  4. Puppeteer: Screenshots PhantomJS Alternative
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 108.2k Aufrufe 18 Beobachtet
  • NegaleinN Negalein
    @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
    Und nach wie vor der Fehler beim Start?
    Sorry, oben vergessen.
    Ja, wieder die Fehler.
    puppeteer.0 2022-08-12 11:05:59.293	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    puppeteer.0 2022-08-12 11:05:59.292	info	terminating
    puppeteer.0 2022-08-12 11:05:59.287	error	Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0 2022-08-12 11:05:59.286	error	Error: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    puppeteer.0 2022-08-12 11:05:59.284	error	unhandled promise rejection: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0 2022-08-12 11:05:59.284	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    puppeteer.0 2022-08-12 11:05:59.250	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
    foxriver76F
    foxriver76F
    foxriver76
    @negalein Zeig mal bitte Output von ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
    Videotutorials & mehr
    • foxriver76F foxriver76
      NegaleinN
      NegaleinN
      Negalein
      nega@ioBroker:~$ ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
              libnss3.so => not found
              libnssutil3.so => not found
              libsmime3.so => not found
      nega@ioBroker:~$
      ° Fixer ---> iob fix
        nega@ioBroker:~$
        foxriver76F
        foxriver76F
        foxriver76
        @negalein sudo apt update && sudo apt install libnss3 installiert er es da. Beim install Log hat er schon gesagt, dass er es nicht findet.. mal sehen woran das liegt
          NegaleinN
          NegaleinN
          Negalein
          Danke, ist jetzt grün. :)
          Screenshot wird nicht erstellt und DP sind leer.
            foxriver76F
            foxriver76F
            foxriver76
            @negalein DPs sind nur zur Konfiguration. Schreibt er was im Log? Evtl. auf Debug wenn du sendTo ausführst?
              NegaleinN
              NegaleinN
              Negalein
              puppeteer.0 2022-08-12 11:33:32.075	debug	Checking path "../wetterstation.png"
              puppeteer.0 2022-08-12 11:33:32.075	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278577}
              puppeteer.0 2022-08-12 11:33:19.946	debug	Checking path "../wetterstation.png"
              puppeteer.0 2022-08-12 11:33:19.946	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278576}
              puppeteer.0 2022-08-12 11:32:57.012	info	Ready to take screenshots
              puppeteer.0 2022-08-12 11:32:56.815	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
                foxriver76F
                foxriver76F
                foxriver76
                @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
                hm gib mal als path im Skript /opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png an
                  NegaleinN
                  NegaleinN
                  Negalein
                  puppeteer.0 2022-08-12 11:38:01.009	error	Could not take screenshot of "http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk": Screenshots cannot be stored inside a node_modules folder
                  puppeteer.0 2022-08-12 11:38:01.009	debug	Checking path "/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"
                  puppeteer.0 2022-08-12 11:38:01.008	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278587}
                  hmmm, muss es woanders speichern. Was würdest du empfehlen?
                    foxriver76F
                    foxriver76F
                    foxriver76
                    @negalein Stimmt ja, schlechter Stil wird ja vom Adapter verhindert :D
                    Sauber ist es im ioBroker storage, mach path weg und dafür das rein:
                          ioBrokerOptions: {
                            storagePath: 'wetterstation.png';
                            ioBrokerOptions: {
                      NegaleinN
                      NegaleinN
                      Negalein
                      was brauch ich da wieder nach }
                      sendTo('puppeteer.0', 'screenshot', {
                          url: 'http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk',
                          clip: {
                              x: 0,
                              y: 0,
                              width: 1920,
                              height: 757
                          ioBrokerOptions: {
                      Edit:
                      so gehts :)
                          clip: {
                              x: 0,
                              y: 0,
                              width: 1920,
                              height: 757
                          ioBrokerOptions: {
                              storagePath: 'wetterstation.png',
                      Edith 2:
                      hmmm, wo speichert er jetzt?
                            clip: {
                                x: 0,
                                y: 0,
                                width: 1920,
                                height: 757
                            ioBrokerOptions: {
                        Edit:
                        so gehts :)
                            clip: {
                                x: 0,
                                y: 0,
                                width: 1920,
                                height: 757
                            ioBrokerOptions: {
                        Edith 2:
                        foxriver76F
                        foxriver76F
                        foxriver76
                        schrieb am zuletzt editiert von foxriver76
                        @negalein geh mal im admin auf Dateien und dann Benutzerdaten
                        Auf dem Filessystem ist das defaultmäßig /opt/iobroker/iobroker-data/files/0_userdata.0/
                          NegaleinN
                          NegaleinN
                          Negalein
                          #66
                          gefunden in /opt/iobroker/iobroker-data/files/0_userdata.0/ :)
                          Jetzt muss ich noch an der Auflösung basteln
                          So ist es original.
                          Puppeteer quetscht es irgendwie.
                            So ist es original.
                            foxriver76F
                            foxriver76F
                            foxriver76
                            #67
                            @negalein Mom.. ich bastel kurz was. Defaultmäßig macht Puppeteer Browser 800x600 Auflösung statt die maximal Mögliche.
                            • foxriver76F
                              foxriver76F
                              foxriver76
                              #68
                              Bitte mal 0.2.4 probieren, ist in 5 Minuten auf npm
                                NegaleinN
                                NegaleinN
                                Negalein
                                #69
                                eingestellt auf 1600x800
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  #70
                                  @negalein Schade, dann mach mal zusätzlich mit in die Message
                                  viewportOptions: {
                                   width: 1600,
                                  height: 1000
                                  Entsprechen angepasst, bin nur am Handy.
                                    viewportOptions: {
                                     width: 1600,
                                    height: 1000
                                    NegaleinN
                                    NegaleinN
                                    Negalein
                                    #71
                                    schon viel besser. :)
                                    Jetzt muss ich nur noch den rechten schwarzen Rand weg bekommen.
                                      foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #72
                                      @negalein das sollte mit den Clip Optionen gehen.
                                        NegaleinN
                                        NegaleinN
                                        Negalein
                                        #73
                                        muss das später in Ruhe testen.
                                        Umso mehr ich mit Clip probiere, umso komischer wird es.
                                        So wie oben (trotz identen Settings) bekomm ich es nicht mehr hin.
                                          foxriver76F
                                          foxriver76F
                                          foxriver76
                                          #74
                                          @negalein Gerne die exakten Settings posten, falls du noch daran hängst.
                                          33.2k
                                          84.4k
