  3. Off Topic
  4. Update auf Nodejs 16 scheitert an grafana
    1.0k
46 Beiträge 3 Kommentatoren 5.2k Aufrufe 2 Beobachtet
  • HomoranH Offline
    HomoranH Offline
    Habe das nach OffTopic verschoben.
    Grafana ist kein Bestandteil von ioBroker
    • E ed210
      Hier der ganze Text:
      root@CT201:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
      ## Installing the NodeSource Node.js 16.x repo...
      ## Populating apt-get cache...
      + apt-get update
      Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
      Get:2 https://deb.nodesource.com/node_14.x bionic InRelease [4584 B]
      Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
      Get:4 https://repos.influxdata.com/ubuntu bionic InRelease [4737 B]
      Get:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
      Err:6 https://packagecloud.io/grafana/stable/debian stretch InRelease
        402  Payment Required [IP: 52.8.238.184 443]
      Get:7 https://repos.influxdata.com/ubuntu bionic/stable amd64 Packages [1267 B]
      Get:8 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages [769 B]
      Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [2707 kB]
      Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [500 kB]
      Get:11 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [889 kB]
      Get:12 http://archive.ubuntu.com/ubuntu bionic-updates/restricted Translation-en [123 kB]
      Get:13 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1837 kB]
      Get:14 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [398 kB]
      Get:15 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [24.9 kB]
      Get:16 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [2366 kB]
      Get:17 http://archive.ubuntu.com/ubuntu bionic-security/main Translation-en [410 kB]
      Get:18 http://archive.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [859 kB]
      Get:19 http://archive.ubuntu.com/ubuntu bionic-security/restricted Translation-en [118 kB]
      Get:20 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [1223 kB]
      Get:21 http://archive.ubuntu.com/ubuntu bionic-security/universe Translation-en [282 kB]
      Get:22 http://archive.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [19.0 kB]
      Reading package lists... Done
      E: Failed to fetch https://packagecloud.io/grafana/stable/debian/dists/stretch/InRelease  402  Payment Required [IP: 52.8.238.184 443]
      E: The repository 'https://packagecloud.io/grafana/stable/debian stretch InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      Error executing command, exiting
      root@CT201:/opt/iobroker# sudo apt install -y nodejs
      Building dependency tree
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 0 to remove and 149 not upgraded.
      Need to get 25.5 MB of archives.
      After this operation, 2564 kB of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_14.x bionic/main amd64 nodejs amd64 14.20.0-1nodesource1 [25.5 MB]
      Fetched 25.5 MB in 3s (7467 kB/s)
      (Reading database ... 37036 files and directories currently installed.)
      Preparing to unpack .../nodejs_14.20.0-1nodesource1_amd64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (14.20.0-1nodesource1) over (14.17.6-1nodesource1) ...
      Setting up nodejs (14.20.0-1nodesource1) ...
      Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
      root@CT201:/opt/iobroker# node -v
      v14.20.0
      @ed210
      Punkt 3:
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      E 2 Antworten Letzte Antwort
      • E ed210
        + apt-get update
          nodejs
        v14.20.0
        HomoranH Offline
        HomoranH Offline
        @Thomas-Braun
        @ed210 sagte in Update auf Nodejs 16 scheitert an grafana:
        root@CT201:
        @ed210
        steht das für ConTainer?
        E 1 Antwort Letzte Antwort
          @ed210
          Punkt 3:
          sudo apt update
          sudo reboot
          ed210
          @thomas-braun Vielen Dank für die ausführliche Beschreibung! Der User ist angelegt und das Update wird gerade ausgeführt. Soweit hat alles geklappt bisher.
            @Thomas-Braun
            root@CT201:
            @ed210
            ed210
            Ja, das Linux läuft in einem Proxmox Container.
            • E ed210
              Zeigen...
              Nach dem reboot:
              sudo apt update
              apt policy grafana
              apt policy nodejs
                @ed210
                Punkt 3:
                sudo apt update
                sudo reboot
                ed210
                Ich bin jetzt alle Punkte durchgegangen. Der grafana-Fehler bleibt leider bestehen:
                ed210@CT201:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                + apt-get update
                Hit:1 https://repos.influxdata.com/ubuntu bionic InRelease
                Hit:2 https://deb.nodesource.com/node_14.x bionic InRelease
                Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                Hit:4 http://archive.ubuntu.com/ubuntu bionic InRelease
                Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                Hit:6 http://archive.ubuntu.com/ubuntu bionic-security InRelease
                Err:7 https://packagecloud.io/grafana/stable/debian stretch InRelease
                  Zeigen...
                  Nach dem reboot:
                  sudo apt update
                  apt policy grafana
                  apt policy nodejs
                  ed210
                  Hab das "Nach dem Reboot" übersehen, sorry.
                    Zeigen...
                    Nach dem reboot:
                    sudo apt update
                    apt policy grafana
                    apt policy nodejs
                    ed210
                    @thomas-braun said in Update auf Nodejs 16 scheitert an grafana:
                    apt policy nodejs
                    + apt-get update
                    Hit:2 https://repos.influxdata.com/ubuntu bionic InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                    Hit:4 https://deb.nodesource.com/node_14.x bionic InRelease
                    Hit:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease
                    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                    Der Fehler ist leider immer noch da, auch nach den 3 Zeilen bei "Nach dem reboot"
                    • E ed210
                      @ed210
                      Es muss noch eine *.list Datei geben, die "packagecloud" enthält.
                      grep -r "packagecloud" /etc/apt/
                      Diese Datei löschen.
                      sudo rm /pfad/zur/datei.list
                        @ed210
                        ed210
                        Der erste Befehl wird gerade ausgeführt. Er scheint ne Weile dafür zu brauchen.
                        • E ed210
                          Sollte eigentlich nicht. So viele Dateien sollten in dem Pfad nicht liegen.
                            ed210
                            > ed210@CT201:/opt/iobroker$ grep -r "packagecloud" /etc/apt/
                            Ich vermute das er was tut, weil ich nach der Eingabe keinen promt mehr bekomme.
                            • E ed210
                              @ed210
                              STRG-C
                              grep -r "grafana" /etc/apt/
                                @ed210
                                STRG-C
                                ed210
                                ed210@CT201:/opt/iobroker$ grep -r "grafana" /etc/apt/
                                /etc/apt/sources.list:deb https://packagecloud.io/grafana/stable/debian/ stretch main
                                /etc/apt/sources.list.d/grafana.list:deb [signed-by=/usr/share/keyrings/grafana.key] https://packages.grafana.com/oss/deb stable main
                                • E ed210
                                  STOP!
                                  Nicht löschen!
                                  Nur die eine Zeile mit dem Eintrag
                                  löschen.
                                  Geht mit nano.
                                  sudo nano /etc/apt/sources.list
                                  Datei speichern: STRG-X, Nachfrage bestätigen.
                                  sudo apt update
                                    STOP!
                                    Nicht löschen!
                                    löschen.
                                    Geht mit nano.
                                    sudo apt update
                                    ed210
                                    So weit erledigt.
                                    Nach dem STRG + X bestätige ich die Nachfrage mit "y"
                                    Danach kommt eine weitere Frage: File Name to Write: /etc/apt/sources.list
                                    DOS Format Append Backup File
                                    Mac Format Prepend To Files
                                    Was soll ich da auswählen?
                                    • E ed210
                                      So weit erledigt.
                                      Keine Ahnung. Die kommt bei mir nie. :-)
                                      • E ed210
                                        So weit erledigt.
                                        HomoranH Offline
                                        HomoranH Offline
                                        %(#ff0000)[DOS Format Append Backup File
                                        womit arbeitest du als Terminal?
                                          ed210
                                          schrieb am zuletzt editiert von ed210
                                          Ich rufe die Konsole über Proxmox auf.
                                          Wenn ich dann Nano starte, kommt GNU nano 2.9.3
                                          Die Nachfrage zum Speicherformat sollte von nano kommen.
