  4. Nach Nodejs Update kein Adapter mehr updatebar
nodejs update adaper update
67 Beiträge 6 Kommentatoren 16.9k Aufrufe 6 Beobachtet
    @tilly
    Beim iobroker Start werden Module neukompiliert.
    Ich vermute stark, da ist in der Vergangenheit mal mit sudo oder gar vollem root was installiert worden und jetzt ist da einiges verbogen.
    Edit: Gerade nochmal hochgescrollt... Du warst ja tatsächlich als root unterwegs. Würde meine Vermutung stützen.
    T
    T
    tilly
    so habe iobroker gestoppt, alle Dateien mit kryptischen Endungen gelöscht und versucht alexa2 upzudaten.
    user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade alexa2 --debug
    This upgrade of "alexa2" will introduce the following changes:
    -> 3.18.6:
    Fix deviceStop sequence command
    -> 3.18.5:
    Fix crash case reported by Sentry
    Add image for Fire Cube
    -> 3.18.3:
    Fix doNotDisturb and doNotDisturb for All devices
    Update do not disturb status after set for all devices
    preserve a changed name for a "This device" device object
    -> 3.18.2:
    Enable commands again for Apps with type A2TF17PFR55MTB - will only work sometimes as it seems
    Would you like to upgrade alexa2 from @3.18.1 to @3.18.6 now? [(y)es, (n)o]: y
    Update alexa2 from @3.18.1 to @3.18.6
    NPM version: 8.11.0
    Installing iobroker.alexa2@3.18.6... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
    npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
    npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
    npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/openzwave-shared
    npm ERR! command failed
    npm ERR! command sh -c node-gyp rebuild
    npm ERR! make: Entering directory '/opt/iobroker/node_modules/openzwave-shared/build'
    npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    npm ERR! openzwave_shared.target.mk:150: recipe for target 'Release/obj.target/openzwave_shared/src/callbacks.o' failed
    npm ERR! make: Leaving directory '/opt/iobroker/node_modules/openzwave-shared/build'
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@8.4.1
    npm ERR! gyp info using node@16.16.0 | linux | x64
    npm ERR! gyp info find Python using Python version 3.6.9 found at "/usr/bin/python3"
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.16.0/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.16.0',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.16.0/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8.h:30:0,
    npm ERR!                  from ../src/openzwave.hpp:27,
    npm ERR!                  from ../src/callbacks.cc:18:
    npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
    npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’
    npm ERR!              !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
    npm ERR!                                       ^~~~~~~~~~~
    npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:38: note: suggested alternative: ‘remove_cv’
    npm ERR!                                       remove_cv
    npm ERR!                                       remove_cv
    npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
    npm ERR!                                                   ^
    npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
    npm ERR!        ^~~~~~~
    npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:63: note: suggested alternative: ‘perror’
    npm ERR!        ^~~~~~~
    npm ERR!        perror
    npm ERR! make: *** [Release/obj.target/openzwave_shared/src/callbacks.o] Error 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
    npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 4.15.0-189-generic
    npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    npm ERR! gyp ERR! node -v v16.16.0
    npm ERR! gyp ERR! node-gyp -v v8.4.1
    npm ERR! gyp ERR! not ok
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_24_18_272Z-debug-0.log
    upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
    upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
    upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
    upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
    upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
    upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
    upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
    upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
    upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
    upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
    upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
    upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
    upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
    upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
    upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
    upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
    upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
    upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
    upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
    upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
    upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript^[Sorry, try again.
    • T tilly
      -> 3.18.6:
      -> 3.18.5:
      -> 3.18.3:
      -> 3.18.2:
      NPM version: 8.11.0
      npm ERR! code 1
      npm ERR!                                       remove_cv
      npm ERR!                                       remove_cv
      npm ERR!                                                   ^
      npm ERR!        ^~~~~~~
      npm ERR!        ^~~~~~~
      npm ERR!        perror
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @tilly
      Ist 'build-essential' installiert?
      apt policy build-essential
        @tilly
        T
        T
        tilly
        @thomas-braun said in Nach Nodejs Update kein Adapter mehr updatebar:
        ja
        user@iobroker-ubuntu:/opt/iobroker$ apt policy build-essential
        build-essential:
          Installiert:           12.4ubuntu1
          Installationskandidat: 12.4ubuntu1
          Versionstabelle:
         *** 12.4ubuntu1 500
                500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
        • T tilly
          ja
          build-essential:
            Versionstabelle:
           *** 12.4ubuntu1 500
          Thomas BraunT
          Thomas BraunT
          @tilly
          Dann lösch den cache mal.
            @tilly
            T
            T
            tilly
            so?
            sudo apt-get clean
            • T tilly
              so?
              sudo apt-get clean
              Thomas BraunT
              Thomas BraunT
              @tilly
              Nein, den npm cache
              cd /opt/iobroker
              sudo -u iobroker npm cache clear --force
                @tilly
                Nein, den npm cache
                cd /opt/iobroker
                T
                T
                tilly
                user@iobroker-ubuntu:/opt/iobroker$ sudo -u iobroker npm cache clear --force
                npm WARN logfile could not be created: Error: EACCES: permission denied, open '/home/user/.npm/_logs/2022-07-22T09_05_23_231Z-debug-0.log'
                npm WARN using --force Recommended protections disabled.
                • T tilly
                  Thomas BraunT
                  Thomas BraunT
                  @tilly
                  sudo -H -u iobroker npm cache clear --force
                    @tilly
                    T
                    T
                    tilly
                    user@iobroker-ubuntu:/opt/iobroker$ sudo -H -u iobroker npm cache clear --force
                    und jetzt nochmal versuchen alexa2 upzudaten?
                    • T tilly
                      Thomas BraunT
                      Thomas BraunT
                      @tilly
                      Nein, der Show Stopper liegt bei openzwave-shared.
                      Das Modul bzw. den zugehörigen Adapter nochmal sauber installieren/rebuilden.
                        @tilly
                        T
                        T
                        tilly
                        möchte jetzt iobroker nicht starten, daher würde ich den Adapter(wird nicht mehr benötigt) über die Konsole löschen.
                        So?
                        iobroker del openzwave-shared
                        • T tilly
                          So?
                          Thomas BraunT
                          Thomas BraunT
                          @tilly
                          Ich vermute der kommt als Dependency aus einem Adapter. Ich würde den ganzen Adapter rauswerfen.
                          Schau wo openzwave-shared hängt:
                          cd /opt/iobroker
                          npm ls openzwave-shared
                          • mickymM
                            mickymM
                            mickym
                            Ich hätte ja das ganze node-modules Verzeichnis gelöscht, inkl. package-lock.json und dann mit npm install neu aufbauen lassen. Wenn du eh eine Datensicherung hast, solltest du ja auch auf den Stand zurückkehren können. Bei mir hat diese Radikalkur jedenfalls geholfen, einen fehlerfreien Baum zu bekommen.
                              @tilly
                              cd /opt/iobroker
                              T
                              T
                              tilly
                              der kommt vom zwave adapter. Den lösche ich dann mit: iobroker del zwave2?
                              user@iobroker-ubuntu:/opt/iobroker$ npm ls openzwave-shared
                              [sudo] password for user:
                              iobroker.inst@2.0.2 /opt/iobroker
                              └─┬ iobroker.zwave@2.0.1
                                └── openzwave-shared@1.7.2
                              • mickymM mickym
                                T
                                T
                                tilly
                                @mickym
                                wie würde ich da vorgehen?
                                mickymM Thomas BraunT 2 Antworten Letzte Antwort
                                • T tilly
                                  @mickym
                                  mickymM
                                  mickymM
                                  mickym
                                  @tilly sagte in Nach Nodejs Update kein Adapter mehr updatebar:
                                  @mickym
                                  also in das /opt/iobroker Verzeichnis wechseln.
                                  IOB stoppen natürlich:
                                  iob stop
                                  cd /opt/iobroker
                                  komplettes node_modules Verzeichnis löschen oder das Verzeichnis umbenennen
                                  sudo rm -rf node_modules
                                  bzw.
                                  sudo mv node_modules node_modules.bak
                                  etwaige package-lock.json löschen
                                  sudo rm package-lock.json
                                  Den cache sicherheitshalber noch leeren:
                                  npm cache clean --force
                                  Dann das node_modules neu aufbauen lassen:
                                  npm install
                                  Die ganzen Informationen über die Adapter und deren Abhängigkeiten stehen in der package.json.
                                  Eine datensicherung oder ein Image würde ich aber in jedem Fall machen, falls was nicht geht. Ist aber noch schneller, als das ganze System neu aufzubauen.
                                  zum Schluss in dem Verzeichnis /opt/iobroker noch den Befehl
                                  npm list
                                  und schauen, ob Du einen sauberen Baum hast. npm cache hast ja soweit ich sehe schon gelöscht.
                                  • T tilly
                                    @mickym
                                    Thomas BraunT
                                    Thomas BraunT
                                    @tilly
                                    iobroker del zwave
                                      @tilly
                                      iobroker del zwave
                                      T
                                      T
                                      tilly
                                      zwave gelöscht und alexa2 erneut versucht zu installieren
                                      -> 3.18.6:
                                      -> 3.18.5:
                                      -> 3.18.3:
                                      -> 3.18.2:
                                      NPM version: 8.11.0
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rename
                                      npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
                                      npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T11_15_10_431Z-debug-0.log
                                      host.iobroker-ubuntu Cannot install iobroker.alexa2@3.18.6: 217
                                      • T tilly
                                        -> 3.18.6:
                                        -> 3.18.5:
                                        -> 3.18.3:
                                        -> 3.18.2:
                                        NPM version: 8.11.0
                                        npm ERR! errno -39
                                        Thomas BraunT
                                        Thomas BraunT
                                        ENOTEMPTY: directory not empty, rename /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                                        Das Spiel ist immer das gleiche...
                                        rm -rf /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                                          T
                                          T
                                          tilly
                                          Habe ich gelöscht und wollte Alexa2 installieren, da sagt er mir ist up to date, komisch.
                                          Als ich dann cloud aktualisieren wollte:
                                          user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade cloud --debug
                                          This upgrade of "cloud" will introduce the following changes:
                                          -> 4.2.1:
                                          Used new version of socket library.
                                          Would you like to upgrade cloud from @4.2.0 to @4.2.1 now? [(y)es, (n)o]: y
                                          Update cloud from @4.2.0 to @4.2.1
                                          NPM version: 8.11.0
                                          Installing iobroker.cloud@4.2.1... (System call)
                                          npm ERR! path /opt/iobroker/node_modules/abbrev
                                          npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
                                          npm ERR! errno -39
                                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T11_25_03_406Z-debug-0.log
                                          host.iobroker-ubuntu Cannot install iobroker.cloud@4.2.1: 217
                                          und die ganzen Verzeichnisse mit.xyz sind auf einmal alle wieder da, obwohl iobroker die ganze zeit aus ist.
                                          Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                                          33.2k
                                          84.3k
