  3. Entwicklung
  4. Adapter: broadlink2
    apollon77A
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 864.7k Aufrufe 93 Beobachtet
  • S
    S
    schubs2802
    #1200
    Das ist die log nach dem Neustart des Adapters:
    broadlink2.0
    2022-07-09 12:34:40.958	info	found macs: 78:0f:77:63:cc:59
    broadlink2.0
    2022-07-09 12:34:40.958	info	broadlink2.0 started and found 1 devices named RM:RMPROPLUS-63-cc-59
    broadlink2.0
    2022-07-09 12:34:40.957	info	Poll every 30 secods.
    broadlink2.0
    2022-07-09 12:34:36.494	info	discover [ '192.168.178.32' ] from 0.0.0.0:56749
    broadlink2.0
    2022-07-09 12:34:36.490	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }:
    broadlink2.0
    2022-07-09 12:34:31.447	info	Device RM:RMPROPLUS-63-cc-59 detected: address=192.168.178.32, mac=78:0f:77:63:cc:59, typ=RMP, id=0x279d devtype=RM3 Pro Plus
    broadlink2.0
    2022-07-09 12:34:31.265	info	discover [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:54546
    broadlink2.0
    2022-07-09 12:34:31.263	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255'}:
    broadlink2.0
    2022-07-09 12:34:31.234	info	Discover Broadlink devices for 10sec on broadlink2.0
    broadlink2.0
    2022-07-09 12:34:31.231	info	macObjects: [ '78:0f:77:63:cc:59' ]
    broadlink2.0
    2022-07-09 12:34:31.229	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255'}:
    broadlink2.0
    2022-07-09 12:34:31.225	info	broadlink2 has 1 old devices!
    broadlink2.0
    2022-07-09 12:34:31.224	info	Devices to rename:
    broadlink2.0
    2022-07-09 12:34:31.223	info	Devices to add:
    broadlink2.0
    2022-07-09 12:34:31.223	info	Scanning additional IP's: 192.168.178.32
    broadlink2.0
    2022-07-09 12:34:31.219	info	broadlink2 initialization started...
    broadlink2.0
    2022-07-09 12:34:30.994	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v14.19.1, js-controller: 4.0.23
    host.schubiioBroker
    2022-07-09 12:34:28.517	info	instance system.adapter.broadlink2.0 started with pid 8670```
    code_text
    • crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      #1201
      @schubs2802 sagte in Adapter: broadlink2:
      Ich nutze den Broadlink RM4 Pro
      das passt aber nicht
      • S
        S
        schubs2802
        #1202
        @crunchip sorry, habe 2. einen 4Pro der ist aktuell ausgemustert. Jetzt hängt der 3 Pro drin.
        • S schubs2802
          crunchipC
          crunchipC
          #1203
          der 3 Pro drin.
          3pro oder 3proplus ? laut log ist es der proplus, den hab ich auch, eingetragen hab ich als Gerätetyp 0x279d=RMP
          • S
            S
            schubs2802
            schrieb am zuletzt editiert von schubs2802
            #1204
            proplus,. Ich versuch's mal mit den Einstellungen. Mal schauen wie es morgen früh aussieht. Bis jetzt läuft er.
            • UllulakiU
              UllulakiU
              Ullulaki
              schrieb am zuletzt editiert von Ullulaki
              #1205
              Uff... was ein Kampf!
              Habe mir im Primeday einen Broadlink 4 Pro zugelegt, um meinen Deckenventilator steuern zu können.
              Bin hier fast irre geworden mit der Einbindung... ich habe und habe es einfach nicht hin bekommen, es ohne Cloud einzurichten, trotz Versuch mit mehreren Apps & Resets bis zum Umfallen, Fehler im Log war folgender:
              Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately
              Ich habe alle von Broadlink im Playstore verfügbaren Apps ausprobiert, auf insgesamt drei unterschiedlichen Android-Devices (2x Handy und 1x Tablet), vorher immer das Gerät resettet und beim Einrichten nach Hinzufügen des WLANs abgebrochen.
              Schlussendlich hat es mit der "aktuellsten" Broadlink-App (https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.international&hl=de&gl=US) funktioniert indem ich das Gerät manuell über das Auswahlmenü der App hinzugefügt habe, sprich: bei der Einbindung in der App taucht ein Popup auf, dass ein Gerät gefunden wurde - dieses schließen und über das Menü die Einrichtung fortsetzen!
              Dann nach der WLAN-Einbindung einfach direkt die App komplett schließen und zack, Gerät im Log gefunden:
              Unknown UN:0x5213_ec:0b:ae:xx:xx:xx with { address: '192.168.20.14', port: 80, devtype: 21011, oname: '智能遥控', cloud: 0, maco: <Buffer 11 3d 8c ae 0b ec>, mac: 'ec:0b:ae:xx:xx:xx', type: 'unknown', name: 'UN:0x5213_ec:0b:ae:xx:xx:xx', devname: 'UKN', devhex: '0x5213', names: [ '0x5213_ec:0b:ae:xx:xx:xx' ], iname: 'UN:0x5213_ec:0b:ae:xx:xx:xx' }
              Zwar noch Unknown aber im Log steht der devtype (in meinem Falle):
              devtype: 21011
              Da ich einen RM4 Pro habe entsprechend in den Instanzeinstellung des Adapters unter Gerätetyp hinterlegt:
              21011=RM4P
              (bei allen anderen Varianten habe ich immer wieder den Fehler mit "Unknown" bekommen.)
              Jetzt nur noch _LearnRF aktiviert und beim anlernen die gewünschte Taste lange gedrückt halten, bis im Log
              found Frequency 1 of 2, you can release button now!
              steht. Anschließend die Taste loslassen und noch einmal drücken... et voilà!
              Ich war kurz davor in das Teil reinzubeißen... habe jetzt insgesamt 2,5 Stunden dran gesessen... aber vielleicht kann ich zumindest dem Nächsten so eventuell ein wenig den Stress nehmen. :)
              A B AtifanA 3 Antworten Letzte Antwort
              • S schubs2802
                S
                S
                Smokey
                schrieb am zuletzt editiert von Smokey
                #1206
                @ullulaki sagte in Adapter: broadlink2:
                @Ullulaki : und wie sich Deine Mühe gelohnt hat. Vielen Dank. Ich dachte schon ich kann die neue App mit dem 4 Pro vergessen. Aber mit Deinem "move" gings dann wirklich. Ist anscheinend selbst dem Entwickler nicht klar. Nur einen winzigen Nachteil: die Remote ist dann auch wirklich in der App nicht drin und nicht komfortabel anlernbar, korrekt? Ist bei mir so. Aber auch gar kein Problem. Wollte nur verstehen, ob ich da vielleicht noch einen Fehler gemacht habe.
                Ansonsten Respekt und Danke :)
                • E
                  E
                  Elektroman
                  #1207
                  Moin,
                  nach vielem gefrickel habe ich es jetzt auch geschafft! (danke für die Vorarbeit!)
                  Ist es eigentlich irgendwie möglich, die IR Signale permanent von der original Fernbedinung abzufangen ?
                  (Also die "learn" Funktion permanent ?
                  Ralla66R 1 Antwort Letzte Antwort
                  • E Elektroman
                    Moin,
                    Ralla66R
                    Ralla66R
                    Ralla66
                    #1208
                    @elektroman
                    Nein
                    E 1 Antwort Letzte Antwort
                    • Ralla66R Ralla66
                      @elektroman
                      Nein
                      E
                      E
                      Elektroman
                      #1209
                      @ralla66
                      Das ging ja schnell,
                      Danke!
                      Schade, ich hätte gerne eine normale Fernbedienung. So muss man ja beim Umschalten immer auf das Smartphone schauen :-(
                      • E Elektroman
                        @ralla66
                        Danke!
                        Ralla66R
                        Ralla66R
                        Ralla66
                        #1210
                        @elektroman
                        ? warum
                        • Ralla66R Ralla66
                          @elektroman
                          ? warum
                          E
                          E
                          Elektroman
                          #1211
                          @ralla66
                          Ich habe bis jetzt mein Fernseher, AV usw mit dem Harmony Hub gesteuert. Jetzt habe ich einen neuen Fernseher und Harmony wurde eingestampft. Also muss ich mir was neues überlegen
                          Eine normale Fernbedienung ist uns einfach lieber (richtige Tasten zum erfühlen)
                          Ziel ist es wieder mit einer FB eine Szene auszulösen z.B. AV + TV + Sat an, Lautstärke über AV, Sender über Sat umschalten usw.
                          Ralla66R padrinoP 2 Antworten Letzte Antwort
                          • E Elektroman
                            @ralla66
                            Ralla66R
                            Ralla66R
                            Ralla66
                            #1212
                            @elektroman
                            Tasten nehmen einer normalen Fernbedienung die nicht in Gebrauch sind oder Code bauen mit
                            mit den Tasten 0 bis 9. Bauste ein Blockly, bsp wenn Taste 1 und 0 und 1 gedrückt wurden schalte TV / Sat usw.
                            Zum IR Code lesen gibt ja hier genug zu lesen.
                            • Ralla66R Ralla66
                              @elektroman
                              E
                              E
                              Elektroman
                              #1213
                              @ralla66
                              Vielen dank. So wollte ich es ja auch machen. Aber mit was für einer Hardware ? Ein zusätzliche IR Empfänger ?
                              • E Elektroman
                                @ralla66
                                Ralla66R
                                Ralla66R
                                Ralla66
                                #1214
                                @elektroman
                                Ja oder ja geht auch
                                • Ralla66R Ralla66
                                  @elektroman
                                  E
                                  E
                                  Elektroman
                                  #1215
                                  @ralla66
                                  Danke!
                                  Etwas fertiges gibt es da nicht, oder ?
                                  Will etwas stabiles haben
                                  • E Elektroman
                                    @ralla66
                                    Danke!
                                    Ralla66R
                                    Ralla66R
                                    Ralla66
                                    #1216
                                    @elektroman
                                    keine Ahnung, bau dir ne Sonoff Brigde auf IR Recv um, fettich
                                    Weicht aber zuweit vom Thema hier ab, dann mach bitte nen eigenen Fred dazu.
                                    • E Elektroman
                                      @ralla66
                                      padrinoP
                                      padrinoP
                                      padrino
                                      #1217
                                      @elektroman sagte in Adapter: broadlink2:
                                      @ralla66
                                      Hmm, auch wenn das Projekt beendet ist, so läuft die Harmony doch noch...
                                      Stand heute, es werden keine FBs mehr produziert, die Server laufen weiter und es werden auch noch neue Geräte in die Datenbank eingepflegt. 🤔
                                      • padrinoP padrino
                                        @ralla66
                                        E
                                        E
                                        Elektroman
                                        #1218
                                        @padrino
                                        Moin,
                                        vielen Dank für den Tipp !!!
                                        Ich habe das letzte Woche einige male versucht. "Server nicht erreichbar" wurde mir immer wieder angezeigt. Habe dann 1 und 1 zusammen gezählt und dachte es funktioniert nicht mehr. Jetzt klappt es doch wieder 🤦 😊
                                        • F
                                          F
                                          Frank06347
                                          #1219
                                          Moin,
                                          ich habe einen RMmini3 (neu) und habe ein Sensor-Kabel angeschlossen:
                                          https://www.amazon.de/gp/product/B087C2TY5C
                                          leider bleiben die Datenpunkte Temperature und Humitidy auf Null:
                                          Habt ihr einen Tipp für mich?
                                          Viele Grüße
                                          Frank
                                          83.9k
