  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.6m Aufrufe 153 Beobachtet
    @gregors installier einfach die aktuelle github version drüber.
    Deine Datenpunkte verschwinden deswegen nicht
    GregorSG
    GregorSG
    GregorS
    #1194
    @crunchip
    Ich kann weder auf die aktuelle Version 0.4.14 updaten noch eine Neuinstallation durchführen.
    Unter NPM findet er sourceanalytix nicht mehr.
    Ich habe es dann über die Konsole versucht.
    pi@TinkerboardS:/opt/iobroker$ iobroker upgrade sourceanalytix
    Adapter "sourceanalytix" is not in the repository and cannot be updated.
    Cannot upgrade: Cannot read property 'controller' of undefined
    pi@TinkerboardS:/opt/iobroker$ npm i iobroker.sourceanalytix
    [sudo] Passwort für pi:
    Das hat nicht funktioniert, bitte nochmal probieren.
    > sharp@0.30.7 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)
    sharp: Installation error: Use with glibc 2.24 requires manual installation of libvips >= 8.12.2
    sharp: Please see https://sharp.pixelplumbing.com/install for required dependencies
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.30.7 (node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.30.7 install: `(node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.sourceanalytix@0.4.8
    updated 1 package in 326.902s
    90 packages are looking for funding
      run `npm fund` for details
    Verstehe ich nicht.
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    P Thomas BraunT 2 Antworten Letzte Antwort
    • GregorSG GregorS
      @crunchip
      Verstehe ich nicht.
      P
      P
      picky
      #1195
      @gregors habe gerade normal updatet und es ging bei mir ohne Probleme über iobroker, habe jetzt die 0.4.14 drauf, vorher noch die 0.4.9 gehabt.
      NODE.JS: V16.16.0
      NPM: 8.11.0
      • GregorSG GregorS
        @crunchip
        Verstehe ich nicht.
        Thomas BraunT
        Thomas BraunT
        #1196
        @gregors sagte in [SourceAnalytix 0.4.8-Final] Released !:
        Verstehe ich nicht.
        Dein Betreibssystem ist vermutlich steinalt. Gib dem eine Frischzellenkur.
          @rosi8818 mal so generell, du loggst teilweise die Geräte doppelt (energy und power) macht keines Sinn
          Zu linkdevice kann ich nichts sagen, verwende ich nicht.
          Vergleich doch mal die jeweiligen RAW eines der Datenpunkte die doppelt sind, bezüglich oroginal und linkdevice.
          R
          R
          Rosi8818
          #1197
          @crunchip danke, das werde ich mal kontrollieren. Mir ist nur nicht bewusst wie ich das geschafft habe.
          Normal gehe ich doch in den jeweiligen Adapter/ Instanz rein, wähle dort SourceAnalytix aus und fertig. Woher die kommen ist mir echt suspekt, wenn ich das wüsste könnte ich es abstellen ;)
          Naja mal sehen was ich da gemacht habe
          • DutchmanD Dutchman
            Troubleshooting
            Before we start troubleshooting, it's important to understand how source analytix initialises as here errors may occur, see issue section.
            The following sequence will be handled :
            1. Start SourceAnalytix
            2. List all states activated for SourceAnalytix
            3. Initiate states, for each state :
            • Read current cumulatedReading
              (if present) and memory values from state
            • Check if unit can be handled {Issue 1}
            • Check if cost type is chosen {Issue 2}
            • Verify if valid price definition is present for cost type {Issue 3}
            • Check if previous init value > current cumulated value {Issue 4}
            • Check if valid known of previous device reset > current cumulated value {Issue 5}
            • Store all data to memory
            1. Initialise states for each state :
            • create state cumulativeReading (to store results of calculation, can also be used for W to kWh only) {Issue 6}
            • create states as chosen in state configuration {Issue 7}
            • start calculation
            1. On state change/update
            • Verify if information is correct
            • transform value to proper unit (unit of state to unit chosen in state configuration)
            • check if value input is correct ( current value > previousInit value) {See 7 At device reset Issue 8}
            • calculate {Issue 9}
            • For Watt : calculate Watt to kWh ,calculate cumulatedReading = currentReading + cumulatedReading
            • For other : calculate cumulatedReading = currentReading + previousDeviceReset (if present)
            1. At night (00.00)
            • List all SourceAnalytix enabled states
            • Reset start (Day/Week/Year/Month) values
            1. At device reset
            • Store current value as previousDeviceReset and previousInit value
              If the device wil be reset again (detected by previousInit value),
              currentReading + previousDeviceReset is stored as to previousDeviceReset.
            Issue 1 No unit defined for ....., cannot execute calculations
            Please select correct unit in state settings
            Issue 2 No cost type defined for ....., please Select Type of calculation at state setting
            Please selected wanted cost-type for to understand what amount should be used to handle calculations
            Issue 3 Selected Type ... does not exist in Price Definitions
            Now Price definitions are found for the chosen cost type, please verify your price setting (adapte config)
            Issue 4 Check settings for ..... ! Known init value : ..... > known cumulative value ..... cannot proceed
            The known init value > known cumulated values, this can be solved by removing or modifying these objects in the state raw object
            "valueAtDeviceInit": xxxx
            Issue 5 Check settings for ..... ! Known valueAtDeviceReset : ..... > known cumulative value ..... cannot procee
            valueAtDeviceReset": xxxx
            Issue 6 State for cumulativeReading is not created
            Initialisation of state did fail, see issue 1 to 5
            Issue 7 States for costs readings ae not created
            Type of calculation is not enabled in state settings
            Main Settings
            Price-Definitions
            Main Settings
            Issue 8 current value < previousInit
            A device reset is detected, see function 7
            Issue 9 My calculations are incorrect
            cumulativeReading-Reset
            1. Verify if the correct unit is chosen (of not selected, SA will try to autodetect)
            2. Verify if the cumulatedReading reflects the correct total value of your value reading, if not
            • Stop SA
            • Go to tab objects
              Main Settings
            • Enter expert mode
            • Change the cumulatedReading
            • Exit expert mode
            • Ensure the start values are set correctly
            • Start SA
            1. Ensure the start values are set correctly
              SA handles calculations by cumulatedReading - known cumulatedReading at period start.<b/>
              These start values are defined at the state settings and should be < than currentReading
              Please ensure cumulativeReading >= DayStart >= WeekStart >= MonthStart >= QuarterStart >= YearStart
              Main Settings
            2. Verify these values in state raw object :
            S
            S
            Sammydk
            #1198
            @dutchman
            Hallo, ich benötige eure Hilfe, sehe den Wald vor lauter Bäumen nicht mehr.
            Ich habe diesen Adapter vor kurzen in der Version 0.4.14 installiert unter IOBROKER 5.3.8.
            Bin verschiedene Post durchgegangen um ihn zu verstehen und einzurichten.
            Ziel was es die Werte des Gaszähler über (WiFi-WZ) und die der Wasseruhr über (MQTT) nach IOBroker zu bekommen, dann über den Wasser Wert noch mal einen DP als Abwasserwert zu erhalten, soweit alles gut.
            Die Werte der drei DP werden nach SA übermittelt und auch auf die Tage verteilt.
            Leider habe ich aber bei den Cost keine Werte, obwohl die Kosten im Adapter für jeden Wert angegeben sind und im DP die richtige Kostenstruktur in SA ausgewählt wurde.
            Deshalb erst mal vorsichtig hier meine Frage, ab wann rechnet die Instanz die Kosten, oder muss ich hier mehr als 1 Tag abwarten!
            Ich habe bei allen DP in der SA die Zählerstartwerte (Tag) eingetragen dennoch bleiben die Cost werte (Null) oder 0€.
            Mache ich hier einen Grundlegenden Fehler wenn ja, sehe ich den leider nicht.
            crunchipC S 2 Antworten Letzte Antwort
            • S Sammydk
              @dutchman
              crunchipC
              crunchipC
              Developer Global Moderator Most Active Forum Testing
              #1199
              @sammydk sobald der Zähler zählt wird auch der Preis berechnet.
              In deiner Einstellung sehe ich erstmal keinen Fehler.
              Kann es sein, dass du die Preisangabe im nachhinein angelegt/eingerichtet hast.
              Zeig mal die Raw Datei eines deiner Zähler, also z.b. deines wifi-wz
              Oder stoppe mal die SA Instanz, lösche die Objekte unterhalb von SA und starte danach die Instanz wieder.
              • S Sammydk
                @dutchman
                S
                S
                Sammydk
                #1200
                @sammydk
                So, bin sicherlich nicht der einzige, der über diesen Punkt gestolpert ist. In einigen wir geschrieben, Komma oder Punkt ist egal bei der eingabe, wird konvertiert. Leider aber nicht in dieser Version. Hier hatte ich die Preiswerte mit Komma eingegeben. Nach einigen weitern Suchen, steht, mach ein Punkt und sieh da es funktioniert.
                Es schreit nach einer Dokumentation in dieser Version angelehnt um hier nicht im dunkeln zu fischen.
                  S
                  S
                  Sammydk
                  schrieb am zuletzt editiert von Sammydk
                  #1201
                  @crunchip Danke für deine Mühen, das hatte ich aber alles schon versucht. es ist so einfach.
                  Ursache lag im Komma bei den Preisen. Mit PUNKT funktioniert es.
                  Es schreit nach einer Dokumentation angelehnt an diese Version um hier nicht weiter im dunkeln zu fischen.
                  • S Sammydk
                    crunchipC
                    crunchipC
                    #1202
                    @sammydk was hast du in der Systemeinstellung von iobroker hinterlegt? , oder .
                    Ich hab da komma drin stehen.
                    Und ich meine, ich hatte auch mal in Sa beim anlegen die Werte mit Komma eingetragen, wurde aber automatisch zum Punkt umgewandelt.
                      S
                      S
                      Sammydk
                      #1203
                      @crunchip
                      Hallo, bei den Datenpunkten die Zählerstartwerte mit Komma, da akzeptiert er keinen Punk. Bei der SA Instanz kann man beides angeben, wobei hier Komma dann nicht funktionniert. In IOBroker ist Komma hinterlegt.
                      • S Sammydk
                        crunchipC
                        crunchipC
                        #1204
                        @sammydk sagte in [SourceAnalytix 0.4.8-Final] Released !:
                        Dann erstell ein Issue auf Github
                          A
                          A
                          andibr
                          #1205
                          @crunchip
                          Hallo, ich vermisse bei den "unit" die Gewichtseinheiten?
                          Habe ich irgendwo übersehen, dass man die selber erstellen könnte, oder gibt es die wirklich nicht?
                          Andi
                          G 1 Antwort Letzte Antwort
                          • A andibr
                            @crunchip
                            Andi
                            G
                            G
                            guergen
                            #1206
                            @andibr Was möchtest Du denn "gewichtet" haben? Holz?
                            • G guergen
                              A
                              A
                              andibr
                              schrieb am zuletzt editiert von andibr
                              #1207
                              @guergen said in [SourceAnalytix 0.4.8-Final] Released !:
                              genau, meine Pellets werden in Tonnen verrechnet und auch verbraucht. Sprich meine Heizung braucht 3.6kg Holz/Stunde. Ist schon klar geht natürlich auch mit der Einheit "Liter", ist aber nicht schön.
                              Damit kann ich dann aus der Laufzeit eine Annährung an den noch verbleibenden Restlagerbestand machen. Ich mache das bereits jetzt schon, via Skript, aber nur eine Summierung. Mit diesem Adapter hätte ich eben die Möglichkeit, das pro Monat zu sehen und in einem FLOTT Diagramm ins Bild zur Witterung zu stellen.
                              Edit: Das gibt natürlich noch eine kleine Knacknuss, weil die Heizung hat als Ursprung natürlich ein Boolean mit "false/true". Das ist natürlich kein Zähler im eigentlichen Sinn.
                              • A andibr
                                B
                                B
                                bassface
                                #1208
                                Guten Tag zusammen,
                                ich nutze den SourceAnalytix schon eine Zeit und habe nun das Problem, dass ich durch einen Adapterwechsel mit den gespeicherten Werten wieder bei "Null" anfangen muss.
                                Gibt es die Möglichkeit, die bisher gesammelten Daten auf einen anderen Datenpunkt zu migrieren?
                                Viele Grüße
                                a200A 1 Antwort Letzte Antwort
                                • B bassface
                                  Guten Tag zusammen,
                                  Viele Grüße
                                  a200A
                                  a200A
                                  a200
                                  schrieb am zuletzt editiert von a200
                                  #1209
                                  @bassface Ja, das geht. Siehe mein Posting https://forum.iobroker.net/post/835238
                                  Solltest du noch Fragen haben, dann melde dich. Ich kann versuchen dir zu helfen.
                                  IoBroker auf QNAP TS-451, Raspi und NUC
                                  • a200A a200
                                    B
                                    B
                                    bassface
                                    #1210
                                    @a200
                                    Sehr cool...
                                    Hat ziemlich gut geklappt für die Ordner aktuelles Jahr und 2022.
                                    Das Jahr 2021 wurde nicht mit übernommen.
                                    Hinweis im Log:
                                    State "sourceanalytix.0.0_userdata__0__Solaranlage__Growatt__pvpowerout.2021.meterReadings.weeks.34" not found
                                    Scheint also "nur" die bestehende neue Struktur zu befüllen und vergangene Jahre nicht anzulegen oder?
                                    Hast du eine Idee? Ansonsten ist mir das nicht ganz so wichtig...
                                    • B bassface
                                      @a200
                                      Sehr cool...
                                      Hinweis im Log:
                                      a200A
                                      a200A
                                      a200
                                      #1211
                                      @bassface sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                      @a200
                                      Hast du Recht. Habe nie soweit gedacht. Bin im Moment ziemlich beschäftigt. Kann mir aber ein paar Gedanken machen, wie man es lösen könnte. Danke für die Rückmeldung. Ich melde mich hier, falls ich eine Lösung finden sollte.
                                      W a200A 2 Antworten Letzte Antwort
                                      • a200A a200
                                        @a200
                                        W
                                        W
                                        Wildbill
                                        #1212
                                        @a200 Ich habe dazu den Admin in den Expertenmodus geschaltet, das Jahr 2021 aus dem alten Sourceanalytixpunkt exportiert und anschließend dann unter dem neuen Gerät bei Sourceanalytix wieder importiert. Vorher natürlich SA stoppen. Hat bei mir problemlos geklappt.
                                        Gruss, Jürgen
                                        • a200A a200
                                          @a200
                                          a200A
                                          a200A
                                          a200
                                          #1213
                                          @bassface: Aber das ist kein Grund mir gleich eine negative Bewertung zu geben. 😁
                                          83.8k
