  4. Kein Update mehr möglich mit Node.js 16
node js
335 Beiträge 16 Kommentatoren 64.7k Aufrufe 16 Beobachtet
  • K kimukao
    @mickym
    pi@raspberrypi:/opt/iobroker $ npm install
    npm WARN skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.parcel.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated loadsh@0.0.4: This is a typosquat on the popular Lodash package. This is not maintained nor is the original Lodash package.
    npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/syno'
    npm WARN tarball tarball data for syno@git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0 (null) seems to be corrupted. Trying again.
    npm ERR! code ENOENT
    npm ERR! path /opt/iobroker/node_modules/syno
    npm ERR! enoent ENOENT: Cannot cd into '/opt/iobroker/node_modules/syno'
    npm ERR! enoent This is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T15_11_34_543Z-debug-0.log```
    mickymM Offline
    mickymM Offline
    mickym
    #309
    @kimukao Ja kümmer Dich erst mal nicht darum, wenn er fertig ist
    npm list
    • mickymM mickym
      npm list
      kimukao
      #310
      @mickym said in Kein Update mehr möglich mit Node.js 16:
      npm list
      pi@raspberrypi:~ $ npm list
      /home/pi
      └── (empty)
      • K kimukao
        npm list
        /home/pi
        └── (empty)
        mickymM Offline
        mickymM Offline
        mickym
        #311
        @kimukao Na in wo hast Du denn das npm install ausgeführt
        Du musst das im /opt/iobroker Verzeichnis ausführen und auch den npm list Befehl
        cd /opt/iobroker
        npm list
        Im Homeverzeichnis des pi - findet er auch hoffentlich nichts.
        • mickymM mickym
          cd /opt/iobroker
          npm list
          kimukao
          #312
          @mickym Sorry. Hier:
          pi@raspberrypi:/opt/iobroker $ npm list
          iobroker.inst@3.0.0 /opt/iobroker
          ├── acorn-globals@ extraneous
          ├── degenerator@ extraneous
          ├── formstream@ extraneous
          ├── googleapis-common@ extraneous
          ├── UNMET DEPENDENCY iobroker.admin@5.3.8
          ├── UNMET DEPENDENCY iobroker.alexa2@^3.11.2
          ├── UNMET DEPENDENCY iobroker.alias-manager@1.2.4
          ├── UNMET DEPENDENCY iobroker.backitup@2.4.9
          ├── UNMET DEPENDENCY iobroker.daswetter@3.1.2
          ├── UNMET DEPENDENCY iobroker.deconz@1.3.21
          ├── UNMET DEPENDENCY iobroker.device-reminder@1.2.9
          ├── UNMET DEPENDENCY iobroker.discovery@3.0.3
          ├── UNMET DEPENDENCY iobroker.fritzdect@^2.2.3
          ├── UNMET DEPENDENCY iobroker.heos@1.10.0
          ├── UNMET DEPENDENCY iobroker.history@1.11.1
          ├── UNMET DEPENDENCY iobroker.ical@1.12.1
          ├── UNMET DEPENDENCY iobroker.icons-material-png@^0.1.0
          ├── UNMET DEPENDENCY iobroker.icons-material-svg@^0.1.0
          ├── UNMET DEPENDENCY iobroker.icons-mfd-svg@1.1.0
          ├── UNMET DEPENDENCY iobroker.icons-open-icon-library-png@^0.1.2
          ├── UNMET DEPENDENCY iobroker.icons-ultimate-png@^1.0.1
          ├── UNMET DEPENDENCY iobroker.influxdb@2.6.3
          ├── UNMET DEPENDENCY iobroker.javascript@5.7.0
          ├── UNMET DEPENDENCY iobroker.js-controller@4.0.23
          ├── UNMET DEPENDENCY iobroker.km200@^2.0.3
          ├── UNMET DEPENDENCY iobroker.lupusec@^1.3.6
          ├── UNMET DEPENDENCY iobroker.netatmo@1.7.1
          ├── UNMET DEPENDENCY iobroker.nuki-extended@github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4
          ├── UNMET DEPENDENCY iobroker.onvif@^0.4.4
          ├── UNMET DEPENDENCY iobroker.parcel@github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd
          ├── UNMET DEPENDENCY iobroker.pushover@2.1.0
          ├── UNMET DEPENDENCY iobroker.shelly@5.3.2
          ├── UNMET DEPENDENCY iobroker.simple-api@2.7.0
          ├── UNMET DEPENDENCY iobroker.smartcontrol@^1.2.1
          ├── UNMET DEPENDENCY iobroker.smartgarden@2.0.0
          ├── UNMET DEPENDENCY iobroker.socketio@4.2.0
          ├── UNMET DEPENDENCY iobroker.sonos@2.1.7
          ├── UNMET DEPENDENCY iobroker.sony-bravia@1.0.3
          ├── UNMET DEPENDENCY iobroker.synology@2.1.7
          ├── UNMET DEPENDENCY iobroker.telegram@1.13.0
          ├── UNMET DEPENDENCY iobroker.text2command@2.2.1
          ├── UNMET DEPENDENCY iobroker.tr-064@4.2.16
          ├── UNMET DEPENDENCY iobroker.trashschedule@2.0.2
          ├── UNMET DEPENDENCY iobroker.uv-protect@0.3.5
          ├── UNMET DEPENDENCY iobroker.vis-fancyswitch@^1.1.0
          ├── UNMET DEPENDENCY iobroker.vis-hqwidgets@1.2.0
          ├── UNMET DEPENDENCY iobroker.vis-icontwo@^0.87.0
          ├── UNMET DEPENDENCY iobroker.vis-inventwo@^3.3.1
          ├── UNMET DEPENDENCY iobroker.vis-material-advanced@^1.7.2
          ├── UNMET DEPENDENCY iobroker.vis-timeandweather@^1.1.7
          ├── UNMET DEPENDENCY iobroker.vis-weather@^2.5.5
          ├── UNMET DEPENDENCY iobroker.vis@1.4.15
          ├── UNMET DEPENDENCY iobroker.vw-connect@0.0.50
          ├── UNMET DEPENDENCY iobroker.web@4.3.0
          ├── UNMET DEPENDENCY iobroker.whatsapp-cmb@0.2.2
          ├── UNMET DEPENDENCY iobroker.yahka@^0.13.1
          ├── jsonwebtoken@ extraneous
          ├── load-bmfont@ extraneous
          ├── make-dir@ extraneous
          ├── node-abi@ extraneous
          ├── node-telegram-bot-api@ extraneous
          ├── package-json@ extraneous
          ├── read-pkg@ extraneous
          ├── request@ extraneous
          ├── semver-diff@ extraneous
          ├── send@ extraneous
          ├── tar@ extraneous
          ├── webdav@ extraneous
          └── win-release@ extraneous
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/acorn-globals
          npm ERR! extraneous: degenerator@ /opt/iobroker/node_modules/degenerator
          npm ERR! extraneous: formstream@ /opt/iobroker/node_modules/formstream
          npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
          npm ERR! missing: iobroker.admin@5.3.8, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.alexa2@^3.11.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.alias-manager@1.2.4, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.backitup@2.4.9, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.daswetter@3.1.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.deconz@1.3.21, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.device-reminder@1.2.9, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.discovery@3.0.3, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.fritzdect@^2.2.3, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.heos@1.10.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.history@1.11.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.ical@1.12.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.icons-material-png@^0.1.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.icons-material-svg@^0.1.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.icons-mfd-svg@1.1.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.icons-open-icon-library-png@^0.1.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.icons-ultimate-png@^1.0.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.influxdb@2.6.3, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.javascript@5.7.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.js-controller@4.0.23, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.km200@^2.0.3, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.lupusec@^1.3.6, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.netatmo@1.7.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.nuki-extended@github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.onvif@^0.4.4, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.parcel@github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.pushover@2.1.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.shelly@5.3.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.simple-api@2.7.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.smartcontrol@^1.2.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.smartgarden@2.0.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.sonos@2.1.7, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.sony-bravia@1.0.3, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.synology@2.1.7, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.telegram@1.13.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.text2command@2.2.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.tr-064@4.2.16, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.trashschedule@2.0.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.uv-protect@0.3.5, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-fancyswitch@^1.1.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-hqwidgets@1.2.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-icontwo@^0.87.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-inventwo@^3.3.1, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-material-advanced@^1.7.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-timeandweather@^1.1.7, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis-weather@^2.5.5, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vis@1.4.15, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.vw-connect@0.0.50, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.web@4.3.0, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.whatsapp-cmb@0.2.2, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.yahka@^0.13.1, required by iobroker.inst@3.0.0
          npm ERR! extraneous: jsonwebtoken@ /opt/iobroker/node_modules/jsonwebtoken
          npm ERR! extraneous: load-bmfont@ /opt/iobroker/node_modules/load-bmfont
          npm ERR! extraneous: make-dir@ /opt/iobroker/node_modules/make-dir
          npm ERR! extraneous: node-abi@ /opt/iobroker/node_modules/node-abi
          npm ERR! extraneous: node-telegram-bot-api@ /opt/iobroker/node_modules/node-telegram-bot-api
          npm ERR! extraneous: package-json@ /opt/iobroker/node_modules/package-json
          npm ERR! extraneous: read-pkg@ /opt/iobroker/node_modules/read-pkg
          npm ERR! extraneous: request@ /opt/iobroker/node_modules/request
          npm ERR! extraneous: semver-diff@ /opt/iobroker/node_modules/semver-diff
          npm ERR! extraneous: send@ /opt/iobroker/node_modules/send
          npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
          npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
          npm ERR! extraneous: win-release@ /opt/iobroker/node_modules/win-release
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T15_19_26_780Z-debug-0.log
          • K kimukao
            ├── tar@ extraneous
            mickymM Offline
            mickymM Offline
            mickym
            #313
            @kimukao dann mach jetzt mal
            npm prune
            und dann wieder
            npm list
            und alles im /opt/iobroker Verzeichnis
            • mickymM mickym
              npm prune
              und dann wieder
              npm list
              kimukao
              schrieb am zuletzt editiert von kimukao
              #314
              npm list
              ├── @types/caseless@0.12.2 extraneous
              ├── @types/request@2.48.8 extraneous
              ├── @types/tough-cookie@4.0.2 extraneous
              ├── coffee-compiler@0.3.2 extraneous
              ├── coffee-script@1.12.7 extraneous
              ├── form-data@2.5.1 extraneous
              ├── iobroker.admin@5.3.8
              ├── iobroker.alexa2@3.19.7
              ├── iobroker.alias-manager@1.2.4
              ├── iobroker.backitup@2.4.9
              ├── iobroker.daswetter@3.1.2
              ├── iobroker.deconz@1.3.21
              ├── iobroker.device-reminder@1.2.9
              ├── iobroker.discovery@3.0.3
              ├── iobroker.fritzdect@2.2.3
              ├── iobroker.heos@1.10.0
              ├── iobroker.history@1.11.1
              ├── iobroker.ical@1.12.1
              ├── iobroker.icons-material-png@0.1.0
              ├── iobroker.icons-material-svg@0.1.0
              ├── iobroker.icons-mfd-svg@1.1.0
              ├── iobroker.icons-open-icon-library-png@0.1.2
              ├── iobroker.icons-ultimate-png@1.0.1
              ├── iobroker.influxdb@2.6.3
              ├── iobroker.javascript@5.7.0
              ├── iobroker.js-controller@4.0.23
              ├── iobroker.km200@2.0.3
              ├── iobroker.lupusec@1.3.6
              ├── iobroker.netatmo@1.7.1
              ├── iobroker.nuki-extended@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#b303d4a823fcba09b4d3de04d1412c770f5c68b4)
              ├── iobroker.onvif@0.4.4
              ├── iobroker.parcel@0.0.15 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#377864c5926b0e0d41c658640e3097152f86a9fd)
              ├── iobroker.pushover@2.1.0
              ├── iobroker.shelly@5.3.2
              ├── iobroker.simple-api@2.7.0
              ├── iobroker.smartcontrol@1.2.1
              ├── iobroker.smartgarden@2.0.0
              ├── iobroker.socketio@4.2.0
              ├── iobroker.sonos@2.1.7
              ├── iobroker.sony-bravia@1.0.3
              ├── iobroker.synology@2.1.7
              ├── iobroker.telegram@1.13.0
              ├── iobroker.text2command@2.2.1
              ├── iobroker.tr-064@4.2.16
              ├── iobroker.trashschedule@2.0.2
              ├── iobroker.uv-protect@0.3.5
              ├── iobroker.vis-fancyswitch@1.1.0
              ├── iobroker.vis-hqwidgets@1.2.0
              ├── iobroker.vis-icontwo@0.87.0
              ├── iobroker.vis-inventwo@3.3.3
              ├── iobroker.vis-material-advanced@1.7.2
              ├── iobroker.vis-timeandweather@1.2.2
              ├── iobroker.vis-weather@2.5.6
              ├── iobroker.vis@1.4.15
              ├── iobroker.vw-connect@0.0.50
              ├── iobroker.web@4.3.0
              ├── iobroker.whatsapp-cmb@0.2.2
              ├── iobroker.yahka@0.13.1
              ├── jsonata@1.8.6 extraneous
              ├── node-inspect@2.0.0 extraneous
              ├── picocolors@1.0.0 extraneous
              ├── typescript@4.8.2 extraneous
              ├── virtual-tsc@0.6.2 extraneous
              └── wake_on_lan@1.0.0 extraneous
              Irre ich, oder sieht das besser aus als vorher?
              • K kimukao
                npm list
                mickymM Offline
                mickymM Offline
                mickym
                #315
                @kimukao Viel besser - auch wenn da immer noch ein paar extrneous teile drin sind.
                Kannst Du nochmal Deine aktuelle package.json posten - so wie sie jetzt ist.
                • mickymM mickym
                  kimukao
                  #316
                  pi@raspberrypi:/opt/iobroker $ cat package.json
                  {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=10.0.0"},"dependencies":{"iobroker.admin":"5.3.8","iobroker.alexa2":"^3.11.2","iobroker.alias-manager":"1.2.4","iobroker.backitup":"2.4.9","iobroker.daswetter":"3.1.2","iobroker.deconz":"1.3.21","iobroker.device-reminder":"1.2.9","iobroker.discovery":"3.0.3","iobroker.fritzdect":"^2.2.3","iobroker.heos":"1.10.0","iobroker.history":"1.11.1","iobroker.ical":"1.12.1","iobroker.icons-material-png":"^0.1.0","iobroker.icons-material-svg":"^0.1.0","iobroker.icons-mfd-svg":"1.1.0","iobroker.icons-open-icon-library-png":"^0.1.2","iobroker.icons-ultimate-png":"^1.0.1","iobroker.influxdb":"2.6.3","iobroker.javascript":"5.7.0","iobroker.js-controller":"4.0.23","iobroker.km200":"^2.0.3","iobroker.lupusec":"^1.3.6","iobroker.netatmo":"1.7.1","iobroker.nuki-extended":"github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4","iobroker.onvif":"^0.4.4","iobroker.parcel":"github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd","iobroker.pushover":"2.1.0","iobroker.shelly":"5.3.2","iobroker.simple-api":"2.7.0","iobroker.smartcontrol":"^1.2.1","iobroker.smartgarden":"2.0.0","iobroker.socketio":"4.2.0","iobroker.sonos":"2.1.7","iobroker.sony-bravia":"1.0.3","iobroker.synology":"2.1.7","iobroker.telegram":"1.13.0","iobroker.text2command":"2.2.1","iobroker.tr-064":"4.2.16","iobroker.trashschedule":"2.0.2","iobroker.uv-protect":"0.3.5","iobroker.vis":"1.4.15","iobroker.vis-fancyswitch":"^1.1.0","iobroker.vis-hqwidgets":"1.2.0","iobroker.vis-icontwo":"^0.87.0","iobroker.vis-inventwo":"^3.3.1","iobroker.vis-material-advanced":"^1.7.2","iobroker.vis-timeandweather":"^1.1.7","iobroker.vis-weather":"^2.5.5","iobroker.vw-connect":"0.0.50","iobroker.web":"4.3.0","iobroker.whatsapp-cmb":"0.2.2","iobroker.yahka":"^0.13.1"}}
                  • K kimukao
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #317
                    Na die schaut eigentlich gut aus. auch wenn das mit dem prune nicht ganz bereinigt hat - liegt halt wahrscheinlich an irgendwelchen Adaptern.
                      "name": "iobroker.inst",
                      "version": "3.0.0",
                      "private": true,
                      "description": "Automate your Life",
                      "engines": {
                        "node": ">=10.0.0"
                      "dependencies": {
                        "iobroker.admin": "5.3.8",
                        "iobroker.alexa2": "^3.11.2",
                        "iobroker.alias-manager": "1.2.4",
                        "iobroker.backitup": "2.4.9",
                        "iobroker.daswetter": "3.1.2",
                        "iobroker.deconz": "1.3.21",
                        "iobroker.device-reminder": "1.2.9",
                        "iobroker.discovery": "3.0.3",
                        "iobroker.fritzdect": "^2.2.3",
                        "iobroker.heos": "1.10.0",
                        "iobroker.history": "1.11.1",
                        "iobroker.ical": "1.12.1",
                        "iobroker.icons-material-png": "^0.1.0",
                        "iobroker.icons-material-svg": "^0.1.0",
                        "iobroker.icons-mfd-svg": "1.1.0",
                        "iobroker.icons-open-icon-library-png": "^0.1.2",
                        "iobroker.icons-ultimate-png": "^1.0.1",
                        "iobroker.influxdb": "2.6.3",
                        "iobroker.javascript": "5.7.0",
                        "iobroker.js-controller": "4.0.23",
                        "iobroker.km200": "^2.0.3",
                        "iobroker.lupusec": "^1.3.6",
                        "iobroker.netatmo": "1.7.1",
                        "iobroker.nuki-extended": "github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4",
                        "iobroker.onvif": "^0.4.4",
                        "iobroker.parcel": "github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd",
                        "iobroker.pushover": "2.1.0",
                        "iobroker.shelly": "5.3.2",
                        "iobroker.simple-api": "2.7.0",
                        "iobroker.smartcontrol": "^1.2.1",
                        "iobroker.smartgarden": "2.0.0",
                        "iobroker.socketio": "4.2.0",
                        "iobroker.sonos": "2.1.7",
                        "iobroker.sony-bravia": "1.0.3",
                        "iobroker.synology": "2.1.7",
                        "iobroker.telegram": "1.13.0",
                        "iobroker.text2command": "2.2.1",
                        "iobroker.tr-064": "4.2.16",
                        "iobroker.trashschedule": "2.0.2",
                        "iobroker.uv-protect": "0.3.5",
                        "iobroker.vis": "1.4.15",
                        "iobroker.vis-fancyswitch": "^1.1.0",
                        "iobroker.vis-hqwidgets": "1.2.0",
                        "iobroker.vis-icontwo": "^0.87.0",
                        "iobroker.vis-inventwo": "^3.3.1",
                        "iobroker.vis-material-advanced": "^1.7.2",
                        "iobroker.vis-timeandweather": "^1.1.7",
                        "iobroker.vis-weather": "^2.5.5",
                        "iobroker.vw-connect": "0.0.50",
                        "iobroker.web": "4.3.0",
                        "iobroker.whatsapp-cmb": "0.2.2",
                        "iobroker.yahka": "^0.13.1"
                    Jetzt schau mal ob Du den iob starten kannst
                    iob start
                    • mickymM mickym
                        "version": "3.0.0",
                        "private": true,
                        "engines": {
                          "node": ">=10.0.0"
                        "dependencies": {
                      iob start
                      kimukao
                      #318
                      YEESSSSS!!! Bin auf der Oberfläche und habe grade sogar den backitup Adapter aktualisiert. Scheint durchgelaufen zu sein.. Unglaublich!! Meine Lichtschalter funktionieren auch wieder, sitze nicht mehr im Dunkeln :) WOW. You made my day! Wohin darf ich den Whiskey schicken?
                      Thomas BraunT mickymM 2 Antworten Letzte Antwort
                      • K kimukao
                        #319
                        @kimukao
                        iobroker update
                        sagt nun?
                          @kimukao
                          iobroker update
                          sagt nun?
                          kimukao
                          #320
                          @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
                          iobroker update
                          pi@raspberrypi:~ $ iobroker update
                          Used repository: stable
                          Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
                          Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
                          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                          Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                          Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                          Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                          Adapter    "heos"         : 1.10.0   , installed 1.10.0
                          Adapter    "history"      : 2.2.0    , installed 1.11.1 [Updatable]
                          Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
                          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                          Adapter    "influxdb"     : 3.1.7    , installed 2.6.3  [Updatable]
                          Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
                          Controller "js-controller": 4.0.23   , installed 4.0.23
                          Adapter    "km200"        : 2.0.3    , installed 2.0.3
                          Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
                          Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
                          Adapter    "nuki-extended": 2.3.1    , installed 2.4.0
                          Adapter    "onvif"        : 0.4.4    , installed 0.4.4
                          Adapter    "parcel"       : 0.0.20   , installed 0.0.15 [Updatable]
                          Adapter    "pushover"     : 3.0.2    , installed 2.1.0  [Updatable]
                          Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
                          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                          Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                          Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                          Adapter    "sonos"        : 2.2.3    , installed 2.1.7  [Updatable]
                          Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.3  [Updatable]
                          Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
                          Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                          Adapter    "text2command" : 2.2.2    , installed 2.2.1  [Updatable]
                          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                          Adapter    "trashschedule": 2.0.3    , installed 2.0.2  [Updatable]
                          Adapter    "uv-protect"   : 0.3.6    , installed 0.3.5  [Updatable]
                          Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                          Adapter    "vis-icontwo"  : 0.89.0   , installed 0.87.0 [Updatable]
                          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                          Adapter    "vis-weather"  : 2.5.5    , installed 2.5.6
                          Adapter    "vw-connect"   : 0.0.51   , installed 0.0.50 [Updatable]
                          Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
                          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                          • K kimukao
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #321
                            @kimukao Na dann scheint die Aktualisierung auch wieder zu klappen. ;)- Freut mich.
                            Wichtig ist - wenn alles funktioniert - ein Image zu ziehen - wenn Dinge im System verkehrt sind, bekommst die über das backup nicht geregelt und musst eben wieder alles von vorne installieren. Vergiss SSD - mach ein Image auf Deinem Windowsrechner von der SD karte. ;)
                            • K kimukao
                              iobroker update
                              #322
                              @kimukao
                              Dann zieh die Adapter jetzt auf Stand.
                              iobroker upgrade all -y
                              Ich will jetzt nicht hochscrollen und suchen, aber hattest du npm separat angepackt / aktualisiert?
                              • mickymM mickym
                                kimukao
                                #323
                                @mickym Nochmal tausend Dank, Du kannst Dir gar nicht vorstellen, wie ich mich freue!! Echt mega!! Hab nen Mac, aber da sollte man ja auch ein Image hinziehen können. Werde den Tipp befolgen. Für heute freue ich mich erstmal, dass es wieder läuft. Und die extraneous Hinweise kann ich ignorieren?
                                • K kimukao
                                  #324
                                  @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
                                  Ja.
                                  Oder nachdem alle Adapter aktualisiert wurden nochmal
                                  cd /opt/iobroker
                                  npm prune
                                  K 2 Antworten Letzte Antwort
                                  • K kimukao
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #325
                                    @kimukao Nun ja das kann man mit npm prune aufräumen - das kommt aber oft wieder wenn irgendwelche Adapter alte Module verwenden und die dann in einer bestimmten Version wieder installiert werden.Extraneous ist unbedenklich - sondern aus Sicht des npm Paketmanagers sind diese Pakete überflüssig - das Modul meint aber es bräuchte die.
                                    Deswegen ist das was Thomas sagt- wie immer natürlich - goldrichtig. Alles updaten und dann mit npm prune nochmal aufräumen - und wenn dann noch was übrig ist - hast Du halt trotzdem irgendwo noch einen Verweis auf eine veraltetes Paket drin.
                                      Ja.
                                      cd /opt/iobroker
                                      npm prune
                                      kimukao
                                      #326
                                      Ja.
                                      cd /opt/iobroker
                                      npm prune
                                      Ziehe grade alle Updates. Auch Dir nochmal tausend Dank! Ihr seid echt klasse. Mega Forum! Danke, danke, danke. Freu mich :)
                                      • K kimukao
                                        Ja.
                                        cd /opt/iobroker
                                        npm prune
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #327
                                        @kimukao Wir hätten Dich ja beinahe schon aufgegeben - ich war auch kurz davor. ;) - Insofern freuen wir uns mit Dir. :)
                                        • mickymM mickym
                                          kimukao
                                          #328
                                          Zum Glück habt Ihr es nicht :)
