  4. Puppeteer: Screenshots PhantomJS Alternative
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 107.5k Aufrufe 18 Beobachtet
  • M Marty56
    @foxriver76 Ich habe den Adapter deinstalliert und dann über die Admin Oberfläche installiert.
    $ iobroker url iobroker.puppeteer --host NUC2 --debug
    install iobroker.puppeteer
    Installing iobroker.puppeteer... (System call)
    109 packages are looking for funding run `npm fund` for details
    upload [0] puppeteer.admin /opt/iobroker/node_modules/iobroker.puppeteer/admin/puppeteer.png puppeteer.png image/png
    Process exited with code 0
    Dann noch die Instanz erzeugt.
    $ iobroker add puppeteer auto --host NUC2 --debug
    host.NUC2 create instance puppeteer
    host.NUC2 object system.adapter.puppeteer.0.alive created
    host.NUC2 object system.adapter.puppeteer.0.connected created
    host.NUC2 object system.adapter.puppeteer.0.compactMode created
    host.NUC2 object system.adapter.puppeteer.0.cpu created
    host.NUC2 object system.adapter.puppeteer.0.cputime created
    host.NUC2 object system.adapter.puppeteer.0.memHeapTotal created
    host.NUC2 object system.adapter.puppeteer.0.uptime created
    host.NUC2 object system.adapter.puppeteer.0.inputCount created
    host.NUC2 object system.adapter.puppeteer.0.outputCount created
    host.NUC2 object system.adapter.puppeteer.0.eventLoopLag created
    host.NUC2 object system.adapter.puppeteer.0.logLevel created
    host.NUC2 object puppeteer.0.url created
    host.NUC2 object puppeteer.0.clipTop created
    host.NUC2 object puppeteer.0.clipWidth created
    host.NUC2 object puppeteer.0.waitForSelector created
    host.NUC2 Set default value of puppeteer.0.fullPage: false
    host.NUC2 Set default value of puppeteer.0.clipTop: 0
    host.NUC2 object system.adapter.puppeteer.0 created
    foxriver76F
    foxriver76F
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    #113
    @marty56 Evtl. werden die Packages beim iob url Kommando nicht mitinstalliert. Wie genau stößt du den Installprozess an? Eigentlich erwarte ich da ein iob add direkt beim ersten mal.
    Videotutorials & mehr
    • NegaleinN Negalein
      @apollon77 sagte in Puppeteer: Screenshots PhantomJS Alternative:
      jetzt ist die frage ob wenn du script stoppst und neu startest danach plkötzlich 2 da sind ...
      tatsächlich
      hier wurde das Script gestoppt und wieder gestartet. Da gibt es schon die 1. Error-Meldung.
      javascript.0 2022-08-18 17:36:47.136	info	Start javascript script.js.Wetter.Wetter_to_FTP
      javascript.0 2022-08-18 17:36:44.540	error	Error by canceling scheduled job "<Anonymous Job 23 2022-08-18T12:57:51.743Z>"
      javascript.0 2022-08-18 17:36:44.539	info	Stop script script.js.Wetter.Wetter_to_FTP
      Und hier dann doppelt im JS und Puppeteer
      javascript.0 2022-08-18 17:39:03.369	error	script.js.Wetter.Wetter_to_FTP: Error on upload: Error: Command failed: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com ()
      javascript.0 2022-08-18 17:39:03.184	error	script.js.Wetter.Wetter_to_FTP: Error on upload: Error: Command failed: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com ()
      javascript.0 2022-08-18 17:39:03.157	info	script.js.Wetter.Wetter_to_FTP: exec: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com
      puppeteer.0  2022-08-18 17:39:03.056	debug	Write file to "wetterstation.png"
      javascript.0 2022-08-18 17:39:02.884	info	script.js.Wetter.Wetter_to_FTP: exec: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com
      puppeteer.0  2022-08-18 17:39:02.783	debug	Write file to "wetterstation.png"
      puppeteer.0  2022-08-18 17:39:00.289	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":298,"ack":false,"time":1660837140274},"_id":79533595}
      puppeteer.0  2022-08-18 17:39:00.289	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":297,"ack":false,"time":1660837140273},"_id":79533594}
      Machen wir das in einem eigenen Thread weiter?
      apollon77A
      apollon77A
      #114
      @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
      na da haben wir den übeltätert. Bitte javascript adapter issue anlegen mit infos zu elcher version und so ... üssen wir ggf da versuchen zu finden. Er kann den Job nicht canceln, daher läuft der weiter
      • apollon77A apollon77
        NegaleinN
        NegaleinN
        Negalein
        #115
        Done
        ° Fixer ---> iob fix
          Done
          foxriver76F
          foxriver76F
          foxriver76
          #116
          @negalein Nochmal zum Skript. Wenn du den JAvascript Adapter neu startest und das Skript nicht, dann läuft der schedule ja nur ein mal. Kommt es dann auch noch zu Upload Fehlern? Ich vermute, dass das parallele Neu schreiben das verursacht hat.
          • foxriver76F foxriver76
            NegaleinN
            NegaleinN
            Negalein
            #117
            @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
            2022-08-18 15:00:00.419  - debug: puppeteer.0 (6031) Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":7,"ack":false,"time":1660827600409},"_id":79533294}
            2022-08-18 15:00:02.897  - debug: puppeteer.0 (6031) Write file to "wetterstation.png"
            Stimmt, das ist mir erst nach Apollon aufgefallen.
              M
              M
              Marty56
              #118
              @foxriver76 ich habe einfach die "Katze" von der Admin Oberfläche angewählt, puppeteer gesucht und installiert
              HW:NUC (16 GB Ram)
              OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
              • M Marty56
                foxriver76F
                foxriver76F
                foxriver76
                #119
                @marty56 Katze ist nicht der klassische installationsweg, weshalb nicht normal über den Adapter Tab? Adapter ist aktuell im Beta Repo, falls du auf stable bist gerne kurz umstellen und dann nochmal Prozedur adapter löschen und installieren, dann geht es hoffentlich. ;-)
                apollon77A M 2 Antworten Letzte Antwort
                  apollon77A
                  apollon77A
                  #120
                  @foxriver76 hhuuusstt. Auf stable muss seit admin 5 keiner mehr das Repo wechseln. Custom install und „von npm“ Tab wählen. ;-)
                    foxriver76F
                    foxriver76F
                    foxriver76
                    #121
                    @apollon77 falls das geht ohne dass der Adapter bereits in irgendeiner Version im stable ist und das ein sauberen install triggered dann auch gerne so.
                    Ach ist ja sowieso im stable.. ganz vergessen. Dann nochmal die Frage warum installierst du via Katze?
                      M
                      M
                      Marty56
                      #122
                      @foxriver76 Danke. Damit hat es funktioniert.
                      HW:NUC (16 GB Ram)
                      • J
                        J
                        jojo182
                        #123
                        ich bekomme leider den Adapter auch nicht grün. Hat jemand eine Idee was es sein könnte?
                        Folgende Fehlermeldung erscheint im Log:
                        2022-08-22 10:43:07.164 - info: host.raspberrypi instance system.adapter.puppeteer.0 started with pid 18342
                        2022-08-22 10:43:09.637 - error: puppeteer.0 (18342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2022-08-22 10:43:09.640 - error: puppeteer.0 (18342) unhandled promise rejection: Failed to launch the browser process!
                        /opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: 16: /opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: Syntax error: ")" unexpected
                        TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
                        2022-08-22 10:43:09.643 - error: puppeteer.0 (18342) Error: Failed to launch the browser process!
                        at onClose (/opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20)
                        at Interface. (/opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:231:68)
                        at Interface.emit (node:events:525:35)
                        at Interface.close (node:readline:590:8)
                        at Socket.onend (node:readline:280:10)
                        at Socket.emit (node:events:525:35)
                        at endReadableNT (node:internal/streams/readable:1358:12)
                        at processTicksAndRejections (node:internal/process/task_queues:83:21)
                        2022-08-22 10:43:09.644 - error: puppeteer.0 (18342) Failed to launch the browser process!
                        2022-08-22 10:43:09.664 - warn: puppeteer.0 (18342) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2022-08-22 10:43:10.363 - error: host.raspberrypi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2022-08-22 10:43:10.363 - info: host.raspberrypi Restart adapter system.adapter.puppeteer.0 because enabled
                        • foxriver76F
                          foxriver76F
                          foxriver76
                          #124
                          Es ist sehr wichtig, den Adapter klassisch zu installieren, nicht via Katze oder ähnliches. Falls anders geschehen bitte Adapter löschen und normal über Admin installieren. Dann werden die nötigen Pakete mit installiert.
                            liv-in-skyL
                            liv-in-skyL
                            #125
                            @foxriver76
                            hast du das mitbekommen - war ursprünglich hier im thread gepostet - wurde aber verschoben
                            https://forum.iobroker.net/post/845827
                            • liv-in-skyL liv-in-sky
                              @foxriver76
                              foxriver76F
                              foxriver76F
                              foxriver76
                              #126
                              @liv-in-sky Ja, sollte nicht gelöscht werden wie von Thomas vermutet. Dort liegt meines Wissens der Browser der von Puppeteer selbst mitgebracht wird.
                              • J jojo182
                                liv-in-skyL
                                liv-in-skyL
                                #127
                                @jojo182
                                hast du das ausgeführt ? https://forum.iobroker.net/post/845727
                                soll nicht heißen, du sollst das ausführen !!!!
                                  NegaleinN
                                  NegaleinN
                                  Negalein
                                  #128
                                  seh gerade, dass es mich da auch erwischt hat.
                                  Also Puppeteer wieder deinstallieren und wieder installieren?
                                    foxriver76F
                                    foxriver76F
                                    foxriver76
                                    #129
                                    @negalein Ja, ist die sauberste Lösung.
                                    • J
                                      J
                                      jojo182
                                      #130
                                      @foxriver76 Also ich hab den ganzen Adapter gelöscht, dann manuell die Reste in node_modules auch.
                                      Dann über Admin Oberfläche den Adapter neu installiert, leider das gleiche Ergebnis.
                                      @liv-in-sky Tatsächlich hatte ich das ausgeführt, danach meckerte dann der Adapter das er chromium gar nicht finden kann wegen dem "." Hatte dann nochmal alles deinstalliert und neu installiert und dann kam wieder der oben genannte Fehler.
                                      Ich muss dazu sagen, dass ich normalerweiße im Javascript immer direkt puppeteer aufgerufen hatte. Seit einer Woche ca. geht das nicht mehr. Wahrscheinlich dann das gleiche Problem, nur zeigt er mir im Log nichts an, deshalb hatte ich gehofft ich bekomm es mit dem puppeteer Adapter wieder ans laufen.
                                      • J jojo182
                                        foxriver76F
                                        foxriver76F
                                        foxriver76
                                        #131
                                        @jojo182 Kannst du was zu deinem System sagen. Zeige mal alle Ausgaben:
                                        node -v
                                        nodejs -v
                                        cd /opt/iobroker
                                        npm ls
                                          node -v
                                          nodejs -v
                                          cd /opt/iobroker
                                          npm ls
                                          J
                                          J
                                          jojo182
                                          #132
                                          @foxriver76
                                          Ist ein Raspberry Pi 4 mit (noch) buster.
                                          node -v
                                          v16.17.0
                                          nodejs -v
                                          v16.17.0
                                          cd /opt/iobroker
                                          npm ls
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├── canvas@2.9.3
                                          ├── iobroker.admin@6.2.17
                                          ├── iobroker.backitup@2.4.12
                                          ├── iobroker.daswetter@3.1.4
                                          ├── iobroker.discovery@3.0.5
                                          ├── iobroker.echarts@1.0.12
                                          ├── iobroker.email@1.1.3
                                          ├── iobroker.energiefluss@1.0.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#0a734637f65acccbe761f460d06ecd1cb0731a96)
                                          ├── iobroker.flot@1.11.0
                                          ├── iobroker.fritzdect@2.2.3
                                          ├── iobroker.history@2.2.1
                                          ├── iobroker.homeconnect@1.0.1
                                          ├── iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954)
                                          ├── iobroker.info@1.9.19
                                          ├── iobroker.jarvis@3.0.13
                                          ├── iobroker.javascript@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#9f30d43e14ff8e86d89860be50d1a4f4e15e2905)
                                          ├── iobroker.js-controller@4.0.23
                                          ├── iobroker.knx@1.0.45
                                          ├── iobroker.mihome-vacuum@3.6.0
                                          ├── iobroker.modbus@5.0.5
                                          ├── iobroker.mqtt@4.0.7
                                          ├── iobroker.node-red@3.3.1
                                          ├── iobroker.openknx@0.2.6
                                          ├── iobroker.openweathermap@0.3.0
                                          ├── iobroker.puppeteer@0.2.6
                                          ├── iobroker.pvforecast@2.3.0
                                          ├── iobroker.shuttercontrol@1.4.14
                                          ├── iobroker.simple-api@2.7.0
                                          ├── iobroker.smartmeter@3.3.4
                                          ├── iobroker.socketio@6.1.8
                                          ├── iobroker.sonoff@2.5.1
                                          ├── iobroker.sql@2.1.8
                                          ├── iobroker.stiebel-isg@1.7.5
                                          ├── iobroker.telegram@1.14.1
                                          ├── iobroker.text2command@2.2.2
                                          ├── iobroker.tr-064@4.2.16
                                          ├── iobroker.vis@1.4.15
                                          ├── iobroker.web@5.2.4
                                          ├── iobroker.ws@2.1.3
                                          ├── iobroker.yr@5.3.0
                                          ├── iobroker.zigbee@1.7.6
                                          └── puppeteer@16.2.0
                                          Javascript Adapter ist übrigens nur über github installiert weil ich gehofft hatte das Task Cancel Problem ist damit behoben.
                                          33.2k
                                          84.3k
