  4. Puppeteer: Screenshots PhantomJS Alternative
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 80.2k Aufrufe 18 Beobachtet
  • apollon77A apollon77
    @negalein PS: ....ääähhmmm ... also im Log ist nach 14:57 genau 1x das drin ... und nur einmalig ... damit wäre doch alles ok ... jetzt ist die frage ob wenn du script stoppst und neu startest danach plkötzlich 2 da sind ... das wäre dann aber was anderes
    M
    M
    Marty56
    schrieb am zuletzt editiert von Marty56
    #107
    Der Adapter stürzt ab, mit folgender Fehlermeldung.
    .NUC2
    2022-08-18 16:36:00.418	error	instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    puppeteer.0
    2022-08-18 16:35:59.844	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    puppeteer.0
    2022-08-18 16:35:59.839	error	Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0
    2022-08-18 16:35:59.838	error	Error: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:525:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    puppeteer.0
    2022-08-18 16:35:59.837	error	unhandled promise rejection: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0
    2022-08-18 16:35:59.836	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.NUC2
    2022-08-18 16:35:28.637	error	instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    puppeteer.0
    2022-08-18 16:35:28.076	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    puppeteer.0
    2022-08-18 16:35:28.066	error	Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0
    2022-08-18 16:35:28.066	error	Error: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:525:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    puppeteer.0
    2022-08-18 16:35:28.064	error	unhandled promise rejection: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0
    2022-08-18 16:35:28.063	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Ich vermute, dass ich den Chrome Browser nicht installiert habe.
    Muss man das separat von der Adapter Installation machen?
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • M Marty56
      .NUC2
      puppeteer.0
      puppeteer.0
      puppeteer.0
      puppeteer.0
      puppeteer.0
      host.NUC2
      puppeteer.0
      puppeteer.0
      puppeteer.0
      puppeteer.0
      puppeteer.0
      foxriver76F
      foxriver76F
      foxriver76
      #108
      @marty56 vermutlich konnte er nicht alle Pakete korrekt installieren. Gerne mal den ganzen Adapter löschen. sudo apt update ausführen und dann den Adapter neu installieren, habe dafür schon ein Controller issue erstellt.
      Videotutorials & mehr
      • foxriver76F foxriver76
        M
        M
        Marty56
        #109
        @foxriver76 hat leider nichts gebracht. Dieselben Fehlermeldungen.
        HW:NUC (16 GB Ram)
        • M Marty56
          foxriver76F
          foxriver76F
          foxriver76
          #110
          @marty56 Bitte mal das install log zeigen.
            M
            M
            Marty56
            #111
            @foxriver76 Ich habe den Adapter deinstalliert und dann über die Admin Oberfläche installiert.
            $ iobroker url iobroker.puppeteer --host NUC2 --debug
            install iobroker.puppeteer
            Installing iobroker.puppeteer... (System call)
            109 packages are looking for funding run `npm fund` for details
            upload [0] puppeteer.admin /opt/iobroker/node_modules/iobroker.puppeteer/admin/puppeteer.png puppeteer.png image/png
            Process exited with code 0
            Dann noch die Instanz erzeugt.
            $ iobroker add puppeteer auto --host NUC2 --debug
            host.NUC2 create instance puppeteer
            host.NUC2 object system.adapter.puppeteer.0.alive created
            host.NUC2 object system.adapter.puppeteer.0.connected created
            host.NUC2 object system.adapter.puppeteer.0.compactMode created
            host.NUC2 object system.adapter.puppeteer.0.cpu created
            host.NUC2 object system.adapter.puppeteer.0.cputime created
            host.NUC2 object system.adapter.puppeteer.0.memHeapTotal created
            host.NUC2 object system.adapter.puppeteer.0.uptime created
            host.NUC2 object system.adapter.puppeteer.0.inputCount created
            host.NUC2 object system.adapter.puppeteer.0.outputCount created
            host.NUC2 object system.adapter.puppeteer.0.eventLoopLag created
            host.NUC2 object system.adapter.puppeteer.0.logLevel created
            host.NUC2 object puppeteer.0.url created
            host.NUC2 object puppeteer.0.clipTop created
            host.NUC2 object puppeteer.0.clipWidth created
            host.NUC2 object puppeteer.0.waitForSelector created
            host.NUC2 Set default value of puppeteer.0.fullPage: false
            host.NUC2 Set default value of puppeteer.0.clipTop: 0
            host.NUC2 object system.adapter.puppeteer.0 created
            HW:NUC (16 GB Ram)
              NegaleinN
              NegaleinN
              Negalein
              #112
              @apollon77 sagte in Puppeteer: Screenshots PhantomJS Alternative:
              tatsächlich
              hier wurde das Script gestoppt und wieder gestartet. Da gibt es schon die 1. Error-Meldung.
              javascript.0 2022-08-18 17:36:47.136	info	Start javascript script.js.Wetter.Wetter_to_FTP
              javascript.0 2022-08-18 17:36:44.540	error	Error by canceling scheduled job "<Anonymous Job 23 2022-08-18T12:57:51.743Z>"
              javascript.0 2022-08-18 17:36:44.539	info	Stop script script.js.Wetter.Wetter_to_FTP
              Und hier dann doppelt im JS und Puppeteer
              javascript.0 2022-08-18 17:39:03.369	error	script.js.Wetter.Wetter_to_FTP: Error on upload: Error: Command failed: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com ()
              javascript.0 2022-08-18 17:39:03.184	error	script.js.Wetter.Wetter_to_FTP: Error on upload: Error: Command failed: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com ()
              javascript.0 2022-08-18 17:39:03.157	info	script.js.Wetter.Wetter_to_FTP: exec: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com
              puppeteer.0  2022-08-18 17:39:03.056	debug	Write file to "wetterstation.png"
              javascript.0 2022-08-18 17:39:02.884	info	script.js.Wetter.Wetter_to_FTP: exec: wput -nc /opt/iobroker/iobroker-data/files/0_userdata.0/wetterstation.png ftp://xxxxx:xxxxx@www37.world4you.com
              puppeteer.0  2022-08-18 17:39:02.783	debug	Write file to "wetterstation.png"
              puppeteer.0  2022-08-18 17:39:00.289	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":298,"ack":false,"time":1660837140274},"_id":79533595}
              puppeteer.0  2022-08-18 17:39:00.289	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":297,"ack":false,"time":1660837140273},"_id":79533594}
              Machen wir das in einem eigenen Thread weiter?
              ° Fixer ---> iob fix
              • M Marty56
                foxriver76F
                foxriver76F
                foxriver76
                schrieb am zuletzt editiert von foxriver76
                #113
                @marty56 Evtl. werden die Packages beim iob url Kommando nicht mitinstalliert. Wie genau stößt du den Installprozess an? Eigentlich erwarte ich da ein iob add direkt beim ersten mal.
                • NegaleinN Negalein
                  tatsächlich
                  apollon77A
                  apollon77A
                  #114
                  @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
                  na da haben wir den übeltätert. Bitte javascript adapter issue anlegen mit infos zu elcher version und so ... üssen wir ggf da versuchen zu finden. Er kann den Job nicht canceln, daher läuft der weiter
                    NegaleinN
                    NegaleinN
                    Negalein
                    #115
                    Done
                      Done
                      foxriver76F
                      foxriver76F
                      foxriver76
                      #116
                      @negalein Nochmal zum Skript. Wenn du den JAvascript Adapter neu startest und das Skript nicht, dann läuft der schedule ja nur ein mal. Kommt es dann auch noch zu Upload Fehlern? Ich vermute, dass das parallele Neu schreiben das verursacht hat.
                        NegaleinN
                        NegaleinN
                        Negalein
                        #117
                        @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
                        2022-08-18 15:00:00.419  - debug: puppeteer.0 (6031) Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://10.0.1.203:3000/d/sRh7W1m4k/wetterstation-copy-2?orgId=1&kiosk","clip":{"x":0,"y":0,"width":1000,"height":1100},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":7,"ack":false,"time":1660827600409},"_id":79533294}
                        2022-08-18 15:00:02.897  - debug: puppeteer.0 (6031) Write file to "wetterstation.png"
                        Stimmt, das ist mir erst nach Apollon aufgefallen.
                          M
                          M
                          Marty56
                          #118
                          @foxriver76 ich habe einfach die "Katze" von der Admin Oberfläche angewählt, puppeteer gesucht und installiert
                          HW:NUC (16 GB Ram)
                          • M Marty56
                            foxriver76F
                            foxriver76F
                            foxriver76
                            #119
                            @marty56 Katze ist nicht der klassische installationsweg, weshalb nicht normal über den Adapter Tab? Adapter ist aktuell im Beta Repo, falls du auf stable bist gerne kurz umstellen und dann nochmal Prozedur adapter löschen und installieren, dann geht es hoffentlich. ;-)
                            apollon77A M 2 Antworten Letzte Antwort
                              apollon77A
                              apollon77A
                              #120
                              @foxriver76 hhuuusstt. Auf stable muss seit admin 5 keiner mehr das Repo wechseln. Custom install und „von npm“ Tab wählen. ;-)
                                foxriver76F
                                foxriver76F
                                foxriver76
                                #121
                                @apollon77 falls das geht ohne dass der Adapter bereits in irgendeiner Version im stable ist und das ein sauberen install triggered dann auch gerne so.
                                Ach ist ja sowieso im stable.. ganz vergessen. Dann nochmal die Frage warum installierst du via Katze?
                                  M
                                  M
                                  Marty56
                                  #122
                                  @foxriver76 Danke. Damit hat es funktioniert.
                                  HW:NUC (16 GB Ram)
                                  • J
                                    J
                                    jojo182
                                    #123
                                    ich bekomme leider den Adapter auch nicht grün. Hat jemand eine Idee was es sein könnte?
                                    Folgende Fehlermeldung erscheint im Log:
                                    2022-08-22 10:43:07.164 - info: host.raspberrypi instance system.adapter.puppeteer.0 started with pid 18342
                                    2022-08-22 10:43:09.637 - error: puppeteer.0 (18342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2022-08-22 10:43:09.640 - error: puppeteer.0 (18342) unhandled promise rejection: Failed to launch the browser process!
                                    /opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: 16: /opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: Syntax error: ")" unexpected
                                    2022-08-22 10:43:09.643 - error: puppeteer.0 (18342) Error: Failed to launch the browser process!
                                    at onClose (/opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20)
                                    at Interface. (/opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:231:68)
                                    at Interface.emit (node:events:525:35)
                                    at Interface.close (node:readline:590:8)
                                    at Socket.onend (node:readline:280:10)
                                    at Socket.emit (node:events:525:35)
                                    at endReadableNT (node:internal/streams/readable:1358:12)
                                    at processTicksAndRejections (node:internal/process/task_queues:83:21)
                                    2022-08-22 10:43:09.644 - error: puppeteer.0 (18342) Failed to launch the browser process!
                                    2022-08-22 10:43:09.664 - warn: puppeteer.0 (18342) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2022-08-22 10:43:10.363 - error: host.raspberrypi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2022-08-22 10:43:10.363 - info: host.raspberrypi Restart adapter system.adapter.puppeteer.0 because enabled
                                    • foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #124
                                      Es ist sehr wichtig, den Adapter klassisch zu installieren, nicht via Katze oder ähnliches. Falls anders geschehen bitte Adapter löschen und normal über Admin installieren. Dann werden die nötigen Pakete mit installiert.
                                        liv-in-skyL
                                        liv-in-skyL
                                        #125
                                        @foxriver76
                                        hast du das mitbekommen - war ursprünglich hier im thread gepostet - wurde aber verschoben
                                        https://forum.iobroker.net/post/845827
                                        • liv-in-skyL liv-in-sky
                                          @foxriver76
                                          foxriver76F
                                          foxriver76F
                                          foxriver76
                                          #126
                                          @liv-in-sky Ja, sollte nicht gelöscht werden wie von Thomas vermutet. Dort liegt meines Wissens der Browser der von Puppeteer selbst mitgebracht wird.
                                          83.8k
