  4. Nach Nodejs Update kein Adapter mehr updatebar
    6.8k
nodejs update adaper update
67 Beiträge 6 Kommentatoren 15.0k Aufrufe 6 Beobachtet
    @tilly
    Das selbe in Grün...
    tilly
    schrieb am zuletzt editiert von tilly
    hab nun alle Dateien in @verzeichnissen mit kryptischen Endungen gelöscht
    jetzt folgendes
    user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade cloud --debug
    This upgrade of "cloud" will introduce the following changes:
    -> 4.2.1:
    Used new version of socket library.
    Would you like to upgrade cloud from @4.2.0 to @4.2.1 now? [(y)es, (n)o]: y
    Update cloud from @4.2.0 to @4.2.1
    NPM version: 8.11.0
    Installing iobroker.cloud@4.2.1... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
    npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
    npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
    npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
    npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-21T19_54_23_300Z-debug-0.log
    host.iobroker-ubuntu Cannot install iobroker.cloud@4.2.1: 217
    • T tilly
      jetzt folgendes
      -> 4.2.1:
      NPM version: 8.11.0
      npm ERR! errno -39
      @tilly sagte in Nach Nodejs Update kein Adapter mehr updatebar:
      rm -rf /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
      Das Spiel kennst du ja schon.
        tilly
        ich wollte gerade Feierabend machen, starte iobroker und wollte morgen weiter machen.
        auf einmal sind die ganzen gelöschten Dateien(z.B. /opt/iobroker/node_modules/.abbrev-5eNud0FY) wieder da?
        • T tilly
          @tilly
          Lief der iobroker eigentlich die ganze Zeit? Knips den aus, wenn du am npm tree bastelst.
            @tilly
            tilly
            nein der war die ganze Zeit aus, wollte den nur bis morgen wieder an machen wenn ich weiter mache.
            • T tilly
              @tilly
              Beim iobroker Start werden Module neukompiliert.
              Ich vermute stark, da ist in der Vergangenheit mal mit sudo oder gar vollem root was installiert worden und jetzt ist da einiges verbogen.
              Edit: Gerade nochmal hochgescrollt... Du warst ja tatsächlich als root unterwegs. Würde meine Vermutung stützen.
                @tilly
                tilly
                so habe iobroker gestoppt, alle Dateien mit kryptischen Endungen gelöscht und versucht alexa2 upzudaten.
                user@iobroker-ubuntu:/opt/iobroker$ iobroker upgrade alexa2 --debug
                This upgrade of "alexa2" will introduce the following changes:
                -> 3.18.6:
                Fix deviceStop sequence command
                -> 3.18.5:
                Fix crash case reported by Sentry
                Add image for Fire Cube
                -> 3.18.3:
                Fix doNotDisturb and doNotDisturb for All devices
                Update do not disturb status after set for all devices
                preserve a changed name for a "This device" device object
                -> 3.18.2:
                Enable commands again for Apps with type A2TF17PFR55MTB - will only work sometimes as it seems
                Would you like to upgrade alexa2 from @3.18.1 to @3.18.6 now? [(y)es, (n)o]: y
                Update alexa2 from @3.18.1 to @3.18.6
                NPM version: 8.11.0
                Installing iobroker.alexa2@3.18.6... (System call)
                npm ERR! code 1
                npm ERR! path /opt/iobroker/node_modules/openzwave-shared
                npm ERR! command failed
                npm ERR! command sh -c node-gyp rebuild
                npm ERR! make: Entering directory '/opt/iobroker/node_modules/openzwave-shared/build'
                npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
                npm ERR! openzwave_shared.target.mk:150: recipe for target 'Release/obj.target/openzwave_shared/src/callbacks.o' failed
                npm ERR! make: Leaving directory '/opt/iobroker/node_modules/openzwave-shared/build'
                npm ERR! gyp info it worked if it ends with ok
                npm ERR! gyp info using node-gyp@8.4.1
                npm ERR! gyp info using node@16.16.0 | linux | x64
                npm ERR! gyp info find Python using Python version 3.6.9 found at "/usr/bin/python3"
                npm ERR! gyp info spawn /usr/bin/python3
                npm ERR! gyp info spawn args [
                npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                npm ERR! gyp info spawn args   'binding.gyp',
                npm ERR! gyp info spawn args   '-f',
                npm ERR! gyp info spawn args   'make',
                npm ERR! gyp info spawn args   '-I',
                npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
                npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.16.0/include/node/common.gypi',
                npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                npm ERR! gyp info spawn args   '-Dvisibility=default',
                npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.16.0',
                npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.16.0/<(target_arch)/node.lib',
                npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
                npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                npm ERR! gyp info spawn args   '--depth=.',
                npm ERR! gyp info spawn args   '--no-parallel',
                npm ERR! gyp info spawn args   '--generator-output',
                npm ERR! gyp info spawn args   'build',
                npm ERR! gyp info spawn args   '-Goutput_dir=.'
                npm ERR! gyp info spawn args ]
                npm ERR! gyp info spawn make
                npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8.h:30:0,
                npm ERR!                  from ../src/openzwave.hpp:27,
                npm ERR!                  from ../src/callbacks.cc:18:
                npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
                npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’
                npm ERR!              !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
                npm ERR!                                       ^~~~~~~~~~~
                npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:38: note: suggested alternative: ‘remove_cv’
                npm ERR!                                       remove_cv
                npm ERR!                                       remove_cv
                npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
                npm ERR!                                                   ^
                npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
                npm ERR!        ^~~~~~~
                npm ERR! /home/iobroker/.cache/node-gyp/16.16.0/include/node/v8-internal.h:492:63: note: suggested alternative: ‘perror’
                npm ERR!        ^~~~~~~
                npm ERR!        perror
                npm ERR! make: *** [Release/obj.target/openzwave_shared/src/callbacks.o] Error 1
                npm ERR! gyp ERR! build error
                npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
                npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
                npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
                npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
                npm ERR! gyp ERR! System Linux 4.15.0-189-generic
                npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
                npm ERR! gyp ERR! node -v v16.16.0
                npm ERR! gyp ERR! node-gyp -v v8.4.1
                npm ERR! gyp ERR! not ok
                npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_24_18_272Z-debug-0.log
                upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript^[Sorry, try again.
                • T tilly
                  -> 3.18.6:
                  -> 3.18.5:
                  -> 3.18.3:
                  -> 3.18.2:
                  NPM version: 8.11.0
                  npm ERR! code 1
                  npm ERR!                                       remove_cv
                  npm ERR!                                       remove_cv
                  npm ERR!                                                   ^
                  npm ERR!        ^~~~~~~
                  npm ERR!        ^~~~~~~
                  npm ERR!        perror
                  @tilly
                  Ist 'build-essential' installiert?
                  apt policy build-essential
                    @tilly
                    tilly
                    @thomas-braun said in Nach Nodejs Update kein Adapter mehr updatebar:
                    ja
                    user@iobroker-ubuntu:/opt/iobroker$ apt policy build-essential
                    build-essential:
                      Installiert:           12.4ubuntu1
                      Installationskandidat: 12.4ubuntu1
                      Versionstabelle:
                     *** 12.4ubuntu1 500
                            500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
                    • T tilly
                      ja
                      build-essential:
                        Versionstabelle:
                       *** 12.4ubuntu1 500
                      @tilly
                      Dann lösch den cache mal.
                        @tilly
                        tilly
                        so?
                        sudo apt-get clean
                        • T tilly
                          so?
                          sudo apt-get clean
                          @tilly
                          Nein, den npm cache
                          cd /opt/iobroker
                          sudo -u iobroker npm cache clear --force
                            @tilly
                            Nein, den npm cache
                            cd /opt/iobroker
                            tilly
                            user@iobroker-ubuntu:/opt/iobroker$ sudo -u iobroker npm cache clear --force
                            npm WARN logfile could not be created: Error: EACCES: permission denied, open '/home/user/.npm/_logs/2022-07-22T09_05_23_231Z-debug-0.log'
                            npm WARN using --force Recommended protections disabled.
                            • T tilly
                              @tilly
                              sudo -H -u iobroker npm cache clear --force
                                @tilly
                                tilly
                                user@iobroker-ubuntu:/opt/iobroker$ sudo -H -u iobroker npm cache clear --force
                                und jetzt nochmal versuchen alexa2 upzudaten?
                                • T tilly
                                  @tilly
                                  Nein, der Show Stopper liegt bei openzwave-shared.
                                  Das Modul bzw. den zugehörigen Adapter nochmal sauber installieren/rebuilden.
                                    @tilly
                                    tilly
                                    möchte jetzt iobroker nicht starten, daher würde ich den Adapter(wird nicht mehr benötigt) über die Konsole löschen.
                                    So?
                                    iobroker del openzwave-shared
                                    • T tilly
                                      So?
                                      @tilly
                                      Ich vermute der kommt als Dependency aus einem Adapter. Ich würde den ganzen Adapter rauswerfen.
                                      Schau wo openzwave-shared hängt:
                                      cd /opt/iobroker
                                      npm ls openzwave-shared
                                      • mickymM Online
                                        mickymM Online
                                        mickym
                                        Ich hätte ja das ganze node-modules Verzeichnis gelöscht, inkl. package-lock.json und dann mit npm install neu aufbauen lassen. Wenn du eh eine Datensicherung hast, solltest du ja auch auf den Stand zurückkehren können. Bei mir hat diese Radikalkur jedenfalls geholfen, einen fehlerfreien Baum zu bekommen.
                                          @tilly
                                          cd /opt/iobroker
                                          tilly
                                          der kommt vom zwave adapter. Den lösche ich dann mit: iobroker del zwave2?
                                          user@iobroker-ubuntu:/opt/iobroker$ npm ls openzwave-shared
                                          [sudo] password for user:
                                          iobroker.inst@2.0.2 /opt/iobroker
                                          └─┬ iobroker.zwave@2.0.1
                                            └── openzwave-shared@1.7.2
