  4. Puppeteer: Screenshots PhantomJS Alternative
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 80.1k Aufrufe 18 Beobachtet
  • foxriver76F foxriver76
    @negalein lösche mal den Adapter und installiere ihn neu bitte. Am Anfang wurden die libraries nicht mit installiert und bei update passiert das leider nicht.
    NegaleinN
    NegaleinN
    Negalein
    @foxriver76
    leider selbes Ergebnis
    puppeteer.0 2022-08-12 00:26:10.626	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    puppeteer.0 2022-08-12 00:26:10.626	info	terminating
    puppeteer.0 2022-08-12 00:26:10.618	error	Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0 2022-08-12 00:26:10.617	error	Error: Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    puppeteer.0 2022-08-12 00:26:10.617	error	unhandled promise rejection: Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    puppeteer.0 2022-08-12 00:26:10.616	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    puppeteer.0 2022-08-12 00:26:10.582	info	starting. Version 0.2.1 (non-npm: foxriver76/ioBroker.puppeteer) in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      @foxriver76
      foxriver76F
      foxriver76F
      foxriver76
      @negalein zeig mal log von iob del puppeteer && iob add puppeteer
      Videotutorials & mehr
        NegaleinN
        NegaleinN
        Negalein
        @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
        nega@ioBroker:/opt/iobroker$ iob del puppeteer && iob add puppeteer
        Delete adapter "puppeteer"
        host.ioBroker Counted 1 instances of puppeteer
        host.ioBroker Counted 1 meta of puppeteer
        host.ioBroker Counted 1 adapter for puppeteer
        host.ioBroker Counted 9 states of puppeteer
        host.ioBroker Counted 14 states of system.adapter.puppeteer
        host.ioBroker Counted 3 states (io.puppeteer.*) from states
        host.ioBroker Counted 14 states (system.adapter.puppeteer.*) from states
        host.ioBroker file puppeteer.admin deleted
        host.ioBroker object puppeteer deleted
        host.ioBroker object puppeteer.admin deleted
        host.ioBroker Deleting 26 object(s).
        host.ioBroker Deleting 17 state(s).
        removed 25 packages in 3s
        193 packages are looking for funding
          run `npm fund` for details
        NPM version: 8.11.0
        Installing iobroker.puppeteer@0.2.1... (System call)
        added 25 packages in 11s
        host.ioBroker install adapter puppeteer
        Cannot install "libnss3": E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nss/libnss3_3.49.1-1ubuntu1.7_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
        The following apt-get packages could not be installed: libnss3. Please install them manually.
        upload [0] puppeteer.admin /opt/iobroker/node_modules/iobroker.puppeteer/admin/puppeteer.png puppeteer.png image/png
        host.ioBroker object system.adapter.puppeteer created/updated
        host.ioBroker create instance puppeteer
        host.ioBroker object system.adapter.puppeteer.0.alive created
        host.ioBroker object system.adapter.puppeteer.0.connected created
        host.ioBroker object system.adapter.puppeteer.0.compactMode created
        host.ioBroker object system.adapter.puppeteer.0.cpu created
        host.ioBroker object system.adapter.puppeteer.0.cputime created
        host.ioBroker object system.adapter.puppeteer.0.memHeapUsed created
        host.ioBroker object system.adapter.puppeteer.0.memHeapTotal created
        host.ioBroker object system.adapter.puppeteer.0.memRss created
        host.ioBroker object system.adapter.puppeteer.0.uptime created
        host.ioBroker object system.adapter.puppeteer.0.inputCount created
        host.ioBroker object system.adapter.puppeteer.0.outputCount created
        host.ioBroker object system.adapter.puppeteer.0.eventLoopLag created
        host.ioBroker object system.adapter.puppeteer.0.sigKill created
        host.ioBroker object system.adapter.puppeteer.0.logLevel created
        host.ioBroker object puppeteer.0.url created
        host.ioBroker object puppeteer.0.filename created
        host.ioBroker object puppeteer.0.fullPage created
        host.ioBroker object puppeteer.0.clipTop created
        host.ioBroker object puppeteer.0.clipLeft created
        host.ioBroker object puppeteer.0.clipWidth created
        host.ioBroker object puppeteer.0.clipHeight created
        host.ioBroker object puppeteer.0.renderTime created
        host.ioBroker object puppeteer.0.waitForSelector created
        host.ioBroker Set default value of puppeteer.0.fullPage: false
        host.ioBroker Set default value of puppeteer.0.clipTop: 0
        host.ioBroker Set default value of puppeteer.0.clipLeft: 0
        host.ioBroker object system.adapter.puppeteer.0 created
          NPM version: 8.11.0
          foxriver76F
          foxriver76F
          foxriver76
          @negalein Und nach wie vor der Fehler beim Start?
            NegaleinN
            NegaleinN
            Negalein
            Sorry, oben vergessen.
            Ja, wieder die Fehler.
            puppeteer.0 2022-08-12 11:05:59.293	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            puppeteer.0 2022-08-12 11:05:59.292	info	terminating
            puppeteer.0 2022-08-12 11:05:59.287	error	Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
            puppeteer.0 2022-08-12 11:05:59.286	error	Error: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
            puppeteer.0 2022-08-12 11:05:59.284	error	unhandled promise rejection: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
            puppeteer.0 2022-08-12 11:05:59.284	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            puppeteer.0 2022-08-12 11:05:59.250	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
              foxriver76F
              foxriver76F
              foxriver76
              @negalein Zeig mal bitte Output von ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
                NegaleinN
                NegaleinN
                Negalein
                nega@ioBroker:~$ ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
                        libnss3.so => not found
                        libnssutil3.so => not found
                        libsmime3.so => not found
                nega@ioBroker:~$
                  nega@ioBroker:~$
                  foxriver76F
                  foxriver76F
                  foxriver76
                  @negalein sudo apt update && sudo apt install libnss3 installiert er es da. Beim install Log hat er schon gesagt, dass er es nicht findet.. mal sehen woran das liegt
                    NegaleinN
                    NegaleinN
                    Negalein
                    Danke, ist jetzt grün. :)
                    Screenshot wird nicht erstellt und DP sind leer.
                      foxriver76F
                      foxriver76F
                      foxriver76
                      @negalein DPs sind nur zur Konfiguration. Schreibt er was im Log? Evtl. auf Debug wenn du sendTo ausführst?
                        NegaleinN
                        NegaleinN
                        Negalein
                        puppeteer.0 2022-08-12 11:33:32.075	debug	Checking path "../wetterstation.png"
                        puppeteer.0 2022-08-12 11:33:32.075	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278577}
                        puppeteer.0 2022-08-12 11:33:19.946	debug	Checking path "../wetterstation.png"
                        puppeteer.0 2022-08-12 11:33:19.946	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278576}
                        puppeteer.0 2022-08-12 11:32:57.012	info	Ready to take screenshots
                        puppeteer.0 2022-08-12 11:32:56.815	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
                          foxriver76F
                          foxriver76F
                          foxriver76
                          @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
                          hm gib mal als path im Skript /opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png an
                            NegaleinN
                            NegaleinN
                            Negalein
                            puppeteer.0 2022-08-12 11:38:01.009	error	Could not take screenshot of "http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk": Screenshots cannot be stored inside a node_modules folder
                            puppeteer.0 2022-08-12 11:38:01.009	debug	Checking path "/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"
                            puppeteer.0 2022-08-12 11:38:01.008	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278587}
                            hmmm, muss es woanders speichern. Was würdest du empfehlen?
                              foxriver76F
                              foxriver76F
                              foxriver76
                              @negalein Stimmt ja, schlechter Stil wird ja vom Adapter verhindert :D
                              Sauber ist es im ioBroker storage, mach path weg und dafür das rein:
                                    ioBrokerOptions: {
                                      storagePath: 'wetterstation.png';
                                      ioBrokerOptions: {
                                NegaleinN
                                NegaleinN
                                Negalein
                                was brauch ich da wieder nach }
                                sendTo('puppeteer.0', 'screenshot', {
                                    url: 'http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk',
                                    clip: {
                                        x: 0,
                                        y: 0,
                                        width: 1920,
                                        height: 757
                                    ioBrokerOptions: {
                                Edit:
                                so gehts :)
                                    clip: {
                                        x: 0,
                                        y: 0,
                                        width: 1920,
                                        height: 757
                                    ioBrokerOptions: {
                                        storagePath: 'wetterstation.png',
                                Edith 2:
                                hmmm, wo speichert er jetzt?
                                      clip: {
                                          x: 0,
                                          y: 0,
                                          width: 1920,
                                          height: 757
                                      ioBrokerOptions: {
                                  Edit:
                                  so gehts :)
                                      clip: {
                                          x: 0,
                                          y: 0,
                                          width: 1920,
                                          height: 757
                                      ioBrokerOptions: {
                                  Edith 2:
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  schrieb am zuletzt editiert von foxriver76
                                  @negalein geh mal im admin auf Dateien und dann Benutzerdaten
                                  Auf dem Filessystem ist das defaultmäßig /opt/iobroker/iobroker-data/files/0_userdata.0/
                                    NegaleinN
                                    NegaleinN
                                    Negalein
                                    #66
                                    gefunden in /opt/iobroker/iobroker-data/files/0_userdata.0/ :)
                                    Jetzt muss ich noch an der Auflösung basteln
                                    So ist es original.
                                    Puppeteer quetscht es irgendwie.
                                      So ist es original.
                                      foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #67
                                      @negalein Mom.. ich bastel kurz was. Defaultmäßig macht Puppeteer Browser 800x600 Auflösung statt die maximal Mögliche.
                                      • foxriver76F
                                        foxriver76F
                                        foxriver76
                                        #68
                                        Bitte mal 0.2.4 probieren, ist in 5 Minuten auf npm
                                          NegaleinN
                                          NegaleinN
                                          Negalein
                                          #69
                                          eingestellt auf 1600x800
                                          83.8k
