  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.3k Aufrufe 147 Beobachtet
  • L lustig29
    @e-i-k-e Genau an dem Problem hängt es bei mir auch. Ich hoffe es kann uns jemand helfen
    lustig29
    schrieb am zuletzt editiert von lustig29
    #545
    Ich bekomme folgende Fehlermeldung im Log.
    eusec.0
    2022-07-17 10:53:39.239	error	Station: T8010P23220312FE Device: T8210P64220333A9 - Error - Stopping livestream... [{}]
    eusec.0
    2022-07-17 10:53:39.231	error	ffmpegStreamToHls(): ffmpeg stderr:ffmpeg version 4.4.1-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2021 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libxml2 --enable-libxvid --enable-libzimg libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100 libpostproc 55. 9.100 / 55. 9.100Input #0, hevc, from 'unix:/tmp/eusec.0.1.sock': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 2048x1536, 15 fps, 15 tbr, 1200k tbn, 15 tbcInput #1, aac, from 'unix:/tmp/eusec.0.2.sock': Duration: N/A, bitrate: 24 kb/s Stream #1:0: Audio: aac (LC), 16000 Hz, mono, fltp, 24 kb/s[hls @ 0x2e98eb0] Stream HEVC is not hvc1, you should use tag:v hvc1 to set it.Output #0, hls, to '/opt/iobroker/iobroker-data/eusec.0/T8010P23220312FE/live/T8210P64220333A9.m3u8': Metadata: encoder : Lavf58.76.100 Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 2048x1536, q=2-31, 15 fps, 15 tbr, 90k tbn, 15 tbc Stream #0:1: Audio: aac (LC), 16000 Hz, mono, fltp, 24 kb/sStream mapping: Stream #0:0 -> #0:0 (copy) Stream #1:0 -> #0:1 (copy)Press [q] to stop, [?] for help[hls @ 0x2e98eb0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properlyframe= 1 fps=0.0 q=-1.0 size=N/A time=00:00:00.00 bitrate=N/A speed= 0x [mpegts @ 0x2e9be40] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly[mpegts @ 0x2e9be40] first pts and dts value must be setav_interleaved_write_frame(): Invalid data found when processing input[mpegts @ 0x2e9be40] AAC bitstream not in ADTS format and extradata missing[hls @ 0x2e98eb0] Opening '/opt/iobroker/iobroker-data/eusec.0/T8010P23220312FE/live/T8210P64220333A90.ts' for writing[hls @ 0x2e98eb0] Opening '/opt/iobroker/iobroker-data/eusec.0/T8010P23220312FE/live/T8210P64220333A9.m3u8.tmp' for writingframe= 1 fps=0.0 q=-1.0 Lsize=N/A time=00:00:00.00 bitrate=N/A speed= 0x video:104kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknownConversion failed!
    eusec.0
    2022-07-17 10:53:39.231	error	ffmpegStreamToHls(): ffmpeg output:
    eusec.0
    2022-07-17 10:53:39.207	error	ffmpegStreamToHls(): An error occurred: ffmpeg exited with code 1: frame= 1 fps=0.0 q=-1.0 Lsize=N/A time=00:00:00.00 bitrate=N/A speed= 0x video:104kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknownConversion failed!
    • Uli977U Uli977
      @cash sagte in [Neuer Adapter] EuSec:
      @uli977 Du musst den Inhalt des Datenpunktes abfragen.
      z. B var url = getState(Datenpunkt).val
      und dann url benutzen. Wie es genau geht kann ich nicht sagen, da ich das nicht nutze. Ich nutze den Adapter nur zum schalten der Modi. Alles andere mache ich mit der Kamera App.
      weiß jemand wie das geht und kann mir helfen?
      Stormbringer
      schrieb am zuletzt editiert von Stormbringer
      #546
      @uli977 Hallo, weiß nicht ob ihr noch immer sucht aber hier mal ein Export von meinem VIS Widget für Eufy.
      [{"tpl":"tplValueStringRaw","data":{"hm_id":"80101","digits":"","factor":1,"min":0,"max":1,"step":0.01,"oid":"eusec.0.T8010P2320280268.cameras.T8213P1122140AD8.last_event_pic_html","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"663px","top":"26px","width":"302px","height":"302px","border":"2px solid rgb(255, 255, 255)","border-radius":"5px","z-index":"0","color":"","background":"#ffffff"},"widgetSet":"basic"}]
      Man muß den DP "Last Event Picture HTML Image verwenden und eine Basic-String Widget ;o)
      Für die, die Probleme haben, dass immer das alte Bild kommt die könnten mal versuchen ob es besser wird wenn man vor den DP Wert noch Speicherpfad mit angibt. Also quasi so:
       <variables>
         <variable id="zDj_NjzC@n9EX4!!A^hc">INT_Pfad_Eufy_Adapter</variable>
       </variables>
       <block type="variables_set" id="4yJzU.[Q/8`~_e?JT;y%" x="413" y="463">
         <field name="VAR" id="zDj_NjzC@n9EX4!!A^hc">INT_Pfad_Eufy_Adapter</field>
         <value name="VALUE">
           <block type="text" id="R`SKA|wbaU-8oeU9@qc3">
             <field name="TEXT">/opt/iobroker/iobroker-data/</field>
           </block>
         </value>
         <next>
           <block type="telegram" id="7G$U|Br3/N`snbzK-ix%">
             <field name="INSTANCE">.2</field>
             <field name="LOG"></field>
             <field name="SILENT">TRUE</field>
             <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
             <value name="MESSAGE">
               <shadow type="text">
                 <field name="TEXT"></field>
               </shadow>
               <block type="text_join" id="eX/TSIgLUE?LAZVCMsQE">
                 <value name="ADD0">
                   <block type="variables_get" id="ffVp(7[2OyY+Y46$:RlZ">
                   </block>
                 </value>
                 <value name="ADD1">
                   <block type="get_value_var" id="{2;;~A+aiAw4,Y+NsMH3">
                     <value name="OID">
                       </shadow>
                       <block type="field_oid" id="#fyGX+AmY!IG)QFJW@~F">
                         <field name="oid">eusec.0.T8010P2320280268.cameras.T8213P1122140AD8.last_event_pic_url</field>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
           </block>
         </next>
       </block>
      </xml>
      @e-i-k-e Mit Synology kenn ich mich nicht aus. Bei Motioneye wird der Link verwendet, den die App ausgibt. GGf. muss man Benutzer und Kennwort aus den Link rauslöschen und separat in ein Feld eintragen. So ist es zumindest bei Motioneye. Dein Link wirkt irgendwie eher wie wenn du einen Wert vom Adapter genommen hättest? Der Adapter hat damit eigentlich nichts zu tun, er startet und stopt nur den Stream. VIS kann mit dem Stream direkt nichts anfangen. Daher der Umweg über Motioneye. Dafür gibts aber Anleitungen im Forum. VLC kann den Link von der App glaube ich direkt verarbeiten.
      Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
      Uli977U E 3 Antworten Letzte Antwort
      • S Stormbringer
         <variables>
         </variables>
             </block>
           </value>
           <next>
                 </shadow>
                   <value name="ADD0">
                     </block>
                   </value>
                   <value name="ADD1">
                       <value name="OID">
                         </shadow>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </next>
         </block>
        </xml>
        Uli977U Offline
        Uli977U Offline
        Uli977
        #547
        @stormbringer Danke dir für deinen Input!
        Leider wird bei mir immer noch ein altes Bild angezeigt.
        Welcher Pfad muss hier denn genau rein?
        • S Stormbringer
           <variables>
           </variables>
               </block>
             </value>
             <next>
                   </shadow>
                     <value name="ADD0">
                       </block>
                     </value>
                     <value name="ADD1">
                         <value name="OID">
                           </shadow>
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </next>
           </block>
          </xml>
          e-i-k-e
          schrieb am zuletzt editiert von e-i-k-e
          #548
          @stormbringer
          Wo finde ich denn den Link in der App?
          • J Offline
            johannes1702
            #549
            leider scheitere ich an der Installation des Adapters. Ich starte die Installation direkt von Github und nach ca. 5 Min kommt dann diese Fehlermeldung(en):
            $ iobroker url https://github.com/bropat/ioBroker.eusec --host ioBroker --debug
            install bropat/ioBroker.eusec#f6e0490293154eba6f42f94be13bd74dc49d4d6a
            NPM version: 6.14.16Installing bropat/ioBroker.eusec#f6e0490293154eba6f42f94be13bd74dc49d4d6a... (System call)
            npm ERR! code ENOTSUP
            npm ERR! notsup Unsupported engine for iobroker.eusec@0.9.4: wanted: {"node":">=14.17.0"} (current: {"node":"12.22.12","npm":"6.14.16"})
            npm ERR! notsup Not compatible with your version of node/npm: iobroker.eusec@0.9.4
            npm ERR! notsup Required: {"node":">=14.17.0"}
            npm ERR! notsup Actual: {"npm":"6.14.16","node":"12.22.12"}
            npm ERR! /home/iobroker/.npm/_logs/2022-08-11T16_58_28_606Z-debug.log
            host.ioBroker Cannot install bropat/ioBroker.eusec#f6e0490293154eba6f42f94be13bd74dc49d4d6a: 1
            ERROR: Process exited with code 25
            Es scheint als wäre es ein Problem mit der Node Version. Mein System ist aktuell, sowohl ioBroker als auch das darunterliegende Ubuntu.
            Jemand eine Lösung? :-)
            LG Jo
            • J johannes1702
              LG Jo
              johannes1702
              #550
              @johannes1702 Hat sich erledigt, habe node manuell aktualisiert :-)
              • S Stormbringer
                 <variables>
                 </variables>
                     </block>
                   </value>
                   <next>
                         </shadow>
                           <value name="ADD0">
                             </block>
                           </value>
                           <value name="ADD1">
                               <value name="OID">
                                 </shadow>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
                </xml>
                e-i-k-e
                #551
                @stormbringer sagte in [Neuer Adapter] EuSec:
                Wo finde ich den Link in der App?
                • B bropat
                  Hallo an alle,
                  ich möchte euch meinen ersten ioBroker Adapter "euSec", an dem ich gerade Arbeite, vorstellen:
                  https://github.com/bropat/ioBroker.euSec
                  Dieser Adapter ermöglicht die Steuerung von Eufy-Sicherheitsgeräten (https://www.eufylife.com/de/products/643/sicherheit) durch die Verbindung mit der Eufy-Cloud.
                  Nähere Infos findet ihr hier: https://bropat.github.io/ioBroker.eusec
                  Für jeweiligen Ratschläge und Verbesserungen bin ich sehr dankbar!
                  Mike Hellracer
                  #552
                  ich habe den Adapter in der Version 0.7.5 auf einem IObroker Pi am Laufen. ffmpeg ist auch in der aktuellen Version installiert.
                  Im Log bekomme ich leider noch:
                  ffmpegStreamToHls(): Not support audio codec or unknown audio codec (NONE)
                  Kann mir einer von euch sagen, wwelches der passende Audo Codec ist? bzw. was ich noch tun muss?
                  • C Offline
                    chiroptera
                    #553
                    Also ich habe immer noch das Problem, dass meine Station und die Cams nicht gefunden werden.
                    Bin jetzt auf 0.9.4 - Instanz neu installiert, Adapter Versionen schon x-mal hin und her installiert. Mit der 0.8.4 wurde die Station noch gefunden, nach dem Update nicht mehr. Jetzt leider auch nicht mehr mit der 0.8.4
                    2FA ist nicht aktiviert, war es auch noch nie. Smartphone App deinstalliert und wieder neu installiert - Region ist Germany und ist auch nicht änderbar. Instanz ist grün - sonst keine Fehlermeldungen.
                    Jemand noch eine Idee, was ich noch versuchen kann?
                    L 1 Antwort Letzte Antwort
                    • C chiroptera
                      lustig29
                      #554
                      Gibt es denn keine Möglichkeit, das Live Bild abzugreifen?
                      W 1 Antwort Letzte Antwort
                      • L lustig29
                        W Offline
                        W Offline
                        worxweis
                        #555
                        @lustig29
                        Hallo Lustig!
                        Bis jetzt hat mir auch noch keiner erklären können wie er ein live view ins Vis bringt! Ich weis zwar, das es das Objekt Livestream gibt, indem nach dem Klingeln bzw. auch nach dem selberstarten ein link drinnen steht, aber was ich mit diesem in vis machen soll, ist mir immer noch ein rätsel!
                        • W worxweis
                          @lustig29
                          Hallo Lustig!
                          lustig29
                          #556
                          @worxweis Na dann wollen wir mal hoffen, dass wir bald Hilfe bekommen
                          G 1 Antwort Letzte Antwort
                          • L lustig29
                            Gonzokalle
                            #557
                            Kann mir bitte jemand helfen wie ich die Meldungen weg bekomme?
                            Das kommt so zwei bis drei mal am Tag. Benutze die 0.9.4
                            FabioF 2 Antworten Letzte Antwort
                            • G Gonzokalle
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              schrieb am zuletzt editiert von Fabio
                              #558
                              @gonzokalle hab ich auch. Habe ein issuses auf gemacht @bropat weiss Bescheid und wird das fixen.
                              Grüße Fabio
                              Iobroker:
                              • Matter over Thread Hilfe
                              • FabioF Fabio
                                Grüße Fabio
                                Gonzokalle
                                #559
                                @fa-bio
                                Ich dachte es lag an mir.
                                Danke für die Info. 👍
                                • C Offline
                                  chiroptera
                                  schrieb am zuletzt editiert von chiroptera
                                  #560
                                  Hallo @bropat,
                                  was kann ich noch versuchen - meine Station will einfach nicht erkannt werden.
                                  Edit: Hat sich erledigt. In den iobroker Settings war das Land nicht definiert ... warum auch immer. Geht jetzt :-)
                                    bug77
                                    #561
                                    ich möchte den m3u8 livestream der Doorbell in der VIS anzeigen lassen, gibt es da eine Lösung wie man das hinbekommt?
                                    Außerdem habe ich immer wieder in der Log diese Fehler:
                                    	P2PClientProtocol.lookup(): station: T8020P1021344260 - All address lookup tentatives failed.
                                    weiß jemand warum das kommt?
                                    nukleuzN B 2 Antworten Letzte Antwort
                                    • B bug77
                                      nukleuzN Offline
                                      nukleuzN Offline
                                      nukleuz
                                      #562
                                      @bug77
                                      Mit dem Stream in den UIs habe ich noch nicht hinbekommen - da scheint wirklich MotionEye nur zu helfen…
                                      Der Log weißt darauf hin, dass keine Station gefunden wurde - hast du denn eine?
                                      Wenn nicht, einfach ignorieren!?
                                      Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                                      • nukleuzN nukleuz
                                        @bug77
                                        mem
                                        #563
                                        Hallo @bropat ,
                                        Respekt für Deine Arbeit an diesem Adapter. Echt klasse und hilfreich. Habe v0.9.4 und bin im Umstieg von der Homebase2(T8010) auf die Homebase3 (S380) mit den eufyCam3(S330). Diese werden ja nicht unterstützt. Die Homebase3 wird zwar erkannt, aber die eufyCam3s erscheinen nicht im iobroker. Besteht die Möglichkeit den Adapter für die Devices fit zu machen ?
                                        • G Gonzokalle
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #564
                                          Hallo @gonzokalle,
                                          @bropat hat den Fehler beseitigt in der Version 0.9.6 hab sie gerade getestet läuft einwandfrei. Danke bropat 👍
                                          Iobroker:
