  3. Off Topic
  4. Hilfe beim Einrichten von InfluxDB und BackItUp
    1.0k
32 Beiträge 7 Kommentatoren 4.0k Aufrufe 7 Beobachtet
  • DJMarc75D DJMarc75
    @berlon
    sudo apt install influxdb
    auf Deinem Hauptsystem ausführen (Brocker) 😙
    Berlon
    Ok, gemacht. Influxdb wurde nun auch auf dem Iobroker Installiert.
    Habe auch den InfluxDB-client installiert.
    Backup läuft nicht durch
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.6.10:/volume1/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.ioBroker 2801 states saved
    [DEBUG] [iobroker] - host.ioBroker 3529 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_09_11-18_43_01_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - Usage of influx:
      -version
           Display the version and exit.
      -host 'host name'
           Host to connect to.
      -port 'port #'
           Port to connect to.
      -socket 'unix domain socket'
           Unix socket to connect to.
      -database 'database name'
           Database to connect to the server.
      -password 'password'
          Password to connect to the server.  Leaving blank will prompt for password (--password '').
      -username 'username'
           Username to connect to the server.
      -ssl
            Use https for requests.
      -unsafeSsl
            Set this when connecting to the cluster using https and not use SSL verification.
      -execute 'command'
           Execute command and quit.
      -format 'json|csv|column'
           Format specifies the format of the server responses:  json, csv, or column.
      -precision 'rfc3339|h|m|s|ms|u|ns'
           Precision specifies the format of the timestamp:  rfc3339, h, m, s, ms, u or ns.
      -consistency 'any|one|quorum|all'
           Set write consistency level: any, one, quorum, or all
      -pretty
           Turns on pretty print for the json format.
      -import
           Import a previous database export from file
      -pps
           How many points per second the import will allow.  By default it is zero and will not throttle importing.
      -path
           Path to file to import
      -compressed
           Set to true if the import file is compressed
    Examples:
        # Use influx in a non-interactive mode to query the database "metrics" and pretty print json:
        $ influx -database 'metrics' -execute 'select * from cpu' -format 'json' -pretty
        # Connect to a specific database on startup and set database context:
        $ influx -database 'metrics' -host 'localhost' -port '8086'
    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker --host http://192.168.6.52:8086 -t v-yX0W1sADx9HEy9z_WFV-d1ffBEI56ANPkB0KYmuyBtPKSvslG2PZO6LvhnhNHq2sGtvIpcI4KtKjyXV8pOOw== "/opt/iobroker/backups/influxDB_2022_09_11-18_43_06_backupiobroker"
    unknown arguments: backup --bucket iobroker --host http://192.168.6.52:8086 -t v-************************************** /opt/iobroker/backups/influxDB_2022_09_11-18_43_06_backupiobroker
    Was muss nun in dieser InfluxDB konfiguriert werden.
    Ich verstehe es nicht...........................................
    Thomas BraunT simatecS 2 Antworten Letzte Antwort
    • B Berlon
        -version
        -host 'host name'
             Host to connect to.
        -port 'port #'
             Port to connect to.
        -ssl
        -unsafeSsl
        -execute 'command'
        -pretty
        -import
        -pps
        -path
        -compressed
      Examples:
      @berlon
      Was hast du denn da jetzt installiert?
      Auf beiden Systemen:
      apt policy influxdb*
      B 2 Antworten Letzte Antwort
      • DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @berlon sagte in BackItUp macht Ärger:
        bitte weniger "Frustrations-Satzzeichen" verwenden - danke !
        Eben gelesen dass Du da mit ProxDings unterwegs bist...
        schau mal bitte ob das hilft ...
        https://github.com/simatec/ioBroker.backitup/issues/390
        Keine Ahnung aber da wird halt das System erwähnt
        Lehrling seit 1975 !!!
        • B Berlon
            -version
            -host 'host name'
                 Host to connect to.
            -port 'port #'
                 Port to connect to.
            -ssl
            -unsafeSsl
            -execute 'command'
            -pretty
            -import
            -pps
            -path
            -compressed
          Examples:
          simatecS Offline
          simatecS Offline
          simatec
          @berlon Du musst influxdb2-cli auf dem System installieren, auf dem dein iobroker läuft.
          Steht auch in der Doku ...
          Von daher finde ich den Titel deines Threads sehr fraglich ...
          wget -q https://repos.influxdata.com/influxdb.key
          echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
          echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
          sudo apt install influxdb2-cli
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • B Berlon
            noch nie hatte ich solche Probleme den Broker aufzusetzten.
            Das aktuelle System hat die IP des ehemaligen Sstems eingenommen.
            Damit entfällt die Umstellung aller Sonoffgeräte.
            Nun zickt der BackItUp
            Daten wurden aus dem ehemaligen Produktivsystem auf diesen Broker übertragen.
            Im Ehemaligen läuft CIFS ohne Probleme.
            Hier bekomme ich mit den gleichen Einstellungen:
            [DEBUG] [mount] - noserverino option: false
            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
            [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
            [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
            mount error(1): Operation not permitted
            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
            [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
            Auch NFS geht nicht:
            [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.6.10:/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
            [ERROR] [mount] - [undefined mount.nfs: Operation not permitted
            [ERROR] [mount] - Error: Command failed: sudo mount 192.168.6.10:/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
            iob fix wurde bereits durchgeführt.
            In der Syno sind die Berechtigungen für NFS und ko richtig gesetzt da der Benutzer im Ordner rw Rechte hat.
            Ich vermute das Problem beim Broker
            Bernd
            HomoranH Offline
            HomoranH Offline
            Ich denke eher dass du mit den Containern und deren Spezialitäten nicht firm bist.
            mit ioBroker hat das nichts zu tun!
            Jetzt da die Schuld zu suchen ist nicht fair.
              Berlon
              Danke für die ganzen Hinweise.
              Mit der Containergeschichte bin ich am lernen.
              Ich habe es für mich momentan so gelöst das Proxmox von den 2 Container
              nachts täglich ein Backup erstellt. Auf der Synology ist jedenfalls
              genug Platz.
              Die Hinweise werde ich noch alle durchlesen und umsetzen.
              Es wird auf jeden Fall noch weiter gelernt :-)
                @berlon
                Berlon
                auf dem ioBroker:
                pi@ioBroker:~$ apt policy influxdb*
                influxdb-client:
                  Installed: 1.6.7~rc0-1
                  Candidate: 1.6.7~rc0-1
                  Version table:
                 *** 1.6.7~rc0-1 500
                        500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb:
                  Version table:
                 *** 1.6.7~rc0-1 500
                pi@ioBroker:~$
                auf der InfluxDB:
                root@InfluxDB-Grafana:/# apt policy influxdb*
                influxdb2-cli:
                  Installed: 2.4.0
                  Candidate: 2.4.0
                  Version table:
                 *** 2.4.0 500
                        500 https://repos.influxdata.com/debian stable/main amd64 Packages
                influxdb-client:
                  Installed: (none)
                  Version table:
                     1.6.7~rc0-1 500
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb:
                  Installed: (none)
                  Candidate: 1.8.10-1
                  Version table:
                     1.8.10-1 500
                     1.6.7~rc0-1 500
                influxdb2:
                  Installed: 2.4.0-1
                  Candidate: 2.4.0-1
                  Version table:
                 *** 2.4.0-1 500
                • B Berlon
                  auf dem ioBroker:
                  influxdb-client:
                    Version table:
                   *** 1.6.7~rc0-1 500
                  influxdb-dev:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  influxdb:
                    Version table:
                   *** 1.6.7~rc0-1 500
                  pi@ioBroker:~$
                  auf der InfluxDB:
                  influxdb2-cli:
                    Installed: 2.4.0
                    Candidate: 2.4.0
                    Version table:
                   *** 2.4.0 500
                  influxdb-client:
                    Installed: (none)
                    Version table:
                       1.6.7~rc0-1 500
                  influxdb-dev:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  influxdb:
                    Installed: (none)
                    Candidate: 1.8.10-1
                    Version table:
                       1.8.10-1 500
                       1.6.7~rc0-1 500
                  influxdb2:
                    Installed: 2.4.0-1
                    Candidate: 2.4.0-1
                    Version table:
                   *** 2.4.0-1 500
                  @berlon
                  Ich vermute ganz stark, dass du mit den Tools von influxdb1 keine Schnitte haben wirst bei einer influxdb2.
                  Den Hinweis auf: "Hampel NICHT als root herum!" hast du bestimmt schon mal gelesen?
                  Darüberhinaus vermute ich ebenfalls, dass es für 'jammy' ein eigenes Repository für influxdb2 geben wird. Richte das gescheit ein.
                    @berlon
                    Berlon
                    schrieb am zuletzt editiert von Berlon
                    hm. Hast Recht.
                    Den neuen Nutzer in der Influx anlegen habe ich vergessen.
                    Kann ich den noch nachträglich anlegen oder ist das Kind schon in den Brunnen gefallen.
                    Wenn ja - wird Influx neu gemacht.
                    • B Berlon
                      hm. Hast Recht.
                      @berlon
                      Wie user in Container gestopft werden sollte man wissen, wenn man die Dinger einsetzt. Ist absoutes Basiswissen, imho.
                      Die influxdb.list-Datei sollte jedenfalls so aussehen:
                      deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/ubuntu stable main
                        @berlon
                        Berlon
                        eine Ubuntu bekomme ich nicht installiert da Ubuntu bei der Auswahl eines Reproservers diese nicht findet.
                        Versuche noch herauszufinden woran das liegt.
                        Und Debian installiert mir gleich den Desktop mit. Den brauche aber nicht und habe
                        auch nicht herausgefunden wie ich das unterbinden kann.
                        • B Berlon
                          Fehlermeldungen wären hilfreich.
                          Und der Inhalt der entsprechenden influxdb.list oder wie die Datei genau heißt.
                          Und da du ja ubuntu fährst ist debian weitgehend uninteressant.
                          • HomoranH Offline
                            HomoranH Offline
                            Da das Thema nichts mit ioBroker sondern mit 3rd party Anwendungen wie influxdb, Containern usw. zu tun hat, habe ich es nach OffTopic verschoben
                            @Berlon Bitte passe den Threadtitel auf die reale Situation an!
                            • Thomas BraunT Online
                              Das halte ich übrigens für ein Gerücht.
                              echad@chet:~ $ apt install influxdb --dry-run
                              NOTE: This is only a simulation!
                                    apt needs root privileges for real execution.
                                    Keep also in mind that locking is deactivated,
                                    so don't depend on the relevance to the real current situation!
                              Reading package lists... Done
                              The following NEW packages will be installed:
                                influxdb
                              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                              Inst influxdb (1.8.10-1 InfluxDB:repos.influxdata.com [arm64])
                              Conf influxdb (1.8.10-1 InfluxDB:repos.influxdata.com [arm64])
                              echad@chet:~ $
                              Ein einsames Paket, von Desktop-Zeuch weit und breit keine Spur.
                              Sieht für influxdb2 ganz ähnlich aus.
                                Berlon
                                Hab die Topic angepasst
                                • B Berlon
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @berlon
                                  Nimm die Befehle aus meinem Post und installiere influxdb2-cli auf dem iobroker System
                                  • simatecS simatec
                                    @berlon
                                    Berlon
                                    Läuft alles, Danke für Eure Hilfe!!
                                    Und Danke für Eure Geduld!
                                    Bernd
                                    • B Berlon
                                      crunchipC Offline
                                      crunchipC Offline
                                      @berlon sagte in Hilfe beim Einrichten von InfluxDB und BackItUp:
                                      Nie und nimmer
