  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.3k Aufrufe 147 Beobachtet
  • S Stormbringer
    @uli977 Hallo, weiß nicht ob ihr noch immer sucht aber hier mal ein Export von meinem VIS Widget für Eufy.
    [{"tpl":"tplValueStringRaw","data":{"hm_id":"80101","digits":"","factor":1,"min":0,"max":1,"step":0.01,"oid":"eusec.0.T8010P2320280268.cameras.T8213P1122140AD8.last_event_pic_html","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"663px","top":"26px","width":"302px","height":"302px","border":"2px solid rgb(255, 255, 255)","border-radius":"5px","z-index":"0","color":"","background":"#ffffff"},"widgetSet":"basic"}]
    Man muß den DP "Last Event Picture HTML Image verwenden und eine Basic-String Widget ;o)
    Für die, die Probleme haben, dass immer das alte Bild kommt die könnten mal versuchen ob es besser wird wenn man vor den DP Wert noch Speicherpfad mit angibt. Also quasi so:
     <variables>
       <variable id="zDj_NjzC@n9EX4!!A^hc">INT_Pfad_Eufy_Adapter</variable>
     </variables>
     <block type="variables_set" id="4yJzU.[Q/8`~_e?JT;y%" x="413" y="463">
       <field name="VAR" id="zDj_NjzC@n9EX4!!A^hc">INT_Pfad_Eufy_Adapter</field>
       <value name="VALUE">
         <block type="text" id="R`SKA|wbaU-8oeU9@qc3">
           <field name="TEXT">/opt/iobroker/iobroker-data/</field>
         </block>
       </value>
       <next>
         <block type="telegram" id="7G$U|Br3/N`snbzK-ix%">
           <field name="INSTANCE">.2</field>
           <field name="LOG"></field>
           <field name="SILENT">TRUE</field>
           <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
           <value name="MESSAGE">
             <shadow type="text">
               <field name="TEXT"></field>
             </shadow>
             <block type="text_join" id="eX/TSIgLUE?LAZVCMsQE">
               <value name="ADD0">
                 <block type="variables_get" id="ffVp(7[2OyY+Y46$:RlZ">
                 </block>
               </value>
               <value name="ADD1">
                 <block type="get_value_var" id="{2;;~A+aiAw4,Y+NsMH3">
                   <value name="OID">
                     </shadow>
                     <block type="field_oid" id="#fyGX+AmY!IG)QFJW@~F">
                       <field name="oid">eusec.0.T8010P2320280268.cameras.T8213P1122140AD8.last_event_pic_url</field>
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </value>
         </block>
       </next>
     </block>
    </xml>
    @e-i-k-e Mit Synology kenn ich mich nicht aus. Bei Motioneye wird der Link verwendet, den die App ausgibt. GGf. muss man Benutzer und Kennwort aus den Link rauslöschen und separat in ein Feld eintragen. So ist es zumindest bei Motioneye. Dein Link wirkt irgendwie eher wie wenn du einen Wert vom Adapter genommen hättest? Der Adapter hat damit eigentlich nichts zu tun, er startet und stopt nur den Stream. VIS kann mit dem Stream direkt nichts anfangen. Daher der Umweg über Motioneye. Dafür gibts aber Anleitungen im Forum. VLC kann den Link von der App glaube ich direkt verarbeiten.
    e-i-k-e
    #551
    @stormbringer sagte in [Neuer Adapter] EuSec:
    Wo finde ich den Link in der App?
    • B bropat
      Hallo an alle,
      ich möchte euch meinen ersten ioBroker Adapter "euSec", an dem ich gerade Arbeite, vorstellen:
      https://github.com/bropat/ioBroker.euSec
      Dieser Adapter ermöglicht die Steuerung von Eufy-Sicherheitsgeräten (https://www.eufylife.com/de/products/643/sicherheit) durch die Verbindung mit der Eufy-Cloud.
      Nähere Infos findet ihr hier: https://bropat.github.io/ioBroker.eusec
      Für jeweiligen Ratschläge und Verbesserungen bin ich sehr dankbar!
      Mike Hellracer
      #552
      ich habe den Adapter in der Version 0.7.5 auf einem IObroker Pi am Laufen. ffmpeg ist auch in der aktuellen Version installiert.
      Im Log bekomme ich leider noch:
      ffmpegStreamToHls(): Not support audio codec or unknown audio codec (NONE)
      Kann mir einer von euch sagen, wwelches der passende Audo Codec ist? bzw. was ich noch tun muss?
      • C Offline
        chiroptera
        #553
        Also ich habe immer noch das Problem, dass meine Station und die Cams nicht gefunden werden.
        Bin jetzt auf 0.9.4 - Instanz neu installiert, Adapter Versionen schon x-mal hin und her installiert. Mit der 0.8.4 wurde die Station noch gefunden, nach dem Update nicht mehr. Jetzt leider auch nicht mehr mit der 0.8.4
        2FA ist nicht aktiviert, war es auch noch nie. Smartphone App deinstalliert und wieder neu installiert - Region ist Germany und ist auch nicht änderbar. Instanz ist grün - sonst keine Fehlermeldungen.
        Jemand noch eine Idee, was ich noch versuchen kann?
        L 1 Antwort Letzte Antwort
        • C chiroptera
          lustig29
          #554
          Gibt es denn keine Möglichkeit, das Live Bild abzugreifen?
          W 1 Antwort Letzte Antwort
          • L lustig29
            W Offline
            W Offline
            worxweis
            #555
            @lustig29
            Hallo Lustig!
            Bis jetzt hat mir auch noch keiner erklären können wie er ein live view ins Vis bringt! Ich weis zwar, das es das Objekt Livestream gibt, indem nach dem Klingeln bzw. auch nach dem selberstarten ein link drinnen steht, aber was ich mit diesem in vis machen soll, ist mir immer noch ein rätsel!
            • W worxweis
              @lustig29
              Hallo Lustig!
              lustig29
              #556
              @worxweis Na dann wollen wir mal hoffen, dass wir bald Hilfe bekommen
              G 1 Antwort Letzte Antwort
              • L lustig29
                Gonzokalle
                #557
                Kann mir bitte jemand helfen wie ich die Meldungen weg bekomme?
                Das kommt so zwei bis drei mal am Tag. Benutze die 0.9.4
                FabioF 2 Antworten Letzte Antwort
                • G Gonzokalle
                  FabioF Offline
                  FabioF Offline
                  Fabio
                  schrieb am zuletzt editiert von Fabio
                  #558
                  @gonzokalle hab ich auch. Habe ein issuses auf gemacht @bropat weiss Bescheid und wird das fixen.
                  Grüße Fabio
                  Iobroker:
                  • Matter over Thread Hilfe
                  • FabioF Fabio
                    Grüße Fabio
                    Gonzokalle
                    #559
                    @fa-bio
                    Ich dachte es lag an mir.
                    Danke für die Info. 👍
                    • C Offline
                      chiroptera
                      schrieb am zuletzt editiert von chiroptera
                      #560
                      Hallo @bropat,
                      was kann ich noch versuchen - meine Station will einfach nicht erkannt werden.
                      Edit: Hat sich erledigt. In den iobroker Settings war das Land nicht definiert ... warum auch immer. Geht jetzt :-)
                        bug77
                        #561
                        ich möchte den m3u8 livestream der Doorbell in der VIS anzeigen lassen, gibt es da eine Lösung wie man das hinbekommt?
                        Außerdem habe ich immer wieder in der Log diese Fehler:
                        	P2PClientProtocol.lookup(): station: T8020P1021344260 - All address lookup tentatives failed.
                        weiß jemand warum das kommt?
                        nukleuzN B 2 Antworten Letzte Antwort
                        • B bug77
                          nukleuzN Offline
                          nukleuzN Offline
                          nukleuz
                          #562
                          @bug77
                          Mit dem Stream in den UIs habe ich noch nicht hinbekommen - da scheint wirklich MotionEye nur zu helfen…
                          Der Log weißt darauf hin, dass keine Station gefunden wurde - hast du denn eine?
                          Wenn nicht, einfach ignorieren!?
                          Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                          • nukleuzN nukleuz
                            @bug77
                            mem
                            #563
                            Hallo @bropat ,
                            Respekt für Deine Arbeit an diesem Adapter. Echt klasse und hilfreich. Habe v0.9.4 und bin im Umstieg von der Homebase2(T8010) auf die Homebase3 (S380) mit den eufyCam3(S330). Diese werden ja nicht unterstützt. Die Homebase3 wird zwar erkannt, aber die eufyCam3s erscheinen nicht im iobroker. Besteht die Möglichkeit den Adapter für die Devices fit zu machen ?
                            • G Gonzokalle
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              #564
                              Hallo @gonzokalle,
                              @bropat hat den Fehler beseitigt in der Version 0.9.6 hab sie gerade getestet läuft einwandfrei. Danke bropat 👍
                              Iobroker:
                              • B bug77
                                bropat
                                #565
                                @bug77
                                Ab Version 0.9.5 des Adapters wird der neue Treiber (eufy-security-client) verwendet. Dieser kann nun lokal das Gerät finden bzw. das Discovery über Cloud wurde nun soweit implementiert, das der oben genannte Fehler nur mehr auftreten kann, wenn das Gerät effektiv nicht erreichbar ist (ausgeschalten, keine Konnektivität vorhanden oder ähnliches).
                                Einfach mal auf der letzten Version des Adapters aktualisieren (0.9.6).
                                • M mem
                                  Hallo @bropat ,
                                  bropat
                                  #566
                                  @mem
                                  Homebase3 (S380) und die eufyCam3(S330) werden ab der Version 0.9.5 des Adapters unterstützt.
                                  PS: Es werden noch nicht alle Funktionalitäten der Homebase3 unterstützt, wie z.B. das Download von Videos funktioniert im Moment noch nicht.
                                  L R 2 Antworten Letzte Antwort
                                  • B bropat
                                    @mem
                                    lustig29
                                    #567
                                    @bropat
                                    Ist es mittlerweile möglich, dass Live Bild abzugreifen?
                                    • B bropat
                                      @mem
                                      Rumpeltec
                                      schrieb am zuletzt editiert von Rumpeltec
                                      #568
                                      @bropat
                                      Hallo bropat,
                                      seit Version 0.9.5 kommt in Minutenabständen eine Fehlermeldung:
                                      Error readValue param 1271 [{"code":"ERR_INVALID_ARG_TYPE"},1271,{"account_id":"....................","snooze_time":0}]
                                      (ID habe ich entfernt).
                                      Ist leider auch mit Version 0.9.6 nicht besser geworden.
                                      Gerade ein Downgrade auf 0.9.4 gemacht und Fehler bleibt nun permanent.
                                      Liegt das Problem an meinem System? Habe nichts geändert.
                                      R 1 Antwort Letzte Antwort
                                        berndpehome
                                        schrieb am zuletzt editiert von berndpehome
                                        #569
                                        gestern Abend habe ich die Version 0.9.6 eingespielt und hatte dann bei Livestream einen RTMP Pfad,
                                        heute ohne Änderung wieder nur den m3u8 Pfad, wie komme ich wieder zu dem RTMP ?
                                        Ich verwende eine 8200 Kamera
                                        • B bropat
                                          Hallo an alle,
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #570
                                          @bropat vielen Dank für die neue Version 0.9.7 läuft tadelos.👍
                                          Iobroker:
