  3. Off Topic
  4. [done] pihole update. pfade stimmen nicht, proxmox update
pihole iobroker proxmox
60 Beiträge 7 Kommentatoren 7.9k Aufrufe 5 Beobachtet
    @da_woody schnell mal nachgelesen, das ist nicht persistent, da muss ebenfalls /etc/hosts angepasst werden, sonst wir es immer wieder überschrieben.
    da_WoodyD Online
    da_WoodyD Online
    @crunchip werkstatt büro, F1, yellow flag... yeah, geklappt. :)
    root@Homeserver:~#  pve6to7 --full
    = CHECKING VERSION INFORMATION FOR PVE PACKAGES =
    Checking for package updates..
    WARN: updates for the following packages are available:
      pve-kernel-5.4, pve-kernel-5.4.195-1-pve, pve-kernel-helper
    Checking proxmox-ve package version..
    PASS: proxmox-ve package has version >= 6.4-1
    Checking running kernel version..
    PASS: expected running kernel '5.4.189-2-pve'.
    = CHECKING CLUSTER HEALTH/SETTINGS =
    SKIP: standalone node.
    = CHECKING HYPER-CONVERGED CEPH STATUS =
    SKIP: no hyper-converged ceph setup detected!
    = CHECKING CONFIGURED STORAGES =
    PASS: storage 'local' enabled and active.
    PASS: storage 'local-lvm' enabled and active.
    PASS: storage 'proxmoxbackup' enabled and active.
    = MISCELLANEOUS CHECKS =
    INFO: Checking common daemon services..
    PASS: systemd unit 'pveproxy.service' is in state 'active'
    PASS: systemd unit 'pvedaemon.service' is in state 'active'
    PASS: systemd unit 'pvestatd.service' is in state 'active'
    INFO: Checking for running guests..
    WARN: 4 running guest(s) detected - consider migrating or stopping them.
    INFO: Checking if the local node's hostname 'Homeserver' is resolvable..
    INFO: Checking if resolved IP is configured on local node..
    PASS: Resolved node IP '192.168.0.254' configured and active on single interface.
    INFO: Checking backup retention settings..
    PASS: no problems found.
    INFO: checking CIFS credential location..
    PASS: no CIFS credentials at outdated location found.
    INFO: Checking custom roles for pool permissions..
    INFO: Checking node and guest description/note legnth..
    PASS: All node config descriptions fit in the new limit of 64 KiB
    PASS: All guest config descriptions fit in the new limit of 8 KiB
    INFO: Checking container configs for deprecated lxc.cgroup entries
    PASS: No legacy 'lxc.cgroup' keys found.
    INFO: Checking storage content type configuration..
    INFO: Checking if the suite for the Debian security repository is correct..
    INFO: Make sure to change the suite of the Debian security repository from 'buster/updates' to 'bullseye-security' - in /etc/apt/sources.list:9
    SKIP: No containers on node detected.
    = SUMMARY =
    TOTAL:    20
    PASSED:   15
    SKIPPED:  3
    WARNINGS: 2
    FAILURES: 0
    ATTENTION: Please check the output for detailed information!
    root@Homeserver:~#
    • da_WoodyD da_Woody
      = SUMMARY =
      TOTAL:    20
      PASSED:   15
      SKIPPED:  3
      WARNINGS: 2
      FAILURES: 0
      root@Homeserver:~#
      crunchipC Abwesend
      crunchipC Abwesend
      @da_woody na also, dann steht dem upgrade ja nix mehr im Wege
        da_WoodyD Online
        da_WoodyD Online
        @crunchip püh, mühsam nähert sich der eichhorn... ;)
        irgend nen schwachsinn muss ich doch verbrochen haben...
        denk mal, die unterste zeile wegklicken...
        ah, zeile 3 und 5...
        hmpf, geht nicht in proxmox...
        crunchipC Meister MopperM 2 Antworten Letzte Antwort
          crunchipC Abwesend
          crunchipC Abwesend
          @da_woody sagte in pihole update. pfade stimmen nicht... proxmox update...:
          ja den Haken entfernen bei enterprise list, die ober 4 müssen aktiv bleiben
          was zurück bleibt ist die Meldung
          weil du proxmox ja umsonst nutzt
          früher musste man das per shell erledigen, mittlerweile bequem per Gui
            da_WoodyD Online
            da_WoodyD Online
            @crunchip siehe letzte zeile. lässt sich nicht wegklicken... hrnz, mit doppelklick kommt deaktivieren. ich werd wirklich alt... :D
            und das no subscription bekommt man temporär auch weg. irgendwo hab ich das mal gefunden. muss man nur nach jedem update neu machen. ob das mit 7.x auch noch funzt, k.a. ist aber egal.
            schankedön für die geduld und hilfe! 🤙
              crunchipC Abwesend
              crunchipC Abwesend
              @da_woody sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
              https://www.antary.de/2022/05/03/proxmox-meldung-no-valid-subscription-entfernen/#:~:text=Voraussetzung dazu ist der Zugriff,Proxmox VE 7.0 und höher.&text=Anschließend könnt ihr euch ausloggen,Anmeldung ist der Hinweis verschwunden.
              sed -i.backup -z "s/res === null || res === undefined || \!res || res\n\t\t\t.data.status.toLowerCase() \!== 'active'/false/g" /usr/share/javascript/proxmox-widget-toolkit/proxmoxlib.js && systemctl restart pveproxy.service
                da_WoodyD Online
                da_WoodyD Online
                @crunchip danke! ein klick weniger.
                ich gebs ja zu, bekennend fauler hund... 🐶
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @da_woody mich stört das nicht, denn so oft ruf ich Proxmox auch nicht auf. Da gibt's schlimmeres, wie z.b. diese sche... cookie Meldungen😂
                    da_WoodyD Online
                    da_WoodyD Online
                    @crunchip auch wieder wahr... :)
                      Marty56
                      Meine Erfahrungen mit dem Promox Update 7 waren sehr negativ.
                      Ich hatte LXC Container verwendet und da ging gar nichts mehr und ich muss auf VMs umstellen.
                      Aber selbst als ich das gemacht hatte, hatte ich diverse Probleme u.a. konnte ich eine virtuelle Platte nicht wiederherstellen und hatte Datenverlust.
                      Ok, ich bin kein Promox Experte, aber ich habe mit der Umstellung 2 Tage verloren und hatte danach immer noch kleinere Probleme.
                      Nach mehreren super arroganten Reaktionen von irgendwelchen Supportern in Promox Forum, habe ich die Platte neu formatiert und alles ohne Virtualisierung aufgesetzt. Jetzt ist Stromverbrauch und Reaktion besser und die Komplexität meines System auch wieder etwas geringer.
                      Der Nachteil ist natürlich, dass das Backup der Linux Partitionen eine Riesenfummelei ist und ich das bisher noch nicht gemacht habe.
                      Auf der anderen Seite ist mein Setup nicht so komplex. Ich hatte meinen Server dank iobroker Backup in ca. 4 h komplett neu aufgesetzt.
                      HW:NUC (16 GB Ram)
                      OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                      crunchipC da_WoodyD 2 Antworten Letzte Antwort
                      • M Marty56
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @marty56 sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                        LXC Container sind nun mal vom Host abhängig und nutzen den selben Kernel. Im Gegensatz zu einer VM.
                        Da muss man eben im Vorfeld sehen, das diese eben auch up to date sind.
                        Natürlich ist es im Einzelfall auch abhängig, was da überhaupt in einem LXC läuft. Mit nem debian oder ubuntu, sollte es da aber normalerweise keine Probleme geben.
                        Falls doch, kann man immer noch nen anderen/älteren Kernel laden, sodas die Problem Maschine wieder läuft.
                          @da_woody sagte in pihole update. pfade stimmen anscheinend nicht...:
                          Fehl:4 http://ftp.at.debian.org/debian bulleye Release
                          Da fehlt ja auch ein S in bullseye.
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Hallo Thomas!
                          Ich wollte auch gerade Pihole updaten, bekomm aber folgende Meldungen.
                          Kannst du weiterhelfen?
                          nega@pihole:~$ pihole -up
                            [✓] Root user check
                                  .ccccc:,.
                                   :cccclll:.      ..,,
                                    :ccccclll.   ;ooodc
                                     'ccll:;ll .oooodc
                                       .;cll.;;looo:.
                            [i] SELinux not detected
                            [✗] Update local cache of available packages
                             Error: Unable to update package cache. Please try "sudo apt update"
                          nega@pihole:~$ sudo apt update
                          Get:1 http://dl.google.com/linux/chrome/deb stable InRelease [1811 B]
                          Err:1 http://dl.google.com/linux/chrome/deb stable InRelease
                            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                          Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                          Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                          Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
                          Reading package lists... Done
                          W: GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
                          E: The repository 'http://dl.google.com/linux/chrome/deb stable InRelease' is not signed.
                          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                          N: See apt-secure(8) manpage for repository creation and user configuration details.
                          nega@pihole:~$
                          ° Fixer ---> iob fix
                          • NegaleinN Negalein
                            Hallo Thomas!
                              [✓] Root user check
                                    .ccccc:,.
                                     :cccclll:.      ..,,
                                      :ccccclll.   ;ooodc
                                       'ccll:;ll .oooodc
                                         .;cll.;;looo:.
                            nega@pihole:~$
                            @negalein sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                            wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
                            oder
                            wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
                            Aber warum chrome auf einem Server?
                              oder
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @thomas-braun sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                              keine Ahnung.
                              Brauche ich nicht. Hab den nicht installiert.
                              Wie bring ich den wieder weg?
                                keine Ahnung.
                                @negalein
                                apt policy chrome*
                                  @negalein
                                  apt policy chrome*
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  apt policy chrome*
                                  nega@pihole:~$ apt policy chrome*
                                  chrome-gnome-shell:
                                    Installed: (none)
                                    Candidate: 10.1-5
                                    Version table:
                                       10.1-5 500
                                          500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                                  chromedriver:
                                    Installed: (none)
                                    Candidate: (none)
                                    Version table:
                                  nega@pihole:~$
                                    Marty56
                                    @crunchip was ist schon normal.
                                    Debmatic hat nicht funktioniert und die ist für mich essentiell.
                                    HW:NUC (16 GB Ram)
                                    • M Marty56
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      wo ist da fummelei?
                                      geht vollkommen automatisch.
                                        wo ist da fummelei?
                                        Marty56
                                        @da_woody Du musst mein Posting richtig lesen ...
                                        HW:NUC (16 GB Ram)
                                        • M Marty56
                                          da_WoodyD Online
                                          da_WoodyD Online
                                          @marty56 sorry, wenn ich da was falsch verstanden hab. ich bezog mich rein aufs backup.
                                          aber klar, jede install ist anders. :)
