  3. Off Topic
  4. Update auf Nodejs 16 scheitert an grafana
    1.0k
46 Beiträge 3 Kommentatoren 5.2k Aufrufe 2 Beobachtet
  • E ed210
    Hier der ganze Text:
    root@CT201:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
    Get:2 https://deb.nodesource.com/node_14.x bionic InRelease [4584 B]
    Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
    Get:4 https://repos.influxdata.com/ubuntu bionic InRelease [4737 B]
    Get:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
    Err:6 https://packagecloud.io/grafana/stable/debian stretch InRelease
      402  Payment Required [IP: 52.8.238.184 443]
    Get:7 https://repos.influxdata.com/ubuntu bionic/stable amd64 Packages [1267 B]
    Get:8 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages [769 B]
    Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [2707 kB]
    Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [500 kB]
    Get:11 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [889 kB]
    Get:12 http://archive.ubuntu.com/ubuntu bionic-updates/restricted Translation-en [123 kB]
    Get:13 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1837 kB]
    Get:14 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [398 kB]
    Get:15 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [24.9 kB]
    Get:16 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [2366 kB]
    Get:17 http://archive.ubuntu.com/ubuntu bionic-security/main Translation-en [410 kB]
    Get:18 http://archive.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [859 kB]
    Get:19 http://archive.ubuntu.com/ubuntu bionic-security/restricted Translation-en [118 kB]
    Get:20 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [1223 kB]
    Get:21 http://archive.ubuntu.com/ubuntu bionic-security/universe Translation-en [282 kB]
    Get:22 http://archive.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [19.0 kB]
    Reading package lists... Done
    E: Failed to fetch https://packagecloud.io/grafana/stable/debian/dists/stretch/InRelease  402  Payment Required [IP: 52.8.238.184 443]
    E: The repository 'https://packagecloud.io/grafana/stable/debian stretch InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    Error executing command, exiting
    root@CT201:/opt/iobroker# sudo apt install -y nodejs
    Building dependency tree
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 149 not upgraded.
    Need to get 25.5 MB of archives.
    After this operation, 2564 kB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_14.x bionic/main amd64 nodejs amd64 14.20.0-1nodesource1 [25.5 MB]
    Fetched 25.5 MB in 3s (7467 kB/s)
    (Reading database ... 37036 files and directories currently installed.)
    Preparing to unpack .../nodejs_14.20.0-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (14.20.0-1nodesource1) over (14.17.6-1nodesource1) ...
    Setting up nodejs (14.20.0-1nodesource1) ...
    Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
    root@CT201:/opt/iobroker# node -v
    v14.20.0
    @ed210
    Punkt 1: Nicht als root rumeimern. Leg dir einen user an, falls da noch keiner ist:
    adduser deinusername
    usermod -aG sudo deinusername
    usermod -aG iobroker deinusername
    exit
    Und dann niemehr als root anmelden, nur noch mit dem user.
    • E ed210
      + apt-get update
        nodejs
      v14.20.0
      @ed210
      Punkt 2:
      Jetzt als user:
      sudo apt-get install -y apt-transport-https
      sudo apt-get install -y software-properties-common wget
      sudo wget -q -O /usr/share/keyrings/grafana.key https://packages.grafana.com/gpg.key
      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
      • HomoranH Offline
        HomoranH Offline
        Habe das nach OffTopic verschoben.
        Grafana ist kein Bestandteil von ioBroker
        • E ed210
          + apt-get update
            nodejs
          v14.20.0
          @ed210
          Punkt 3:
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          E 2 Antworten Letzte Antwort
          • E ed210
            + apt-get update
              nodejs
            v14.20.0
            HomoranH Offline
            HomoranH Offline
            @Thomas-Braun
            @ed210 sagte in Update auf Nodejs 16 scheitert an grafana:
            root@CT201:
            @ed210
            steht das für ConTainer?
            E 1 Antwort Letzte Antwort
              @ed210
              Punkt 3:
              sudo apt update
              sudo reboot
              ed210
              @thomas-braun Vielen Dank für die ausführliche Beschreibung! Der User ist angelegt und das Update wird gerade ausgeführt. Soweit hat alles geklappt bisher.
                @Thomas-Braun
                root@CT201:
                @ed210
                ed210
                Ja, das Linux läuft in einem Proxmox Container.
                • E ed210
                  Zeigen...
                  Nach dem reboot:
                  sudo apt update
                  apt policy grafana
                  apt policy nodejs
                    @ed210
                    Punkt 3:
                    sudo apt update
                    sudo reboot
                    ed210
                    Ich bin jetzt alle Punkte durchgegangen. Der grafana-Fehler bleibt leider bestehen:
                    ed210@CT201:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                    + apt-get update
                    Hit:1 https://repos.influxdata.com/ubuntu bionic InRelease
                    Hit:2 https://deb.nodesource.com/node_14.x bionic InRelease
                    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                    Hit:4 http://archive.ubuntu.com/ubuntu bionic InRelease
                    Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                    Hit:6 http://archive.ubuntu.com/ubuntu bionic-security InRelease
                    Err:7 https://packagecloud.io/grafana/stable/debian stretch InRelease
                      Zeigen...
                      Nach dem reboot:
                      sudo apt update
                      apt policy grafana
                      apt policy nodejs
                      ed210
                      Hab das "Nach dem Reboot" übersehen, sorry.
                        Zeigen...
                        Nach dem reboot:
                        sudo apt update
                        apt policy grafana
                        apt policy nodejs
                        ed210
                        @thomas-braun said in Update auf Nodejs 16 scheitert an grafana:
                        apt policy nodejs
                        + apt-get update
                        Hit:2 https://repos.influxdata.com/ubuntu bionic InRelease
                        Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_14.x bionic InRelease
                        Hit:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease
                        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                        Der Fehler ist leider immer noch da, auch nach den 3 Zeilen bei "Nach dem reboot"
                        • E ed210
                          @ed210
                          Es muss noch eine *.list Datei geben, die "packagecloud" enthält.
                          grep -r "packagecloud" /etc/apt/
                          Diese Datei löschen.
                          sudo rm /pfad/zur/datei.list
                            @ed210
                            ed210
                            Der erste Befehl wird gerade ausgeführt. Er scheint ne Weile dafür zu brauchen.
                            • E ed210
                              Sollte eigentlich nicht. So viele Dateien sollten in dem Pfad nicht liegen.
                                ed210
                                > ed210@CT201:/opt/iobroker$ grep -r "packagecloud" /etc/apt/
                                Ich vermute das er was tut, weil ich nach der Eingabe keinen promt mehr bekomme.
                                • E ed210
                                  @ed210
                                  STRG-C
                                  grep -r "grafana" /etc/apt/
                                    @ed210
                                    STRG-C
                                    ed210
                                    ed210@CT201:/opt/iobroker$ grep -r "grafana" /etc/apt/
                                    /etc/apt/sources.list:deb https://packagecloud.io/grafana/stable/debian/ stretch main
                                    /etc/apt/sources.list.d/grafana.list:deb [signed-by=/usr/share/keyrings/grafana.key] https://packages.grafana.com/oss/deb stable main
                                    • E ed210
                                      STOP!
                                      Nicht löschen!
                                      Nur die eine Zeile mit dem Eintrag
                                      löschen.
                                      Geht mit nano.
                                      sudo nano /etc/apt/sources.list
                                      Datei speichern: STRG-X, Nachfrage bestätigen.
                                      sudo apt update
                                        STOP!
                                        Nicht löschen!
                                        löschen.
                                        Geht mit nano.
                                        sudo apt update
                                        ed210
                                        So weit erledigt.
                                        Nach dem STRG + X bestätige ich die Nachfrage mit "y"
                                        Danach kommt eine weitere Frage: File Name to Write: /etc/apt/sources.list
                                        DOS Format Append Backup File
                                        Mac Format Prepend To Files
                                        Was soll ich da auswählen?
                                        • E ed210
                                          So weit erledigt.
                                          Keine Ahnung. Die kommt bei mir nie. :-)
