-09-17 18:33:55.775  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-09-17 18:33:55.779  - info: backitup.0 (2367) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:33:55.780  - info: backitup.0 (2367) cleaned everything up...
      2022-09-17 18:33:55.780  - info: backitup.0 (2367) terminating
      2022-09-17 18:33:55.781  - info: backitup.0 (2367) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-17 18:33:55.819  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 send kill signal
      2022-09-17 18:33:56.223  - info: host.iobroker_2022-09-17 iobroker NPM version: 8.15.0
      2022-09-17 18:33:56.224  - info: host.iobroker_2022-09-17 iobroker Installing iobroker.backitup@2.4.10... (System call)
      2022-09-17 18:33:56.314  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-17 18:34:00.219  - info: host.iobroker_2022-09-17 iobroker changed 2 packages in 4s
      2022-09-17 18:34:00.219  - info: host.iobroker_2022-09-17 iobroker 38 packages are looking for funding  run `npm fund` for details
      2022-09-17 18:34:00.260  - info: host.iobroker_2022-09-17 iobroker Update "system.adapter.backitup.0"
      2022-09-17 18:34:00.279  - info: host.iobroker_2022-09-17 iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      2022-09-17 18:34:00.296  - info: host.iobroker_2022-09-17 iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      2022-09-17 18:34:00.301  - info: host.iobroker_2022-09-17 iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      2022-09-17 18:34:00.313  - info: host.iobroker_2022-09-17 iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      2022-09-17 18:34:00.637  - info: host.iobroker_2022-09-17 iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      2022-09-17 18:34:00.848  - info: host.iobroker_2022-09-17 iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      2022-09-17 18:34:00.908  - info: host.iobroker_2022-09-17 iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      2022-09-17 18:34:00.916  - info: host.iobroker_2022-09-17 iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      2022-09-17 18:34:00.934  - info: host.iobroker_2022-09-17 iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      2022-09-17 18:34:00.941  - info: host.iobroker_2022-09-17 iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      2022-09-17 18:34:00.960  - info: host.iobroker_2022-09-17 iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      2022-09-17 18:34:00.968  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 Adapter "system.adapter.backitup.0" is started
      2022-09-17 18:34:00.975  - info: host.iobroker_2022-09-17 "system.adapter.backitup.0" enabled
      2022-09-17 18:34:01.041  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 started with pid 2477
      2022-09-17 18:34:01.835  - info: backitup.0 (2477) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:34:01.866  - info: backitup.0 (2477) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-09-17 18:34:01.999  - info: host.iobroker_2022-09-17 iobroker exit 0
      2022-09-17 18:34:03.651  - info: host.iobroker_2022-09-17 iobroker upgrade discovery@3.0.5
      2022-09-17 18:34:04.486  - info: host.iobroker_2022-09-17 iobroker Update discovery from @3.0.3 to @3.0.5
      2022-09-17 18:34:04.937  - info: host.iobroker_2022-09-17 iobroker NPM version: 8.15.0
      2022-09-17 18:34:04.937  - info: host.iobroker_2022-09-17 iobroker Installing iobroker.discovery@3.0.5... (System call)
      2022-09-17 18:34:07.072  - info: host.iobroker_2022-09-17 iobroker changed 1 package in 2s
      2022-09-17 18:34:07.073  - info: host.iobroker_2022-09-17 iobroker 38 packages are looking for funding  run `npm fund` for details
      2022-09-17 18:34:07.117  - info: host.iobroker_2022-09-17 iobroker Update "system.adapter.discovery.0"
      2022-09-17 18:34:07.123  - info: host.iobroker_2022-09-17 stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-09-17 18:34:07.127  - info: discovery.0 (2352) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:34:07.128  - info: discovery.0 (2352) terminating
      2022-09-17 18:34:07.129  - info: discovery.0 (2352) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-17 18:34:07.140  - info: host.iobroker_2022-09-17 iobroker upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      2022-09-17 18:34:07.155  - info: host.iobroker_2022-09-17 iobroker upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      2022-09-17 18:34:07.157  - info: host.iobroker_2022-09-17 stopInstance system.adapter.discovery.0 send kill signal
      2022-09-17 18:34:07.161  - info: host.iobroker_2022-09-17 iobroker upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      2022-09-17 18:34:07.165  - info: host.iobroker_2022-09-17 iobroker upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      2022-09-17 18:34:07.169  - info: host.iobroker_2022-09-17 iobroker upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      2022-09-17 18:34:07.174  - info: host.iobroker_2022-09-17 iobroker upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      2022-09-17 18:34:07.178  - info: host.iobroker_2022-09-17 iobroker upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      2022-09-17 18:34:07.650  - info: host.iobroker_2022-09-17 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-17 18:34:08.211  - info: host.iobroker_2022-09-17 iobroker exit 0
      2022-09-17 18:34:09.864  - info: host.iobroker_2022-09-17 iobroker upgrade admin@6.2.22
      2022-09-17 18:34:10.181  - info: host.iobroker_2022-09-17 instance system.adapter.discovery.0 started with pid 2545
      2022-09-17 18:34:10.707  - info: host.iobroker_2022-09-17 iobroker Update admin from @5.3.8 to @6.2.22
      2022-09-17 18:34:10.726  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 Adapter "system.adapter.admin.0" is stopped.
      2022-09-17 18:34:10.731  - info: host.iobroker_2022-09-17 "system.adapter.admin.0" disabled
      2022-09-17 18:34:10.732  - info: host.iobroker_2022-09-17 stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-09-17 18:34:10.733  - info: admin.0 (2336) Adapter is disabled => stop
      2022-09-17 18:34:10.736  - info: admin.0 (2336) terminating http server on port 8081
      2022-09-17 18:34:10.739  - info: admin.0 (2336) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:34:10.740  - info: admin.0 (2336) terminating
      2022-09-17 18:34:10.741  - info: admin.0 (2336) Terminated (NO_ERROR): Without reason
      2022-09-17 18:34:10.775  - info: host.iobroker_2022-09-17 stopInstance system.adapter.admin.0 send kill signal
      2022-09-17 18:34:10.938  - info: discovery.0 (2545) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:34:11.200  - info: host.iobroker_2022-09-17 iobroker NPM version: 8.15.0
      2022-09-17 18:34:11.201  - info: host.iobroker_2022-09-17 iobroker Installing iobroker.admin@6.2.22... (System call)
      2022-09-17 18:34:11.263  - info: host.iobroker_2022-09-17 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2022-09-17 18:34:28.145  - info: host.iobroker_2022-09-17 iobroker added 6 packages, and changed 4 packages in 17s38 packages are looking for funding  run `npm fund` for details
      2022-09-17 18:34:28.185  - info: host.iobroker_2022-09-17 iobroker Update "system.adapter.admin.0"
      2022-09-17 18:34:28.363  - info: host.iobroker_2022-09-17 iobroker upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      2022-09-17 18:34:28.371  - info: host.iobroker_2022-09-17 iobroker upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
      2022-09-17 18:34:28.473  - info: host.iobroker_2022-09-17 iobroker upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      2022-09-17 18:34:28.559  - info: host.iobroker_2022-09-17 iobroker upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
      2022-09-17 18:34:29.139  - info: host.iobroker_2022-09-17 iobroker upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
      2022-09-17 18:34:29.162  - info: host.iobroker_2022-09-17 iobroker upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      2022-09-17 18:34:29.205  - info: host.iobroker_2022-09-17 iobroker upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      2022-09-17 18:34:29.211  - info: host.iobroker_2022-09-17 iobroker upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      2022-09-17 18:34:29.220  - info: host.iobroker_2022-09-17 iobroker upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      2022-09-17 18:34:29.228  - info: host.iobroker_2022-09-17 iobroker upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      2022-09-17 18:34:29.237  - info: host.iobroker_2022-09-17 iobroker upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      2022-09-17 18:34:29.246  - info: host.iobroker_2022-09-17 iobroker upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      2022-09-17 18:34:29.254  - info: host.iobroker_2022-09-17 iobroker upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      2022-09-17 18:34:29.264  - info: host.iobroker_2022-09-17 iobroker upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      2022-09-17 18:34:29.299  - info: host.iobroker_2022-09-17 iobroker upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      2022-09-17 18:34:29.307  - info: host.iobroker_2022-09-17 iobroker upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      2022-09-17 18:34:29.315  - info: host.iobroker_2022-09-17 iobroker upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      2022-09-17 18:34:29.324  - info: host.iobroker_2022-09-17 iobroker upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      2022-09-17 18:34:29.337  - info: host.iobroker_2022-09-17 iobroker upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      2022-09-17 18:34:29.350  - info: host.iobroker_2022-09-17 iobroker upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2022-09-17 18:34:29.358  - info: host.iobroker_2022-09-17 iobroker upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2022-09-17 18:34:29.367  - info: host.iobroker_2022-09-17 iobroker upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2022-09-17 18:34:29.375  - info: host.iobroker_2022-09-17 iobroker upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2022-09-17 18:34:29.385  - info: host.iobroker_2022-09-17 iobroker upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2022-09-17 18:34:29.393  - info: host.iobroker_2022-09-17 iobroker upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      2022-09-17 18:34:29.407  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 Adapter "system.adapter.admin.0" is started
      2022-09-17 18:34:29.417  - info: host.iobroker_2022-09-17 "system.adapter.admin.0" enabled
      2022-09-17 18:34:29.442  - info: host.iobroker_2022-09-17 instance system.adapter.admin.0 started with pid 2600
      2022-09-17 18:34:30.292  - info: admin.0 (2600) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:34:30.317  - info: admin.0 (2600) requesting all states
      2022-09-17 18:34:30.318  - info: admin.0 (2600) requesting all objects
      2022-09-17 18:34:30.504  - info: host.iobroker_2022-09-17 iobroker exit 0
      2022-09-17 18:34:30.551  - info: admin.0 (2600) received all objects
      2022-09-17 18:34:30.643  - info: admin.0 (2600) Request actual repository...
      2022-09-17 18:34:30.690  - info: admin.0 (2600) http server listening on port 8081
      2022-09-17 18:34:30.691  - info: admin.0 (2600) Use link "http://localhost:8081" to configure.
      2022-09-17 18:34:30.695  - info: admin.0 (2600) socket.io server listening on port 8081
      2022-09-17 18:34:30.794  - info: host.iobroker_2022-09-17 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-09-17 18:34:32.429  - info: admin.0 (2600) Repository received successfully.
      2022-09-17 18:34:34.987  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:01.249  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:12.894  - info: admin.0 (2600) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:14.388  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:22.290  - info: admin.0 (2600) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:33.500  - info: host.iobroker_2022-09-17 iobroker add yahka --host iobroker_2022-09-17
      2022-09-17 18:35:34.779  - info: host.iobroker_2022-09-17 iobroker NPM version: 8.15.0
      2022-09-17 18:35:34.780  - info: host.iobroker_2022-09-17 iobroker Installing iobroker.yahka@0.13.1... (System call)
      2022-09-17 18:35:42.098  - info: host.iobroker_2022-09-17 iobroker added 69 packages in 7s
      2022-09-17 18:35:42.099  - info: host.iobroker_2022-09-17 iobroker 75 packages are looking for funding  run `npm fund` for details
      2022-09-17 18:35:42.122  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 install adapter yahka
      2022-09-17 18:35:42.464  - error: host.iobroker_2022-09-17 iobroker Cannot install "pam-devel": E: Unable to locate package pam-devel
      2022-09-17 18:35:42.465  - error: host.iobroker_2022-09-17 iobroker The following apt-get packages could not be installed: pam-devel. Please install them manually.
      2022-09-17 18:35:42.485  - info: host.iobroker_2022-09-17 iobroker upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
      2022-09-17 18:35:42.499  - info: host.iobroker_2022-09-17 iobroker upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
      2022-09-17 18:35:42.503  - info: host.iobroker_2022-09-17 iobroker upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
      2022-09-17 18:35:42.507  - info: host.iobroker_2022-09-17 iobroker upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
      2022-09-17 18:35:42.535  - info: host.iobroker_2022-09-17 iobroker upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
      2022-09-17 18:35:42.542  - info: host.iobroker_2022-09-17 iobroker upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
      2022-09-17 18:35:42.551  - info: host.iobroker_2022-09-17 iobroker upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
      2022-09-17 18:35:42.559  - info: host.iobroker_2022-09-17 iobroker upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
      2022-09-17 18:35:42.569  - info: host.iobroker_2022-09-17 iobroker upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
      2022-09-17 18:35:42.576  - info: host.iobroker_2022-09-17 iobroker upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
      2022-09-17 18:35:42.584  - info: host.iobroker_2022-09-17 iobroker upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
      2022-09-17 18:35:42.593  - info: host.iobroker_2022-09-17 iobroker upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
      2022-09-17 18:35:42.603  - info: host.iobroker_2022-09-17 iobroker upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
      2022-09-17 18:35:42.610  - info: host.iobroker_2022-09-17 iobroker upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
      2022-09-17 18:35:42.618  - info: host.iobroker_2022-09-17 iobroker upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
      2022-09-17 18:35:42.627  - info: host.iobroker_2022-09-17 iobroker upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
      2022-09-17 18:35:42.638  - info: host.iobroker_2022-09-17 iobroker upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
      2022-09-17 18:35:42.650  - info: host.iobroker_2022-09-17 iobroker upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
      2022-09-17 18:35:42.835  - info: host.iobroker_2022-09-17 iobroker upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
      2022-09-17 18:35:42.998  - info: host.iobroker_2022-09-17 iobroker upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
      2022-09-17 18:35:43.012  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object yahka.meta._accessoryCategories created/updated
      2022-09-17 18:35:43.016  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka created/updated
      2022-09-17 18:35:43.035  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 create instance yahka
      2022-09-17 18:35:43.039  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.alive created
      2022-09-17 18:35:43.042  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.connected created
      2022-09-17 18:35:43.045  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.compactMode created
      2022-09-17 18:35:43.049  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.cpu created
      2022-09-17 18:35:43.052  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.cputime created
      2022-09-17 18:35:43.056  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.memHeapUsed created
      2022-09-17 18:35:43.065  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.memHeapTotal created
      2022-09-17 18:35:43.083  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.memRss created
      2022-09-17 18:35:43.090  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.uptime created
      2022-09-17 18:35:43.094  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.inputCount created
      2022-09-17 18:35:43.107  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.outputCount created
      2022-09-17 18:35:43.113  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.eventLoopLag created
      2022-09-17 18:35:43.120  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.sigKill created
      2022-09-17 18:35:43.123  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0.logLevel created
      2022-09-17 18:35:43.129  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.0 created
      2022-09-17 18:35:44.151  - info: host.iobroker_2022-09-17 iobroker exit 0
      2022-09-17 18:35:45.392  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:46.082  - info: admin.0 (2600) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:46.163  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.0 started with pid 2740
      2022-09-17 18:35:47.097  - info: yahka.0 (2740) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:35:47.114  - info: yahka.0 (2740) adapter ready, checking config
      2022-09-17 18:35:47.115  - info: yahka.0 (2740) first time initialization
      2022-09-17 18:35:47.123  - info: yahka.0 (2740) publishing bridge Yahka-0 on 0.0.0.0 using ciao
      2022-09-17 18:35:47.190  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.0 (force=false, process=true)
      2022-09-17 18:35:47.193  - info: yahka.0 (2740) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:35:47.194  - info: yahka.0 (2740) cleaning up ...
      2022-09-17 18:35:47.194  - info: yahka.0 (2740) cleaned up ...
      2022-09-17 18:35:47.194  - info: yahka.0 (2740) terminating
      2022-09-17 18:35:47.195  - info: yahka.0 (2740) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-17 18:35:47.232  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.0 send kill signal
      2022-09-17 18:35:47.720  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-17 18:35:50.253  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.0 started with pid 2755
      2022-09-17 18:35:51.056  - info: yahka.0 (2755) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:35:51.076  - info: yahka.0 (2755) adapter ready, checking config
      2022-09-17 18:35:51.085  - info: yahka.0 (2755) publishing bridge Yahka-0 on 0.0.0.0 using ciao
      2022-09-17 18:35:52.406  - info: host.iobroker_2022-09-17 iobroker add yahka --host iobroker_2022-09-17
      2022-09-17 18:35:53.123  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 create instance yahka
      2022-09-17 18:35:53.129  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.alive created
      2022-09-17 18:35:53.132  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.connected created
      2022-09-17 18:35:53.135  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.compactMode created
      2022-09-17 18:35:53.138  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.cpu created
      2022-09-17 18:35:53.143  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.cputime created
      2022-09-17 18:35:53.146  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.memHeapUsed created
      2022-09-17 18:35:53.149  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.memHeapTotal created
      2022-09-17 18:35:53.152  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.memRss created
      2022-09-17 18:35:53.155  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.uptime created
      2022-09-17 18:35:53.160  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.inputCount created
      2022-09-17 18:35:53.163  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.outputCount created
      2022-09-17 18:35:53.167  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.eventLoopLag created
      2022-09-17 18:35:53.170  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.sigKill created
      2022-09-17 18:35:53.173  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1.logLevel created
      2022-09-17 18:35:53.180  - info: host.iobroker_2022-09-17 iobroker host.iobroker_2022-09-17 object system.adapter.yahka.1 created
      2022-09-17 18:35:54.197  - info: host.iobroker_2022-09-17 iobroker exit 0
      2022-09-17 18:35:55.479  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:35:56.196  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.1 started with pid 2794
      2022-09-17 18:35:56.999  - info: yahka.1 (2794) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:35:57.016  - info: yahka.1 (2794) adapter ready, checking config
      2022-09-17 18:35:57.017  - info: yahka.1 (2794) first time initialization
      2022-09-17 18:35:57.025  - info: yahka.1 (2794) publishing bridge Yahka-1 on 0.0.0.0 using ciao
      2022-09-17 18:35:57.096  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.1 (force=false, process=true)
      2022-09-17 18:35:57.099  - info: yahka.1 (2794) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:35:57.099  - info: yahka.1 (2794) cleaning up ...
      2022-09-17 18:35:57.100  - info: yahka.1 (2794) cleaned up ...
      2022-09-17 18:35:57.100  - info: yahka.1 (2794) terminating
      2022-09-17 18:35:57.101  - info: yahka.1 (2794) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-17 18:35:57.139  - info: host.iobroker_2022-09-17 stopInstance system.adapter.yahka.1 send kill signal
      2022-09-17 18:35:57.629  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-17 18:35:58.165  - info: admin.0 (2600) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:36:00.157  - info: host.iobroker_2022-09-17 instance system.adapter.yahka.1 started with pid 2809
      2022-09-17 18:36:00.961  - info: yahka.1 (2809) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:36:00.979  - info: yahka.1 (2809) adapter ready, checking config
      2022-09-17 18:36:00.986  - info: yahka.1 (2809) publishing bridge Yahka-1 on 0.0.0.0 using ciao
      2022-09-17 18:36:14.377  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:36:38.908  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-09-17 18:36:38.910  - info: backitup.0 (2477) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:36:38.911  - info: backitup.0 (2477) cleaned everything up...
      2022-09-17 18:36:38.912  - info: backitup.0 (2477) terminating
      2022-09-17 18:36:38.912  - info: backitup.0 (2477) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-09-17 18:36:38.950  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 send kill signal
      2022-09-17 18:36:39.011  - info: admin.0 (2600) <== Disconnect system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:36:39.435  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-09-17 18:36:41.975  - info: host.iobroker_2022-09-17 instance system.adapter.backitup.0 started with pid 2861
      2022-09-17 18:36:42.715  - info: backitup.0 (2861) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.17.0, js-controller: 4.0.23
      2022-09-17 18:36:42.748  - info: backitup.0 (2861) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-09-17 18:36:44.350  - info: admin.0 (2600) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2022-09-17 18:36:56.238  - info: host.iobroker_2022-09-17 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-09-17 18:38:07.749  - info: admin.0 (2600) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:38:07.753  - info: yahka.1 (2809) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:38:07.759  - info: yahka.0 (2755) Got terminate signal TERMINATE_YOURSELF
      2022-09-17 18:38:07.760  - info: yahka.0 (2755) cleaning up ...
      Hier ist noch das Log aus dem Portainer:
      -----                    Startupscript is now running.                     -----
      -----                          Please be patient!                          -----
      -----                        Debugging information                         -----
      -----                                System                                -----
      -----                    arch:                x86_64                       -----
      -----                    hostname:            iobroker_2022-09-17          -----
      -----                             Docker-Image                             -----
      -----                    image:               v7.0.1                       -----
      -----                    build:               2022-07-05T18:51:52+00:00    -----
      -----                               Versions                               -----
      -----                    node:                v16.17.0                     -----
      -----                    npm:                 8.15.0                       -----
      -----                                 ENV                                  -----
      -----                    SETGID:              1000                         -----
      -----                    SETUID:              1000                         -----
      -----                  Step 1 of 5: Preparing container                   -----
      This is not the first run of this container. Skipping first run preparation.
      Installing additional packages is set by ENV.
      Checking the following Packages: ...
      Reading package lists... 0%
      Reading package lists... 93%
      Reading package lists... 96%
      Reading package lists... 99%
      Reading package lists... Done
      Building dependency tree... 0%
      Building dependency tree... 50%
      Reading state information... 0%
      Reading package lists... 91%
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Done.
      -----             Step 2 of 5: Detecting ioBroker installation             -----
      Existing installation of ioBroker detected in /opt/iobroker.
      -----             Step 3 of 5: Checking ioBroker installation              -----
      (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
      Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
      -----                Step 4 of 5: Applying special settings                -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      -----                    Step 5 of 5: ioBroker startup                     -----
      Starting ioBroker...
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
      host.iobroker_2022-09-16-1 check instance "system.adapter.admin.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.history.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.node-red.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.socketio.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.bshb.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.bshb.1" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.homeconnect.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.klf200.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.modbus.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.modbus.1" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.onkyo.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.ping.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.samsung.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.shelly.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.sma-em.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.synology.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.discovery.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.backitup.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.yahka.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.yahka.1" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.accuweather.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.cloud.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.fritzdect.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.info.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.lgtv.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.net-tools.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.rest-api.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.simple-api.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.switchbot-hub.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.web.0" for host "iobroker_2022-09-17"
      host.iobroker_2022-09-16-1 check instance "system.adapter.worx.0" for host "iobroker_2022-09-17"
      • S sascho
        @glasfaser
        -----                                System                                -----
        -----                                 ENV                                  -----
        Done.
        GlasfaserG Offline
        GlasfaserG Offline
        @sascho
        Das ist nicht die Ausgabe die ich wollte .
        Aber ..
        mache mal in der Syn Docker Terminal Konsole mal ein :
        pkill -u iobroker
        iobroker host this
        und danach den Container neu starten
          @sascho
          Aber ..
          pkill -u iobroker
          iobroker host this
          sascho
          @glasfaser said in Container ohne Volumen zu C. mit Volumen migrieren | Yahka:
          iobroker host this
          Sorry wieder Parallelpost.
          Das kommt jetzt:
          • S sascho
            iobroker host this
            Das kommt jetzt:
            GlasfaserG Offline
            GlasfaserG Offline
            @sascho
            Ja alles richtig .
            Und danach neu starten
              @sascho
              Ja alles richtig .
              sascho
              @glasfaser
              Jetzt sind die Adapter wieder da - wow! Was hat das denn bewirkt?
              Muss mal gleich alles Testen...
              • S sascho
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                das sollte eigentlich Automatisch gehen ...
                denn dein Backup ist von einem anderen Container , deshalb stimmt der Name nicht .
                kannst du hier erkennen
                  sascho
                  @glasfaser
                  Okay, wow!!! Besten Dank!
                  Dann schaue ich jetzt mal nach der Yahka Portierung.
                  Da muss ich aber noch den Yahka Ordner manuell aus dem alten Container rauskopieren laut diesem Artikel:
                  https://github-wiki-see.page/m/jensweigele/ioBroker.yahka/wiki/ioBroker.yahka-auf-ein-anderes-System-umziehen
                  Wie kann ich denn einen Ordner in der Exec Konsole des Portainers downloaden?
                  • S sascho
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Warum legts du kein Volume nachträglich an , dann ist er doch ohne umwege vorhanden !?
                      sascho
                      @glasfaser
                      Im alten Container? Dann müsste ich ja einen Datenaustausch zwischen zwei Container realisieren. Yahka auf dem alten Container, die Fritzsteckdosen, Bosch Schalter usw. auf dem neuen. Das meintest Du, odeR?
                      haus-automatisierungH GlasfaserG 2 Antworten Letzte Antwort
                      • S sascho
                        @glasfaser
                        haus-automatisierungH Offline
                        @sascho Du kannst mit docker cp ganz einfach Daten aus einem Container auf den Host kopieren (oder andersrum). Also einfach in ein Verzeichnis kopieren und danach als Volume mappen.
                        (habe nicht den ganzen Thread gelesen, aber das wollte ich als Info noch hier lassen)
                        https://docs.docker.com/engine/reference/commandline/cp/
                        📚 Meine Dokumentation
                        • S sascho
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Im alten Container?
                          Ja ...
                          Container stoppen , dann bearbeiten .
                          Nein , das ist doch nur das du die Datein ohne viel aufwand herrausholst
                            Im alten Container?
                            Ja ...
                            sascho
                            @glasfaser @haus-automatisierung
                            Also es hat jetzt auch ohne das manuelle Herauskopieren der zwei Yahka Ordner geklappt. Ich habe einfach die Backups der Instanzen 0 und 1 per backitup wiederhergestellt und es hat funktioniert.
                            Der Hinweis, dass man über Bearbeiten des Dockers auch nachträglich noch ein produktiv verwendetes Volumen hinzufügen kann, war trotzdem hilfreich!
                            • S sascho
                              GlasfaserG Offline
                              GlasfaserG Offline
                              es hat jetzt auch ...geklappt
                              Schön das es funktioniert ... ;)
                              Dann setze den Thread auf [gelöst]
                                sascho
                                @glasfaser
                                Ja, mache ich sobald ich den Knopf finde. 1000 Dank!!!
                                • S sascho
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Im Startbeitrag gehen und bei den 3 Punkten kannst du es ändern
                                    sascho
                                    @glasfaser
                                    Da kann ich glaube ich nichts ändern, fehlt mir da ein Auswahlpunkt?
                                    • S sascho
                                      @glasfaser
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      @sascho edit anklicken und den Titel ändern 😀
                                      Lehrling seit 1975 !!!
