  3. Off Topic
  4. [done] pihole update. pfade stimmen nicht, proxmox update
pihole iobroker proxmox
60 Beiträge 7 Kommentatoren 7.9k Aufrufe 5 Beobachtet
    @haselchen @da_Woody
    Ja, da ist das ganze Repo falsch.
    Die entsprechende Zeile muss
    deb http://security.debian.org/debian-security bullseye-security main contrib non-free
    lauten.
    Meine sources.list schaut so aus:
    deb http://deb.debian.org/debian bullseye main contrib non-free
    deb http://deb.debian.org/debian bullseye-updates main contrib non-free
    # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
    #deb-src http://deb.debian.org/debian bullseye main contrib non-free
    #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
    #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
    da_WoodyD Online
    da_WoodyD Online
    @thomas-braun thnx, anscheinend tippfehler meinereiner...
    gerade versucht nach @crunchip proxmox update. der nächste kack.
    root@Homeserver:~#  pve6to7 --full
    = CHECKING VERSION INFORMATION FOR PVE PACKAGES =
    Checking for package updates..
    WARN: updates for the following packages are available:
      pve-kernel-5.4, pve-kernel-5.4.195-1-pve, pve-kernel-helper
    Checking proxmox-ve package version..
    PASS: proxmox-ve package has version >= 6.4-1
    Checking running kernel version..
    PASS: expected running kernel '5.4.189-2-pve'.
    = CHECKING CLUSTER HEALTH/SETTINGS =
    SKIP: standalone node.
    = CHECKING HYPER-CONVERGED CEPH STATUS =
    SKIP: no hyper-converged ceph setup detected!
    = CHECKING CONFIGURED STORAGES =
    PASS: storage 'local' enabled and active.
    PASS: storage 'local-lvm' enabled and active.
    PASS: storage 'proxmoxbackup' enabled and active.
    = MISCELLANEOUS CHECKS =
    INFO: Checking common daemon services..
    PASS: systemd unit 'pveproxy.service' is in state 'active'
    PASS: systemd unit 'pvedaemon.service' is in state 'active'
    PASS: systemd unit 'pvestatd.service' is in state 'active'
    INFO: Checking for running guests..
    WARN: 4 running guest(s) detected - consider migrating or stopping them.
    INFO: Checking if the local node's hostname 'Homeserver' is resolvable..
    INFO: Checking if resolved IP is configured on local node..
    FAIL: Resolved node IP '192.168.1.35' not configured or active for 'Homeserver'
    INFO: Checking backup retention settings..
    PASS: no problems found.
    INFO: checking CIFS credential location..
    PASS: no CIFS credentials at outdated location found.
    INFO: Checking custom roles for pool permissions..
    INFO: Checking node and guest description/note legnth..
    PASS: All node config descriptions fit in the new limit of 64 KiB
    PASS: All guest config descriptions fit in the new limit of 8 KiB
    INFO: Checking container configs for deprecated lxc.cgroup entries
    PASS: No legacy 'lxc.cgroup' keys found.
    INFO: Checking storage content type configuration..
    INFO: Checking if the suite for the Debian security repository is correct..
    INFO: Make sure to change the suite of the Debian security repository from 'buster/updates' to 'bullseye-security' - in /etc/apt/sources.list:9
    SKIP: No containers on node detected.
    = SUMMARY =
    TOTAL:    20
    PASSED:   14
    SKIPPED:  3
    WARNINGS: 2
    FAILURES: 1
    ATTENTION: Please check the output for detailed information!
    Try to solve the problems one at a time and then run this checklist tool again.
    root@Homeserver:~#
    mich hat das schon länger gewundert, daß ich am server eine andere IP lese. dort seh ich am monitor https://192.168.1.35: 8006. der server hat aber 192.168.0.254:8006
    danke @Homoran fürs verschieben... ;)
    • da_WoodyD da_Woody
      = SUMMARY =
      TOTAL:    20
      PASSED:   14
      SKIPPED:  3
      WARNINGS: 2
      FAILURES: 1
      root@Homeserver:~#
      crunchipC Abwesend
      crunchipC Abwesend
      @da_woody sagte in pihole update. pfade stimmen nicht... proxmox update...:
      bist du damit mal "umgezogen" auf nen anderen Rechner?
        da_WoodyD Online
        da_WoodyD Online
        @crunchip nope. das ist noch immer der i5 von anfang an... 😵
        k, pihole hab ich mal erledigt mit deiner liste! :)
          crunchipC Abwesend
          crunchipC Abwesend
          @da_woody dann pass die IP an, unter
          /etc/issue
          danach sollte die Ausgabe auf deinem Bildschirm auch wieder stimmen
          bzw hast du zwei nics? zeig mal die Ausgabe von /etc/network/interfaces
            /etc/issue
            da_WoodyD Online
            da_WoodyD Online
            @crunchip sorry, musste mal weg. nachbar ist heute früh gestorben...
            # network interface settings; autogenerated
            # Please do NOT modify this file directly, unless you know what
            # you're doing.
            # If you want to manage parts of the network configuration manually,
            # please utilize the 'source' or 'source-directory' directives to do
            # so.
            # PVE will preserve these directives, but will NOT read its network
            # configuration from sourced files, so do not attempt to move any of
            # the PVE managed interfaces into external files!
            auto lo
            iface lo inet loopback
            iface eno1 inet manual
            auto vmbr0
            iface vmbr0 inet static
                    address 192.168.0.254/21
                    gateway 192.168.0.1
                    bridge-ports eno1
                    bridge-stp off
                    bridge-fd 0
            musste mich aber händisch dort hinhangeln... bei den anderen dingens bekomm ich
            root@Homeserver:/etc/network# /etc/network/interfaces
            -bash: /etc/network/interfaces: Permission denied
            root@Homeserver:/etc/network# /etc/issue
            -bash: /etc/issue: Permission denied
              # you're doing.
              # so.
              auto lo
              auto vmbr0
                      gateway 192.168.0.1
                      bridge-ports eno1
                      bridge-stp off
                      bridge-fd 0
              crunchipC Abwesend
              crunchipC Abwesend
              Hä warum, einfach auf dem Host eingeben
              cat /etc/network/interfaces
              Aber passt schon so, die IP ist die
              192.168.0.254
              Und das andere mit nano bearbeiten
              nano /etc/issue
              Und dort die richtige ip eintragen, das ändert dann die Eingabemaske wie oben in deinem Screen zu sehen.
              Das muss man z.b. anpassen, bei einem Serverumzug, wenn eine neue IP vergeben wird, deshalb fragte ich.
              Weshalb das bei dir allerdings nicht übereinstimmt, wundert mich.
              Ps, oder hattest du nach dem Einrichten nachträglich die Ip geändert?
                192.168.0.254
                nano /etc/issue
                da_WoodyD Online
                da_WoodyD Online
                @crunchip 😳 als linux nulpe...
                cat war mir nicht bewusst. mit nano hab ich nach dem hinholpern das ja rauskopiert.
                hüstel. die kiste hat mir damals ein "freund" eingerichtet. wie auch das LAN umgeschnitzt. alles was ich jetzt, teilweise kann, hab ich mir dann selbst beigebracht. klar, da wurde die IP auf 192.168.0.254 geändert. steht ja auch in der datei so drinnen. warum sich die kiste so meldet?
                ich muss auch nach einem reboot jedesmal
                ethtool -K eno1 gso off gro off tso off tx off rx off
                eingeben. sonst gibts probleme. hab ich mal im proxmox forum gefunden. das seh ich nur auf dem überflüssigen monitor, der hal am homeserver angestoppelt ist.
                btw: hab inzwischen auch die VM mit influx/grafana/tasmoadmin hoch gezogen... :)
                  crunchipC Abwesend
                  crunchipC Abwesend
                  Hast de es denn nu angepasst?
                    da_WoodyD Online
                    da_WoodyD Online
                    @crunchip was soll ich anpassen? steht ja die richtige drinnen.
                    auto lo
                    auto vmbr0
                            gateway 192.168.0.1
                            bridge-ports eno1
                            bridge-stp off
                            bridge-fd 0
                    das ist ja mein problem, keine ahnung, wo die andere IP her kommt. 192.168.1.35 gibts in meinem router nicht.
                      auto lo
                      auto vmbr0
                              gateway 192.168.0.1
                              bridge-ports eno1
                              bridge-stp off
                              bridge-fd 0
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @crunchip sagte in pihole update. pfade stimmen nicht... proxmox update...:
                      nano /etc/issue
                      Hab ich dir doch erklärt, beim einrichten, war es die
                      192.168.1.35, deshalb steht die auch in der Eingabemaske.
                      Wenn du nun die statische Ip änderst, bleibt die Anzeige unverändert, wie in deinem Fall, deshalb musst du /etc/issue manuell anpassen und dort die richtige eintragen.
                        nano /etc/issue
                        da_WoodyD Online
                        da_WoodyD Online
                        @crunchip hmpf. 2x jetzt nano /etc/issue geändert. nach nem neustart kommt wieder die 1.35
                        bin ich wirklich so dämlich? 🤕
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @da_woody schnell mal nachgelesen, das ist nicht persistent, da muss ebenfalls /etc/hosts angepasst werden, sonst wir es immer wieder überschrieben.
                          da_WoodyD 2 Antworten Letzte Antwort
                            da_WoodyD Online
                            da_WoodyD Online
                            @crunchip thnx! schau ich mir nach der F1 an... ;)
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @da_woody bzw schau mal https://www.bachmann-lan.de/proxmox-login-banner-aendern/
                                da_WoodyD Online
                                da_WoodyD Online
                                @crunchip werkstatt büro, F1, yellow flag... yeah, geklappt. :)
                                PASS: Resolved node IP '192.168.0.254' configured and active on single interface.
                                = SUMMARY =
                                TOTAL:    20
                                PASSED:   15
                                SKIPPED:  3
                                WARNINGS: 2
                                FAILURES: 0
                                root@Homeserver:~#
                                  = SUMMARY =
                                  TOTAL:    20
                                  PASSED:   15
                                  SKIPPED:  3
                                  WARNINGS: 2
                                  FAILURES: 0
                                  root@Homeserver:~#
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @da_woody na also, dann steht dem upgrade ja nix mehr im Wege
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    @crunchip püh, mühsam nähert sich der eichhorn... ;)
                                    irgend nen schwachsinn muss ich doch verbrochen haben...
                                    denk mal, die unterste zeile wegklicken...
                                    ah, zeile 3 und 5...
                                    hmpf, geht nicht in proxmox...
                                    crunchipC Meister MopperM 2 Antworten Letzte Antwort
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      ja den Haken entfernen bei enterprise list, die ober 4 müssen aktiv bleiben
                                      was zurück bleibt ist die Meldung
                                      weil du proxmox ja umsonst nutzt
                                      früher musste man das per shell erledigen, mittlerweile bequem per Gui
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        @crunchip siehe letzte zeile. lässt sich nicht wegklicken... hrnz, mit doppelklick kommt deaktivieren. ich werd wirklich alt... :D
                                        und das no subscription bekommt man temporär auch weg. irgendwo hab ich das mal gefunden. muss man nur nach jedem update neu machen. ob das mit 7.x auch noch funzt, k.a. ist aber egal.
                                        schankedön für die geduld und hilfe! 🤙
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @da_woody sagte in [done] pihole update. pfade stimmen nicht, proxmox update:
                                          https://www.antary.de/2022/05/03/proxmox-meldung-no-valid-subscription-entfernen/#:~:text=Voraussetzung dazu ist der Zugriff,Proxmox VE 7.0 und höher.&text=Anschließend könnt ihr euch ausloggen,Anmeldung ist der Hinweis verschwunden.
                                          sed -i.backup -z "s/res === null || res === undefined || \!res || res\n\t\t\t.data.status.toLowerCase() \!== 'active'/false/g" /usr/share/javascript/proxmox-widget-toolkit/proxmoxlib.js && systemctl restart pveproxy.service
